Audi S3 8V new rear brake discs, callipers and line locks fitted - now EPB fault
Flatcap
C?ID=284841
i've just fitted big brakes to the rear of my Audi S3 8V this included removing the stock line lock and replacing with one sized for the new caliper hangers. I didn't touch the electric supply cable to the EPB motor. All went fine until i started her up and tried the EPB and the fault light came on the dash. The EPB locks on and will not come off - either when lifting the clutch or manually pressing the button. I can release it if i run the parking brake test module. The following VCDS report came up. Can anyone assist please? many thanks.
Address 03: ABS Brakes Labels: 5Q0-907-379-IPB-V1.CLB
Control Module Part Number: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component and/or Version: ESC H42 0623
Software Coding: 31F193A254222A6E017F070641C9698CC92A5480E08296F6144150F88008
Work Shop Code: WSC 06385 790 00016
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036 (AU37)
ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
VCID: 79FE3FA1F8210889AE-802C
32800 - Supply Voltage for Left Parking Brake Motor
C100D F0 [137] - Short Circuit
Reset counter: 148
Mileage: 17017 km
Date: 2017.04.21
Time: 20:03:19
32801 - Supply Voltage for Right Parking Brake Motor
C100E F0 [137] - Short Circuit
Reset counter: 148
Mileage: 17017 km
Date: 2017.04.21
Time: 20:03:18
32830 - Parking Brake Motors
C10E1 29 [008] - Signal Implausible
Fault Frequency: 7
Reset counter: 188
Mileage: 17017 km
32951 - Control Module for Electronic Parking Brake
C10E2 54 [137] - Missing Calibration / Basic Setting
Reset counter: 147
Mileage: 17017 km
Date: 2017.04.23
Time: 13:19:20
Flatcap
C?ID=284841
ABS Security Access Code
Does anyone know what this is for my Audi S3 8V?
What are you trying to accomplish?
Flatcap
C?ID=284841
To see what functionality there is in there and if any can resolve my current issue with the EPB brake (separate thread)
Sebastian
Magdeburg, Germany
HN0-nnnnnn
You need to be a little more specific, depending on the variant in your car - there are more than 50 different security access codes, each with a different function/meaning.
Yep, people tend to be under the impression that there's ONE security access code that opens up everything in a specific module, but unfortunately, windmills do not work that way. ;)
Flatcap
C?ID=284841
OK. Tell me what info you need from me and i can tell you.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
I took the liberty of merging your two topics, as this is really what this is about. Looking at your DTCs, I don't see anything where a security access code may even remotely help you.
According to your initial statement, you replaced the rear brakes. What part numbers and pr codes were the original ones and what are the current/new ones? Where did the new parts come from (new or used, audi or aftermarket)? Why did you replace the rear brakes in the first place? A complete Auto-Scan should always be included in any topic in this forum, in cases like this - the vehicle VIN is crucial as well.
Great post Sebastian........./\
OP:
How about measuring the step count and comparing the parking brake motors?
Did you just bolt on your equipment and plug it in or did you retract the old calipers to baseline and then install the new calipers?
Is the brake module the correct part for the upgrade, rotor thickness, and pad thickness?
Flatcap
C?ID=284841
OP:
New aftermarket calipers, pads, discs and line locks as part of a big brake kit upgrade. The EPM motor is the orgiginal. I didn't post the rest of the autoscan as that didn't show any faults so i didn't think it would be pertinent? I am new to VCDS so don't know where all the functionality is at the moment. After i had changed everything and put the wheels back on the brakes did apply and I heard the usual motors driving them on. The problem then was that I couldn’t release them either by manually lifting the switch - whilst my foot was on the brake as is required. I also couldn’t pull away by lifting the clutch pedal to biting point. The only way I could release them was to plug in the VCDS and go through the emergency brake test module which cycles them on and off. I can't understand why the fault refers to a short circuit - surely if this were the case the EPB wouldn't work at all as it would have blown a fuse?
How do i measure the step count?
Thanks for your help.
Andy
Sector 7G
HC424490
You need to start over............
Do you have the SSP and Repair manual?
Are your line locks interfering with the function?
I hate retrofits and technically this is where this belongs not being general car repair.
I bet you didn't default the module and basic brake settings......... and just retracted like doing brake pads.......?
First you need to make sure the park brake motors work and move the calipers in and out manually!
Move the calipers all the way in manually relaxed bottom out.....then clear DTC's and trace if with fault or replace module from frying due to failing to use a battery charger or bug in module.
Once faults for shorts are rectified setup module for new install.
Posting a complete auto-scan & PR codes is absolutely always relevant because it gives us details you negate, as does the JPPSG.
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
Simulate/isolate the EBP function by leaving motors uninstalled from mechanical circuit and get module to operate without a fault!
Watch video...... RTFB & JPPSG
NostraJackAss Has Spoken!
Flatcap
C?ID=284841
Please post the complete AutoScan since it will show us more info about the car, even if you don't think it would be relevant.,
Next, are you able to successfully run the Basic Settings for Start Lining Change mode and End Lining Change mode as described here?
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_VII_(5G/AU)_ABS_Brakes#Basic_Setting
I have pasted the autoscan below - i hope ive done this correctly? I have run the start lining change and end lining change but still have the following faults:
Tuesday,23,May,2017,11:26:49:63578
VCDS Version: 17.1.3.0 (x64)
Dealer/Shop Name: Kevin
VIN: WAUZZZ8V1G1022866   License Plate:
Mileage: 17882km-11111mi   Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 52 55 5F A9
          BB BC
VIN: WAUZZZ8V1G1022866   Mileage: 17882km-11111miles
Address 01: Engine (J623-CJXC)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 F    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 0A1900122446010B3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259F 001004
   ROD: EV_ECM20TFS0205G0906259F_VW37.rod
   VCID: 43829D49CA6D8259B4-8016
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 61935000000603
          C100D F0 [009] - Short Circuit
                    Reset counter: 158
                    Mileage: 17872 km
                    Date: 2017.05.20
                    Time: 22:09:55
          C100E F0 [009] - Short Circuit
                    Reset counter: 158
                    Mileage: 17872 km
                    Date: 2017.05.20
                    Time: 22:09:55
                    Reset counter: 198
                    Mileage: 17872 km
                    Date: 2017.05.20
                    Time: 22:11:00
                    Reset counter: 151
                    Mileage: 17872 km
                    Date: 2017.05.20
                    Time: 22:11:00
   Revision: 00021000    Serial number: 0372733467
   Coding: 030C0C
   VCID: 3A7CE0ADBDA7C391E7-806E
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000688610
   Coding: 03100004000000011000000000001100
   VCID: 3362CD899ACD32D924-8066
   Serial number: 818987B7000000000001
328964 - Motor for Front Air Distribution Flap
          B1091 71 [008] - Actuator stuck
                    Reset counter: 193
                    Mileage: 17052 km
                    Date: 2017.05.08
                    Time: 07:49:37
                    Voltage terminal 30: 14.6 V
                    Interior temperature: 18.0 °C
                    Outside air temperature: 9.5 °C
                    Front air distribution flap: actual value: 100.0 %
                    Front air distribution flap: actual value: 104
                    Front air distribution flap: specified value: 100
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0173
   Serial number: 01061518800908
   Coding: 07050C46C24106FD03804004B11807A80800000000000000000000000000
   ROD: EV_BCMBOSCH_016_AU37.rod
   VCID: 091E4F61A8C11809BE-805C
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 150630  042 0585
   Serial number:         150702005003
   Coding: 0A47F7
   Serial number: 24088377
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
   Serial number: 25 04 2015  00000919
   Serial number: 000000000ZY151531V10
   Serial number: 00000000000032564392
204546 - Remote key 2
          B147A 18 [008] - Current Too Low
                    Reset counter: 189
                    Mileage: 1048574 km
                    Time: 00:00:00
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [008] - Alert Emergency Activation Stage 1
                    Reset counter: 167
                    Mileage: 15610 km
                    Date: 2017.04.05
                    Time: 09:17:09
527372 - Local Data Bus 3
          U10DB 00 [008] - Electrical Malfunction
                    Reset counter: 188
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Revision: --------    Serial number: 39391518006250
   Coding: 0050050001
13637120 - Databus
                    Fault Frequency: 43
                    Reset counter: 198
                    Mileage: 17017 km
                    Date: 2017.04.23
                    Time: 13:00:46
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 N    HW: 5Q0 907 567 N
   Component: ACC3          H10 0400
   Serial number: 30061503090391
   Coding: 00200301FE0309
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 4684845DF95FB77193-8012
1060 - Databus
          U1123 00 [040] - Received Error Message
                    Reset counter: 198
                    Mileage: 17022 km
                    Date: 2017.05.07
                    Time: 11:30:24
                    Voltage terminal 15: 14.6 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1061 - Databus
                    Reset counter: 198
                    Mileage: 17022 km
                    Date: 2017.05.07
                    Time: 11:30:24
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       100715004
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide_002_AU37.rod
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Serial number: 003MMR0XJKV5
   Coding: 98FCC0000C0000005C5400CA00C800000065
   VCID: 000852459BFB5941E9-8054
   Subsystem 1 - Part No SW: -----------    HW: 480 000 207 15
   Serial number: 357670000004DC64051U
   Subsystem 2 - Part No SW: -----------    HW: 480 000 207 15
   Serial number: 358670000000FC64051T
   Subsystem 3 - Part No SW: -----------    HW: 480 400 707 15
   Serial number: 3516502A51B7E8F0913K
   Subsystem 4 - Part No SW: -----------    HW: 480 400 107 15
   Serial number: 3526502C31B65D52003+
   Subsystem 5 - Part No SW: -----------    HW: 480 402 502 15
   Serial number: 3556502BD1993FB5E10W
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 106 15
   Serial number: 2286502BB1B5A88443BQ
   Subsystem 7 - Part No SW: -----------    HW: 480 401 106 15
   Serial number: 2296502BD1B5A882736P
   Subsystem 8 - Part No SW: -----------    HW: 480 002 204 15
   Serial number: I0M800000009E478441D
   Subsystem 9 - Part No SW: -----------    HW: 480 002 204 15
   Serial number: I0N8000000024378441$
   Part No SW: 8V0 953 521 FK    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 01071504400023
   Coding: E008
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 08184A65B3CB6101A1-805C
   Part No SW: 8V0 920 972 A    HW: 8V0 920 972 A
   Component: KOMBI         H03 6420
   Coding: 278D18123F8026000181E8001000000000000000
   VCID: 3C70E6B5B793FDA1F5-8068
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 06071510803588
   Coding: 030100043F085A005B000278880B00000001010000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75E63391D4396CE9CA-8020
   Serial number: 24 03 2015  F0080670
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185703001507140285
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Serial number: HA1-00002.06.15
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_SK12.rod
   Revision: 00000000    Serial number: 15000170558008
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 3460CE959FC335E13D-8060
   Serial number: 010715BFT10057
   Coding: 00109A204001040000001003
   Coding: 8103
   ROD: EV_SteerAssisMQB_VW31.rod
   VCID: 377AF9998EB5DEF918-8062
   Serial number: 020715BG114712
   Coding: 001092204001040000001003
   VCID: 428C984DD5778B51BF-8016
   Coding: 01A600002B200200
   ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
   VCID: 3F8A91B9A685E6B9D0-806A
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels: 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 874 C    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    042 0461
   Serial number: A7F00807150430
   Coding: 01730101FF00000021111101000A00002F0005060100010006
   ASAM Dataset: EV_MUStd6C3PASE 002010
   ROD: EV_MUStd6C3PASE_AU37.rod
   Subsystem 1 - Part No SW: 8V0 919 866 C    HW: -----------
   Component:  ECE 2015  --- 0045
   Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30C1BG
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
   Serial number: C1000024041500040367
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 150620202523
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
   VCID: 7DF62BB1EC0934A982-8028
Address BB: Door Rear Drv (J388)       Labels: None
   Serial number: 250615BFO16625
   Coding: 000092204001040000001002
   VCID: 45868351C459BC699A-8010
Address BC: Door Rear Pass (J389)       Labels: None
   Serial number: 250615BFO1580B
End-------------------------(Elapsed Time: 04:50)--------------------------
Flatcap
C?ID=284841
Thanks. I had already watched the video before i started. Ironic that most of that isnt actually in the Audi repair manual that i have but anyway. The parking brake motors do work - they engage and disengage but not necessarily on command - when i press the EPB button. They will come on and the light on the dash appears and then they are unable to be disengaged - unless i plug in the VCDS and run the test EPB module. I can't understand why the fault codes are saying the motors have shorted but they still work? How can they still work if they have been shorted?
