Audi Q7 2017, Recoding, DRL OFF
dcggames
C?ID=137935
Hi all,
Does anybody know how to turn OFF the DRL lights normally fitted in the front bumper?
I suspect that the solution lies in the 09 coding. But... Which bytes/bits? Since there is no coding info available (yet).
Tuesday,02,April,2019,18:12:03:29464
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ4M0HD028302   License Plate:
Mileage: 105705km-65682mi   Repair Order:
Chassis Type  4M-AU73 (8W7)
Scan: 01 02 03 06 08 09 13 15 16 17 19 23 36 3C 42 44 46 47 51 52
          5F 65 69 6C 6D 74 81 8B 8C A5 AC BA BB BC C5 C6 CA CF
VIN: WAUZZZ4M0HD028302   Mileage: 105705km-65682miles
46-Central Conv. -- Status: INTERFACE NOT COMPATIBLE
74-Chassis Control -- Status: INTERFACE NOT COMPATIBLE
C5-Therm. mgt. -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CVZA)       Labels: Redir Fail!
   Part No SW: 4M0 907 401 A    HW: 059 907 309 F
   Component: 3.0TDI MD1    H23 0008
   Revision: C7H23---
   Coding: 2A2A4032056E050334382B00000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0114M0907401A 001016
   ROD: EV_ECM30TDI0114M0907401A.rod
   VCID: 275DE2975E9E0C72BC-8072
   Active accelerator pedal:
   Subsystem 1 - Part No SW: 4M1 723 523     HW: 4M1 723 523
   Component: J1115 - FFP  H17 0007
   Serial number: 123456789ABCDEFGHIJK
   Clutch Control Unit Sub:
   Subsystem 2 - Part No SW: 0D7 142 057 D    HW: 0D7 142 057 D
   Component: J1128 CCU  H04 0031
17156 - Databus
                    Mileage: 105705 km
                    Date: 2019.04.02
                    Time: 17:43:05
                    Coolant temperature: 16 癈
                    Intake air temperature: 18 癈
                    Voltage terminal 30: 12.940 V
                    Engine status: COENG_READY
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 4M0 927 158 M    HW: 0D7 927 156 B
   Component: 0D7 30TDIRdW  H03 1009
   Revision: --H03---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002011
   ROD: EV_TCMALX52011.rod
   VCID: 3E7327F3A104ADBAEF-806A
   Automatic Transmission Fluid Pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component:     V552 ATFP  D.4 0000
   Serial number:             00001057
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M0 907 379 P    HW: 4M0 907 379 P
   Component: ESP9 Premium  H09 0649
   Coding: 2C9830B232A40A9E91A11891187F12A2F6A6DA340C4C5089181848456F655B
   Shop #: WSC 48910 002 1048576
   ASAM Dataset: EV_ESP9BOSCHAU536P 011013
   ROD: EV_ESP9BOSCHAU536P_AU73.rod
   VCID: 4487551BCFE8C76AB9-8010
Address 06: Seat Mem. Pass (J521)       Labels:* None
   Part No SW: 4M1 959 760 B    HW: 4M1 959 760 B
   Component: MEM-BFS       008 0031
   Serial number: 00000226078717
   Coding: 001010000000B0810060010101010000110000171700171700000000000000
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 387F31EB8320938A25-806C
   Valve Block 1 In Passenger Side Front Seat:
   Subsystem 1 - Part No SW: 4M0 907 182     HW: 4M0 907 182
   Component: N477 VB1 BFSv  H06 0030
   Serial number: SJ800103111601100171
   Coding: B72F00
   Part No SW: 4M0 820 043 AE    HW: 4M0 820 043 AE
   Component: Klima Zone 3  H52 0093
   Coding: 661A08094544400D022C0280800000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 68DFA1AB9300C30A75-803C
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000001131476
   Serial number: A3F9C65800PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: Klima Heck  H40 0073
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0266
   Coding: 07501943C13900CD0503571958AF8CF9130331019000000000000000600016810A4502AB22B71A
   ASAM Dataset: EV_BCM1BOSCHAU736 018006
   ROD: EV_BCM1BOSCHAU736_018_AU49.rod
   VCID: 020B9303957C095ACB-8056
   Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 160916  043 0893
   Serial number: 89555300401626000867
   Coding: 1BC7F7
   Serial number: 62394104
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 30 06 2016  00525165
   Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE101081611521465
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 CK    HW: 4M0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: Q00213587
   Electrically Adjustable Steering Column:
   Subsystem 6 - Part No SW: 4M0 907 705 A    HW: 4M0 907 705 A
   Component: J866-EVLS-SG  H03 0080
   Serial number: WA125705000026451315
   Coding: 020100
   Subsystem 7 - Part No SW: 4M0 925 301 H    HW: 4M0 925 301 H
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000004659
   Seat Backrest Fan 1 Front Left:
   Subsystem 8 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V512 LLR1SLvL  H03 0012
   Serial number: L14DG22300367
   Seat Cushion Fan 1 Front Left:
   Subsystem 9 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V514 LLR1SKvL  H03 0012
   Serial number: L14DG22300048
   Seat Backrest Fan 1 Front Right:
   Subsystem 10 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V516 LLR1SLvR  H03 0012
   Serial number: L14DG22201686
   Seat Cushion Fan 1 Front Right:
   Subsystem 11 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V518 LLR1SKvR  H03 0012
   Serial number: L14DG22300046
67735 - Databus
                    Reset counter: 100
                    Mileage: 105705 km
                    Date: 2019.04.02
                    Time: 17:43:07
                    average_Voltage_terminals: 13.00 V
                    Outside air temperature sensor-Resistance: 0.00 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 16.50 癈
                    interior_temperature: 18.00 癈
                    Vehicle speed: 0.00 km/h
                    Terminal control-Terminal 75 status: On
                    Terminal control-Terminal 15 status signal: On
                    Terminal control-Terminal 15 via CAN: On
                    Terminal control-Term 75: qualification: OFF
67737 - Databus
                    Reset counter: 100
                    Mileage: 105705 km
                    Date: 2019.04.02
                    Time: 18:03:04
                    average_Voltage_terminals: 12.90 V
   Part No SW: 4M0 907 561 D    HW: 4M0 907 561
   Component: LRR4          H10 0220
   Coding: 5477E7F358FFEC0A949C80E0
   ASAM Dataset: EV_ACCBOSCHAU736 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 31690CCF605A42C262-8064
1229 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 100
                    Mileage: 105705 km
                    Date: 2019.04.02
                    Time: 17:43:05
                    Control Module temperature: 28 癈
                    Voltage terminal 15: 12.8 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s?
2153 - Databus
                    Reset counter: 100
                    Mileage: 105705 km
                    Date: 2019.04.02
                    Time: 17:43:05
   Part No SW: 4M0 959 655     HW: 4M0 959 655
   Component: Airbag10.44   H70 0086
   Serial number: 003L10031LZ%
   Coding: AAFCF0C00CA0000098F600F3C04C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 78FFF1EBC3A0538AE5-802C
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705D0301Q01481
   Coding: 88001B
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706J0301Q01102
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 061 510 16
   Component: SideSensor_Df  1E2 0887
   Serial number: 3577Y00A31FD753264D9
   Subsystem 4 - Part No SW: -----------    HW: 442 061 510 16
   Component: SideSensor_Pf  1E2 0887
   Serial number: 3587Y00A51FD7531B144
   Subsystem 5 - Part No SW: -----------    HW: 442 0B0 310 16
   Component: SideSensor_Dr  1C7 0148
   Serial number: 3517700A921E1146713$
   Subsystem 6 - Part No SW: -----------    HW: 442 0B3 009 16
   Component: SideSensor_Pr  1C7 0148
   Serial number: 35277009921590A0B1B6
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 109 16
   Component: FrontSensor_D  1C5 014A
   Serial number: 3557500C321ADC74733G
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 109 16
   Component: FrontSensor_P  1C5 014A
   Serial number: 3567500BF218C285205B
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C2 109 16
   Component: PedP_Sensor_C  1C5 014A
   Serial number: 2307500A721438F3437+
   Subsystem 10 - Part No SW: -----------    HW: 442 420 809 16
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U00991FFD131326R
   Subsystem 11 - Part No SW: -----------    HW: 442 420 809 16
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U00B71FB75F3428$
   Central Sensor XY:
   Subsystem 12 - Part No SW: -----------    HW: 410 203 110 16
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O78009D21A82B4323$
1060613 - Databus
                    Reset counter: 100
                    Mileage: 105705 km
                    Date: 2019.04.02
                    Time: 17:43:05
1060614 - Databus
                    Reset counter: 100
                    Mileage: 105705 km
                    Date: 2019.04.02
                    Time: 17:43:05
1060615 - Databus
                    Reset counter: 100
                    Mileage: 105705 km
                    Date: 2019.04.02
                    Time: 17:43:06
1060617 - Databus
                    Reset counter: 100
                    Mileage: 105705 km
                    Date: 2019.04.02
                    Time: 17:43:06
   Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
   Component: Lenks.Modul   H11 0009
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 01099C0F907A1242D2-8054
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
   Part No SW: 4M0 920 794 B    HW: 4M0 920 794 B
   Component: FHybRDW       H15 0302
   Coding: 040401C07C9800080DA6E9701204400000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736_AU49.rod
   VCID: 326B03C3655C79DA1B-8066
          U1014 00 [009] - -
                    Reset counter: 100
                    Mileage: 105705 km
                    Date: 2019.04.02
                    Time: 17:43:05
   Part No SW: 8W7 907 468 D    HW: 8W7 907 468 C
   Component: Gateway       H30 0308
   Revision: 5C000001    Serial number: 0185C289016A26
   Coding: 02010101000206C08C82010000590032DC520007180000000175079E10000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 4C977D3BE7B80F2A71-8018
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20161031171629 01046
   Serial number: 3523561904
Address 23: Brake Booster (J539)       Labels: None
   Part No SW: 4M0 909 059 C    HW: 4M0 909 059
   Component: J539 EBKV H11 0194
   Serial number:   085430010122
   ASAM Dataset: EV_BrakeBoostBOSCHAU736 001001
   ROD: EV_BrakeBoostBOSCHAU736_AU73.rod
   VCID: 346705DB9F4877EA09-8060
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 4M0 909 057 A    HW: 4M0 909 057
   Component: VX70BrakeAssi  H04 0153
   Serial number: 05802861240916212422
   Component: MEM-FS        008 0031
   Serial number: 00000226074333
   Coding: 00181B000000B0810000010101010000110000171700171700000000000000
   ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
   Valve Block 1 In Driver Side Front Seat:
   Component: N475 VB1 FSv  H06 0030
   Serial number: SJ80010311160110018A
   Coding: BF2F00
   Part No SW: 4M0 907 566 B    HW: 4M0 907 566
   Component: MRR1Rear      H13 0230
   Revision: --------
   Coding: 0EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
   Component: TSG FS        009 0052
   Serial number: 0000223132042
   Coding: 005D9B005E000080000130B2
   VCID: 428B5303D5FCC95A8B-8016
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H20 0005
   Serial number: 0000333734
   Coding: B0110101010001
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
Address 46: Central Conv.
Interface not compatible.
   Part No SW: 4M0 035 223 C    HW: 4M0 035 223
   Component: MIB2_amp_PD   H03 0440
   Serial number: 00000000000457
   Coding: 0135960B008AF53AAF0000010001
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 2345F6872AA6E052E0-8076
   Part No SW: 4M1 907 080 B    HW: 4M1 907 080 B
   Component: A73P7828S1000 H02 0018
   Revision: --H02---
   Coding: 01000000000000000000
   ASAM Dataset: EV_DMCM08530214M1907080B 001002
   ROD: EV_DMCM08530214M2907080.rod
   VCID: 2C571DBB47782F2A51-8078
   Part No SW: 4M0 959 792 G    HW: 4M0 959 792 C
   Component: TSG BFS       009 0052
   Serial number: 0000223497033
   Coding: 005D9B005E000080000130B0
   VCID: 41895C0FD0FAD24292-8014
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M1 035 035     HW: 4M1 035 035
   Component: MU-P-LND-EU   033 0917
   Serial number: A641J0GB005440
   Coding: 013796010000000053111102000A00332F001DE5017001009E
   VCID: 62CBB383753CA95AAB-8036
   Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9GJ4035J7
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
   Component: ControlUnit_P  H15 0209
   Serial number: 27101600000000000193
   Component: Gracenote2  --- 1015
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H04 0010
   Serial number: 30000000008201
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 2F6D0AB7766E543274-807A
   Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
   Component: ConWysTrailer H20 0211
   Serial number: 0384670490
   Coding: 0100000202000000
   VCID: 336506C79A4670D210-8066
   Part No SW: 4M0 907 428 E    HW: 4M0 907 428
   Component: Areaview 2    H13 0315
   Serial number: C854607JG004990
   Coding: 02350601BE0FA10008404100
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: 31022644600000
   Coding: 0070
Address 74: Chassis Control
Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
   Part No SW: 4M1 713 041 F    HW: 4M1 713 041 F
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20161026001336
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736_AU73.rod
   VCID: 285FE1AB5380030AB5-807C
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 D    HW: 4M0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU736 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
Address 8C: Hybrid Battery
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
   Component: BVS           H14 0042
   Coding: 040703060000040202202386CD0000B4B0F0C020E280
   ROD: EV_BVSMLBevKOSTAAU736.rod
0646 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 100
                    Mileage: 105705 km
                    Date: 2019.04.02
                    Time: 17:43:05
                    Control Module temperature: 25 癈
                    Voltage terminal 15: 13.10 V
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 B    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H04 0005
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736.rod
   VCID: 306F09CB6B504BCA6D-8064
Address BA: Motor Mounts (J931)       Labels: None
   Part No SW: 4M0 907 145 D    HW: 4M0 907 145 B
   Component: AEMevo        H09 0111
   ASAM Dataset: EV_AEMZFAU736 006012
   ROD: EV_AEMZFAU736_006.rod
   Part No SW: 4M0 959 795 G    HW: 4M0 959 795 C
   Component: TSG HFS       009 0052
   Serial number: 0000223986999
   Coding: 004D990000000080000030A0
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   Component: TSG HBFS      009 0052
   Serial number: 0000223986998
   ROD: EV_DCU2RearPasseMAXHCONT.rod
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4M0 965 429 D    HW: 4M0 965 429 B
   Component: TME-Max       H04 0021
   Serial number: 0027841
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 001023
   ROD: EV_ThermContrVISAU49X_VW37.rod
   Subsystem 1 - Part No SW: 4M0 959 603 B    HW: 4M0 959 603 B
   Component: G395 pT-Sens1  H10 0009
   Subsystem 2 - Part No SW: 12E 963 231 G    HW: 12E 963 231 G
   Component: J848 HV-PTC  H09 0208
   Serial number: LM161623003810000271
   Subsystem 3 - Part No SW: 4M0 816 797 A    HW: 4M0 816 797 A
   Component: J842 EKK es33  H02 0012
   Serial number: 00000000016102600130
   Refrigerant Pressure And Temperature Sender 2:
   Subsystem 4 - Part No SW: 4M0 959 603 B    HW: 4M0 959 603 B
   Component: G826 pT-Sens2  H10 0009
   Refrigerant Pressure And Temperature Sender 3:
   Subsystem 5 - Part No SW: 4M0 959 603 B    HW: 4M0 959 603 B
   Component: G827 pT-Sens3  H10 0009
   Refrigerant Expansion Valve 1:
   Subsystem 6 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N636 EV1_KaMi  H12 0102
   Serial number: 00000000000150142410
   Refrigerant Shut Off Valve 2:
   Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N640 AV2_KaMi  H12 0102
   Serial number: 00000000000130143082
   Refrigerant Shut Off Valve 3:
   Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 00000000000130143174
   Refrigerant Shut Off Valve 4:
   Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000130143092
   Refrigerant Shut Off Valve 5:
   Subsystem 10 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000130143170
Address C6: Batt. Chrg. (AX4)       Labels:* 5QE-915-681.clb
   Part No SW: 5QE 915 681 G    HW: 5QE 915 681 G
   Component: OBC Delta-ES  H55 0721
   Coding: 11508B207000
   ASAM Dataset: EV_OBCTwoPhaseDT2AU736 006011
   ROD: EV_OBCTwoPhaseDT2AU736.rod
   VCID: 50AF694B0B902BCA0D-8004
Address CA: Sunroof
There are lots of DRL-related bits in the "experimental" coding that you'd have access to if you were using an interface that's fully compatible with the vehicle.
Setting Byte 2, bit 1 may give you options in your MMI.
Unsetting Byte 2, bit 0 may kill off the DRLs entirely.
I thought that DRLs were a legal requirement in the EU on all cars introduced after 2014?
dcggames
C?ID=137935
Thanks Uwe. I will give it a try. Fortunately I should be updating my interface soon.
dcggames
C?ID=137935
It should be just the DRLs originally fitted to the front bumper. I haven't seen the car yet myself, but if I understand the newly fitted bumper is part of a original ABT package for this car.
