Possible to turn off bulb error light on VW Jetta 2016
Borja
Mexico City
C?ID=326888
Dears
I install European led Tail Lights on VW jetta 2016 but as you know the bulb error message appear on the dashboard of the car i saw on Internet and it seems it is not possible to delete the bulb error if someone can confirm if we can erase that Bulb error ?
Thanks in advance
Tuesday,25,September,2018,21:17:16:37874
VIN: 3VW1W2AJ8GM374995   License Plate: MYK4448
Mileage: 35600km-22120mi   Repair Order:
Chassis Type: AJ-VW36 (7E0)
Scan: 01 03 05 08 09 15 17 19 25 2B 56
VIN: 3VW1W2AJ8GM374995   Mileage: 35600km-22120miles
Address 01: Engine (CCC)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 EC    HW: 07K 907 309 B
   Component: 2,5L 125KW      G01 1401
   Revision: T4H07---    Serial number:
   Coding: 0000071
   Shop #: WSC 00066 000 00000
   VCID: 73B3229677BC17BF7C6-8026
053271 - Please Check Fault Codes in Control Module for ABS Brakes
               U1017 - 000 -  - Intermittent
                    Mileage: 35243 km
                    Date: 2018.09.18
                    Time: 11:16:54
                    RPM: 2321 /min
                    Load: 32.1 %
                    Speed: 38.0 km/h
                    Temperature: 92.0°C
                    Temperature: 72.0°C
                    Absolute Pres.: 780.0 mbar
Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0106
   Revision: 00H35001
   Coding: 0020833
   Shop #: WSC 00066 790 00014
   VCID: 7BA30AB65FEC5FFF246-802E
   Revision: 00092000    Serial number: 0396094799
   Coding: 000F0F
   Shop #: WSC 00066 000 00295
   VCID: 372BD6862FC4BB9F80E-8062
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 CR    HW: 5C0 820 047 CR
   Component: J301  Klimaanlage   0211
   Revision: 2001401S    Serial number: 00000003222248
   VCID: 72BD279208A61EB7770-8026
   Part No SW: 7E0 937 189     HW: 7E0 937 189
   Component: BCM PQ25 MMI3 H80 0736
   Revision: BA080001    Serial number: 18007105160151
   Coding: 73994BBA083B0700083920802C0A84D50DC6720E60C40020B1A010030844
   Shop #: WSC 00066 123 12345
   VCID: 71BF289E01A025AF8EA-8024
   Subsystem 1 - Part No SW: 6R0 959 801 DF    HW: 6R0 959 801 DF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  022 1466
   Serial number: 14102743160311065331
   Coding: 020000
   Subsystem 2 - Part No SW: 6R0 959 802 DJ    HW: 6R0 959 802 DJ  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  022 1466
   Serial number: 14102742160308062643
   Coding: 020000
   Subsystem 3 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
   Component: J245 PS41.402  H03 0004
   Serial number: 0000FST000S10B400000
   Coding: 180000
   Subsystem 4 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
   Serial number: 0481616030901588AD1B
   Coding: 280000
   Subsystem 5 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
   Component: J388__TSG_HL  022 1466
   Serial number: 14102745160328233238
   Subsystem 6 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
   Component: J389__TSG_HR  022 1466
   Serial number: 14102744160330220310
   Part No SW: 5C0 959 655 AF    HW: 5C0 959 655 AF
   Component: AirbagVW10    015 0614
   Serial number: 003S2M088FNN
   Coding: 00004341
   ASAM Dataset: EV_AirbaVW10SMEVW360 001032
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 76B51B82684E02975B8-8022
   Serial number: 3572MSME5D4C0A57ZZZ6
   Serial number: 3582MSME224C0A57ZZZ-
   Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3516KSME2A1F2F3CZZZ6
   Serial number: 3526KSME302F2F3CZZZ%
   Part No SW: 5C6 920 855 A    HW: 5C6 920 855 A
   Component: KOMBI         H04 1007
   Coding: 170B000000
   Shop #: WSC 00066 790 00320
   VCID: 2C01F9EAE6820847FDC-8078
   Part No SW: 7E0 909 901     HW: 7E0 937 189
   Component: GW-K-CAN TP20 H80 0736
   Revision: BA080001
   Coding: 102200
   VCID: 688945FA327AE467D94-803C
            000 -  -  - Intermittent
                    Date: 2018.01.20
                    Time: 00:00:00
   Component: IMMO          H04 1007
   Coding: 000007
   VCID: 6A8D3FF22CF6D677CF0-803E
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Revision: 00000000    Serial number: 16000060349004
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 313FE89EC1A065AFCEA-8064
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         534 5314
   Revision: --------    Serial number: VWZZZ4R6203904
   Coding: 16000440040005
   Shop #: WSC 00078 790 00217
   VCID: 46D5AB4258AED2170B8-8012
00874 - Treble Speaker Front Left (R20)
                    Fault Status: 00111011
                    Reset counter: 204
                    Mileage: 32260 km
                    Date: 2018.01.19
                    Time: 18:08:17
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 204
                    Mileage: 32260 km
                    Date: 2018.01.19
                    Time: 18:08:17
00876 - Treble Speaker Rear Left (R14)
                    Reset counter: 204
                    Mileage: 32260 km
                    Date: 2018.01.19
                    Time: 18:08:17
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 204
                    Mileage: 32260 km
                    Date: 2018.01.19
                    Time: 18:08:17
                    Reset counter: 40
                    Mileage: 34927 km
                    Date: 2018.08.16
                    Time: 10:17:58
End----------(Elapsed Time: 01:17, VBatt start/end: 14.3V/14.3V)-----------
iichel
Netherlands, eastern part
C?ID=284912
Hard to say. The bcm doesn't tell which lights it's unhappy with so hard to advise on a coding.
When does the light appear? Which light do you suspect? Brake, recess, fog, indicator?
myounus
Northwest UK
C?ID=321059
We also have no idea what wiring has been changed
Borja
Mexico City
C?ID=326888
Hello Guys
Thanks for you feedback let me explain what i have done in order to install this Lights
Description:
I use to have the normal lights as you can check on the images with 4 pins for the ones that are on the Right & left and 3 pins for the ones that goes on the center of the car as you can check on the images
https://imgur.com/a/rRUpmWP
rRUpmWP
https://imgur.com/a/JjLy8Xt
JjLy8Xt
https://imgur.com/a/IRESQx2
IRESQx2
The problem with the European lights is that they dont use the Amber Light like in USA and Mexico so as i know there two types of LED Jetta GLI tail lights with 4 pins that have the amber color and 3 pins with out the Amber Color.
So for the installation as i know for my electronic courses LOL :p I need to use the led resistor to connect them
https://imgur.com/a/xg8qOK9
xg8qOK9
European 3 pins LED tail lights:
https://imgur.com/a/FriQ8YG
FriQ8YG
https://imgur.com/a/Qg0PYYH
Qg0PYYH
After Finish wiring the Led Tail lights (i can add the diagram if it is needed) all is working fine stop light , reverse light , Etc.
https://imgur.com/a/crcqYOR
crcqYOR
After all this wiring procedures i think the car will not recognize the led Tail lights because this is an adaptation and when I activate the lights the Bulb error appear on the dashboard an thats why I want to delete form the dashboard i mean not to clear the Bulb error like in the correct meaner because i think that can not be achive because this is an adaptation of the lights
Answering Mr Iichel Questions:
Borja: After finish the wiring process
Borja:I supect that are all the Tail lights show the indicator, when i start the car there is not Bulb error but when i activate Brake, Recess , Fog the indicator appear , when i stop the car the Bulb error clear until i activate again the breake ETC
All of them
Borja
Mexico City
C?ID=326888
Hello Iichel
I answer to your questions and make a description of the problem on the history of the post regarding your comments the BCM module don’t show witch lights what can I do to know ? And image of the serial part of the light ?
Borja
Mexico City
C?ID=326888
Hello Myounus
I make a description of the problem if the diagram of needs I can attach to the history of the post thanks in advance
myounus
Northwest UK
C?ID=321059
Hi Borja
So you have gone from incandescent to LED - is that correct?
myounus
Northwest UK
C?ID=321059
Hi Borja
The voltage used by LED lights is a fraction of incandescent ones which would explain why you are getting bulb errors. Have you made any coding changes in your BCM?
Borja
Mexico City
C?ID=326888
Hi Borja
Hello Ounus
I see, i haven't change anything on the BCM of the car because i am not sure if there is way to disable the Bulb Sensor of the car or a way to trick the car in order they believe they have the incandescent ones.
I want to ask first before doing something wrong LOL :)
Thanks
iichel
C?ID=284912
Yes, thank you for your answers. My question is more like, does the bulb error come on when pressing the brake, starting the indicator, directly when key is turned, etc?
myounus
Northwest UK
C?ID=321059
Thanks UWE :).
My phone is playing up or the internet so I can't see the posts properly. What have you got for Byte 18?
Borja
Mexico City
C?ID=326888
Hello Iichel
Borja: Yes the Bulb error come when presing the brake, activate the turn right/left indicator , When the key is turned on nothing happens until i activate any function of the lights
Borja
Mexico City
C?ID=326888
Thanks UWE :).
Hello Ounus
I want to confirm if the information sharing with you regarding Byte 18 are the correct one:
Steps:
1.-I go to the "Select control module" option from the main screen
2.- Then I select "09-cent. Elect. " Button
3.- Then Coding "07 button" and a menu pop out with several options i select the one on blue, I dont know if the other ones are different options
https://imgur.com/a/ntACx5K
https://imgur.com/a/qhHdLeC
4.- From the option on blue selected on the previews step i go to the 18 byte as you can check the value on the image
https://imgur.com/a/aM3F97K
Thanks :thumbs:
iichel
C?ID=284912
I'm afraid this cannot be solved, the PQ25 BCM that you have in your jetta has no option to disable the warning light for indicators (i.e. if you install LED).
The warning light for the brakes can be disabled if you set the byte for the light diagnosis in the BCM.
I guess the LED tail lights has only been an option for the PQ35 BCM.
Just to verify, all of the lights in the rear LED cluster work?
Sounds like your best option is to add resistors in parallel with the indicator LEDs - this is what I had to do on my other car (a Citroen C1) to make them flash at the correct rate.
iichel
C?ID=284912
Yes, I agree, but I wouldn't call it a nice solution for an OEM installation.
