Audi A5 Cabrio top, base line values for CLOSED and OPEN
Jef
HQ
From a 2017 S5 Cabrio
http://forums.ross-tech.com/showthread.php?7674-2017-S5-Cabrio-(CTUB-engine)
Copy text below, save as a *.CSV and you can then view it as a simple 3 colum spread sheet.
8F0-959-255, Auto Roof - CLOSED,,
Group,Description,Actual,
IDE00019,Voltage terminal 30,12.2V,
IDE00020,Terminal 15 status,On,
IDE00075,Vehicle speed,N/A---,
IDE00556,Outside air temperature,N/A---,
IDE01715,Status terminal S,On,
IDE02299-MAS02293,Status window regulator-Window position driver door,N/A---,
IDE02299-MAS02294,Status window regulator-Window position passenger door,N/A---,
IDE02299-MAS02295,Status window regulator-Left rear window position,N/A---,
IDE02299-MAS02296,Status window regulator-Right rear window position,N/A---,
IDE02299-MAS02297,Status window regulator-Driver door high,not activated,
IDE02299-MAS02298,Status window regulator-Driver door low,not activated,
IDE02299-MAS02299,Status window regulator-Passenger door high,not activated,
IDE02299-MAS02300,Status window regulator-Passenger door low,not activated,
IDE02299-MAS02301,Status window regulator-Left rear high,not activated,
IDE02299-MAS02302,Status window regulator-Left rear low,not activated,
IDE02299-MAS02303,Status window regulator-Right rear high,not activated,
IDE02299-MAS02304,Status window regulator-Right rear low,not activated,
IDE02664-MAS02263,Switch for folding top-Convertible top open position switch,not activated,
IDE02664-MAS02264,Switch for folding top-Convertible top front closed position switch,operated,
IDE02664-MAS02265,Switch for folding top-Convertible top latch -open- switch,not activated,
IDE02664-MAS02266,Switch for folding top-Convertible top left lock switch,operated,
IDE02664-MAS02268,Switch for folding top-Switch for folding top closed: left,operated,
IDE02664-MAS02269,Switch for folding top-Switch for folding top closed: right,operated,
IDE02664-MAS02270,Switch for folding top-Upper tensioning bow switch,not activated,
IDE02664-MAS02271,Switch for folding top-Left tensioning bow switch,operated,
IDE02664-MAS02272,Switch for folding top-Right tensioning bow switch,operated,
IDE02664-MAS02273,Switch for folding top-Convertible top compartment -open- switch,not activated,
IDE02664-MAS02274,Switch for folding top-Left convertible top compartment cover switch,operated,
IDE02664-MAS02275,Switch for folding top-Right convertible top compartment cover switch,operated,
IDE02664-MAS02276,Switch for folding top-Convertible top compartment latch -unlocked- switch,not activated,
IDE02664-MAS02277,Switch for folding top-Convertible top compartment -locked- switch,operated,
IDE02664-MAS02278,Switch for folding top-Left convertible top compartment enclosure switch,operated,
IDE02664-MAS02279,Switch for folding top-Right convertible top compartment enclosure switch,operated,
IDE02664-MAS02280,Switch for folding top-Left wind deflector switch,not activated,
IDE02664-MAS02281,Switch for folding top-Right wind deflector switch,not activated,
IDE02665,Power top operation switch,not activated,
IDE02666-MAS00538,Convertible top status-Convertible top operation indicator lamp,OFF,
IDE02666-MAS01535,Convertible top status-Rear window defogger,On,
IDE02666-MAS01911,Convertible top status-Tone sensor,OFF,
IDE02666-MAS02282,Convertible top status-Position,N/A---,
IDE02666-MAS02283,Convertible top status-Condition,closed,
IDE02666-MAS02290,Convertible top status-Rear lid,Enabled,
IDE02666-MAS02426,Convertible top status-Text display in instrument panel insert,0,
IDE02667-MAS00370,Cut-out requirements-Vehicle speed,OK,
IDE02667-MAS02286,Cut-out requirements-Hydraulic pump,OK,
IDE02667-MAS02289,Cut-out requirements-Outside air temperature,OK,
IDE02667-MAS02290,Cut-out requirements-Rear lid,Open,
IDE02667-MAS02427,Cut-out requirements-Folding top run blocked,active,
IDE02667-MAS02428,Cut-out requirements-Switch positions,OK,
IDE02667-MAS02429,Cut-out requirements-Supply voltage at start,OK,
IDE02667-MAS02430,Cut-out requirements-Supply voltage during folding top run,OK,
IDE02667-MAS02431,Cut-out requirements-CAN malfunction,OK,
IDE02667-MAS02432,Cut-out requirements-Convertible top locking motor,OK,
IDE02667-MAS02433,Cut-out requirements-Output stages,OK,
IDE02667-MAS02434,Cut-out requirements-Folding top latch,OK,
IDE02667-MAS02435,Cut-out requirements-Folding top cover lock,OK,
IDE02667-MAS02436,Cut-out requirements-Power top operation switch,OK,
IDE02667-MAS02440,Cut-out requirements-Output Diagnostic Test Mode (DTM),not active,
IDE02667-MAS02441,Cut-out requirements-Side window,OK,
IDE02668,Central window regulator switch,not activated,
IDE03111-IDE03110,Interior light-Status terminal 30G,On,
IDE03111-MAS02443,Interior light-Release for rear interior light,On,
IDE03111-MAS02444,Interior light-Central locking,Open,
IDE03112-MAS02263,Switch for folding top: last OK condition-Convertible top open position switch,not activated,
IDE03112-MAS02264,Switch for folding top: last OK condition-Convertible top front closed position switch,not activated,
IDE03112-MAS02265,Switch for folding top: last OK condition-Convertible top latch -open- switch,not activated,
IDE03112-MAS02266,Switch for folding top: last OK condition-Convertible top left lock switch,not activated,
IDE03112-MAS02268,Switch for folding top: last OK condition-Switch for folding top closed: left,not activated,
IDE03112-MAS02269,Switch for folding top: last OK condition-Switch for folding top closed: right,not activated,
IDE03112-MAS02270,Switch for folding top: last OK condition-Upper tensioning bow switch,not activated,
IDE03112-MAS02271,Switch for folding top: last OK condition-Left tensioning bow switch,not activated,
IDE03112-MAS02272,Switch for folding top: last OK condition-Right tensioning bow switch,not activated,
IDE03112-MAS02273,Switch for folding top: last OK condition-Convertible top compartment -open- switch,not activated,
IDE03112-MAS02274,Switch for folding top: last OK condition-Left convertible top compartment cover switch,not activated,
IDE03112-MAS02275,Switch for folding top: last OK condition-Right convertible top compartment cover switch,not activated,
IDE03112-MAS02276,Switch for folding top: last OK condition-Convertible top compartment latch -unlocked- switch,not activated,
IDE03112-MAS02277,Switch for folding top: last OK condition-Convertible top compartment -locked- switch,not activated,
IDE03112-MAS02278,Switch for folding top: last OK condition-Left convertible top compartment enclosure switch,not activated,
IDE03112-MAS02279,Switch for folding top: last OK condition-Right convertible top compartment enclosure switch,not activated,
IDE03112-MAS02280,Switch for folding top: last OK condition-Left wind deflector switch,not activated,
IDE03112-MAS02281,Switch for folding top: last OK condition-Right wind deflector switch,not activated,
IDE03112-MAS02282,Switch for folding top: last OK condition-Position,0,
IDE03112-ENG99138,Switch for folding top: last OK condition-Top request,not activated,
IDE03113-MAS02263,Switch for folding top when error occurred-Convertible top open position switch,not activated,
IDE03113-MAS02264,Switch for folding top when error occurred-Convertible top front closed position switch,not activated,
IDE03113-MAS02265,Switch for folding top when error occurred-Convertible top latch -open- switch,not activated,
IDE03113-MAS02266,Switch for folding top when error occurred-Convertible top left lock switch,not activated,
IDE03113-MAS02268,Switch for folding top when error occurred-Switch for folding top closed: left,not activated,
IDE03113-MAS02269,Switch for folding top when error occurred-Switch for folding top closed: right,not activated,
IDE03113-MAS02270,Switch for folding top when error occurred-Upper tensioning bow switch,not activated,
IDE03113-MAS02271,Switch for folding top when error occurred-Left tensioning bow switch,not activated,
IDE03113-MAS02272,Switch for folding top when error occurred-Right tensioning bow switch,not activated,
IDE03113-MAS02273,Switch for folding top when error occurred-Convertible top compartment -open- switch,not activated,
IDE03113-MAS02274,Switch for folding top when error occurred-Left convertible top compartment cover switch,not activated,
IDE03113-MAS02275,Switch for folding top when error occurred-Right convertible top compartment cover switch,not activated,
IDE03113-MAS02276,Switch for folding top when error occurred-Convertible top compartment latch -unlocked- switch,not activated,
IDE03113-MAS02277,Switch for folding top when error occurred-Convertible top compartment -locked- switch,not activated,
IDE03113-MAS02278,Switch for folding top when error occurred-Left convertible top compartment enclosure switch,not activated,
IDE03113-MAS02279,Switch for folding top when error occurred-Right convertible top compartment enclosure switch,not activated,
IDE03113-MAS02280,Switch for folding top when error occurred-Left wind deflector switch,not activated,
IDE03113-MAS02281,Switch for folding top when error occurred-Right wind deflector switch,not activated,
IDE03113-ENG99138,Switch for folding top when error occurred-Top request,not activated,
IDE03114-MAS01582,Comfort function-Return message,not active,
IDE03114-MAS02445,Comfort function-Folding top request,not activated,
IDE03114-MAS02447,Comfort function-Release,blocked,
IDE05230,Number of convertible top run cycles,81,
8F0-959-255, Auto Roof - OPEN,,
IDE00019,Voltage terminal 30,12.4, V
IDE02664-MAS02263,Switch for folding top-Convertible top open position switch,operated,
IDE02664-MAS02264,Switch for folding top-Convertible top front closed position switch,not activated,
IDE02664-MAS02268,Switch for folding top-Switch for folding top closed: left,not activated,
IDE02664-MAS02269,Switch for folding top-Switch for folding top closed: right,not activated,
IDE02664-MAS02271,Switch for folding top-Left tensioning bow switch,not activated,
IDE02664-MAS02272,Switch for folding top-Right tensioning bow switch,not activated,
IDE02666-MAS01535,Convertible top status-Rear window defogger,OFF,
IDE02666-MAS02283,Convertible top status-Condition,Open,
IDE02667-MAS02290,Cut-out requirements-Rear lid,closed,
IDE02667-MAS02427,Cut-out requirements-Folding top run blocked,not active,
IDE03111-MAS02443,Interior light-Release for rear interior light,OFF,
