Unable to select basic settings for 01 engine or 02 Auto Transmission
AJKlmnop
C?ID=306997
Hi All,
I've only had my HEX-V2 (3 VIN) and VCDS for 2 days and still not sure if I'm using the software correctly.
My VCDS is registered, validated and updated and as yet I've not been requested to register one of my VIN.
I purchased the cable because a friend advised me that I should have done an adaptations reset and TBA
following a MAF sensor change in February. To be honest the MAF certainly improved the engine performance
but also made the erratic/inconsistent auto gearshifts more noticeable.
I initially tried to do the adaptations on the 02 Auto Trans but that box is greyed out, then tried to do the
adaptations on 01 Engine but only got error messages. I assumed this was due to not having an associated
label file for the engine and have since sent Ross-Tech my control module map files.
My next train of thought was to select basic settings for both engine and auto transmission but once again these
boxes are greyed out.
Any help or advice would be really appreciated.
AJ
AJKlmnop
C?ID=306997
Below is a copy of my latest auto scan results, just a few minor issues but nothing
engine or auto transmission related except for missing label files. Would these missing
label files be the root cause of not being able to run adaptations or basic settings?
 Friday,09,June,2017,19:22:49:08897
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4341.4
VIN: WV2ZZZ7HZ5H003795   License Plate:
Mileage: 266660km-165694mi   Repair Order:
Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
          57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ5H003795   Mileage: 266660km-165694miles
   Part No SW: 070 906 016 K    HW: 028 101 127 1
   Component: R5 2,5L EDC 0000AG  6188
   Revision: 12345678    Serial number: VWZ7Z0D0078527
   Coding: 0001075
   Shop #: WSC 02756 785 00200
   VCID: 186AC1A55E8187D7F59-513C
Readiness: 0 0 X X X
   Part No: 09K 927 750 F
   Component: AQ 250 6F           0573
   Coding: 0000008
   Shop #: WSC 02737 785 00200
   VCID: 382A21253E41A7D7D59-5118
Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP-F.lbl
   Part No: 7H0 907 379 H
   Component: ESP FRONT MK25      0202
   Coding: 0006315
   VCID: 3A2E3B2D004DB5C723D-5118
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 7H0 820 045 S
   Component: CLIMA/AC            0202
   VCID: 3534281129535ABFCEF-5118
Address 09: Cent. Elect.        Labels: 7H0-937-049.lbl
   Part No: 7H0 937 049 L
   Component: BORDNETZ SGVER 1.0  1901
   Coding: 0000869
   Shop #: WSC 02760 785 00200
   VCID: 3B203E290F778CCF38B-5118
   Part No: 1C0 909 605 F
   Component: 13 AIRBAG VW61 0R0S 0003
   Coding: 12595
   Shop #: WSC 02756
   VCID: 2708F259E6FF382F4C3-5118
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H5 920 960 E
   Component: KOMBI+WEGFAHRSP VDO V02
   Coding: 05412
   Shop #: WSC 00001
   VCID: 333016092227448FE0B-5118
   WV2ZZZ7HZ5H003795     VWZ7Z0D0078527
Address 18: Aux. Heat        Labels: 7H0-819-008.lbl
   Part No: 7H0 815 071 B
   Component: Standheizung        0128
   VCID: 2708F259E3FF382F4C3-5118
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02737
   VCID: 70BAD90513B13F97DD9-5118
Address 45: Inter. Monitor        Labels: 7Hx-951-171.lbl
   Part No: 7H5 951 171 A
   Component: Innenraumueberw.    2409
   Coding: 0000012
   Shop #: WSC 00976 210 17027
   VCID: 2D040071C103127FB6F-5184
   Subsystem 1 - Part No: 7H0 951 171 A
   Component: Innenraumueberw.    1506
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: C   Komfortgerát     0004
   Coding: 00078
   Shop #: WSC 02756
   VCID: 323E130DDD3D4D87EBD-4AE0
   Subsystem 1 - Part No: 7H2959802A
   Component: Tõrsteuer.FS KLO 0203
   Subsystem 2 - Part No: 7H2959801A
   Component: Tõrsteuer.BF KLO 0203
01134 - Alarm Horn (H12)
            49-00 - No Communications
Address 76: Park Assist        Labels: 7E0-919-283.lbl
   Part No: 7E0 919 283
   Component: Parkingsyst. T5 T5M 801
   Coding: 01127
   Shop #: WSC 02771
   VCID: 6C82CD753F99DB77E11-5118
            31-10 - Open or Short to Ground - Intermittent
End----------(Elapsed Time: 08:04, VBatt start/end: 12.6V/12.5V)-----------
          57 6E 76 77 78 7D
Address 01: Engine        Labels: REDIR FAIL!
   Coding: 0001075
Address 02: Auto Trans        Labels: 09G-927-750.CLB
   Coding: 0000008
Address 03: ABS Brakes        Labels: 7H0-907-37X-ESP-F.LBL
   Coding: 0006315
Address 08: Auto HVAC        Labels: REDIR FAIL!
Address 09: Cent. Elect.        Labels: 7H0-937-049.LBL
   Coding: 0000869
   VCID: 3B203E290F778CCF38B-50F4
Address 15: Airbags        Labels: 6Q0-909-605-VW5.LBL
   Coding: 12595
   Shop #: WSC 02756
Address 17: Instruments        Labels: 7HX-920-XXX-17.LBL
   Coding: 05412
   Shop #: WSC 00001
Address 18: Aux. Heat        Labels: 7H0-819-008.LBL
Address 19: CAN Gateway        Labels: 6N0-909-901-19.LBL
   Coding: 00006
   Shop #: WSC 02737
Address 45: Inter. Monitor        Labels: 7HX-951-171.LBL
   Coding: 0000012
Address 46: Central Conv.        Labels: 7H0-959-433.LBL
   Coding: 00078
   Shop #: WSC 02756
Address 76: Park Assist        Labels: 7E0-919-283.LBL
   Coding: 01127
   Shop #: WSC 02771
End------(Elapsed Time: 17:20, VBatt start/end: 12.5V/12.4V, Deb=2)--------
Hi All,
AJ
Your friend wants you to do a TAB on a diesel engine, eh? ;)
Lack of a label file won't prevent you from doing the things that the ECU is capable of doing, but that 2005 diesel doesn't have a throttle in the traditional sense.
There are definitely some basic settings available in your engine. Are you trying to go from Measuring Blocks directly to Basic Settings? That doesn't work with the KWP-2000 protocol your ECU uses. You must go to directly Basic Settings from this screen:
Your ECU does support Basic Settings for EGR and Boost Pressure Regulation, but I wouldn't advise running them willy-nilly. In fact, the Basic Settings page of the VCDS Manual warns:
Warnings:
  • You should refer to the Factory Repair Manual for your particular car (or some other documented procedure) before "playing" with the ]Basic Settings function. Failure to follow the proper procedures can result in serious damage to the vehicle.
  • Although you can use the [Up] and [Dn] buttons to scroll through the available groups just like on the Measuring Blocks screen, this is probably not a good idea since you may put the Controller into Basic Settings for a Group that you did not intend.
As for your transmission shifting erratically, at 165,000 miles it doesn't really owe you much. When was the last time it had a fluid change? Basic Settings in it are documented. It's a two-step process. Group 001 first, then Group 002.
AJKlmnop
C?ID=306997
Thanks Uwe,
My mate definitely recommended an adaptations reset and a "TBA check would'nt hurt".
I must admit that I have been trying to select basic settings from the measuring blocks directly
as this method was detailed on the Ross Tech website for KWP-2000 protocol and applies to my
vehicle. I'll try selecting basic settings 04 tomorrow as its rather late here in UK now. My intention
is to apply basic stock settings as I'm not a fan of overclocking or "playing" with boost pressure/EGR
settings.
Thanks again for your help and rapid reply and I apologise for my lack of knowledge in this field, this
is not my area of expertise but it intrigues me none the less.
BTW, automatic transmission fluid and filter was been changed 8 months ago and again 2 months /3000 miles later.
vehicle.
Have you got a link to the page where it suggests doing it that way on KWP-2000? 'Cause I don't see it.
Good. On many automatics, VW claims it's not necessary to change the fluid and that it's a "lifetime fill". What they don't tell you is that the lifetime of the trans will generally be longer with regular fluid changes.
AJKlmnop
C?ID=306997
I stand corrected, I've been trying to use the wrong procedure for my drive
by wire Caravelle. Correct procedure below.
Drive-by-Wire (DBW) Engines using KWP-2000 or CAN
(These are engines WITHOUT a physical cable between the accelerator and the throttle. Check to see if the engine speaks KWP-2000 or CAN by looking in the top left of the Open Controller Screen. An example of a KWP-2000 engine controller is the 2002+ B6 Audi A4 1.8T. Some examples of CAN engine controllers are the Mk5 Golf 2.0T FSI)
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Basic Settings - 04]
Group 060
[Go!]
It should say "Basic Settings: OFF" on the top of your screen.
Click [ON/OFF/Next] to turn on Basic Settings.
It should now say "Basic Settings: ON" on the top of your screen. Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switched basic settings on. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
Click [ON/OFF/Next] to turn off Basic Settings.
It should now say "Basic Settings: OFF" on the top of your screen
Click the [Done, Go Back] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
If it did not complete, or resulted in Error, see the Special Notes below.
Right.
But keep in mind, this is for Petrol engines and is not applicable to any diesel.
PetrolDave
Westbury, UK
C?ID=1423
Because diesel engines don't have a throttle body... their "performance" is controlled by the amount and timing of fuel injected not by throttling the passage of air into the engine.
AJKlmnop
C?ID=306997
Thanks guys, as I said "not my area of expertise".
The internet and VCDS has certainly enlightened me to diesel technology over the last few days.
Hopefully I'll get a chance to try your recommendations tomorrow.
In the meantime, I'm off to see the Undertones play at a local music festival.
Thanks again.
AJ
Late-model diesels actually do have air-throttling capabilities. They need this to prevent excessive amounts of air in the combustion chamber (which is replaced by recirculated exhaust gasses) in order to limit NOx formation.
But they still don't do a TBA using Basic Settings Group 060 like the older petrol engines did. :)
