MK6 Golf Edition 35 Lost ABS Coding - Race Car
MNZ
New Zealand
C?ID=155812
Hi Guys,
Quick run down, we have two race cars we bought from Poland and now have here in New Zealand. They were from VW Castrol Cup.
One of the vehicles (CUP79 in scans below) appears to have lost ABS coding - big line of 0000000000000000. Easy to sort we thought copy the coding from the other vehicle as they are identical, however we keep getting the dreaded "request out of range" we have entered security access 40168 which it appears to accept, but will not take any coding.
Now to make matters interesting they are both running Syvecs plug and play ECU's, however we have put stock ECU's back in and tried to code but with same issue.
Any help or ideas much appreciated.
Excuse all the "malfunctions" as cars are race cars they are always present and also have kill switches which cause multiple voltage faults.
This is car that is NOT ok.
Thursday,21,September,2017,11:29:58:26018
VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4401.4
VIN: WVWZZZ1KZCW333492 License Plate: CUP79
Gateway Installation List: 7N0 907 530 M
03-ABS Brakes -- Status: Not registered 0011
Thursday,21,September,2017,11:34:17:26018
This is car that is ok.
VIN: WVWZZZ1KZCW332707 License Plate: CUP275
15-Airbags -- Status: Not registered 0011
MNZ
New Zealand
C?ID=155812
Good Car:
Thursday,21,September,2017,14:19:23:26018
Mileage: 8380km-5207mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52
VIN: WVWZZZ1KZCW332707   Mileage: 8380km-5207miles
Address 01: Engine
   Part No SW: 02E 300 051 R    HW: 02E 927 770 AL
   Component: F33Ra3PtP_OWXX_3512 3399
   Revision: 05551213    Serial number: 00001204102399
   Coding: 0000024
   VCID: 22082237FDAA5356BC-8076
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -  - Intermittent
                    Fault Frequency: 255
                    Reset counter: 1
                    Mileage: 8378 km
                    Date: 2017.09.21
                    Time: 00:53:52
   Part No SW: 5C0 907 379 CL    HW: 1K0 907 379 BL
   Component: ESP MK60EC1   H31 XA04
   Revision: 00H31001
   Coding: 143B800D492500FC281201E492200061700000
   Shop #: WSC 75000 666 121355
   VCID: 7AB83A57F5BAFB96C4-802E
18020 - Engine Control Module Incorrectly Coded
            P1612 - 000 -  - Intermittent
                    Reset counter: 59
                    Mileage: 8377 km
                    Date: 2017.09.21
                    Time: 00:00:01
                    Count: 29184
                    Count: 8197
                    Count: 43008
            000 -  -  - Intermittent
                    Reset counter: 59
                    Mileage: 8377 km
                    Date: 2017.09.21
                    Time: 00:00:36
                    Count: 12800
                    Count: 294
                    Count: 50944
                    Count: 8
                    Count: 513
                    Fault Status: 00100011
                    Reset counter: 59
                    Mileage: 8378 km
                    Date: 2017.09.21
                    Time: 00:53:51
                    Count: 4608
                    Count: 83
                    Count: 51712
                    Count: 255
                    Reset counter: 59
                    Mileage: 8378 km
                    Date: 2017.09.21
                    Time: 00:53:51
                    Count: 4608
                    Count: 67
                    Count: 51712
                    Count: 255
03756 - ESP De-Activated
                    Reset counter: 63
                    Date: 2017.09.21
                    Time: 00:00:31
                    Count: 1
                    Count: 12
                    Count: 20992
                    Count: 394
                    Count: 43520
   Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
   Component: AC Manuell    H19 0404
   Revision: 00001018
   Coding: 0000004002
   VCID: 7F4ECB43E698DEBEF3-802A
9481748 - High Pressure Sensor
          B10AE 14 [009] - Open or Short to Ground
                    Reset counter: 64
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:23:43
   Part No SW: 1K0 937 086 M    HW: 1K0 937 086 M
   Component: BCM PQ35  M   110 0651
   Revision: 00110 AC
   Coding: 0018003A80800000400800C0000008E04A05048810008820E40400240040
   VCID: 3A38FA57B53A3B9684-806E
   Component: Wischer 17041  26  0512
   Coding: 009795
03266 - Control Circuit for Signal Horn
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 63
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:03:34
                    Voltage: 11.90 V
                        Term 50 Off
01134 - Alarm Horn (H12)
                    Reset counter: 62
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:00:01
                        Term 15 Off
                    Voltage: 12.15 V
                        Term 50 Off
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Serial number: 003G5RAJE3W0
   Coding: 00005931
   Shop #: WSC 01604 666 39481
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 312ADD7B604CF8CE35-8064
   Serial number: 3572MSME606C046DZZZ/
   Serial number: 3582MSME4154056DZZZW
   Serial number: 3512QSME784C147DZZZ4
   Serial number: 3522QSME78020F33ZZZU
12 Faults Found:
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:23:45
12854016 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [009] - -
                    Reset counter: 64
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:23:50
9440083 - Driver's side; side-airbag igniter
          B100B 53 [009] - Deactivated
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:23:43
9439827 - Front Passenger's Side Airbag Igniter
          B100A 53 [009] - Deactivated
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:23:43
9438547 - Igniter for Driver head airbag
          B1005 53 [009] - Deactivated
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:23:43
9438291 - Igniter for Front passenger's Head Curtain Airbag
          B1004 53 [009] - Deactivated
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:23:43
9437779 - Igniter for Passenger's Airbag
          B1002 53 [009] - Deactivated
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:23:43
9438803 - Igniter for Seat Belt Tensioner; Driver's Side
          B1006 53 [009] - Deactivated
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:23:43
9439059 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 53 [009] - Deactivated
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:23:43
9442643 - Igniter for battery interrupt
          B1015 53 [009] - Deactivated
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:23:43
9440339 - Driver side knee airbag igniter
          B100C 53 [009] - Deactivated
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:23:43
9445459 - Key switch for deactivation of passenger-side airbag
          B1020 53 [009] - Deactivated
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:23:43
   Part No SW: 5K0 953 507 AG    HW: 5K0 953 549 A
   Revision: --------    Serial number:  90440LCQ000UF
   Coding: 5892000000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 75A2296BD4A494EEA9-8020
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0032
   Serial number: 0005670
117028 - Databus
                    Reset counter: 64
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:23:43
   Part No SW: 5K6 920 872     HW: 5K6 920 872
   Coding: 170800
   VCID: 72A81277A5CA83D68C-8026
   Revision:   H42       Serial number: 140412F2001571
   Coding: 350000
                    Fault Frequency: 17
                    Mileage: 7899 km
                    Date: 2017.09.21
                    Time: 00:00:01
   Component: IMMO          H03 0607
   VCID: 6A980A178D1A4B1634-803E
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2103
   Coding: 0000052
   VCID: 373EE363462826FE7B-8062
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 251    X444
   Revision: 00H22000
   VCID: 393AE55B703C308E8D-806C
                    Reset counter: 60
                    Mileage: 8377 km
                    Date: 2017.09.21
                    Time: 00:00:36
                    Battery Volts: 14.0 V
                        DU
                    Temperature: 42.0°C
                    Count: 5
                    Steering Angle: 108.94°
                    Count: 1
                        SteerAng n.Init
                    Fault Status: 00101101
                    Reset counter: 59
                    Mileage: 8380 km
                    Date: 2017.09.21
                    Time: 01:22:38
                    Voltage: 14.25 V
                        DU
                    Temperature: 32.0°C
                    RPM: 1715 /min
                    Speed: 14.0 km/h
                    Speed: 14.0 km/h
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.5 V
                        PD
                    Temperature: 24.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Component: Tuer-SG         009 2117
   Coding: 0000052
   VCID: 3228D277AD4AC3D64C-8066
End----------(Elapsed Time: 00:56, VBatt start/end: 12.3V/12.3V)-----------
Not Good Car:
Thursday,21,September,2017,14:16:50:26018
Mileage: 9810km-6095mi   Repair Order:
Scan: 01 02 03 08 09 16 17 19 25 42 44 46 52
VIN: WVWZZZ1KZCW333492   Mileage: 9810km-6095miles
Address 01: Engine
   Revision: 05551213    Serial number: 00001204030391
   Revision: 00H31001
                    Reset counter: 87
                    Date: 2017.09.21
                    Time: 00:00:57
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 44288
   Revision: 00001018
   Coding: 0000004002
13701968 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:57
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:57
   Revision: 00110 AC
   Coding: 009795
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:55
                    Voltage: 12.30 V
                        Term 50 Off
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:03:31
                        Term 15 Off
                    Voltage: 12.30 V
                        Term 50 Off
   Revision: --------    Serial number:  90440LCQ000U3
   Coding: 5892040000
   Serial number: 0005921
117028 - Databus
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:01:13
   Coding: 170800
9453330 - Outside temperature sensor
          B103F 1B [009] - Resistance Too High
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:57
   Revision:   H42       Serial number: 140412F1001397
   Coding: 350000
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:01
   Coding: 0000052
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 74     3305
   Revision: 00H22000
            000 -  -  - MIL ON
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:55
                    Battery Volts: 12.4 V
                        DD
                    Temperature: 11.0°C
                    Count: 2
                        SteerAng n.Init
   Coding: 0000052
End----------(Elapsed Time: 00:49, VBatt start/end: 12.4V/12.4V)-----------
MNZ
New Zealand
C?ID=155812
That worked great!
My only worry is that it doesn't say ESP - De-activated as one of the faults.
This is important for us as we don't want any intervention on race track.
It still will not accept the coding that the other vehicle has.
MNZ
New Zealand
C?ID=155812
Address 01: Engine
   Revision: 00H31001
                    Reset counter: 87
                    Date: 2017.09.21
                    Time: 00:00:57
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 44288
   Revision: 00001018
   Coding: 0000004002
          U1113 00 [009] - -
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:57
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:57
   Revision: 00110 AC
   Coding: 009795
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:55
                    Voltage: 12.30 V
                        Term 50 Off
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:03:31
                        Term 15 Off
                    Voltage: 12.30 V
                        Term 50 Off
   Coding: 5892040000
117028 - Databus
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:01:13
   Coding: 170800
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:57
   Coding: 350000
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:01
   Coding: 0000052
   Revision: 00H22000
            000 -  -  - MIL ON
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:55
                        DD
                    Temperature: 11.0°C
                    Count: 2
                        SteerAng n.Init
   Coding: 0000052
Thursday,21,September,2017,16:23:28:26018
Address 01: Engine
   Revision: 00H31001
   Coding: 143B800D492580FD280F01ED921B0161700000
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:07:03
                    Count: 1
                    Count: 12
                    Count: 25088
                    Count: 8226
                    Count: 44288
                    Count: 512
   Revision: 00001018
   Coding: 0000004002
          U1113 00 [009] - -
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:57
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:57
   Revision: 00110 AC
   Coding: 009795
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:55
                    Voltage: 12.30 V
                        Term 50 Off
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:03:31
                        Term 15 Off
                    Voltage: 12.30 V
                        Term 50 Off
   Coding: 5892040000
117028 - Databus
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:01:13
   Coding: 170800
                    Reset counter: 87
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:57
   Coding: 350000
   Coding: 0000052
   Revision: 00H22000
            000 -  -  - MIL ON
                    Mileage: 9819 km
                    Date: 2017.09.21
                    Time: 00:00:55
                        DD
                    Temperature: 11.0°C
                    Count: 2
                        SteerAng n.Init
   Coding: 0000052
End----------(Elapsed Time: 00:48, VBatt start/end: 12.2V/12.2V)-----------
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
That worked great!
Did you try coding what I gave you in post #4?
When you put this coding , what happens , is it says coding reject?
VIN: WVWZZZ1KZCW332707 License Plate: CUP275 GOOD
Vehicle Identification No.
WVWZZZ1KZCW332707
Model
Golf GTI
GOLF
Date of production
02.05.2012
Year
2012
Sales type
5K19P3
Engine Code
CDLG
Transmission Code
NLT
Axle drive
6A
Equipment
XE
Roof color
B4
Exterior color / Paint Code
B4 / B9A
VIN: WVWZZZ1KZCW333492 BAD CAR :rolleyes:
WVWZZZ1KZCW333492
Model
Golf GTI
GOLF
Date of production
03.05.2012
Year
2012
Sales type
5K19P3
Engine Code
CDLG
Transmission Code
NLT
Axle drive
6A
Equipment
XE
Roof color
B4
B4 / B9A
0x01 <<<<<<<<<<<<<<<<<<<<<<<<<< NO reach on CG x2 ( 5K0-907-115K ) Same!
Part No SW: 02E 300 051 R HW: 02E 927 770 AL <<<<<<<<< x2
Address 03: ABS Brakes (J104) Labels: None <<<<<<<<<<<<<< Donor by OP
Revision: 00H31001
Part No SW: 5C0 907 379 CL HW: 1K0 907 379 BL <<<<<<<<<<<<<<< HMMM FLAG! on hardware abstract DATA says should be 1K0-907-375BJ or legacy 379BJ
Revision: 00H31001
Marin the magnificent.......:rolleyes:
Coding: 143B800D492500FD280F01ED921B0061700000
Coding: 143B800D492500FC281201E492200061700000 Good car decode..... SS(REGEN)BRAKE LHD
Coding: 144B000C092500FC281200E490200000000000 STRIP LHD
Coding: 144B000C092500FD280F00ED901B0000000000 Strip as BL or BJ same LHD!
Coding: 143B800D492500FD880F01ED912B0061700000 OP try this?
Coding: 143B800D492500FD812F01ED922B0061700000
MNZ
New Zealand
C?ID=155812
WVWZZZ1KZCW332707
Model
Golf GTI
GOLF
Date of production
02.05.2012
Year
2012
Sales type
5K19P3
Engine Code
CDLG
Transmission Code
NLT
Axle drive
6A
Equipment
XE
Roof color
B4
B4 / B9A
WVWZZZ1KZCW333492
Model
Golf GTI
GOLF
Date of production
03.05.2012
Year
2012
Sales type
5K19P3
Engine Code
CDLG
Transmission Code
NLT
Axle drive
6A
Equipment
XE
Roof color
B4
B4 / B9A
Revision: 00H31001
Revision: 00H31001
I tried both of the lower coding you have posted there and both not working, rejected.
This coding is accepted yes, but the issue is that the ESP is not showing as de-activated as the other good car is. We can't run with ESP as it is a race car.
iichel
Netherlands, eastern part
C?ID=284912
If I take the coding of the working car
VIN WVWZZZ1KZCW3 32707
and substitute the VIN bytes, I end up with:
WVWZZZ1KZCW3 33492
Just like Jetta, 97
MartinsX
Riga, Latvia
C?ID=268515
WVWZZZ1KZCW3 33492
Just like Jetta, 97
I tried the same and result is identical.
MartinsX
Riga, Latvia
C?ID=268515
I could be useful to see and compare both engine codings. Why HEX-NET isn't communicating with ECU on both cars?
iichel
C?ID=284912
Maybe the engines are running modified software?
Jetta 97
C?ID=81680
After coding most of the sensors will be out of the line, and you have to adopt all sensors.
Did you do that?
MNZ
New Zealand
C?ID=155812
All basic settings are done, only fault code left is due to airbag module being removed from vehicle. So ABS is now ok, I just have to be sure ESP is not going to intervene on track.
Address 03: ABS Brakes Labels: None
Control Module Part Number: 5C0 907 379 CL HW: 1K0 907 379 BL
Component and/or Version: ESP MK60EC1 H31 XA04
Software Coding: 143B800D492580FD280F01ED921B0161700000
Work Shop Code: WSC 75000 666 121355
Reset counter: 87
Mileage: 9819 km
Date: 2005.14.23
Time: 00:07:47
Count: 1
Count: 25088
Count: 8226
Count: 48384
The reason Address 01 is not shown is due to Syvecs ECU being fitted to vehicles, these replace stock ECU. Everything else remains stock including DSG transmission and Syvecs sends same data to all units as stock ECU.
MNZ
New Zealand
C?ID=155812
Ok I have decoded the steering angle sensor from Address 44 - Steering Assist. So now the ESP has no reference and can't activate.
I will try on track this weekend.
Does this part # go to this car?
VIN: WVWZZZ1KZ9P009260
Part No SW: 03G 906 018 FB HW: 03G 906 018 FB
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Coding: 11 4B 00 0C 09 22 00 03 88 0D 00 EA 90 19 00 00 00 00 Stripped LHD
pronet
Romania
C?ID=157414
A friend of mine has experienced an ABS problem and has changed the ABS unit. Unfortunately he didn''t save the previous ABS codding. So, the new module mounted on the car is not codded. Please find attach the scan. If you be so kind to give me the correct codding in order to codding the ABS properly.
 Monday,25,September,2017,20:26:06:56830
VIN: WVWZZZ1KZ9P009260   License Plate:
Mileage: 184620km-114717mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ9P009260   Mileage: 184620km-114717miles
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Component: R4 2.0l PPD1.2 G    2527
   Revision: --H52---    Serial number: VWX7Z0H53N57WQ
   Coding: 0000072
   Shop #: WSC 10101 599 07319
   VCID: 6AD0378145A2171634-803E
Readiness: N/A
   Revision: 00H35001
   VCID: 74EC29F9D766D1E69E-8020
                    Reset counter: 134
                    Count: 4608
                    Count: 195
                    Count: 43776
                    Count: 65024
   Part No SW: 1K0 907 044 DD    HW: 1K0 907 044 DD
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 6CDC31994F56092646-8038
   Revision: 00H54000    Serial number: 00000008483095
   Coding: 038B0F2700041500471400001400000000097F075C000100000000000000
   Shop #: WSC 00028 028 00001
   VCID: 336EEAE552E896DE47-8066
   Component: Wischer 210508 021  0501
   Coding: 00038805
   Shop #: WSC 00028
                    Reset counter: 134
                    Mileage: 184627 km
                    Voltage: 12.25 V
00154 - Windshield Wiper Motor;  Passenger Side (V217)
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 134
                    Mileage: 184627 km
                    Voltage: 12.20 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                    Reset counter: 134
                    Mileage: 184627 km
                    Voltage: 12.20 V
   Component: 37 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD220JF1
   Coding: 0013111
   VCID: 3D7ACCDD64AC50AEA1-8068
   Subsystem 1 - Serial number: 6332MSME2D216E65K
   Subsystem 2 - Serial number: 6342MSME3A74185CM
   Subsystem 3 - Serial number: 6352QSME6A6121159
   Subsystem 4 - Serial number: 6362QSME6A612373G
   Part No SW: 1K0 953 549 BP    HW: 1K0 953 549 BP
   Component: J0527           752 0101
   Coding: 0002022
   VCID: 0102702D58D4F44E85-8054
   Part No SW: 1K0 920 874 B    HW: 1K0 920 874 B
   Component: KOMBIINSTRUMENT VDD 2416
   Revision: V0002000    Serial number: VWX7Z0H53N57WQ
   Coding: 0007103
   Shop #: WSC 65536 645 577705
   VCID: 2C5CF1998FD6C92606-8078
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 010608F1000893
   Coding: E9817F060002020002
   VCID: 356AD4FD5C9C88EE69-8060
   Component: IMMO            VDD 2416
   Component: Tuer-SG         006 1219
   Coding: 0000180
   VCID: 3874DDC94B8E758672-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Coding: 809002005103087F2D04840560084F03E0FC00
   VCID: 030E7A2542C8E65E97-8056
   Coding: 0000180
   VCID: 3972D8CD70846C8E8D-806C
00110 - Right Mirror Turn Signal Lamp (L132)
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74EC29F91766D1E69E-8020
00496 - Sensor for Vehicle Leveling; Front
            010 - Open or Short to Plus
   Part No: 1K0 035 186 AF
   Component: Radio GR0       035 0034
   Revision: 0003505S    Serial number: VWZ2Z2H1131535
   Coding: 0040400
   Component: Tuer-SG         006 1302
   Coding: 0000144
   Shop #: WSC 00028 028 1012545
   Coding: 0000144
End-------------------------(Elapsed Time: 01:47)--------------------------
iichel
C?ID=284912
WVWZZZ1KZ9P009260
LHD
FWD
Manual gearbox
2.0 TDI
312/253mm brakes?
TPMS guess yes
normal ESP deactivation
114B600C09220003880D06EA90190042040C00
pronet
Romania
C?ID=157414
without TPMS.
