S3 8P ABS Coding Help!
Paullaith
Unverified
Hi, I'm new the the forum amd joined to get some advice, I don't yet have VCDS but I plan to buy it when funds allow. I've recently bought a 2008 Audi S3 Sportback and the lights behind the cluster were taped over and warning message saying break fault on start up. I've removed the tape from the cluster lights and the traction control, ABS and handbrake lights are flashing. I had it scanned and it was say no communication with the ABS module so I've had a play with the wires and fuses and that fault seems to have gone. I'm now left with these faults
Removed.  Data from pirated copies of VCDS is not welcome here!
What I want to know is this now just a coding issue and if so can it be dons using VCDS? Thanks in advance.
If you don't yet have VCDS, where did the data you posted come from? ;)
Yes, I think those faults can be fixed with VCDS, although coding an MK60EC1 can be a bit hit or miss.
Paullaith
Unverified
A mate of mine scanned it to help put me in the right direction but he isn't to clued up in coding unfortunately.
