Retro Fitting Brembo 17Z 6 Piston Callipers to MY08 T2 Touareg
hedditch
Australia
C?ID=131483
I am about to retrofit a pair of 17Z Brembo Callipers to an MY08 V6 TDI and would like find out if the ABS Coding is any different on a vehicle fitted with 6 Piston callipers compared with the 4 Piston units fitted to the V6 TDI.
I am looking at units fitted with the ESP ALLRAD MK25E1 model ABS unit, rather than the T1 Pre MY08 (7LA) version,.
Sunday,19,October,2014,17:10:46:04442
VCDS Version: 12.12.3.0 (x64)
Data version: 20140822
Dealer/Shop Name: Hedditch
Workshop Code: 123 12345 054321
VIN: WVGZZZ7LZ8D046567   License Plate: XVG493
Mileage: 177790km-110473mi   Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 28 34 37 46 55 56 68 69 6C
          76 77
VIN: WVGZZZ7LZ8D046567   Mileage: 177790km/110473miles
68-Wiper Electr. -- Status: OK 0000
Address 01: Engine (CAS)       Labels: 059-907-401-CAT1.clb
   Part No SW: 7L0 907 401 N    HW: 7L0 907 401 H
   Component: 3.0TDI EDC17G104AG  0060
   Revision: --H02---    Serial number: VWX3Z0G1687973
   Coding: 04210023590F0D68
   Shop #: WSC 12345 123 54321
   VCID: 36693693425627AE711-508E
   Part No SW: 09D 927 750 FT    HW: 09D 927 750 FT
   Component: AL 750 6A           1168
   Revision: 00H75000    Serial number:
   Coding: 0012392
   VCID: 850B015FCF30FC3628B-50E6
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 L    HW: 7L0 907 379 L
   Component: ESP ALLRAD MK25E1   0303
   Revision: 00H53001
   Coding: 0004482
   Shop #: WSC 31414 790 00001
   VCID: 42815A43199E8B0ECD9-8017
   Part No SW: 3D0 909 139 B    HW: 5WK 485 04
   Component:    Kessy            6840
   Revision: 68406620    Serial number: VWX3Z0G1687973
   Coding: 0000232
   VCID: 2855E8EB98E2415EF3D-50C8
Address 08: Auto HVAC        Labels: 7L6-907-044.clb
   Part No: 7L6 907 044 AF
   Component: CLIMAtronic 2+2     4331
   Coding: 0020020
   VCID: 78F5F8AB0FC211DEA3D-802D
   Subsystem 1 - Part No: 7L6 907 049 F
   Component: CLIMAtronic FOND    0503
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2000
   Revision: -0004---    Serial number: --------------
   Coding: 600004003B221C000000000000000000
   VCID: 8005104BD712D91E1BD-80D5
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655     HW: 7L0 959 655
   Component: J234  39 VW8T       0250
   Revision: 92011025    Serial number: 0039P003JRFF
   Coding: 0013113
   VCID: FAF162A3B1CE83CE559-80AF
   Part No: 7L6 953 549 F
   Component: J527                3601
   Coding: 0010011
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl ESP ALLRAD MK25E1
   Part No SW: 7L6 920 890 K    HW: 7L6 920 890 K
   Component: J285 KOMBI-INST.    9733
   Revision: KHH06V02
   Coding: 0005701
   VCID: 4085504B1392991EDBD-8015
Address 19: CAN Gateway        Labels: 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 890 K
   Component: J533  GW-K-CAN TP20 9733
   Coding: 7FE2E7EBC8046003
   VCID: F0E5408BE3B2C99EEBD-80A5
Address 22: AWD        Labels: None ESP ALLRAD MK25E1
   Part No: 0AD 927 755 BG
   Component: TRANSFERCASE        0126
   VCID: 8103154FDB18D016143-50E6
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 J
   Component: LUFTFDR.-CDC- 3C3P1 3125
   Coding: 0015521
   VCID: 3A7122A3714EC3CE959-806F
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 7L6 035 680 C    HW: 7L6 035 680 A
   Component: RNS-MID       H04 3810
   Revision: AB001001    Serial number: VWZ6Z7G7272099
   Coding: 06010402040000210000
   VCID: 32610A836D3E3B8E5D9-8067
   Part No: 7L6 959 933 A
   Component: 1A HSG              0600   ESP ALLRAD MK25E1
   Coding: 0000081
   Shop #: WSC 30049 959 91392
   VCID: 4085504B1092991EDBD-4A9C
   Subsystem 1 - Part No: 7L0 959 701 R
   Component: Tuersteuergeraet FS 6302
   Subsystem 2 - Part No: 7L0 959 702 R
   Component: Tuersteuergeraet BF 6302
   Subsystem 3 - Part No: 7L6 959 703
   Component: Tuersteuergeraet HL 0202
   Subsystem 4 - Part No: 7L6 959 704
   Component: Tuersteuergeraet HR 0202
   Subsystem 5 - Part No: 7L0 907 719 A
   Component:    Neigungssensor   0020
   Subsystem 6 - Part No: 7L6 951 171 B
   Component:    Innenraumsensor  0020
------------------------------------------------------------------------------- ESP ALLRAD MK25E1
Address 55: Xenon Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 A    HW: 7L6 907 357 A
   Component: AFS-Steuergeraet    0001
   Revision:   H02       Serial number:
   Coding: 1288579
   VCID: 39733DAF7448C8D69C3-806C
   Subsystem 1 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul l    X008
   Coding: 00000019
   Subsystem 2 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul r    X008
   Coding: 00000019
No fault code found.Sunday,19,October,2014,17:10:46:04442
Any assistance would be very greatly appreciated.
Kind regards
Stuart.....
hedditch
Australia
C?ID=131483
Can anybody provide any key values to the Coding Field in the ABS Module?
The code field in most "short code" option in VW land are a sum value of a number of sub components, so far the only value I am aware of is the change to add ACC to my car.
00004482 + 2048 = 0006530
Does anybody have are table of options for this module?
EG; +1243 = xxxxx or +3421 = yyyyy etc....
Or is this code positional as it is in the Bosch 5.3 5.7 series , where the position in the code describes a component/function, eg: 000x?xx where position ? describes the option.
Any advice will be gladly received.
Stuart..
hedditch
Australia
C?ID=131483
Obviously NOBODY is at all interested......
Bruce
Near Philadelphia, PA, USA
I think you have drawn an improper conclusion. There have been 62 views of your thread. Obviously there is interest.
The people in this forum are some of the most knowledgeable people regarding VAG. If information has not been supplied, it is quite possible that none have the answers sought.
Case in point: The Ross-Tech Wiki does not have any information on the ABS coding for your Touareg.
http://wiki.ross-tech.com/wiki/index.php/VW_Touareg_(7L)_Brake_Electronics#Coding
Should an answer be found, the forum would appreciate the sharing of that information such that the knowledge represented here might increase.
DrPeter
16.4905° S, 151.7375° W
... would like find out if the ABS Coding is any different on a vehicle fitted with 6 Piston callipers compared with the 4 Piston units fitted to the V6 TDI.
Yes the coding is different, if you have the calipers that look like these [7L6615123S] (PR_1LT)
... and you have automatic transmission without distance regulation. Your coding should be the following:
- Warning the coding below is NOT original to this vehicle and should be considered experimental and potentially dangerous.
Proceed at your own risk! Ross-Tech does not have ANY way to test this coding and your results will be unknown.
Hope this helps,
drpeter
hedditch
Australia
C?ID=131483
Thank You very much for this, and I accept the "beating from Bruce" as I probably deserved every bit of it... ooops! .
The Callipers are 7L6 615 123/4 T , rather than the "S" suffix you mention. I am not sure if that has any relevance?
Accepting that the base vehicle doesn't currently have distance regulation (ACC) but I have the parts and I am about to install it in the next few weeks, would this mean that
adding distance regulation would be (the value provided by DrPeter) + 2048 ??
I will now do some extensive testing on paved and unpaved surfaces, and provide feedback on the result.
Kind Regards, and Apologies
Stuart..........
DrPeter
- You welcome.
- The part number [7L6 615 123 T] fist 2003 to 2007 Touareg, while the [7L6 615 123 S] fits 2007 to 2010 Touareg(7L6)
Yes, you are correct, the coding change is as stated below.
- With Automatic distance regulation = [2048]
- W/out Automatic distance regulation = [0]
- That would be appreciated!, thanks
No worries!, glad to help,
drpeter
hedditch
Australia
C?ID=131483
I have just done some initial testing , and everything seems to be working correctly.
ABS works well on both paved and unpaved surfaces.
Braking performance feels excellent, and the "seat of pants" meter reports that it feels better than before the recode..(may be wishful thinking).
Stability control is working.
I tested it by applying 90 degree of left lock then immediately 90 degree of right lock to the steering, at 65 km/h on a gravel road. This put the vehicle into a acute broadside, at which instant the stability control kicked in and pulled the vehicle back on line. The instantaneous nature of the recovery was profound and initially a little scary. I repeated this 4 times and every time the recovery (with hands off the wheel) was instant and precise. The last test was done at 75 km/h (45 mph) which was absolutely raucous !!!
Testing was done on a local road which is quite wide and has large grass run off areas on both sides. Testing a system is one thing, bending the car, and myself is another.
I will continue testing over this next weekend, as I will be able test the traction control off road.
Stuart....
hedditch
Australia
C?ID=131483
Just finished testing the traction control off road, and everything is working perfectly. It looks like the coding we have is a good match with this non-factory combination.
My thanks to Dr.Peter.
Kind regards
Stuart...
hedditch
Australia
C?ID=131483
I have now added ACC as a retrofit and recoded the ABS to suit, and everything works like its a Factory Build.
Many thanks to everybody for the help.
Stuart...
Final Scan if anybody can benefit from this....
One final question, is the coding for the ACC Radar Address 13: is 0010000, I have seen a number of units showing 0020000 in the coding, does anybody any input as to the difference. My unit came from Europe and the "2" values was seen on a NAR unit. ????
 Tuesday,30,June,2015,13:10:23:04442
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
Mileage: 196240km-121937mi   Repair Order:
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 28 34 37 46 55 56 68 69
          6C 76 77
VIN: WVGZZZ7LZ8D046567   Mileage: 196240km-121937miles
   Component: 3.0TDI EDC17A104AG  0060
   Coding: 04210023590F0E68
   VCID: 3669369342562791843-508E
   Coding: 0012392
   VCID: 050B815F4F307C095D9-50C8
   Revision: 00H53001
   Coding: 0014722
   VCID: 42815A43199E8B3138B-8017
   Coding: 0000232
   VCID: 2855E8EB9FE2416106F-807D
   Coding: 0020020
   VCID: 78F5F8AB0FC211E156F-802D
   Coding: 600004002B221C000000000000000000
   VCID: 0005904B571259216EF-8055
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 7L6 907 567     HW: 7L6 907 567
   Component: AC201  RDW 1    030 0363
   Revision: 00030000    Serial number: 00000000003464
   Coding: 0010000
   Shop #: WSC 98765 666 38533
   VCID: 7BFFE7A73EF43AF93BD-802E
   Coding: 0013113
   VCID: 7AF1E2A331CE03F120B-802F
   Coding: 0010021
   Revision: KHH06V02
   Coding: 0005701
   VCID: 4085504B139299212EF-8015
   Coding: FFE2E7EBC8046003
   VCID: 70E5C08B63B249A19EF-8025
   VCID: 0103954F5B185029611-50E6
Address 28: HVAC, Rear
   Coding: 0015521
   VCID: 3A7122A3714EC3F160B-806F
   Component: RNS-MID       H04 5238
   Coding: 0E0004020400002100
   VCID: 32610A836D3E3BB1A8B-8067
   Coding: 0000081
   VCID: 4085504B109299212EF-4A9C
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Coding: 1288579
   VCID: 39733DAF7448C8E9691-806C
   Coding: 00000019
   Coding: 00000019
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 C
   Component: J400__ Front Wiper  5301
   Coding: 0001397
   VCID: 3A7122A3754EC3F160B-806F
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     271107 046  0204
   Coding: 00208933
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
   Component: ANHAENGERELEKTRONIK 8854
   Coding: 0000003
   VCID: 387538AB4F42D1E196F-806D
   Part No SW: 7L6 907 441 B    HW: 7L6 907 441 B
   Component: J772__Rearview      0033
   Revision: 00H13000    Serial number:    PA8 J790212
   Coding: 0010001
   VCID: 346D0C9B572A3581BA7-8061
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
Address 77: Telephone        Labels: RETROFIT77.lbl
   Part No SW: KTC 364 96P     HW: KTC 364 96P
   Component: SWP:3.24.7      H24 0212
   Shop #: WSC 21977 142 74100
   VCID: 3E792EB36966EFD15C3-806B
End-------------------------(Elapsed Time: 03:36)--------------------------
hedditch
Australia
C?ID=131483
It has been now over 2 month since retrofitting the 6 Piston Brembo 17Z callipers to MY08 Touareg. I have, in that time, attempted to perform every possible test know to man.
I can confidently say that they are working perfectly, and that success has only been possible through the wonderful support provided by the kind people of this forum.
Once again, thanks to everybody.
Stuart...
hedditch
Australia
C?ID=131483
Just a final update for anybody interested, over Christmas New Year my wife and I did a trip from Melbourne to Port Lincoln in South Australia towing my 20 ft caravan (trailer) which weighs in at about 2100 kg. The new brakes feel fantastic whilst towing this combination. I an very glad I spent the money. The original brakes were very good, but the new 6 piston units are nothing short of excellent.
Again, my sincere thanks for all your help from this forum.
Stuart....
hedditch
Australia
C?ID=131483
Firstly, thank you for the coding supplied that allowed me to install the Brembo 17Z 6 Piston calipers on my 2008 V6 TDI. It has now been working well over the past two years and the 6 piston caliper is a dream on the road. Especially allowing for the behavior of some of Melbourne finest drivers....!
All in all not a good result, a great result!
One interesting thing we found, is that this coding works on vehicles with Air Suspension, but on one vehicle, fitted with steel suspension, the code fails to load. I assume that this coding has a dependency on the Level Control module ( Address 34 ) which is absent in the steel sprung vehicle.
If my logic is correct, is there a change that I can make to the current coding (0014722) to allow the steel sprung vehicle to accept it ?
Anyway thanks again for the support.
Kind Regards
Stuart
Melbourne AU
hedditch
Australia
C?ID=131483
Sorry the vehicle with steel suspension does not have ACC (Distance Regulation), so my question should have been.
Does anybody know if there is a change that can be made to coding 0012674 to allow it to be loaded on a vehicle with steel suspension?
Kind Regards
Stuart....
hedditch
Australia
C?ID=131483
Dr Peter, if you are about, would you care to cast you eyes over this issue for a second time. I would have PM'ed you but your mail queue is full.
Merry Christmas
Stuart....
