2009 VW Jetta ABS Coding (MK60EC1)
naushad2982
Kenya
C?ID=58306
I need the coding for the ABS Module for the below Jetta, the old module was non responsive so couldn't save it. TIA. :)
Thursday,13,April,2017,18:45:09:58772VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
Dealer/Shop Name: Euro Tecnik Ltd
VIN: WVWZZZ1KZ9U004441   License Plate: KCJ 811L
Mileage: 94760km-58881mi   Repair Order: Valerie-PostABS
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ9U004441   Mileage: 94760km-58881miles
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 Q    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0H324M0O3
   Coding: 040300431C070160
   Shop #: WSC 00046 412 00000
   VCID: 3461FE3157DEFBE13D-8060
049441 - No Communication with ABS Brake Control Module
               U0121 - 008 -  - Intermittent
                    Mileage: 94765 km
                    Time: 00:10:44
                    RPM: 1060 /min
                    Load: 15.3 %
                    Temperature: 81.0°C
                    Temperature: 63.0°C
                    Absolute Pres.: 820.0 mbar
                    Voltage: 12.319 V
001281 - Vehicle Speed Sensor
               P0501 - 002 - Implausible Signal - Intermittent
                    Mileage: 94765 km
                    Time: 00:10:44
001287 - Idle Control System RPM
               P0507 - 001 - Higher than Expected. - Intermittent
                    Fault Status: 00100001
                    Mileage: 94765 km
                    Time: 00:15:07
                    RPM: 1223 /min
                    Load: 13.3 %
                    Temperature: 78.0°C
                    Temperature: 27.0°C
                    Voltage: 14.224 V
012555 - Low Pressure Fuel regulation
               P310B - 002 - Fuel Pressure Outside Specification - Intermittent
                    Mileage: 94765 km
                    Time: 00:15:07
               P1602 - 002 - Voltage too Low
                    Fault Status: 01100010
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0110 0101
   Part No SW: 02E 300 051 C    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1817
   Revision: 04843012    Serial number: 00000805051931
   Shop #: WSC 44551 111 44551
   VCID: 13235DAD32901CD944-8046
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller - Intermittent
                    Fault Frequency: 255
                    Reset counter: 40
                    Mileage: 94765 km
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Shop #: WSC 00028 028 00001
   VCID: 75E70335DC24A2E9CA-8020
                    Reset counter: 131
                    Count: 3
                    Count: 4608
                    Count: 195
                    Count: 50944
   Part No SW: 1K0 907 044 DA    HW: 1K0 907 044 DA
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 69DF5F45409C76095E-803C
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Revision: 00H54000    Serial number: 00000008455206
   Coding: E7878F2700041500470A00000F00000000095D035C000100000000000000
   Shop #: WSC 54030 981 97870
   VCID: 3363FD2D52D0FCD924-8066
   Component: Wischer 280708 020  0501
   Coding: 00049109
   Shop #: WSC 54030
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     180608 046  0204
   Coding: 00733221
   Shop #: WSC 54030
   Component: 56 AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0B7CV8
   Coding: 0013622
   VCID: 6CD126514F6E632125-8038
   Subsystem 1 - Serial number: 6332MSME3362513F9
   Subsystem 2 - Serial number: 6342MSME294221787
   Subsystem 3 - Serial number: 6351HSME163D144BA
   Subsystem 4 - Serial number: 6361HSME163D172BC
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Component: J0527           752 0101
   Coding: 0012121
   VCID: 04016EF147FE8B61CD-8050
8 Faults Found:
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
01751 - Multi-Function Switch in Steering Wheel(E441); Right
01750 - Multi-Function Switch in Steering Wheel (E440); Left
   Part No SW: 1K0 920 864 A    HW: 1K0 920 864 A
   Component: KOMBIINSTRUMENT 3HL 1212
   Revision: V0002000    Serial number: VWX7Z0H324M0O3
   Coding: 0023503
   VCID: 2A5DE049851ABD1197-807E
                    Reset counter: 171
                    Mileage: 94764 km
                    Time: 16:44:19
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 250508F2001445
   Coding: ED817F060002021003
   VCID: 3567C3355CA4E2E90A-8060
                    Fault Status: 00110100
                    Fault Frequency: 16
                    Reset counter: 171
                    Mileage: 94670 km
                    Time: 18:53:02
                    Fault Frequency: 16
                    Reset counter: 171
                    Mileage: 94670 km
                    Time: 18:53:02
   Component: IMMO            3HL 1212
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1520
   Revision: 71009005    Serial number: 00000752088517
   Coding: 0004790
   VCID: 71EF3725684C8EC916-8024
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 69     2301
   Revision: 00H15000
                    Reset counter: 181
                    Mileage: 94769 km
                    Time: 06:57:04
                    Voltage: 13.75 V
                        DU
                    Temperature: 41.0°C
                    RPM: 1152 /min
                    Speed: 12.0 km/h
                    Speed: 12.0 km/h
            000 -  -  - MIL ON
                    Reset counter: 181
                    Mileage: 94769 km
                    Time: 06:57:04
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 90900A0001060C7F2D0484056008DF03E0FCA0
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1520
   Revision: 71009005    Serial number: 00000608688525
   Coding: 0005046
   VCID: 72ED38296D4AB5D1EF-8026
                    Fault Status: 01100101
                    Reset counter: 131
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74E13E31175EBBE1FD-8020
Address 56: Radio
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1120
   Revision: 11006001    Serial number: 00000002788987
   Coding: 0000144
   Shop #: WSC 00046 000 00000
   VCID: 3D77DB1564943AA9C2-8068
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1120
   Revision: 11006001    Serial number: 00000002818049
   Coding: 0000144
   VCID: 3E75DC19699221B1DB-806A
End-------------------------(Elapsed Time: 02:25
naushad2982
Kenya
C?ID=58306
Anyone? @Dana
Dana
Western PA, USA
If you can plug in the old module and hit it a few times with the key on I would try that just to see if it produces one last breath of communication.
I believe this would be the factory condition coding:
163B600D092200FE680F06E8901A0081B500
Vehicle Identification No. WVWZZZ1KZ9U004441
Model jetta 2,0
JE
Date of production 07.08.2008
Year 2009
Sales type 1K22V3
Engine Code BWA
D2L 4-Zylinder-Ottomotor 2,0 L/147 KW (16V) Turbo FSI, homogen Grundmotor ist: T59/T61/TQ2/TU2/TD6/TN6
Transmission Code KPV
G1A 6-speed automatic transmission
1N3 Speed-related variable steering assist (Servotronic)
L0R Right-hand drive vehicle
1ZD Disc brakes, front (Geomet D)
1KE Disc brakes, rear
1AT Electronic stabilization program (ESP)
0YE Weight range 5 installation control only, no requirement forecast
UG1 Hill hold control
7K6 Flat tire indicator
2UC Sports version
B0L Component parts set, complying with vehicle type for Japan, various parts
Everything I like, except a key on/off instruction..........
hit it a few times
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
Only connect one time correctly because if it fails to see the VIN on the BUS it will zero the coding!
On the bench you have one shot and in the car it is advised to only plug in module with key on and after verifying the gateway and cluster are working in broadcast on CAN High/Low.
Do not use the ignition key.........!
Why you ask?
Because you don't want to switch terminal 15 in this case.
NostraJackAss Has Spoken!
Revision: 00H35001
Coding: 134B000C092200FEC80F00E8901A00000000 RHD Strip BASE
Coding: 163B600D092200FE680F06E8901A0081B500 DANA
Scans on the net
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107 Revision: 00H45001
Coding: 133B600D092400FAC81406E5901F0081B500
