2006 Audi A4 2.0 - P0301 Cyl 1 misfire / P0300 Random misfire / RUNS BETTER ONCE WARM
  • Thread starter Deleted member 12080
  • Start date
D
Guest
Hello, I have a 2006 Audi A4 2.0T FWD with the CVT transmission. It has 131,000 miles.
I have VCDS and it is pulling two codes
16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
16685/P0301/000769 - Cylinder 1 Misfire Detected
Symtoms:
The car starts without too much hesitation, but when cold the whole car shakes pretty hard. I believe it is definitely running on 3 cylinders when cold. But once the car warms up, it doesn't shake anywhere near as bad and drives okay. There is still hesitation but the vibration is reduced greatly, and I was able to drive it 30 miles home without much of an issue. I've drove a Toyota Camry before with only 3 of 4 cylinders running and it barely had enough power to do the speed limit.
The CEL flashes when the car is first started and the engine is cold, but once it warms up the CEL becomes solid and stays lit.
Things I have done trying to solve the problem:
I switched cylinder 1 and 4 coils, cleared the codes, and started the engine again. Eventually the same codes came back on. To me this rules out the coil, but I might change them all just to be safe. At least one of them has been changed before as it does not have numbers written on the top like the other 3 do. I pulled all the spark plugs and they all look rather similar. Light brown color on all of them. They are Autolite plugs (im not a fan) and will be changing those too, but I don't believe they are the problem.
The previous owner took it to a mechanic and he said it was carbon buildup on the valves. I haven't looked into this much yet but I do know that carbon buildup is a common problem on cars with direct injection, but I am unsure if that could cause this misfire. I will look more into that and how hard it is to clean them. I don't want to pull the whole head off if I don't have to.
Looking at Ross-Tech Wiki, it could be a lot of things causing this but I was hoping someone would have some input.
Thanks for your help!
-Derek
D
Guest
Sorry, I wrote that from my desktop and I have to use my crappy old laptop for the VCDS.
Autoscan with car off. Plugs and coils are currently removed from motor.
Sunday,12,November,2017,14:53:54:02058
VIN: WAUBF78E96A049522   License Plate: AUDISPARKPLUGREMOVED
Mileage: 210860km-131022mi   Repair Order:
          67 69 75 76 77
VIN: WAUBF78E96A049522   Mileage: 210860km-131022miles
   Part No SW: 8E0 910 115 M    HW: 8E0 907 115 D
   Component: 2.0l R4/4V TFSI     0070
   Revision: --H10---    Serial number:
   Coding: 0104010A02070120
   Shop #: WSC 25169 444 57715
   VCID: 2B000F0B9F05B0FFDE8-807E
               P0300 - 001 -
                    Fault Status: 01100001
                    Mileage: 210864 km
                    RPM: 1242 /min
                    Load: 54.9 %
                    Temperature: 24.0°C
                    Temperature: 8.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.589 V
000769 - Cylinder 1
               P0301 - 001 - Misfire Detected
                    Mileage: 210864 km
                    RPM: 1303 /min
                    Load: 47.8 %
                    Temperature: 24.0°C
                    Temperature: 8.0°C
                    Voltage: 13.716 V
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 8E3 910 155 C    HW: 01J 927 156 HT
   Component: V30 01J 2.0TFSI USA 0010
   Revision: 00000011    Serial number: 00000001230498
   Shop #: WSC 04940 001 00001
   VCID: 280AF0078EF39BE733A-807C
Address 03: ABS Brakes        Labels: 8E0-910-517.clb
   Part No SW: 8E0 910 517 D    HW: 8E0 614 517 AK
   Component: ESP8 front      H04 0120
   Coding: 0004525
   Shop #: WSC 06335 000 00000
   Part No: 8E0 820 043 AM
   Component:   A4 Klimaautomat   2831
   Coding: 00000
   VCID: 6C82CC175F9B77C7972-50D0
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  USA 0504
   Coding: 01023
   Shop #: WSC 65536
   VCID: 3B203F4B6A75207F4E8-4AC2
            30-00 - Open or Short to Plus
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW:
   Component: SDAR XM
   Revision:             Serial number: AUZ4Z7E2027995
   VCID: 2B000F0B9F25B0FFDE8-5160
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H11 3540
   Revision: 91H1135    Serial number: 0036N000RJTL
   Coding: 0032607
   VCID: 3C223C576A6B2747472-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 33SDE
   Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB401CD0D1F ÿ†63
   Subsystem 5 - Serial number: D0D1F ÿ†6342DRB401C046A5Mÿ†63
   Subsystem 6 - Serial number: 046A5Mÿ†6352ARB40086D69BZÿ†63
   Subsystem 7 - Serial number: 6D69BZÿ†6362ARB400863E41Jÿ†63
   Subsystem 8 - Serial number: 63E41Jÿ†63729RB4008CF9B0 ÿ†63
   Subsystem 9 - Serial number: CF9B0 ÿ†63829RB4008CFA06Zÿ
   Subsystem 10 - Serial number: CFA06Zÿ
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0601
   Coding: 04141
   Shop #: WSC 06335
   VCID: 41DC4DA308994AAF144-4AC2
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
   Part No SW: 8E0 920 982 F    HW: 8E0 920 982 F
   Component: KOMBI+WFS 4     H12 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0022261
   Shop #: WSC 02101 444 999999
   VCID: 313C1D63BD39DA2FE44-50F4
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
   Coding: 0022261
   Part No: 8E0 959 433 BT
   Component: Komfortgerát T7B    3332
   Coding: 11836
   Shop #: WSC 06335
   VCID: 045284B7570B9F877F2-4AC2
   Component: Tõrsteuer.FS BRM 0406
   Component: Tõrsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0205
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0205
            35-00 -  -
            35-00 -  -
            35-00 -  -
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Component: AFS 1           H01 0030
   Coding: 0000019
   Shop #: WSC 22130 444 64374
   VCID: 2616FE3F84E78D97016-8072
   Subsystem 1 - Part No: NOSUBSYSTEM
   Component: AFS-Modul links
   Subsystem 2 - Part No: NOSUBSYSTEM
   Component: AFS-Modul rechts
02071 - Local Databus
                    Fault Status: 11100100
                    Reset counter: 40
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8E0 035 192 F    HW: 8E0 035 192 F
   Component: RNS-E US        H70 0260
   Revision:      01S    Serial number: AUZBZ7E2001534
   Coding: 0301637
   VCID: 2708F33B83CD949F3A0-5160
                    Reset counter: 147
                    Date: 2014.09.02
                    Time: 07:40:45
                    Voltage: 11.50 V
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
                    Fault Status: 00101011
                    Reset counter: 145
                    Date: 2012.09.14
                    Time: 08:26:07
                    Mileage: 655350 km
                    Count: 1111
                    Clock: 17:30
   Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
   Component: FSE_255x BT     H26 0290
   Revision: 00000000    Serial number: 00000005016937
   Coding: 0001677
   Shop #: WSC 22130 444 84210
   VCID: 3D24315371612E4F70C-50D0
End----(Elapsed Time: 04:26, VBatt start/end: 11.4V/11.4V. VIgn 11.4V)-----
Larry Manton
C?ID=112505
Symtoms:
-Derek
Don't know what Jack recommends, most people use walnut shell blaster for doing valves, in many cases head stays on, about the only way I know to do it, but i don't own one of the problematic GDI motors.
I would do this right out of the gate, as sounds like it needs to be done, then go from there. You might get in and find the rumor was false, is so good.
I have buddies with mini coopers, they do it routinely, about every 20,000 miles.
Component: 2.0l R4/4V TFSI 0070 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Firmware Update required 0080 or higher!
JPPSG........
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
Compression check compare across entire engine bank?
Check grounds and wire harness to coil packs.
Swap or change spark plugs as part of isolation strategy
Report............?
Davor Sule
Croatia
C?ID=282324
Do cylinder leakdown test and compare cold engine/warm engine, also if leakage is high you must find where is leaking. I had same symptoms and issue, cold engine with misfires, warm engine with no misfires. Warm cylinder was leaking about 20 %, and cold was leaking about 60%. Exhaust valve on 3. cylinder was worn. This is just example.
D
Guest
Okay, I have switched the spark plug location to rule out both the spark plugs and the ignition coils.
Compression test looked good. It was preformed on a slightly warm engine.
Cylinder 1: 180 PSI
Cylinder 2: 175 PSI
Cylinder 3: 185 PSI
Cylinder 4: 190 PSI
They look pretty good to me but I will check again when the engine is completely cold to see if it makes a difference.
I still need to look into the coil wiring and ground. I will have to do some research to figure out how to check that. That will be my next step.
I also was running the advanced measuring value mode on VCDS and noticed that the engine consistently misfired when cold and at idle. It still misfired at idle when it was warm but not as often. It would also misfire at higher RPM here and there but it was sporadic. This was all done in Park so there was no load on the engine. But it was always and only Cylinder 1 with the misfire.
As of now I will look into the coil wiring, then do a cold compression test, and then maybe pull the intake manifold to check out the injectors and carbon buildup on valves.
Davor Sule
Croatia
C?ID=282324
It's better to do leakdown test with cold engine. With compression test on warm engine you don't know where it's leaking. And try to do compression test when engine is cold (after 10 hours).
Also check power and ground of ECU and all sensors.
Have you checked injectors? Maybe there is some issue.
Davor Sule
Croatia
C?ID=282324
Also try to measure vacuum of engine before taking engine head off. Neddle of vacuum gauge should be stabile if valves are good, if not neddle twitches.
You have to consider that valve lifters can cause this if they don't work in good order.
