Can I change adaption in A6 2010 that backlights are not on during daytime?
roadster
C?ID=99261
Wednesday,07,June,2017,10:08:03:33791
VCDS Version: 17.1.3.0 (x64)
VIN: WAUZZZ4F2AN028500   License Plate: A&ANDER
Mileage: 160880km-99966mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 42 46 4F 52 53 55 56 5F 62
          72 76
VIN: WAUZZZ4F2AN028500   Mileage: 160880km-99966miles
Address 01: Engine (J623-CAHA)       Labels: 03L-906-022-CAG.clb
   Part No SW: 03L 906 019 AH    HW: 03L 906 022 FG
   Component: R4 2,0L EDC   H01 6413
   Revision: 11H01---    Serial number:
   Coding: 0105002C02172120
   Shop #: WSC 11400 205 63513
   ASAM Dataset: EV_ECM20TDI03L906019AH A01004
   ROD: EV_ECM20TDI03L906019AH.rod
   VCID: 71E2DFDFA02AE5C916-8024
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 4F9 910 155 D    HW: 01J 927 156 JG
   Component: V30 0AN 2.0l CR RdW 0020
   Revision: --H05---    Serial number: 00000000000086
   Shop #: WSC 02145 785 00200
   VCID: 2C5C0EAB8F88C82165-8078
   Part No SW: 4F0 910 517 AK    HW: 4F0 614 517 AT
   Component: ESP8 front      H03 0060
   Coding: 0020860
   VCID: 6DDAC3AF7412012932-8038
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601406211
   Coding: 0000003
   VCID: 254AFB8FEC62F969BA-8070
   Subsystem 1 - Part No: 4F0 910 132 E
   Component: FBSAUDIC6 IDG   H01 0054
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Component: KLIMABETAETIGUNGH30 0080
   Revision: 00000074    Serial number: 00000030473379
   Coding: 0010260
   VCID: 1D3AD36FC43231A9E2-8048
   Part No SW: 4F0 910 279 R    HW: 4F0 907 279
   Component: ILM Fahrer      H24 0340
   Coding: 0003122
   Shop #: WSC 02335 785 00200
   VCID: 387422FB4BD0748111-806C
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
Address 15: Airbags (J234)       Labels: 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 Q    HW: 4F0 959 655 G
   Component: Airbag AU1042 H06 0160
   Revision: --------    Serial number: 003F9001FWYN
   Coding: 30314236303630303031554A304C34463053
   Shop #: WSC 02324 785 00200
   ROD: EV_Airba10AURB4.rod
   VCID: 356A2BCF94C289E90A-8060
   Serial number: 3574SRB400009720F33%
   Serial number: 3584SRB400009708B2DB
   Serial number: 3516HRB402F9ICPJ74KX
   Serial number: 3526HRB402T9JRN35BRF
   Serial number: 3554NRB40000509D192Z
   Serial number: 3564NRB4000050AB520U
12583424 - Powertrain Databus
             U0002 00 [008] - No Communications
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026092540166
   Coding: 0002041
   VCID: 2756F187966EEB7988-8072
Address 17: Instruments (J285)       Labels: 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 933 Q    HW: 4F0 920 933 Q
   Component: KOMBIINSTR.   H08 0144
   Revision: 00000000    Serial number: CN100NF99
   Coding: 0F56080502000008010100
   Shop #: WSC 02391 823 56573
   VCID: 356A2BCF9CC289E90A-8060
Address 18: Aux. Heat        Labels: None
   Part No SW: 4F0 910 105 A    HW: 4F0 265 081 AA
   Component: Heizgeraet      H08 0100
   Revision:        B    Serial number: 09018641
   Coding: 0000111
   VCID: 1B3EDD77DA263F991C-804E
00664 - Fuel gauge
                    Reset counter: 151
                    Mileage: 158851 km
                    Date: 2017.05.09
                    Time: 07:33:18
Address 19: CAN Gateway (J533)       Labels: 4F0-907-468.clb
   Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0035
   Revision: LB100029    Serial number: 2900L099060105
   Coding: 000B03
   VCID: 397227FFB0DA6D89EE-806C
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140156255
Address 42: Door Elect, Driver (J386)       Labels: 4F0-959-793.clb
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000101920254
   Coding: 011C06205040410001
   VCID: 46885C03F124127193-8012
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
   Component: Komfortgeraet   H29 0250
   Revision: 02500029    Serial number: 01222860760000
   Coding: 0132229
   VCID: 356A2BCF5CC289E90A-8060
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000485725
   Coding: 0001004
   VCID: 5EB8946389B46AB1BB-800A
Address 52: Door Elect, Pass. (J387)       Labels: 4F0-959-792.clb
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000101949694
   VCID: 458A5B0FCC2219699A-8010
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000131
   VCID: 2142EF9FF84A1549C6-8074
   Part No: 8P0 907 357 H
   Coding: 0000003
   Shop #: WSC 02325 785 00200
   VCID: 3F8649E76EFE43B9D0-806A
   Part No SW: 4F0 035 056 B    HW: 4F0 035 056
   Component: Radio U STD   H45 0020
   Revision: AB001007    Serial number: 342I0097679084
   Coding: 010003020100000000
   VCID: 1F46E9670E3E23B9F0-804A
   Part No SW: 4E0 035 646 B    HW: 4E0 035 646
   Component: B-B-ER        H52 0040
   Revision: --------    Serial number: 348I%097532278
   Coding: 01000000010283ED01000305EF6300030201
   VCID: 234EE59722560759D4-8076
   Subsystem 1 - Part No SW: 4L0 919 604     HW: 4L0 919 604
   Component: DU6 Basic  H43 0306
   Serial number: 9355IR091034922
   Subsystem 2 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 M
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001402368
                    Reset counter: 20
                    Mileage: 115545 km
                    Date: 2015.03.09
                    Time: 09:48:31
                    Voltage: 13.10 V
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000101937698
   Coding: 010804204040220001
   VCID: 438E4517C2162759B4-8016
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000101937691
   Part No SW: 4L0 910 283 B    HW: 4L0 919 283 B
   Component: Parkhilfe 4-Kan H02 0500
   Revision: 00H02000    Serial number: 12330920801246
   Coding: 0001006
   VCID: 2952F7BF807ADD099E-807C
End-------------------------(Elapsed Time: 02:56)--------------------------
You could try telling your 09: Cent. Elect. module that it is somewhere other than "2 = Northern European Countries" (last digit of its coding).
However, my understanding is that tail lights are required to be on 24/7 in Scandinavian countries, no?
roadster
C?ID=99261
Thanks I try. Cars are more more using only front daytimelights and normal lights Front/rear when its darker/evening. We save gasoline and bulbs :). This is normal in Scandinavia.
roadster
C?ID=99261
Does this need any security code to open place where code is changed or is Ross tech helping while open elect module?
I would not expect a coding change on this module to require a security code.
roadster
C?ID=99261
I did security access and coding. America number 3 and also tried others. Everything went well and back taillights went of, Only thing what appered is faulty codes fron front daylight driving lights. Also warning lights on dashboard. Those don t go away by resetting. Then I changed old settins and warnings went away.
Thursday,08,June,2017,17:09:47:33791
VIN: WAUZZZ4F2AN028500   License Plate: ANDER2
Mileage: 161040km-100065mi   Repair Order:
          72 76
VIN: WAUZZZ4F2AN028500   Mileage: 161040km-100065miles
   Coding: 0020860
   Coding: 0000003
   Coding: 0010260
   Coding: 0003123
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
                    Reset counter: 156
                    Mileage: 161040 km
                    Date: 2017.06.08
                    Time: 16:47:00
                    Reset counter: 156
                    Mileage: 161040 km
                    Date: 2017.06.08
                    Time: 16:47:00
   Coding: 0002041
   Coding: 0000111
00664 - Fuel gauge
                    Reset counter: 151
                    Mileage: 158851 km
                    Date: 2017.05.09
                    Time: 07:33:18
   Coding: 000B03
   Coding: 0132229
   Coding: 0001004
   Revision: --H05---
   Coding: 0000131
   Coding: 0000003
                    Reset counter: 156
                    Mileage: 161041 km
                    Date: 2017.06.08
                    Time: 17:05:05
                    Voltage: 12.40 V
   Coding: 0001006
End-------------------------(Elapsed Time: 02:51)--------------------------
Address 09: DTCs cleared
Address 09,4F0 910 279 R,recoded (Short coding),from,0003123,to,0003122,(02335/785/00200),
Address 09,4F0 910 279 R,recoded (Short coding),from,0003122,to,0003123,(02335/785/00200),
