Anyone know the meaning of these 5 measured values in attached pic? For example, does "misalignment angle" mean the angle the ECU has measured as an offset error? The 3rd line states "performed adjustment...". Does that mean that was the adjustment made at the factory that the ECU recorded?
I ask because my ACC stopped working. I get the yellow triangle warning symbol in the dash and I get the below error code C110300. I did a rough alignment check of the radar alignment mirror that's bonded to the radar surface (square block unit in center, front, lower grill) and I calculate the mirror to be near perfect normal to the geometric vertical plane of the car and pointing .33 degrees too high to the earth level horizontal plane. I measured the mirror to be near perfect normal to the vertical car plane. I'll post the procedure separately if it makes sense to do so - if my measured offset of .33 deg is correctable and ACC starts back up.
13 Adaptive Cruise Control
System description: ACC BOSCH MQB
Software number: 5Q0907572G
Software version: 0571
Hardware number: 5Q0907572G
Hardware version: H10
ODX name: EV_ACCBOSCHVW416
ODX version: 001005
Long coding: D50087C219FFC428949C8055000026
Trouble codes:
C110300 - Adaptive cruise control sensor misadjusted
static
static
U112300 - Databus error value received
Intermittent
ODX version: 001005
Trouble codes:
static
static
Intermittent
