volkswagen oem bluetooth unit
scano.ie
Ireland
C?ID=214169
I recently installed the oem bluetooth unit in to my6 golf(2009). The unit itself is working and integrated with both the mfd and my rns510. But I have noticed that for some reason the mfd only displays the bluetooth icon and not the battery and iPod logo as shown in this picture
I have scanned the car and indeed there is 2 errors with the unit being reported but I am unable to find a fix for these errors. Any help would be great
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 N    HW: 7P6 035 730 N
   Component: TELEFON       H15 4217
   Revision: 1B001001    Serial number: 00007666085611
   Coding: 0201000000010000
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3D712881ACDC05F6B01-8068
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
                    Reset counter: 210
                    Mileage: 108204 km
                    Date: 2003.14.30
                    Time: 11:35:02
          U1014 00 [009] - -
                    Reset counter: 210
                    Mileage: 108204 km
                    Date: 2003.14.30
                    Time: 11:35:03
scano.ie
Ireland
C?ID=214169
how do i find the correct coding for it
Jef
HQ
Retrofits like this are not my strong point, but I'll take a stab at it...
Looking at the coding there are two thing I find that believe need be changed.
Byte 6 is currently set to "00 Telephone Baseplate Diagnostic active". I suspect that should be set to "01 Telephone Baseplate Diagnostic inactive"
Byte 7 is currently set to "00 Operating Unit for Cell Phone Preparation (3-Button Keypad): North America". With your location listed as "Ireland", I feel safe in saying North America is not correct. To that end, this leaves 2 other options for Byte 7. No 3-Button Keypad installed, and with 3-Button Keypad installed for Rest of World (Ireland).
Those would be my starting points.
scano.ie
Ireland
C?ID=214169
ok thanks guys for the help I'll give it a try and report back
scano.ie
Ireland
C?ID=214169
So I changed the bits I was ment to but now I'm receiving this error
Coding: 0201000000010101
ROD: EV_UHVNA.rod
Reset counter: 211
Mileage: 108219 km
Date: 2003.14.31
Time: 10:44:18
Dana
Western PA, USA
You have Operating Unit for Cell Phone Preparation (3-Button Keypad): Rest of the World enabled and that fault code is common when a overhead console is not installed. If you did not retrofit the 3 button console switch assembly I would code that position off (Operating Unit for Cell Phone Preparation (3-Button Keypad) not installed).
scano.ie
Ireland
C?ID=214169
perfect thanks for the help no errors found:D
Emzy
C?ID=310014
Scano.ie's response also cured a similar fault I was having with my 2014 tiguan. I changed my MFSW to remove Push to talk (PTT) and a Telematics code started showing. Making the 3-button key NOT active fixed the 75-telematics fault I was having.
2103041 - Control Module
