;SW:5Q0-907-379-K HW:5Q0-907-379-F --- ABS Brakes,,,,
;Component:ESC H31 0371, Coding:01FA6BA13420096E007B020481CB2980D62C9000408194B400430050C009,,,
;EV_Brake1UDSContiMK100ESP,33001,EV_Brake1UDSContiMK100ESP_VW37.rod,,
;Wednesday,15,October,2014,12:15:43:38718
;VCDS Version: Release 12.12.3 (x64) Data version: 20140822,,,,
;VCID: 44A9A242CF0CE13EFF5-8011,,,,
ABS in lower speed range,activated ,,,
Activating and deactivating all development messages,0,,,
Brake booster,4,,,
Brake disk drying,Weak ,,,
Brake prefill,activated ,,,
Brake system vacuum pump,5,,,
Braking torque boost for distance regulation,3,,,
Counter steer support,Strong ,,,
Electronic Stability Program,not activated ,,,
Engine drag torque control,activated ,,,
Hill-start assistant,normal ,,,
Hill-start assistant; increase threshold,6%,,,
Hydraulic brake assistant,normal ,,,
Hydraulic brake booster,8,,,
No display,Standard ,,,
Offroad,0,,,
Overboost in brake system,activated ,,,
Roller test bench mode,Manual activation; possible ,,,
Roller test bench mode; functional,not activated ,,,
Running manufacturer number,activated ,,,
Starting vibration reduction,Strong ,,,
Straight ahead brake stabilization,activated ,,,
Thresholds for brake performance,activated ,,,
Tire pressure monitoring display,2,,,
Tire pressure monitoring display; tire selection,2,,,
Vehicle and trailer stabilization,not activated ,,,
XCP calibration protocol,not activated ,,,
Developer_Function_1,0,,,
