Passat B8 2016 retrofit
VAGParts
C?ID=61241
Hi.
I hope it is okay I start a new thread as I now have more problems after retrofitting the last parts.
I can't figure out and load the autoscan right.
I've retrofitted..:
Blind spot
PLA 3.0
Area view
TPMS
A5 camera
LED High front
AID
I think I've got the Blind spot coded but don't know until next week when I get the CP removed
But I can't figure out why I have "Local databus" error in A5 camera
Camera gets calibrated Friday.
When I drive forward and get close to something the p-sensor turns on but they do not appear on the screen.
I need to turn off the p-sensor on the button and turn it on again for it to appear on the screen.
Every time I start the car it makes the sign assist error in the cluster. I hope it will be resolved Friday when calibrated.
It shows the sign in the cluster but only the same as in the navi and it does not read the right boards I pass by
Wednesday,06,November,2019,16:43:38:52337
Workshop Code: 970 22339 012345
VIN: WVWZZZ3CZGExxxxxx   License Plate:
Mileage: 89856km-55833mi   Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 52 55 5F
          65 69 6C 6D A5 BB BC CF
VIN: WVWZZZ3CZGExxxxxx   Mileage: 89856km-55833miles
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
   Component: R4 2.0l TDI   H23 2011
   Revision: B4H23---
   Coding: 011D003A047405083000
   Shop #: WSC 22339 970 00001
   ASAM Dataset: EV_ECM20TDI01104L906026FN 004002
   ROD: EV_ECM20TDI01104L906026FM_004_VW48.rod
   VCID: 7BB621D8F2291197F2-802E
   Part No SW: 0D9 300 041 J    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4906
   Revision: 06253104    Serial number: TFK01602241041
   Shop #: WSC 05311 115 00061
   ROD: EV_TCMDQ250021.rod
   VCID: 1F0E35480671ADB7BE-804A
   Revision: 00000000    Serial number: 61046000000938
   Coding: 0FEC6A8F34220B74077D060841C549F0562CD0E0608292F11862F078C209
   VCID: 7AB824DCFD13289FE9-802E
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0710
   Revision: 00026000    Serial number: 0401603713
   Coding: 000F0F0F03
   Shop #: WSC 05311 115 00236
   VCID: 393AFBD0B895E387A0-806C
   Part No SW: 5G0 907 044 BH    HW: 5G0 907 044 BH
   Component: Climatronic   H04 1202
   Revision: 00001K10
   Coding: 12020104204101011015500000101802
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_ACClimaBHBVW37X 005137
   VCID: 6E90188CB15B743F45-803A
   Air quality sensor:
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Component: BCM PQ37BOSCH 028 0163
   Revision: --------    Serial number: 8658160416012I
   Coding: 00071D46C2C102FF53C44004001457081C80000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
   ROD: EV_BCMBOSCH_015.rod
   VCID: 034659388AD96957BA-8056
   Component: WWS    160326  042 0607
   Serial number:         160408192827
   Subsystem 2 - Part No SW: 8UD 955 559 B    HW: 8UD 955 559 B  Labels: 8U0-955-559.CLB
   Serial number: 90070925
   Coding: 00006E
   Serial number: 20 01 2016  10000219
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Serial number: 000308417618081
   Coding: 0A71265A51
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 50ECA6740B2F42CF77-8004
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Coding: 3200670B51FFC428949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3424CAE49FF71EEF73-8060
   Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003STP7HZFH4
   Coding: 88CCC000008000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F4ED5C8E6310DB7DE-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 204 16
   Serial number: 3576U000000426303A1.
   Subsystem 2 - Part No SW: -----------    HW: 454 000 204 16
   Serial number: 3586U000000A5B5D4A1P
   Subsystem 3 - Part No SW: -----------    HW: 454 802 503 16
   Serial number: 3516RE6FDFF090000000
   Subsystem 4 - Part No SW: -----------    HW: 454 802 503 16
   Serial number: 3526RB1E4FF09000000Q
   Subsystem 5 - Part No SW: -----------    HW: 454 802 803 16
   Serial number: 3556VB451470A0000006
   Part No SW: 3Q0 953 521 DJ    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20160303501287
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 3G0 920 791 A    HW: 3G0 920 791 A
   Component: KOMBI         412 1460
   Coding: 07A509986F8C000C01887F0F3001000000000000
   VCID: 271E2DA85E216577C6-8072
   Part No SW: 5Q0 963 272 E    HW: 5Q0 963 272 E
   Component: STH-MQB       007 0072
   Coding: 9309
   Shop #: WSC 00015 115 00001
   VCID: 383CFED4839FFA8F5F-806C
   Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001374380
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 10041610801934
   Coding: 0B0300345F017300FB0002581C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 79BA3BD0F8152387E0-802C
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0040
   Serial number: 29160000731660016146
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 0448649703
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: WECHSELRICHTE  H55 0033
   Serial number: 0226931
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Serial number: 16000073540012
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71AA03F0A0656BC758-8024
   Part No SW: 3Q0 907 566 B    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0230
   Revision: --------
   Coding: 14C002
   VCID: 373EFDE88E81F5F756-8062
267010 - Databus
          [FAULT_SLAVE]
                    Reset counter: 243
                    Mileage: 89856 km
                    Date: 2019.11.06
                    Time: 16:39:18
                    Control Module temperature: 31 °C
                    Voltage terminal 30: Measured value not available
                    Vehicle speed: 0.00 km/h
                    Terminal 15 status: Measured value not available
                    Voltage terminal 15: 11.60 V
          U1101 00 [009] - Active
          [Component protection is active]
                    Reset counter: 243
                    Mileage: 89856 km
                    Date: 2019.11.06
                    Time: 16:39:18
                    Voltage terminal 15: 11.70 V
   Serial number: 040416ED414997
   Coding: 001F0B20DC00020000001000
   VCID: 43C69938CA59A957FA-8016
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000735503
   Coding: 01010011005000
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
   VCID: 3D32EFC0ACBDDFA78C-8068
   Serial number: 060416ED60262A
   Coding: 001F0120DC00020000001000
   VCID: 42C89C3CD543A05FF1-8016
   Component: AFS-ECU       H01 0120
   Coding: 039A00001F210200
   VCID: 3FCE95C8A6B1CDB79E-806A
   Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 0001
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 0001
   Coding: E02400
   Coding: E02400
   Component: LeiMo rechts  H02 X003
   Coding: E02400
   Part No SW: 3G0 035 043 J    HW: 3G0 035 043
   Component: MU-H-N-EU     H50 0343
   Serial number: A683D0GB030629
   Coding: 02840201FF00000051110001000808031F0106E441200000DF
   VCID: 230639B82A1989579A-8076
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL00H4C
   Subsystem 2 - Part No SW: V03 959 806 FM    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Component: Gracenote2  --- 1012
          U1111 00 [008] - -
                    Reset counter: 28
                    Mileage: 89856 km
                    Date: 2019.11.06
                    Time: 16:39:20
                    Voltage terminal 30: 12.0 V
                    BAP-BAP_Function_ID: 01
   Serial number: 30000000199487
   ROD: EV_RDKBERU30_006_VW48.rod
8398082 - Tire Pressure Sensor(s)
          C111A 31 [009] - No Signal
                    Reset counter: 201
                    Mileage: 88074 km
                    Date: 2019.10.19
                    Time: 03:02:17
                    Vehicle speed: 58 km/h
                    Outside air temperature: 9.5 °C
                    Reception level antenna 1: 620 mV
                    Offset level antenna 1: 270 mV
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0203
   Revision: 8A001003    Serial number: 0400569602
   Coding: 0100000202000000
   VCID: 3B36E1D8B2A9D197B2-806E
   Part No SW: 5Q0 907 556     HW: 5Q0 907 556
   Component: Areaview 2    H11 0329
   Serial number: C854706JG000690
   Coding: 01840201E70F200000204814
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 003013
   ROD: EV_CamSysRVAV2ARCE2MQBAB_003_VW37.rod
   VCID: 76A030ECC90B4CFF8D-8022
9616786 - Surroundings Camera Front
          B127C F0 [009] - Calibration Failed
                    Reset counter: 243
                    Mileage: 89856 km
                    Date: 2019.11.06
                    Time: 16:39:18
9616787 - Surroundings Camera Rear
          B127D F0 [009] - Calibration Failed
                    Reset counter: 243
                    Mileage: 89856 km
                    Date: 2019.11.06
                    Time: 16:39:18
10489856 - No Basic Setting
          B2010 00 [009] - -
          [RearView system not calibrated]
                    Reset counter: 243
                    Mileage: 89856 km
                    Date: 2019.11.06
                    Time: 16:39:18
9616994 - Front Surroundings Camera
          B127C 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 243
                    Mileage: 89856 km
                    Date: 2019.11.06
                    Time: 16:39:18
9617993 - Rear Surroundings Camera
          B127D 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 243
                    Mileage: 89856 km
                    Date: 2019.11.06
                    Time: 16:39:18
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30613377500000
   Coding: 0280
   Component: MQB_B_MFK     H09 0272
   Serial number: 04091815P12091
   Coding: 0004080200000401002423478040A10094000E200020
   VCID: 3C34E2C4B7A7D6AFBB-8068
0660 - No Basic Setting
          B2010 00 [009] - -
          [Initial_calibration_missing]
                    Reset counter: 243
                    Mileage: 89856 km
                    Date: 2019.11.06
                    Time: 16:39:18
                    Control Module temperature: 28 °C
                    Outside air temperature: 2.5 °C
                    System run time: 224.9 s
                    Voltage terminal 15: 11.6 V
                    mid: 00 1E
                    Status of camera: System malfunction
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1122597 - Local Data Bus
          U1169 00 [009] - Missing Message
                    Reset counter: 243
                    Mileage: 89856 km
                    Date: 2019.11.06
                    Time: 16:39:18
                    System run time: 225.3 s
                    mid: 01 43
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Serial number: 090316EC817976
   Coding: 000E01200100020000001000
   VCID: 45C28720C46D9767D4-8010
   Serial number: 090316EC817797
   Part No SW: 3Q0 907 590 B    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
                    Reset counter: 243
                    Mileage: 89856 km
                    Date: 2019.11.06
                    Time: 16:39:18
End----(Elapsed Time: 02:31, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
nirvananils
C?ID=289109
First you have to remove Component Protection in all ECU. Then you have to search in ECU 5F in Adaptions for "0x07" to activate TPMS in Menu. Also you have to do all Basic Setting in the new ECU. After that please give us a new Scan and we have to look which things you have to do
siLc
Tallinn, Estonia
C?ID=330192
Did you run the seperate CAN circuit from A5 camera to ACC radar and activated the appropriate option in ACC radar coding? Be advised, when you change the coding, the local databus fault would be gone but ACC will cease to function. ACC will work again once camera is calibrated.
VAGParts
C?ID=61241
Yes there are CAN wires for radar fitted. Orange / white - orange / brown and I have coded the camera in 13-Auto Dist. Reg
MasterTommy
Amsterdam
C?ID=295586
TPMS module needs a dataset if its a new module.
siLc
Tallinn, Estonia
C?ID=330192
If the CAN interface is coded in both A5 and 13 and the A5 fault still remains and ACC is still working, then either there is something wrong with the coding or the CAN connection (CAN-H/CAN-L wires mixed up?). I don't have any coding samples available at the moment to verify if your 13 coding is correct.
VAGParts
C?ID=61241
I've come a little further with my project.
I'm having problems with my TPMS High. Sometimes it works and other times it doesn't, inside discover pro it writes "starter" and then nothing happens anymore.
In AID, it switches between displaying tire pressure and "Tire pressure disabled"
After I got the error in 03-ABS it does not work at all.
The car had TPMS Low from the factory
Wednesday,27,November,2019,22:21:01:52337
VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
Mileage: 92672km-57583mi   Repair Order: 271119
VIN: WVWZZZ3CZGExxxxxx   Mileage: 92672km-57583miles
   Revision: B4H23---
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 79
                    Date: 2019.11.26
                    Time: 14:11:04
   Coding: 000F0F0F03
   Revision: 00001K10
   Air quality sensor:
   Coding: 00006E
10506 - Bulb for Left Tail Light
          B12BE 15 [008] - Open or Short to Plus
                    Reset counter: 83
                    Mileage: 92586 km
                    Date: 2019.11.26
                    Time: 16:33:52
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Reset counter: 84
                    Mileage: 92652 km
                    Date: 2019.11.27
                    Time: 16:35:58
1049604 - Lamp 1 for Contour Lighting of Door; Front Left
          U1176 00 [009] - No Communications
          [Leuchte 1 für Türkonturbeleuchtung vorn linkskeine Kommunikation]
                    Reset counter: 39
                    Mileage: 92586 km
                    Date: 2019.11.26
                    Time: 14:11:07
1050628 - Lamp 1 for Contour Lighting of Door; Front Right
          U1178 00 [009] - No Communications
          [Leuchte 1 für Türkonturbeleuchtung vorn rechtskeine Kommunikation]
                    Reset counter: 39
                    Mileage: 92586 km
                    Date: 2019.11.26
                    Time: 14:11:07
1051652 - Lamp 1 for Contour Lighting of Door; Rear Left
          U117A 00 [009] - No Communications
          [Leuchte 1 für Türkonturbeleuchtung hinten linkskeine Kommunikation]
                    Reset counter: 39
                    Mileage: 92586 km
                    Date: 2019.11.26
                    Time: 14:11:07
1052676 - Lamp 1 for Contour Lighting of Door; Rear Right
          U117C 00 [009] - No Communications
          [Leuchte 1 für Türkonturbeleuchtung hinten rechtskeine Kommunikation]
                    Reset counter: 39
                    Mileage: 92586 km
                    Date: 2019.11.26
                    Time: 14:11:07
   Coding: 0A71267A51
   Coding: 3200674B51FFC428949C804D
   Coding: 0C10
   Coding: 9309
   Coding: 2DFFFF
   Analog clock:
   Revision: --------
   Coding: 14C002
   Coding: E02400
   Coding: E02400
   Coding: E02400
   Coding: E02400
8389634 - TPMS Display
          C1239 F0 [008] - Position Determination Not Possible
                    Reset counter: 84
                    Mileage: 92621 km
                    Date: 2019.11.27
                    Time: 10:01:44
                    Outside air temperature: 8.0 °C
                    Reception level antenna 1: 670 mV
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG034284
   Coding: 01840201E30F20000000480C
   Shop #: WSC 00070 000 00000
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
          B2010 00 [009] - -
                    Fault Frequency: 10
                    Reset counter: 44
                    Mileage: 92586 km
                    Date: 2019.11.26
                    Time: 21:21:05
                    Reset counter: 39
                    Mileage: 92586 km
                    Date: 2019.11.26
                    Time: 21:21:05
                    Reset counter: 39
                    Mileage: 92586 km
                    Date: 2019.11.26
                    Time: 21:21:05
9618000 - Left Surroundings Camera
          B127E 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 39
                    Mileage: 92586 km
                    Date: 2019.11.26
                    Time: 21:21:05
9618001 - Right Surroundings Camera
          B127F 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 39
                    Mileage: 92586 km
                    Date: 2019.11.26
                    Time: 21:21:05
   Coding: 0280
   Coding: 000408020000040100242347C040A90094000E200020
   Shop #: WSC 22339 970 12345
   Revision: --------
   Coding: 14C002
End----------(Elapsed Time: 02:27, VBatt start/end: 12.2V/12.1V)-----------
