Audi A7 2015 developer mode locked
sergiocorleon
France
C?ID=204227
I am Philippe from France, I read your helping procedure for other member of the forum, I have the same problem to activate the developer mode in my MMI 3GP (google version) from 2015.
Can you also help me please ?
Please find below the information requested in the forum :
Part No SW: 4G1 035 044 D HW: 4G1 035 044
Component: MU-H-LN-EU H33 0389
Serial number: A277G0E7506658
Coding: 017503010000000013110002000A00132F000CE5F17001009F
VCID: 204FE3443BF401472C-8074
Many thanks per advance.
Best regards.
Philippe
GaryM
Oxford, UK
C?ID=226919
You need to post a FULL Auto-Scan. Not just a snippet form the 5F module.
sergiocorleon
France
C?ID=204227
It would also be good to Get Verified.
Hi Uwe,
I filled my cable serial number during my registration. Correct me if I am wrong, but no problem I can provide it other time. I bought my cable in group team to ross-tech France.
Thanks for your help.
sergiocorleon
France
C?ID=204227
Hello GaryM,
Please find below the full auto-scan :
Wednesday,31,May,2017,23:40:14:14306
VCDS Version: 17.4.2.3 (x64)
Data version: 20170505 DS270.4
VIN: WAUZZZ4G0FN012215   License Plate:
Mileage: 64843km-40291mi   Repair Order:
Chassis Type: 4G (4G8)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 30 36 3B 42 44 46 52
          53 55 5F 62 6C 6D 72 85 8B 8E 8F 90 A9 AC C0
VIN: WAUZZZ4G0FN012215   Mileage: 64843km-40291miles
Address 01: Engine (J623-CVUA)       Labels: None
   Part No SW: 4G0 907 589 B    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0001
   Revision: 54H23---
   Coding: 1A2A4032256603030800
   ASAM Dataset: EV_ECM30BTD0114G0907589B 001003
   ROD: EV_ECM30BTD0114G0907589B.rod
   VCID: 33651C089A028ADFC1-8066
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 4G0 927 158 AK    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H18 1003
   Revision: --H18---
   Coding: 000001
   VCID: 77FDE818CEFAA6FF3D-8022
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 49A79E4B92E579D29B00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3F8D4038A64A5EBF35-806A
   Part No SW: 4H0 907 064 FP    HW: 4H0 907 064 EP
   Component: BCM2 2.0      H36 0551
   Coding: 05AA6F0E000000000000
   VCID: 7CF7F734FFDC85A750-8028
   Part No SW: 4G0 820 043 CC    HW: 4G0 820 043 CC
   Component: KLIMA 4 ZONEN H14 0112
   Serial number: 11071400041386
   Coding: 368311782D0000
   VCID: 62CBA94C757853577A-8036
   Part No SW: 4H0 907 063 DF    HW: 4H0 907 063 AF
   Revision: 13020001    Serial number: 00000824388701
   Coding: 0105001440349FE2C10140C4A0001800CF9CC30A2E080201800008946101130200400008090000
   VCID: 6FEDD078BEAAEE3FE5-803A
   Component: WWS57X 140704  H37 0080
   Serial number:         140710132224
   Coding: 0045F7
   Serial number: 22924807
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 15 07 2014  00000670
   Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA108556000008251477
   Coding: 020300
   Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: DCF80C37000000000001
03455 - Function Restriction due to Faults in Other Modules
            000 -  -  - Intermittent
                    Reset counter: 175
                    Mileage: 60185 km
                    Date: 2016.12.29
                    Time: 00:43:03
Address 10: Park/Steer Assist (J791)       Labels: None
   Part No SW: 4G0 919 475 E    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0050
   Revision: --------    Serial number: 56261420400114
   Coding: B80B10
   ASAM Dataset: EV_EPHVA2CAU64X0000 001009
   ROD: EV_EPHVA2CAU57X0000.rod
Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0053
   Coding: 7C04010201
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
   ROD: EV_AdaptCruisContrAU57X_002.rod
   VCID: 2959FE6048CEC00F7B-807C
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1001M2AL
   Coding: 30333046313230303939554A304C34473853
   VCID: 3B753428B252429F19-806E
   Serial number: 3575HRB405J2M4PGEPMI
   Serial number: 3585HRB404V2M4PG9OLN
   Serial number: 3515JRB405P2SLKA219Q
   Serial number: 3525JRB405P2SLKANH4G
   Serial number: 3554VRB401G52M1AN9IP
   Serial number: 3564VRB400O52MDQI1TG
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Revision: --------    Serial number: 90372NGM000B6
   Coding: 00043C
   VCID: 387F2B248B646987F4-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 12 07 2014  F0038461
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 933 F    HW: 4G8 920 933 F
   Component: TDieRdwAcc    H07 0041
   Revision: 03001035    Serial number: 658230714592023
   Coding: 138702020F470008030300
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K.rod
   Part No HW: 4G8 907 468
   Component: J533--Gateway H13 0075
   Revision: --------    Serial number: 00000001480349
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 001024
   ROD: EV_GatewPkoUDS_001.rod
   VCID: 55A182903436B4EF0F-8000
   Serial number: 5591314003
   Voltage stabilizer:
          U140B 00 [008] - -
                    Reset counter: 188
                    Mileage: 64137 km
                    Date: 2017.05.14
                    Time: 21:33:42
                    Voltage terminal 30: 11.2 V
                    Voltage terminal 15: 11.2 V
                    Control Module temperature: 26 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 1
Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 18071400040813
   Coding: 20
   VCID: 3D713A30AC464CAF27-8068
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000062945
   Coding: 01010200000000000001020202
   Shop #: WSC 58921 001 1048576
   VCID: 64C7AF54676C5D6788-8030
   Revision: AA000000    Serial number: 00000109824993
   VCID: 77FDE818C6FAA6FF3D-8022
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA8207WNM2
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3663251C89709FF7E6-8062
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F56035E20628002080403
   VCID: 458152D0CC96046F7F-8010
Address 44: Steering Assist (J500)       Labels: 4G0-909-144.clb
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0020789507
   Coding: 101100010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0341988671
   Coding: 013A0E20A0B9B885C3200A840E030D470000000000000000000000000000
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO3103241V
   Coding: 901F00
   Subsystem 4 - Part No SW: 4G0 947 135 F    HW: 4G0 947 135
   Serial number: 0000000AP00008266955
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA108557000008099342
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93135229
03976 - Control Module for Rear Lid/Hatch Opening: Play Protection Active
                    Reset counter: 169
                    Mileage: 62998 km
                    Date: 2017.03.08
                    Time: 09:24:58
03932 - Real Lid/Hatch Opening Sensor
                    Fault Status: 00100101
                    Reset counter: 186
                    Mileage: 64122 km
                    Date: 2017.05.12
                    Time: 02:51:36
   Coding: 011F56035E20628002080402
   VCID: 468355DCF1900F7776-8012
   Revision: --------    Serial number: 00000001147659
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 2D510A707C26DC2F97-8078
Address 55: Headlight Range (J745)       Labels: 4H4-907-357-V2.clb
   Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0081
   Coding: 05FA02202A130200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
   Subsystem 1 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7540
   Coding: E02100
   Subsystem 2 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7540
   Coding: E02100
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0021
   Coding: E02100
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0021
   Coding: E02100
13706001 - Databus
                    Fault Frequency: 7
                    Reset counter: 175
                    Mileage: 60184 km
                    Date: 2016.12.29
                    Time: 00:42:01
5353456 - Fog mode active
          C118E 00 [008] -  -
                    Fault Frequency: 24
                    Reset counter: 175
                    Mileage: 60275 km
                    Date: 2017.01.01
                    Time: 04:34:15
   Subsystem 1 - Part No SW: V03 959 801 FC    HW: -----------
   Component: ECE 2017  --- 0157
   Subsystem 2 - Part No SW: 4G1 919 605     HW: 4G1 919 605
   Component: DU8 C7 SV  H41 0007
   Serial number: AUZ8Z9EL8000VP
   Multimedia Operating Unit:
   Serial number: 90349NGN0007Z
   Component: Gracenote2  --- 1012
3086 - Antenna for Telephone Mount
          B1564 01 [008] - Electrical Failure
                    Fault Frequency: 140
                    Reset counter: 205
                    Mileage: 60282 km
                    Date: 2017.01.01
                    Time: 14:04:53
                    Voltage terminal 30: 11.4 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
6669 - Optical Data Bus for Digital Sound System
          U10CC 00 [008] - Intermittent Disruption
                    Reset counter: 186
                    Mileage: 63866 km
                    Date: 2017.05.11
                    Time: 14:40:03
                    Voltage terminal 30: 14.9 V
                    Temperature of MOST transceiver-max.value: -50 °C
                    Temperature of MOST transceiver-min.value: -41 °C
                    Temperature of MOST transceiver-Current: 48 °C
   Coding: 010F14024020628002080002
   VCID: 49995EE0E08EE00F9B-801C
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0166956
   Coding: 0216000001010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   ROD: EV_CamerSysteTopViewAUDI.rod
   VCID: 2E530D7C7120A737AE-807A
Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
   Part No SW: 4G8 959 107 S    HW: 4G8 959 107 H
   Component: HDSG-Modul    H14 0049
   Revision: 11014001    Serial number: 190401135
   Coding: 0A3305C022
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 458152D0C496046F7F-8010
02123 - Door Warning Light / Entry Light
                    Fault Status: 00101100
                    Reset counter: 186
                    Mileage: 63823 km
                    Date: 2017.05.11
                    Time: 13:38:18
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
   Component: DPC-SG        H27 0081
   Coding: 6A140000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C570774473CD52780-8078
Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7C04010201
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   ROD: EV_AdaptCruisContr2AU57X_002.rod
   VCID: 275DF8585EDAF67F6D-8072
Address 8E: Image Processing (J851)       Labels: None
   Part No SW: 4H0 907 107 G    HW: 4H0 907 107
   Component: BV-SG         H32 0084
   Serial number: 005000482207147
   Coding: 0380A9181111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 2B5504684232D21F89-807E
   Coding: 00660600031F0376000308014248D2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 31691600601EB8CFB3-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 326B190C651883D7CA-8066
   Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0007
   Serial number: 140627200711
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0010
   Revision: 00000000    Serial number: 141710041
   ROD: EV_RDCMA00100_008.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0011
   Serial number: 140701200232
   ROD: EV_ActuaForExterNoiseUDS_VW12.rod
End-------------------------(Elapsed Time: 06:41)--------------------------
Hi Uwe,
Yes, but you have never registered it with Ross-Tech in the USA. That means you're in category 2) of the How to get Verified post.
Dana
Western PA, USA
Hello Philippe,
After you fill out that form please bump this back up. At that point in time I will have contact information on file for you so we can e-mail a file to you for testing.
Regards,
Dana
sergiocorleon
France
C?ID=204227
Hello Uwe,
I filled the form category 2 as asked.
Regards
Hello Uwe,
Regards
sergiocorleon
France
C?ID=204227
Ok, thanks a lot Dana. I will apply your procedure.
Dana
Western PA, USA
I sent an email with the tester file. Keep us posted!
Ref to FS#1374
sergiocorleon
France
C?ID=204227
Hello Dana,
Unfortunately it doesn't work, I tried to make the code "S12345", then I tested only "12345" with no success.
I checked, I put directly your file (without changing the name or extension) in my folder :C:\Ross-Tech\VCDS-Beta\Logs
Do you have an idea why it doesn't work?
Regards.
VCDS isn't looking for it there! Please try putting it in:
C:\Ross-Tech\VCDS-Beta\Labels\
or
C:\Ross-Tech\VCDS-Beta\Labels\User\
sergiocorleon
France
C?ID=204227
Oups sorry I said bad information, yes I put in this file first : C:\Ross-Tech\VCDS-Beta\Labels\User\
I tried to copy also in C:\Ross-Tech\VCDS-Beta\Labels\ , and test the code ''S12345'' but no success.
I cannot test now I need to wait because the code was wrong, is it ''12345'' without the S?
regards
It definitely needs the 'S'...
sergiocorleon
France
C?ID=204227
In this case I have no idea where is the problem? because I tested with this code "S12345".
I will send you tomorrow a screenshot of the message.
sergiocorleon
France
C?ID=204227
Hello Dana,
I have this message when I test the code given.:(
I send to you by email the screenshot.
Dana
Western PA, USA
This was my fault. I sent the proper location for the new file (C:\Ross-Tech\VCDS-Beta\Labels\User ) ... however I didn't hyphenate the file when I saved it. I sent "4G1 035 044.clb" instead of 4G1-035-044.clb. Everything should work as planned this time and I apologize for the inconvenience Philippe!
sergiocorleon
France
C?ID=204227
Thanks no problem Dana, I tested it's ok now, I did ''back'' and the ''bottom left of the silver keys'' to go in the hidden green menu. But unfortunately the green menu is poor, I cannot modify the splash screen of the HMI :-(?
Do you have a tips for that? and about VIM?
thanks.
