Lamborghini Huracan and Hex Nex
SHARDUL
C?ID=248471
I purchased a Hex Net to use on a 2015 Lamborghini Huracan.
When I go into central electronics / coding
All the coding does not have any description
Here is a copy of my auto scan
Tuesday,23,May,2017,17:41:21:55582
VCDS Version: 17.1.0.0 (x64)  HEX-NET CB: 0.4336.4
Data version: 20170106 DS267.0
VIN: ZHWUC1ZF7FLA01704   License Plate:
Chassis Type: ZF (4S0)
Scan: 01 02 03 05 08 09 11 31 14 15 16 17 19 1B 22 3B 42 44 46 52
          53 55 56 5F 65 6C C2 D0
VIN: ZHWUC1ZF7FLA01704   Mileage: 25050km-15565miles
C2-Auto Trans 2 -- Status: OK 0000
D0-Frt Axle Lift -- Status: OK 0000
Address 01: Engine (------CSJC)       Labels: None
   Part No SW: 4T0 907 552 A    HW: 4T0 907 552 A
   Component: 5.2l V10HDZ / H55 0004
   Revision: NHH55---
   Coding: 1E2500320506000D2000
   Shop #: WSC 47382 001 1048576
   ASAM Dataset: EV_ECM52FSI1114T0907552A 001005
   ROD: EV_ECM52FSI1114T0907552A.rod
   VCID: 3522C3D0949868E92C-8060
22593 - Fuel Level Sensor Circuit
          P0461 00 [096] - Implausible Signal
Address 02: Auto Trans (J217)       Labels: 0BH-927-711.clb
   Part No SW: 4T0 927 155 A    HW: 0BH 927 711 D
   Component: 0BZ_52FSI_NAR H09 0813
   Revision: 00H09V01
   ASAM Dataset: EV_TCMDL800041 001009
   ROD: EV_TCMDL800041_LB72.rod
   VCID: 3620C4DC899E63F125-8062
   Part No SW: 4S0 907 379     HW: 4S0 907 379
   Component: ESP PREMIUM   H09 0087
   Coding: 218AC141845183824B00
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004041
   ROD: EV_ESPPremiAU57X_AU72.rod
   VCID: 7AB810ECFD06479181-802E
0004 - Brake Switch (F)
          P0571 00 [008] - Implausible Signal
                    Reset counter: 147
                    Mileage: 24161 km
                    Date: 2017.01.25
                    Time: 14:51:07
                    VzRef: 01
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 32
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 0A
                    Uz: BD
29198 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 147
                    Mileage: 24161 km
                    Date: 2017.01.25
                    Time: 14:51:08
                    VzRef: 01
                    Bit Info 1: 00
                    Bit Info 2: 42
                    Bit Info 3: 32
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 36
                    Uz: BD
   Part No SW: 4H0 907 064 FD    HW: 4H0 907 064 ED
   Component: BCM2 2.0      H36 0560
   Coding: 09803006000000000000
   VCID: 70AC32C4A37A0DC13F-8024
   Serial number: 3214000145060008
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 106
                    Mileage: 24160 km
                    Date: 2017.01.25
                    Time: 09:13:51
   Part No SW: 4T0 820 043 A    HW: 4T0 820 043 A
   Component: KLIMA 1 ZONE  H03 0130
   Revision: A1013000    Serial number: 01061120140019
   Coding: 4A02208000
   VCID: 2A18E0AC45263711B1-807E
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
   Revision: 21020001    Serial number: 00000954903101
   Coding: 00E90090402001303D01C8C300202800001C47C8020602C10000081C0440100000400034010000
   VCID: 76A004DCC11E23F1E5-8022
   Subsystem 1 - Part No SW: 4T1 955 113     HW: 955 113
   Component: WWS72x 140803  041 0015
   Serial number:         ????????????
   Coding: 0000F7
   Serial number: 23449666
   Coding: 02005D
   Subsystem 3 - Part No SW: 4T1 941 531 D    HW: 4T1 941 531 D
   Component: LCU  H02 0012
   Serial number: BC288A57000000000001
Address 11: Engine II (-----)       Labels: None
   Revision: NHH55---
   ASAM Dataset: EV_ECM52FSI2114T0907552A 001005
   ROD: EV_ECM52FSI2114T0907552A.rod
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 4S0 907 376 A    HW: 4S0 907 376 A
   Component: DAEMPFUNGS-SG H03 0043
   Serial number:       051114020
   ASAM Dataset: EV_AudiMagneRide 002004
   ROD: EV_AudiMagneRide_AU72.rod
   VCID: 383CCAE4838A958137-806C
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G0001LP5S
   Coding: 303333343033303030364A55304C34543053
   VCID: 3424FED49FE271E11B-8060
   Serial number: 6940000Y1400017VPS0L
   Serial number: 3575HRB40532MV3CEHK-
   Serial number: 3585HRB40532MV3CEH4L
   Serial number: 3515JRB404P32020CG8I
   Serial number: 3525JRB405932020C9F4
   Serial number: 3554VRB405J3201SH193
   Serial number: 3564VRB405L3201SL1NO
   Part No SW: 4T0 953 513     HW: 4T0 953 513
   Component: Lenks.Modul   H02 0080
   Revision: C0068719    Serial number: 90815NKI0004S
   VCID: 72A838CCAD763FD1C9-8026
   Subsystem 1 - Part No SW: 18G 959 542 B    HW: 18G 959 542 B
   Component: E221__MFL-TAS  H05 0012
   Serial number: 0003498 TAT 20140918
Address 17: Instruments (J285)       Labels: 4T0-920-xxx-17.clb
   Part No SW: 4T0 920 900 B    HW: 4T0 920 900 B
   Component: KOMBIINSTR.   013 0159
   Revision: AA001001    Serial number: 40400107013MOC
   Coding: 01F80094B3B1C3F0020000
   VCID: 2E10ECBC79CE5B316D-807A
03158 - Control Module for Information Electronics 1 (J794)
                    Fault Frequency: 181
                    Reset counter: 175
                    Mileage: 24160 km
                    Date: 2017.01.24
                    Time: 14:06:55
02750 - Switch for Display Head
                    Fault Status: 00101110
                    Reset counter: 110
                    Mileage: 24166 km
                    Date: 2017.01.28
                    Time: 12:29:26
   Part No SW: 4S0 907 468     HW: 4S0 907 468
   Revision: --------    Serial number: 00000001635556
   Coding: 0009071600
   ROD: EV_GatewPKOUDS_VW51.rod
   VCID: 79BA0FE0F8004C8988-802C
   Subsystem 1 - Part No SW: 8K0 915 181 M    HW: 8K0 915 181 M
   Component: J367-BDM  H08 0190
   Serial number: 51297K21463371983582
   Voltage stabilizer:
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
                    Reset counter: 164
                    Mileage: 24403 km
                    Date: 2017.03.17
                    Time: 23:29:21
                    Voltage terminal 30: 12.5 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 33 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Coding: 050000
   VCID: 393ACFE0B0808C89C8-806C
Address 22: AWD (J492)       Labels: 4T0-907-160.clb
   Part No SW: 4T0 907 160     HW: 4T0 907 160
   Component: 4 Wheel Drive H02 0006
   Revision: 00001002    Serial number: BBKR545
   ASAM Dataset: EV_AllWheelContrBORGLB724 004010
   ROD: EV_AllWheelContrBORGLB724_004.rod
   VCID: 6FAE31B8B644123926-803A
0115 - Databus
          U1123 00 [012] - Received Error Message
                    Reset counter: 147
                    Mileage: 24161 km
                    Date: 2017.01.25
                    Time: 14:51:07
                    Vehicle speed: 1.80 km/h
                    Steering angle: 8.30 °
                    Outside air temperature: 15.40 °C
                    Accelerator pedal travel: 18.40 %
                    Torque specifications: front axle: 550.00 Nm
                    Torque: front axle: 550 Nm
                    State_Of_System: not active
                    State_Of_System: active
                    Hydraulic pressure sensor 1: 27.89 bar
                    Hydraulic temperature sensor: 17 °C
                    Cooling fin temperature: 16 °C
                    Haldex clutch pump current: 8.50 A
                    Haldex clutch pump voltage: 7.00 V
                    Voltage terminal 30: 14.50 V
0194 - Databus
                    Reset counter: 147
                    Mileage: 24161 km
                    Date: 2017.01.25
                    Time: 14:51:07
                    Vehicle speed: 1.96 km/h
                    Steering angle: 8.80 °
                    Accelerator pedal travel: 17.60 %
                    Hydraulic pressure sensor 1: 27.99 bar
                    Haldex clutch pump current: 8.25 A
0196 - Databus
                    Reset counter: 147
                    Mileage: 24161 km
                    Date: 2017.01.25
                    Time: 14:51:07
0197 - Databus
                    Reset counter: 147
                    Mileage: 24161 km
                    Date: 2017.01.25
                    Time: 14:51:07
                    Vehicle speed: 1.85 km/h
                    Steering angle: 8.70 °
                    Hydraulic pressure sensor 1: 28.09 bar
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E018YM.
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2_VW51.rod
   VCID: 373EC9D88E949AF93E-8062
   Part No SW: 4T0 959 793 H    HW: 4T0 959 793 H
   Component: TSG FA        H07 0801
   Revision: --------    Serial number: 0000116743510
   Coding: 010C4B025000620100080102
   VCID: 4AD8802CE566171151-801E
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 4S0 909 144 D    HW: 4S0 909 144 B
   Component: EPS           H12 0901
   Revision: 00000000    Serial number:      L00061902
   Coding: 09
   ASAM Dataset: EV_EPSZFAU72X 001001
   ROD: EV_EPSZFAU72X_001.rod
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0350994060
   Coding: 011E029A18F20081A0B0C800008503470000000000000000000000000000
   Subsystem 1 - Part No: 8J0 951 177
   Component: DWA-Sensor  H03 0030
   Part No SW: 4T0 959 792 H    HW: 4T0 959 792 H
   Component: TSG BF        H07 0801
   Revision: --------    Serial number: 0000126793503
   Coding: 010C4B825000620100080100
   VCID: 49DABF20E0601C0958-801C
   Part No SW: 4S0 907 801     HW: 8K0 907 801
   Component: EPB-4         H02 0001
   Revision: --------    Serial number: 00000000000250
   ROD: EV_ParkiBrake_AU72.rod
   VCID: 70AC32C4AB7A0DC13F-8024
Address 55: Headlight Range (J431)       Labels: 4H4-907-357-V1.clb
   Part No SW: 4T0 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0003
   Serial number: 141119-0004-045
   Coding: 72846F6118020200
   ASAM Dataset: EV_AFSLEDHELLALB72X 006131
   ROD: EV_AdvanFrontSyste_LB72.rod
   Subsystem 1 - Part No SW: 7PP 941 329 S    HW: 7PP 941 329 S
H01 7020
   Coding: 1D0000
   Subsystem 2 - Part No SW: 7PP 941 329 S    HW: 7PP 941 329 S
H01 7020
   Coding: 1D0000
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156K60E8115975
   Coding: 020007020100000001
   VCID: 24040E942702E1618B-8070
   Part No SW: 4T0 035 664     HW: 4T0 035 664
   Component: H-BN-NA       H40 0795
   Revision: --------    Serial number: 325K 0E7500717
   Coding: 010200000001A16F0100820600000001FD0000020000000000
   Subsystem 1 - Part No: 4T0 919 859 D
   Component: NAR 2014  0801
   Subsystem 3 - Part No SW: 4T0 919 609 A    HW: 4T0 919 609 A
   Component: E380 BDT LB2  H01 0011
   Serial number: 00000000002217
   Component: CD-Database  5571
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0820
   Serial number: 10000000011490
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 2A18E0AC4D263711B1-807E
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
   Part No SW: 4T0 907 441     HW: 5Q0 907 441 A
   Component: LB72x RVC Mid H07 0030
   Coding: 080004010A01000300
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 71AA37C0A07004C930-8024
Address C2: Auto Trans 2 (J217)       Labels: None
   Part No SW: 4T0 927 109     HW: 4T0 927 109
   Component: DL800 ZSG     H28 0006
   Revision: --H28---    Serial number: 0000000098
   Coding: 000001
   ASAM Dataset: EV_TCMDL800421 001019
   ROD: EV_TCMDL800421.rod
   VCID: 74A43ED4DF6231E1DB-8020
Address D0: Frt Axle Lift (J988)       Labels: None
   Part No SW: 4S0 959 257     HW: 4S0 959 257
   Component: Lift-VA006 1980
   Revision: 00000000    Serial number: 142870038
   Coding: 020607
   ASAM Dataset: EV_LiftVA003 001001
   ROD: EV_LiftVA003.rod
   VCID: 7CB416F4F73279A193-8028
End----------(Elapsed Time: 02:01, VBatt start/end: 12.2V/12.2V)-----------
Andy
Sector 7G
HC424490
We hope to add documentation for this 09 module to a future update to VCDS. In the meantime, is there a specific Coding item you are trying to change?
ref: FS#1410
SHARDUL
C?ID=248471
ref: FS#1410
Thank for your reply.
No there is not anything specific I want to change, but I would like to know what can be changed for example in the R8 you could enable flashing rear tail lights under hard braking
