2012 GTI 2.0L TSI CCTA ABS, ASR AIRBAG, TPM came 2 mornings
GavGTI
C?ID=321153
High everyone, two mornings in a row my MIF lights came on and stayed ON for the drive. When I restarted vehicle to travel once again the MIF did not show up. I knew that my battery was on its last leg, so I replaced it today. I installed the OEM VW battery, it has the same code. Do I install the vent plug? or leave it open to vent?
Do I need to erase or clear these faults or leave them alone or is the fault something more serious.
Monday,13,November,2017,09:57:27:53083
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4407.4
VIN: WVWFV7AJ2CWxxxxxx   License Plate:
Mileage: 117090km-72756mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 77
VIN: WVWFV7AJ2CWxxxxxx   Mileage: 117090km-72756miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AS    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0040
   Revision: AAH18---    Serial number:
   Coding: 0403010A1C070160
   Shop #: WSC 35252 001 1048576
   VCID: 77AB151173C1B10F6A0-8022
               U1017 - 015 -  - Intermittent
                    Fault Status: 00101111
                    Mileage: 117094 km
                    Date: 2012.04.05
                    Time: 09:50:40
                    RPM: 1263 /min
                    Load: 21.6 %
                    Temperature: 24.0°C
                    Temperature: 26.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.557 V
   Part No SW: 02E 300 057 C    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2724
   Revision: 05351113    Serial number: 00001107280798
   VCID: 196F33A9A595477FBC4-804C
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -  - Intermittent
                    Fault Frequency: 255
                    Reset counter: 1
                    Mileage: 117056 km
                    Date: 2012.04.04
                    Time: 14:20:20
   Revision: 00H31001
   Coding: 114B600C492300FE881106E692200041B70800
   VCID: 7BA3092143E9956F0E8-802E
                    Fault Status: 00101100
                    Reset counter: 70
                    Mileage: 117056 km
                    Count: 3
                    Count: 12
                    Count: 4096
                    Count: 56
                    Count: 43008
                    Count: 65280
                    Count: 254
                    Reset counter: 69
                    Mileage: 117056 km
                    Date: 2012.04.04
                    Time: 14:20:29
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 16390
                    Count: 50432
                    Count: 65280
                    Count: 254
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0304
   Revision: 00001016
   Coding: 0000001002
   VCID: 00597ECD2A8FF6B75BA-8054
   Part No SW: 1K0 937 086 P    HW: 1K0 937 086 P
   Component: BCM PQ35  M   110 0651
   Revision: 00110 AC
   Coding: 6F180A1A90272A04008800C17000054448010386534D8D60648020200040
   VCID: 3D27C7391D7D5B5F70C-8068
   Component: Wischer 05091  26  0512
   Coding: 009795
   Serial number: 003GVRA0KGF9
   Coding: 00003131
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3FDBBD3117F1494F620-806A
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--00060U5M00
   Serial number: 3572MSME39000263ZZZG
   Serial number: 3582MSME1A6B6562ZZZ+
   Serial number: 3512QSME42255D22ZZZQ
   Serial number: 3522QSME7E385B14ZZZ2
   Serial number: 35527SME49646628ZZZL
   Serial number: 35627SME606B6628ZZZM
9483008 - Seat Occupied Recognition
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Reset counter: 110
                    Mileage: 117056 km
                    Date: 2017.11.12
                    Time: 14:20:36
   Part No SW: 5K0 953 507 AJ    HW: 5K0 953 549 B
   Revision: --------    Serial number:  90422KHF000DD
   Coding: 589A140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 78A9162D725FBE7763A-802C
   Component: E221__MFL-TAS  H08 0010
   Serial number: 0085037
   Part No SW: 5K6 920 972 C    HW: 5K6 920 972 C
   Coding: 270F01
   VCID: 3635D81538CB8807B16-8062
   Revision:   H42       Serial number: 020911F1001578
   Coding: 350000
   VCID: 3537DF19254D831FB8C-8060
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223REJ6N06
   VCID: 7EA500355CFB8047296-802A
   Component: IMMO          H03 0607
   VCID: 6A8D3C653CF31CE7E5E-803E
   Revision: A1001003    Serial number: 7660800500
   VCID: 290F0369F9F5D7FF2C4-807C
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2103
   Coding: 0001076
   VCID: 372BD5113341710FAA0-8062
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 74     3201
   Revision: 00H20000
   VCID: 3431E21D22379A178F2-8060
                    Fault Status: 00101101
                    Reset counter: 110
                    Mileage: 117094 km
                    Date: 2012.04.05
                    Time: 09:50:42
                    Voltage: 14.13 V
                        DU
                    Temperature: 26.0°C
                    RPM: 1139 /min
   Component: Tuer-SG         009 2117
   Coding: 0001076
   VCID: 323DE405D82394279DE-8066
   Part No SW: 1K0 035 164 C    HW: 1K0 035 164 C
   Component: LOW NAR SDARS H02 0004
   Revision: -----03S    Serial number: VWZ4Z6L3179074
   Coding: 01000400040005
   VCID: 221D144584C304A76DE-8076
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007660754150
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 270B0551EF61E18F3A0-8072
End----------(Elapsed Time: 01:01, VBatt start/end: 12.0V/12.1V)-----------
OP can you be so kind before clearing any codes to post a scan of the OBD2 function for this vehicle using VCDS?
It would be most appreciated.
Engine & Transmission
Do you mean MIL/CHECK ENGINE LIGHT = MIF?
Thank you....
GavGTI
C?ID=321153
I tried doing the OBD2 is it normal for the inface to be blinking red & green? To be honest i don’t how
Alternate red/green just indicates communications.
Yes that is an indication of communication.
Please go to in main screen hit OBD2 button ( 0x33 ) and read codes plus pending and save data.
Then post here please.
Additionally did you mean MIL means MIF please advise?
GavGTI
C?ID=321153
Sorry about that Jack, theirs no MIL light. I thought MIL meant any dash lights, but (MIL) is for engine light only, is that correct. I apologize for my inexperience. I hope this data is the OBD2 info you were looking for.
Thanks, Jack
Monday,13,November,2017,21:28:26:53083
VCDS Release 17.8.0 (x64):  Generic OBD2
Mode 01 - PID 01 : Readiness  --  Address 7E8
Number of DTCs stored: 0  --  MIL Status: MIL OFF
Misfire monitoring:  Passed
Fuel System:  Passed
Comprehensive Components:  Passed
Catalyst monitoring:  Passed
Heated catalyst monitoring: Not installed.
Evaporative system monitoring:  Passed
Secondary air system monitoring: Not installed.
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring:  Passed
Oxygen sensor heater monitoring:  Passed
Exhaust Gas Recirculation:  Passed
Monday,13,November,2017,21:29:47:53083
No Freeze Frame Data available.
Monday,13,November,2017,21:30:12:53083
Mode 03: Emission related fault codes
Address 7E8: No fault code found.
Address 7E9: No fault code found.
Monday,13,November,2017,21:30:33:53083
Mode 07: Pending emission related fault codes
Monday,13,November,2017,21:30:58:53083
Mode 9 : Calibration Identification
Type 02 - VIN : WVWFV7AJ2CWxxxxxx (Address E8)
Type 04 - Calibration ID : 1K0907115AS 0040 (Address E8)
Type 04 - Calibration ID : 02E300057C  2724 (Address E9)
Type 06 - Calibration Verification Number : 12283862 (Address E8)
Type 06 - Calibration Verification Number : 0000E69E (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 583
    Ignition cycle count : 1638
    Conditions completion count / Specificied conditions encountered count
         Catalyst monitor bank 1 : 636 / 583
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 658 / 583
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 1197 / 583
         AIR monitor : 0 / 0
         EVAP monitor : 260 / 141
         Secondary O2 Sensor monitor bank 1 : 824 / 583
         Secondary O2 Sensor monitor bank 2 : 0 / 0
Type 0A - Controller Name : ECM-EngineControl (Address E8)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Monday,13,November,2017,21:31:22:53083
Mode 10: Permanent Fault Codes
GavGTI
C?ID=321153
I haven't cleared anything out so far, Jack
GavGTI
C?ID=321153
Monday,13,November,2017,21:13:51:53083
Mileage: 117170km-72806mi   Repair Order:
VIN: WVWFV7AJ2CWxxxxxx   Mileage: 117170km-72806miles
                    Mileage: 117094 km
                    Date: 2012.04.05
                    Time: 09:50:40
                    RPM: 1263 /min
                    Load: 21.6 %
                    Temperature: 24.0°C
                    Temperature: 26.0°C
                    Voltage: 11.557 V
   Revision: 00H31001
                    Reset counter: 110
                    Mileage: 117056 km
                    Count: 3
                    Count: 12
                    Count: 4096
                    Count: 56
                    Count: 43008
                    Count: 65280
                    Count: 254
                    Reset counter: 111
                    Mileage: 117056 km
                    Date: 2012.04.04
                    Time: 14:20:29
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 16390
                    Count: 50432
                    Count: 65280
                    Count: 254
   Revision: 00001016
   Coding: 0000001002
   Revision: 00110 AC
   Coding: 009795
   Coding: 00003131
                    Reset counter: 110
                    Mileage: 117056 km
                    Date: 2017.11.12
                    Time: 14:20:36
   Coding: 589A140000
   Coding: 270F01
   Coding: 350000
   Coding: 0001076
   Revision: 00H20000
                    Reset counter: 110
                    Mileage: 117094 km
                    Date: 2012.04.05
                    Time: 09:50:42
                    Voltage: 14.13 V
                        DU
                    Temperature: 26.0°C
                    RPM: 1139 /min
   Coding: 0001076
   ROD: UHVNA.rod
End----------(Elapsed Time: 01:01, VBatt start/end: 14.2V/14.2V)-----------
Fuel System:  Passed
Fuel System:  Passed
         AIR monitor : 0 / 0
Fuel System:  Passed
GavGTI
C?ID=321153
Here is my JPPSG post
Hi Jack, I cleared the DTC and did a fresh Auto-Scan.
1. Volkswagen/GTI/2012/VI
2. WVWFV7AJ2CWXXXXXX
3. Stock (all parts used for repairs are OEM and done at the dealer)
4. VCDS SCAN (see below)
5. Most recent is the repair of the left rear ABS sensor (WHT-003-859) at 71450 miles
a. At 61250 miles, during 60k service, tech found RH (small fan) INOP replace BOPTH S10 replace both cooling fans, 1 1K0-959-455-FR & 1 1K0-959-455-ET $$$! They also performed ECM software update. Old version-0010. New version-0040. And they did the 60K service as outline in manual.
b. At 69532 miles, during 10k service, tech found oil leak, cause: Rear Main Crank seal leaking oil. They replaced seal. $$$! They also performed the water pump test and found that to be leaking; Replace water pump 1 06H-121-026-DD $$$! Tech also found a Fault in the ECM, cause: FAULT 2015 found in ECM, replace 1-06J-133-201-BH manifold, 4 06J-998-907-B repair kit, 1 G-001-780-M3 additive, 1 N-107-732-01 bolt, 1 06H-133-583-F hose. This was done once before when the care was younger. This is part of an extended warrantee in effect till 2021 year or 120K.
6. When I received my interface cable I did the auto scan, and everything was 100% no faults. I suspected my battery was on it last leg being over three years old and I know this could cause issues. And in the morning when I started my car to go out I saw these symptoms on my dash, ABS, ASR, Airbag and TPMS warning lights illuminated. I suspected it maybe because of low voltage, because after driving the car around and restarting to go somewhere else, no warning lights. So, it did that for two mornings straight and then I made up my mind to replace my battery with the OEM battery before this causes more issues. The memory of my last ABS issue came back to haunt me and the cost of another 300 bucks. My dealer told me not to be surprise, if the rear right-side ABS sensor fails in a month or so, “because we see this recur in other VW cars.”
7. All fuses tested good. Battery connections checked and okay. I’m going to forgo the load test since the battery is brand new.
8. I use this manual 2010 – 2016 Golf VI GTI Golf R 5k. PDF Repair Manual CC 2010 ➤ , Eos 2006 ➤ , Golf 2004 ➤ , Golf 2009 ➤ , Passat 2006 ➤ , Passat CC 2009 ➤ , Tiguan 2008 ➤ 4-Cylinder Fuel Injection Engine (K1.8L and 2.0L engine, chain drive) engine ID CBFA & CCTA and Wiring Diagram
9. Since I replace my battery with the OEM battery (my car does not have a BEM) with the same code my visual symptoms (warning lights are gone.) Just the Faults in the auto-scan remain.
Tuesday,14,November,2017,20:14:05:53083
VIN: WVWFV7AJ2CWxxxxx   License Plate: AFTER CLEARING DTC"s
Mileage: 117300km-72886mi   Repair Order:
VIN: WVWFV7AJ2CWxxxxx   Mileage: 117300km-72886miles
Readiness: 0000 0101
   Revision: 00H31001
   Revision: 00001016
   Coding: 0000001002
   Revision: 00110 AC
   Coding: 009795
   Coding: 00003131
   Coding: 589A140000
   Coding: 270F01
   Coding: 350000
   Coding: 0001076
   Revision: 00H20000
   Coding: 0001076
                    Reset counter: 75
                    Mileage: 117305 km
                    Date: 2012.04.06
                    Time: 19:43:10
   ROD: UHVNA.rod
End----------(Elapsed Time: 01:00, VBatt start/end: 13.9V/13.9V)-----------
GavGTI
C?ID=321153
   Revision: 00H31001
   Revision: 00001016
   Coding: 0000001002
   Revision: 00110 AC
   Coding: 009795
   Coding: 00003131
   Coding: 589A140000
   Coding: 270F01
   Coding: 350000
   Coding: 0001076
   Revision: 00H20000
   Coding: 0001076
                    Reset counter: 75
                    Mileage: 117305 km
                    Date: 2012.04.06
                    Time: 19:43:10
   ROD: UHVNA.rod
Here is my Broadcast
4. VCDS SCAN
Excellent keep an eye on everything and report back if any new issues occur please........ :D
If you would be so kind to let us know what you had to pay for or by posting your bill if you feel comfortable with that?
You could also do 3 tests with VCDS to complete readiness.
0x01-04-070/071/046
or
0x01-04-200 and step on brake and gas.......
GavGTI
C?ID=321153
0x01-04-070/071/046
or
Thanks Jack & Uwe for your help and patient with this newbie.
If I had to do over again I would opted for the extended warrantee when I purchased my GTI (vehicle) but at the time I didn't want to add to the cost. I've been burned before in the past by warrantee's. But, if I knew repairs were that expensive it would have been well-worth-it. But onward thought the fog. "as the say" I will try to make as many repairs myself, or at least have a chance to shop-around on the cost.
Fan repair: When the small fan when out they recommended I do both. Part & Labor $938.25
Seal replacement: Replacement of rear main crank seal was very pricey, considering I did all the routine services at the dealer using there synthetic oil and for the seal to fail at 69K is kind of suspicious in my book. That repair was extremely pricey $1,246.50 and they gave me 10% and two months of sat radio.
Water Pump: This was done at the same time as the Main Crank Seal. I would of thought this failure or leak should of fallen under defected pump by VW because I had read online about there being a recall on water pumps and I checked with the recall department and they said no, there is no defects with you engine. This cost was $861.29
ABS: This repair I could of done myself but I had concerns about not being able to clear the Fault, So, off I went to the dealer. That cost was $349.67.
Oil Changes: 10K service cost $119.For the 60K service I had a coupon 20% off $267.84 From now on I plan to DIY oil change and use Liqu Moly oil.
As far as the other Scans you requested Jack, I will try to get them done today some time.
Thanks again for all your help.
GavGTI
C?ID=321153
0x01-04-070/071/046
or
Well Jack here goes... I finally picked up on the "What is Jack talking about"post
Thursday	16	November	2017	15:01:27:53083-VCID:77AB151173C1B10F6A0-8022	VCDS Version: Release 17.8.0 (x64)	Data version: 20170721 DS276.2
1K0 907 115 AS		2.0l R4/4V TFSI     0040
	Group A:	'070				Group B:	 Not Running				Group C:	 Not Running
		Evap. Emissions	Lambda Control	Evap. Emissions	EVAP Valve
	TIME	Sol. Valve (Open)		Sol. Valve (Flow)	Test	TIME					TIME
Marker	STAMP	 %	 %			STAMP					STAMP
	0.01	5.1	0	 	Test OFF
	0.15	5.1	0	 	Test OFF
	0.28	5.1	0	 	Test OFF
	0.43	5.1	0	 	Test OFF
	0.57	5.1	0	 	Test OFF
	0.71	5.1	0	 	Test OFF
	0.84	5.1	0	 	Test OFF
	0.98	5.1	0	 	Test OFF
	1.13	5.1	0	 	Test OFF
	1.26	5.1	0	 	Test OFF
	1.41	5.1	0	 	Test OFF
	1.57	5.1	0	 	Test OFF
	1.69	5.1	0	 	Test OFF
	1.83	5.1	0	 	Test OFF
	1.97	5.1	0	 	Test OFF
	2.11	5.1	0	 	Test OFF
	2.25	5.1	0	 	Test OFF
	2.4	5.1	0	 	Test OFF
	2.53	5.1	0	 	Test OFF
	2.67	5.1	0	 	Test OFF
	2.82	5.1	0	 	Test OFF
	2.96	5.1	0	 	Test OFF
	3.1	5.1	0	 	Test OFF
	3.24	5.1	0	 	Test OFF
	3.38	5.1	0	 	Test OFF
	3.52	5.1	0	 	Test OFF
	3.66	5.1	0	 	Test OFF
	3.8	5.1	0	 	Test OFF
	3.93	5.1	0	 	Test OFF
	4.08	5.1	0	 	Test OFF
	4.22	5.1	0	 	Test OFF
	4.38	5.1	0	 	Test OFF
	4.52	5.1	0	 	Test OFF
	4.65	5.1	0	 	Test OFF
	4.8	5.1	0	 	Test OFF
	4.94	5.1	0	 	Test OFF
	5.08	5.1	0	 	Test OFF
	5.22	5.1	0	 	Test OFF
	5.36	5.1	0	 	Test OFF
	5.5	5.1	0	 	Test OFF
	5.64	5.1	0	 	Test OFF
	5.79	5.1	0	 	Test OFF
	5.93	5.1	0	 	Test OFF
	6.06	5.1	0	 	Test OFF
	6.21	5.1	0	 	Test OFF
	6.35	5.1	0	 	Test OFF
	6.49	5.1	0	 	Test OFF
	6.63	5.1	0	 	Test OFF
	6.76	5.1	0	 	Test OFF
	6.91	5.1	0	 	Test OFF
	7.05	5.1	0	 	Test OFF
	7.18	5.1	0	 	Test OFF
	7.33	5.1	0	 	Test OFF
	7.49	5.1	0	 	Test OFF
	7.63	5.1	0	 	Test OFF
	7.77	5.1	0	 	Test OFF
	7.91	5.1	0	 	Test OFF
	8.05	5.1	0	 	Test OFF
	8.19	5.1	0	 	Test OFF
	8.33	5.1	0	 	Test OFF
	8.49	5.1	0	 	Test OFF
	8.63	5.1	0	 	Test OFF
	8.77	5.1	0	 	Test OFF
	8.92	5.1	0	 	Test OFF
	9.07	5.1	0	 	Test OFF
	9.2	5.1	0	 	Test OFF
	9.35	5.1	0	 	Test OFF
	9.49	5.1	0	 	Test OFF
	9.63	5.1	0	 	Test OFF
	9.76	5.1	0	 	Test OFF
	9.91	5.1	0	 	Test OFF
	10.05	5.1	0	 	Test OFF
	10.19	5.1	0	 	Test OFF
	10.33	5.1	0	 	Test OFF
	10.47	5.1	0	 	Test OFF
	10.62	5.1	0	 	Test OFF
	10.76	5.1	0	 	Test OFF
	10.91	5.1	0	 	Test OFF
	11.05	5.1	0	 	Test OFF
	11.19	5.1	0	 	Test OFF
	11.33	5.1	0	 	Test OFF
	11.47	5.1	0	 	Test OFF
	11.61	5.1	0	 	Test OFF
	11.75	5.1	0	 	Test OFF
	11.89	5.1	0	 	Test OFF
	12.04	5.1	0	 	Test OFF
	12.17	5.1	0	 	Test OFF
	12.32	5.1	0	 	Test OFF
	12.46	5.1	0	 	Test OFF
	12.6	5.1	0	 	Test OFF
	12.73	5.1	0	 	Test OFF
	12.88	5.1	0	 	Test OFF
	13.02	5.1	0	 	Test OFF
	13.16	5.1	0	 	Test OFF
	13.3	5.1	0	 	Test OFF
	13.44	5.1	0	 	Test OFF
	13.57	5.1	0	 	Test OFF
	13.73	5.1	0	 	Test OFF
	13.88	5.1	0	 	Test OFF
	14.01	5.1	0	 	Test OFF
	14.16	5.1	0	 	Test OFF
	14.3	5.1	0	 	Test OFF
	14.44	5.1	0	 	Test OFF
	14.58	5.1	0	 	Test OFF
	14.71	5.1	0	 	Test OFF
	14.86	5.1	0	 	Test OFF
	15	5.1	0	 	Test OFF
	15.13	5.1	0	 	Test OFF
	15.29	5.1	0	 	Test OFF
	15.42	5.1	0	 	Test OFF
	15.57	5.1	0	 	Test OFF
	15.7	5.1	0	 	Test OFF
	15.85	5.1	0	 	Test OFF
	15.99	4.7	0	 	Test OFF
	16.12	5.1	0	 	Test OFF
	16.27	5.1	0	 	Test OFF
	16.41	5.1	0	 	Test OFF
	16.55	5.1	0	 	Test OFF
	16.68	5.1	0	 	Test OFF
	16.83	5.1	0	 	Test OFF
	16.97	5.1	0	 	Test OFF
	17.11	5.1	0	 	Test OFF
	17.24	5.1	0	 	Test OFF
	17.38	5.1	0	 	Test OFF
	17.53	5.1	0	 	Test OFF
	17.67	5.1	0	 	Test OFF
	17.81	5.1	0	 	Test OFF
	17.96	5.1	0	 	Test OFF
	18.1	5.1	0	 	Test OFF
	18.24	5.1	0	 	Test OFF
	18.38	5.1	0	 	Test OFF
	18.52	5.1	0	 	Test OFF
	18.65	5.1	0	 	Test OFF
	18.79	5.1	0	 	Test OFF
	18.93	5.1	0	 	Test OFF
	19.08	5.1	0	 	Test OFF
	19.21	5.1	0	 	Test OFF
	19.36	5.1	0	 	Test OFF
	19.5	5.1	0	 	Test OFF
	19.64	5.1	0	 	Test OFF
	19.79	5.1	0	 	Test OFF
	19.93	5.1	0	 	Test OFF
	20.07	5.1	0	 	Test OFF
	20.2	5.1	0	 	Test OFF
	20.34	5.1	0	 	Test OFF
	20.48	5.1	0	 	Test OFF
	20.62	5.1	0	 	Test OFF
	20.76	5.1	0	 	Test OFF
	20.9	5.1	0	 	Test OFF
	21.04	5.1	0	 	Test OFF
	21.19	5.1	0	 	Test OFF
	21.32	5.1	0	 	Test OFF
	21.47	5.1	0	 	Test OFF
	21.6	5.1	0	 	Test OFF
	21.75	5.1	0	 	Test OFF
	21.9	5.1	0	 	Test OFF
	22.04	5.1	0	 	Test OFF
	22.18	5.1	0	 	Test OFF
	22.31	5.1	0	 	Test OFF
	22.46	5.1	0	 	Test OFF
	22.59	5.1	0	 	Test OFF
	22.73	5.1	0	 	Test OFF
	22.88	5.1	0	 	Test OFF
	23.02	5.1	0	 	Test OFF
	23.16	5.1	0	 	Test OFF
	23.3	5.1	0	 	Test OFF
	23.44	5.1	0	 	Test OFF
Thursday	16	November	2017	15:07:10:53083-VCID:77AB151173C1B10F6A0-8022	VCDS Version: Release 17.8.0 (x64)	Data version: 20170721 DS276.2
Marker	STAMP					STAMP					STAMP
	0.02	1	Brakes	Full Throt	10 Times
	0.13	1	Brakes	Full Throt	10 Times
	0.27	1	Brakes	Full Throt	10 Times
	0.42	1	Brakes	Full Throt	10 Times
	0.55	1	Brakes	Full Throt	10 Times
	0.69	1	Brakes	Full Throt	10 Times
Friday	17	December	2018	15:01:27:53083-VCID:77AB151173C1B10F6A0-8023	VCDS Version: Release 17.8.0 (x64)	Data version: 20170721 DS276.3
1K0 907 115 AS		2.0l R4/4V TFSI     0041
	Group A:	'071				Group B:	 Not Running				Group C:	 Not Running
Thursday	16	November	2017	15:02:14:53083-VCID:77AB151173C1B10F6A0-8022	VCDS Version: Release 17.8.0 (x64)	Data version: 20170721 DS276.2
		Reed Contact	Malfunction	Test Status	Leak Diagnostic
	TIME	Condition	Message		Test Status	TIME					TIME
	0.01	Reed Closed	Abort	 	Test OFF
	0.15	Reed Closed	Abort	 	Test OFF
	0.29	Reed Closed	Abort	 	Test OFF
	0.43	Reed Closed	Abort	 	Test OFF
	0.57	Reed Closed	Abort	 	Test OFF
	0.7	Reed Closed	Abort	 	Test OFF
	0.86	Reed Closed	Abort	 	Test OFF
	1.14	Reed Closed	Abort	 	Test OFF
	1.27	Reed Closed	Abort	 	Test OFF
	1.42	Reed Closed	Abort	 	Test OFF
	1.56	Reed Closed	Abort	 	Test OFF
	1.7	Reed Closed	Abort	 	Test OFF
	1.84	Reed Closed	Abort	 	Test OFF
	1.98	Reed Closed	Abort	 	Test OFF
	2.11	Reed Closed	Abort	 	Test OFF
	2.26	Reed Closed	Abort	 	Test OFF
	2.39	Reed Closed	Abort	 	Test OFF
	2.54	Reed Closed	Abort	 	Test OFF
	2.68	Reed Closed	Abort	 	Test OFF
	2.81	Reed Closed	Abort	 	Test OFF
	2.95	Reed Closed	Abort	 	Test OFF
	3.1	Reed Closed	Abort	 	Test OFF
	3.25	Reed Closed	Abort	 	Test OFF
	3.39	Reed Closed	Abort	 	Test OFF
	3.52	Reed Closed	Abort	 	Test OFF
	3.67	Reed Closed	Abort	 	Test OFF
	3.81	Reed Closed	Abort	 	Test OFF
	3.94	Reed Closed	Abort	 	Test OFF
	4.08	Reed Closed	Abort	 	Test OFF
	4.22	Reed Closed	Abort	 	Test OFF
	4.37	Reed Closed	Abort	 	Test OFF
Thursday	16	November	2017	15:06:00:53083-VCID:77AB151173C1B10F6A0-8022	VCDS Version: Release 17.8.0 (x64)	Data version: 20170721 DS276.2
	Group A:	'200				Group B:	 Not Running				Group C:	 Not Running
		Status Counter	Status	Status	Status
	TIME					TIME					TIME
	0.06	18	Brakes	Full Throt	10 Times
	0.21	18	Brakes	Full Throt	10 Times
	0.34	18	Brakes	Full Throt	10 Times
	0.49	18	Brakes	Full Throt	10 Times
	0.64	18	Brakes	Full Throt	10 Times
	0.78	18	Brakes	Full Throt	10 Times
	0.93	18	Brakes	Full Throt	10 Times
	1.06	18	Brakes	Full Throt	10 Times
	1.2	18	Brakes	Full Throt	10 Times
	1.36	18	Brakes	Full Throt	10 Times
	1.52	18	Brakes	Full Throt	10 Times
	1.66	18	Brakes	Full Throt	10 Times
	1.81	18	Brakes	Full Throt	10 Times
	1.95	18	Brakes	Full Throt	10 Times
	2.08	18	Brakes	Full Throt	10 Times
	2.22	18	Brakes	Full Throt	10 Times
	2.37	18	Brakes	Full Throt	10 Times
	2.5	18	Brakes	Full Throt	10 Times
	2.64	18	Brakes	Full Throt	10 Times
	2.78	18	Brakes	Full Throt	10 Times
	2.93	18	Brakes	Full Throt	10 Times
	3.07	18	Brakes	Full Throt	10 Times
	3.22	18	Brakes	Full Throt	10 Times
	3.36	18	Brakes	Full Throt	10 Times
	3.5	18	Brakes	Full Throt	10 Times
	3.64	18	Brakes	Full Throt	10 Times
	3.78	18	Brakes	Full Throt	10 Times
	3.93	18	Brakes	Full Throt	10 Times
	4.07	18	Brakes	Full Throt	10 Times
	4.22	18	Brakes	Full Throt	10 Times
	4.36	18	Brakes	Full Throt	10 Times
	4.5	18	Brakes	Full Throt	10 Times
	4.64	18	Brakes	Full Throt	10 Times
	4.78	18	Brakes	Full Throt	10 Times
	4.93	18	Brakes	Full Throt	10 Times
	5.08	18	Brakes	Full Throt	10 Times
	5.22	18	Brakes	Full Throt	10 Times
	5.37	18	Brakes	Full Throt	10 Times
	5.51	18	Brakes	Full Throt	10 Times
	5.64	18	Brakes	Full Throt	10 Times
	5.78	18	Brakes	Full Throt	10 Times
	5.92	18	Brakes	Full Throt	10 Times
	6.07	18	Brakes	Full Throt	10 Times
	6.22	18	Brakes	Full Throt	10 Times
	6.36	18	Brakes	Full Throt	10 Times
	6.5	18	Brakes	Full Throt	10 Times
	6.64	18	Brakes	Full Throt	10 Times
	6.78	18	Brakes	Full Throt	10 Times
	6.93	18	Brakes	Full Throt	10 Times
	7.08	18	Brakes	Full Throt	10 Times
	7.22	18	Brakes	Full Throt	10 Times
	7.37	18	Brakes	Full Throt	10 Times
	7.5	18	Brakes	Full Throt	10 Times
	7.64	18	Brakes	Full Throt	10 Times
	7.78	18	Brakes	Full Throt	10 Times
	7.92	18	Brakes	Full Throt	10 Times
	8.06	18	Brakes	Full Throt	10 Times
	8.21	18	Brakes	Full Throt	10 Times
	8.36	18	Brakes	Full Throt	10 Times
	8.5	18	Brakes	Full Throt	10 Times
	8.65	18	Brakes	Full Throt	10 Times
	8.79	18	Brakes	Full Throt	10 Times
	8.92	18	Brakes	Full Throt	10 Times
	9.07	18	Brakes	Full Throt	10 Times
	9.2	18	Brakes	Full Throt	10 Times
	9.35	18	Brakes	Full Throt	10 Times
	9.5	18	Brakes	Full Throt	10 Times
	9.64	18	Brakes	Full Throt	10 Times
	9.78	18	Brakes	Full Throt	10 Times
	9.93	18	Brakes	Full Throt	10 Times
	10.06	18	Brakes	Full Throt	10 Times
Thursday	16	November	2017	15:03:03:53083-VCID:77AB151173C1B10F6A0-8022	VCDS Version: Release 17.8.0 (x64)	Data version: 20170721 DS276.2
	Group A:	'071				Group B:	'046				Group C:	 Not Running
		Reed Contact	Malfunction	Test Status	Leak Diagnostic		Engine Speed	Catalytic Converter	Catalytic	Cat. Conversion
	TIME	Condition	Message		Test Status	TIME	(G28)	Bank 1 Temp.	Conversion Bank 1	Test Bank 1	TIME
Marker	STAMP					STAMP	 /min	°C			STAMP
	0.15	Reed Closed	Abort	 	Test OFF	0.01	760	294	0	Test OFF
	0.42	Reed Closed	Abort	 	Test OFF	0.28	760	294	0	Test OFF
	0.72	Reed Closed	Abort	 	Test OFF	0.58	760	294	0	Test OFF
	1.02	Reed Closed	Abort	 	Test OFF	0.86	720	294	0	Test OFF
	1.3	Reed Closed	Abort	 	Test OFF	1.15	760	294	0	Test OFF
	1.58	Reed Closed	Abort	 	Test OFF	1.45	720	294	0	Test OFF
	1.86	Reed Closed	Abort	 	Test OFF	1.72	760	294	0	Test OFF
	2.14	Reed Closed	Abort	 	Test OFF	2	760	294	0	Test OFF
	2.42	Reed Closed	Abort	 	Test OFF	2.28	720	294	0	Test OFF
	2.7	Reed Closed	Abort	 	Test OFF	2.56	760	288	0	Test OFF
	3	Reed Closed	Abort	 	Test OFF	2.86	720	288	0	Test OFF
	3.28	Reed Closed	Abort	 	Test OFF	3.15	720	288	0	Test OFF
	3.56	Reed Closed	Abort	 	Test OFF	3.42	720	288	0	Test OFF
	3.85	Reed Closed	Abort	 	Test OFF	3.7	720	288	0	Test OFF
	4.13	Reed Closed	Abort	 	Test OFF	3.99	760	288	0	Test OFF
	4.41	Reed Closed	Abort	 	Test OFF	4.27	760	288	0	Test OFF
	4.69	Reed Closed	Abort	 	Test OFF	4.55	760	288	0	Test OFF
	4.97	Reed Closed	Abort	 	Test OFF	4.83	720	288	0	Test OFF
	5.26	Reed Closed	Abort	 	Test OFF	5.11	720	288	0	Test OFF
Thursday,16,November,2017,14:20:30:53083
   Revision: 00H31001
   Revision: 00001016
   Coding: 0000001002
   Revision: 00110 AC
   Coding: 009795
   Coding: 00003131
   Coding: 589A140000
   Coding: 350000
   Coding: 0001076
   Coding: 0001076
                    Reset counter: 78
                    Mileage: 117334 km
                    Date: 2006.14.12
                    Time: 17:39:19
   ROD: UHVNA.rod
End----------(Elapsed Time: 01:21, VBatt start/end: 13.9V/13.8V)-----------
