Port injector reading
Goublin
Australia
C?ID=341311
Hi all,
Please can some one help me. I have a Passat TSI R-line 2.0 EA888 gen 3
does anyone know how I can log the measurements on the port injector?
any help is gratefully received
Without a scan to see exactly what ECU this car has, that could be quite difficult. ;)
We need you to insert a full Auto-Scan not just a screen shot - see my signature for a link which shows how-to :thumbs:
Goublin
Australia
C?ID=341311
Sorry guys, I’m running some logs in about an hour so will get this done
Goublin
Australia
C?ID=341311
Saturday,23,February,2019,10:55:38:53577
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
VIN: WVWZZZ3CZHE064587   License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44 52
          55 5F 6C A5 BB BC CF
VIN: WVWZZZ3CZHE064587   Mileage: 31924km-19836miles
BC-Door Rear Pass -- Status: Malfunction 0010
Address 01: Engine (J623-CJXA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 259 B    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 0A1D00322466050B3000
   Shop #: WSC 05311 115 00311
   ASAM Dataset: EV_ECM20TFS0203G0906259B 001003
   ROD: EV_ECM20TFS0203G0906259B.rod
   VCID: 2B03FB49238824CF1BF-807E
16469 - Throttle Actuator Control Circuit
          P2100 00 [032] - Open Circuit
                    Mileage: 30922 km
                    Date: 2019.02.09
                    Time: 09:31:24
                    Coolant temperature: 48 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 11.875 V
                    Unlearning counter according OBD: 11
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 97 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.978 V
                    FAC_TPS_1_SAE: 16.015625 %
                    FUP_H_SAE: 12740.0 kPa
Readiness: 0010 0001
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A TVS  H54 4999
   Revision: 06354004    Serial number: TFK01608060079
   Shop #: WSC 05311 115 12345
   ROD: EV_TCMDQ250021.rod
   VCID: 53F383A95B785C0F73F-8006
          P1734 00 [002] - -
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 62366000003171
   Coding: 0EEC938F54261B70477C070841CA6970C92AD8E2E0829675384250B8C2A902
   Shop #: WSC 00015 115 08193
   VCID: 7BA30B099368744FCBF-802E
0156 - ASR and ESP Switch
          C109C 29 [008] - Signal Implausible
                    Reset counter: 142
                    Mileage: 31923 km
                    Date: 2019.02.22
                    Time: 17:38:58
Address 05: Acc/Start Auth.
   Part No SW: 5G0 907 044 BP    HW: 5G0 907 044 BP
   Component: Climatronic   H04 1601
   Revision: 00001K10
   Coding: 1112000420010001111550000010182A
   ROD: EV_ACClimaBHBVW37X_006_VW48.rod
   VCID: 76B51A3DA84A2927B41-8022
   Air quality sensor:
          B10CD 00 [009] -  -
                    Reset counter: 142
                    Mileage: 30922 km
                    Date: 2019.02.09
                    Time: 10:22:10
                    Voltage terminal 30: 10.9 V
                    CAN input signal(s) status-Back-up light: OFF
   Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 032 0222
   Revision: --------    Serial number: 865806081601DO
   ROD: EV_BCMBOSCH_017.rod
   VCID: 015F79E1F1841E9F913-8054
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    160723  043 0607
   Serial number:         160730130427
   Component: RLHS  042 0105
   Serial number: S4Y16M08D30H05M30S21
   Coding: 00A8DD
   Serial number: 31 05 2016  10000617
   Serial number: 000000000ZY162041D5B
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000066540919
589592 - Databus
          U1201 00 [008] - No Communications
          [CAN Keine Kommunikation]
                    Reset counter: 40
                    Mileage: 31196 km
                    Date: 2019.02.12
                    Time: 20:22:22
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 97
                    Mileage: 30326 km
                    Date: 2019.02.02
                    Time: 16:17:00
262936 - Sensor for anti-theft alarm system
          B1330 29 [008] - Signal Implausible
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616238
   Coding: 0371167851
   Shop #: WSC 05311 115 00084
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000_009_VW48.rod
   VCID: 0D4755D1BDDC4AFFE5B-8058
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Coding: 320467D359FFC428949C8045
   Shop #: WSC 00015 115 00001
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3431E035FEB67B374A5-8060
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 151
                    Mileage: 30922 km
                    Date: 2019.02.09
                    Time: 09:31:24
                    Control Module temperature: 47 °C
                    Voltage terminal 15: 11.6 V
   Serial number: 14081641350236
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3829D405E2DE9F5766D-806C
   Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003STPFUCZTY
   Coding: 98FCC0C0000000005C540000008800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5BFF198770686FE77-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 508 16
   Serial number: 3576U00000029C757C1K
   Subsystem 2 - Part No SW: -----------    HW: 454 000 508 16
   Serial number: 3586U000000620557C14
   Subsystem 3 - Part No SW: -----------    HW: 454 800 608 16
   Serial number: 3516R716F040C0000001
   Subsystem 4 - Part No SW: -----------    HW: 454 800 608 16
   Serial number: 3526R732A2D0C0000006
   Subsystem 5 - Part No SW: -----------    HW: 454 803 107 16
   Serial number: 3556V42A1650B0000003
   Part No SW: 3Q0 953 521 DA    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20160806501742
   Coding: 0810
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 72BD262DC4223507989-8026
   Part No SW: 3G0 920 791 B    HW: 3G0 920 791 B
   Component: KOMBI         404 2153
   Coding: 27A40018FF88000801886B0B1001000000000000
   ROD: EV_DashBoardVDDMQBAB_VW48.rod
   VCID: 28090445327E0FD7F6D-807C
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 163
                    Mileage: 30307 km
                    Date: 2019.02.02
                    Time: 15:44:26
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 26081610520303
   Coding: 030300347F085900FB00025A9C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013_VW48.rod
   VCID: 7CA1081596667377C25-8028
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0040
   Serial number: 29160001656180096344
   Coding: 2DFFFF
   Serial number: 75410803001608302422
   Analog clock:
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Reset counter: 182
                    Mileage: 31924 km
                    Date: 2019.02.23
                    Time: 00:59:22
                    Supply voltage: Terminal 30: 12.3 V
                    Terminal 15: OFF
   Serial number: HA1-00001.08.16
   Coding: 0301
   VCID: 4ACD9ECD8C321DC7009-801E
   Serial number: 16000193219014
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BF2921C1240E1F613-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 B    HW: 3Q0 959 760 B
   Component: Sitzmemory    H05 0020
   Serial number: Y0006PHP14224
   Coding: 0014000000000500818280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   VCID: 3A2DCE0DDCD28D47909-806E
   Part No SW: 3Q0 907 566 C    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0310
   Revision: --------
   Coding: 44C002
   Serial number: 051116EK416027
   Coding: 003F1A20D201020000000000
   VCID: 43D3B3E9AB18CC8FC3F-8016
65593 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
                    Fault Frequency: 10
                    Reset counter: 181
                    Mileage: 30530 km
                    Date: 2019.02.04
                    Time: 12:20:04
65799 - Door Warning / Enrty Lighting
          B1775 01 [008] - Electrical Failure
                    Reset counter: 158
                    Mileage: 31169 km
                    Date: 2019.02.12
                    Time: 08:15:46
65649 - Lamp for Ambient Illumination
          B1325 13 [008] - Open Circuit
                    Reset counter: 158
                    Mileage: 31169 km
                    Date: 2019.02.12
                    Time: 08:15:46
   Coding: 9307
   Shop #: WSC 00015 115 00311
   ROD: EV_SteerAssisMQB_013.rod
   Serial number: 170616EFH03214
   Coding: 003F1020DE01020200001000
   VCID: 42DDB6EDB402C587C89-8016
                    Reset counter: 159
                    Mileage: 31169 km
                    Date: 2019.02.12
                    Time: 08:49:54
                    Reset counter: 158
                    Mileage: 31169 km
                    Date: 2019.02.12
                    Time: 08:49:54
   Component: AFS-ECU       H01 0120
   Coding: 03A603000F210200
   Shop #: WSC 05311 000 08193
   VCID: 3FDBBF19C7F0A86FA77-806A
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Coding: E02400
   Component: LeiMo rechts  H02 0003
   Coding: E02400
5538554 - LED Headlamp; Right
          C1178 F0 [008] - Over-Temp Protection Active
                    Reset counter: 182
                    Mileage: 30922 km
                    Date: 2019.02.09
                    Time: 10:21:12
   Part No SW: 3G0 035 045 C    HW: 3G0 035 045
   Component: MU-H-N-RW     H51 0687
   Serial number: A688E0G7503256
   Coding: 02840108FF00000051510001000808001F0106E601200002DF
   VCID: 1E65229D603AC1678C1-804A
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL03A0P
   Subsystem 2 - Part No SW: V03 959 801 EB    HW: -----------
   Component: ROW 2016/2017  --- 0058
   Component: Gracenote2---  --- 4009
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 0184010162002017000040
   Shop #: WSC 05311 000 00150
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
   VCID: 77AB1739AF40502FAF7-8022
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0220
   Serial number: 29081611P12051
   Coding: 000408010000010100022346C050410084000E300000
   Serial number: 120816DH704787
   Coding: 000E10200101020000000000
   VCID: 45D7ADF1A52CF2BFEDB-8010
   Serial number: 120816DH70478A
                    Reset counter: 153
                    Mileage: 31015 km
                    Date: 2019.02.09
                    Time: 14:00:11
   Part No SW: 3Q0 907 590 C    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
   VCID: 3537DD31F5CC623F7DB-8060
End----(Elapsed Time: 02:32, VBatt start/end: 10.7V/10.1V. VIgn 10.2V)-----
Having scrolled through the half a bazillion measuring values available from that ECU, I don't see anything that shows the low-pressure (port) injection vs. the high-pressure (direct) injection.
You could have a look at:
IDE00148 -- Median injection timing
IDE00472 -- Mean injection quantity
IDE07019 -- Number of ignitions direct injection
IDE07020 -- Number of ignitions intake manifold injection
But I'm not sure any of that is really what you're looking for.
Goublin
Australia
C?ID=341311
Worked great, got the info we needed. Thanks for your help.
