;SW:8W1-907-064-AC HW:8W1-907-064-C --- Central Conv.
;Component:BCM2 MLBevo 044 0529, Coding:01350000402010E0630980000C00080011024010804006502F0400004504803F001F0001030010
;EV_BCM2HellaAU736,017017,EV_BCM2HellaAU736_017_AU49.rod
;Tuesday,15,October,2019,13:14:44:04807
;VCDS Version: Release 19.6.2 (x64) Data version: 20190930 DS308.0
IDE00001-MAS10843-Production mode-Deactivate interior lighting,not active ,3
IDE00001-MAS10851-Production mode-Deactivate engine start,not active ,3
IDE00001-MAS10853-Production mode-Deactivate sensor-controlled rear lid opening,not active ,3
IDE00001-MAS10854-Production mode-Deactivate central locking: function lock,not active ,3
IDE00001-MAS10855-Production mode-Deactivate ignition switch-off when vehicle has been left,not active ,3
IDE00001-MAS12009-Production mode-Deactivate lighting,not active ,3
IDE00001-MAS12010-Production mode-Deactivate automatic unlocking,not active ,3
IDE00001-MAS17290-Production mode-Suppress further signal sources for “Terminal 15 on”,not active ,3
IDE00820-Activating and deactivating all development messages,00 ,1
IDE01464-MAS01167-Rear window defogger-Actuation time,600 s,2
IDE01464-MAS01186-Rear window defogger-Shut-off temperature,35.0 °C,2
IDE04923-MAS08465-Turn signal control-Freeway flashing: flashing cycles,5 ,4
IDE04923-MAS08466-Turn signal control-Confirmation flashing unlocking central locking:flashing cycles,2 ,4
IDE04923-MAS08467-Turn signal control-Confirmation flashing locking central locking: flashing cycles,1 ,4
IDE04923-MAS10114-Turn signal control-Turn signal with relocking,On ,4
IDE04923-MAS10115-Turn signal control-Anti-theft blinkers by inter. door handle activ.,On ,4
IDE04923-MAS13291-Turn signal control-Motorway flashing cancel by counter tap,On ,4
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
IDE07279-Anti-theft warning system: monitoring diagnostics connection,On ,1
IDE07392-Terminal 15,Default ,1
IDE08221-MAS02444-Personalization settings key 1-Central locking,global opening ,3
IDE08221-MAS06456-Personalization settings key 1-Autolock,On ,3
IDE08221-MAS06457-Personalization settings key 1-autounlock,On ,3
IDE08221-MAS06696-Personalization settings key 1-Comfort opening sunroof,OFF ,3
IDE08221-MAS06697-Personalization settings key 1-Acoustic acknowledge signal,On ,3
IDE08221-MAS06698-Personalization settings key 1-Freeway flashing,On ,3
IDE08221-MAS06740-Personalization settings key 1-Release button in rear lid handle locked,OFF ,3
IDE08221-MAS06756-Personalization settings key 1-Window shade automatic,OFF ,3
IDE08221-MAS06880-Personalization settings key 1-Mirror fold-in (Audi),On ,3
IDE08221-MAS10221-Personalization settings key 1-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE08221-MAS10228-Personalization settings key 1-Comfort opening window: driver side,On ,3
IDE08221-MAS10229-Personalization settings key 1-Comfort opening window: frt. pass. side,On ,3
IDE08221-MAS10230-Personalization settings key 1-Comfort opening rear window: driver side,On ,3
IDE08221-MAS10231-Personalization settings key 1-Comfort opening rear window: frt. pass. side,On ,3
IDE08222-MAS02444-Personalization settings key 2-Central locking,global opening ,3
IDE08222-MAS06456-Personalization settings key 2-Autolock,On ,3
IDE08222-MAS06457-Personalization settings key 2-autounlock,On ,3
IDE08222-MAS06696-Personalization settings key 2-Comfort opening sunroof,OFF ,3
IDE08222-MAS06697-Personalization settings key 2-Acoustic acknowledge signal,On ,3
IDE08222-MAS06698-Personalization settings key 2-Freeway flashing,On ,3
IDE08222-MAS06740-Personalization settings key 2-Release button in rear lid handle locked,OFF ,3
IDE08222-MAS06756-Personalization settings key 2-Window shade automatic,OFF ,3
IDE08222-MAS06880-Personalization settings key 2-Mirror fold-in (Audi),On ,3
IDE08222-MAS10221-Personalization settings key 2-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE08222-MAS10228-Personalization settings key 2-Comfort opening window: driver side,OFF ,3
IDE08222-MAS10229-Personalization settings key 2-Comfort opening window: frt. pass. side,OFF ,3
IDE08222-MAS10230-Personalization settings key 2-Comfort opening rear window: driver side,OFF ,3
IDE08222-MAS10231-Personalization settings key 2-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08223-MAS02444-Personalization settings key 3-Central locking,global opening ,3
IDE08223-MAS06456-Personalization settings key 3-Autolock,On ,3
IDE08223-MAS06457-Personalization settings key 3-autounlock,On ,3
IDE08223-MAS06696-Personalization settings key 3-Comfort opening sunroof,OFF ,3
IDE08223-MAS06697-Personalization settings key 3-Acoustic acknowledge signal,On ,3
IDE08223-MAS06698-Personalization settings key 3-Freeway flashing,On ,3
IDE08223-MAS06740-Personalization settings key 3-Release button in rear lid handle locked,OFF ,3
IDE08223-MAS06756-Personalization settings key 3-Window shade automatic,OFF ,3
IDE08223-MAS06880-Personalization settings key 3-Mirror fold-in (Audi),OFF ,3
IDE08223-MAS10221-Personalization settings key 3-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE08223-MAS10228-Personalization settings key 3-Comfort opening window: driver side,OFF ,3
IDE08223-MAS10229-Personalization settings key 3-Comfort opening window: frt. pass. side,OFF ,3
IDE08223-MAS10230-Personalization settings key 3-Comfort opening rear window: driver side,OFF ,3
IDE08223-MAS10231-Personalization settings key 3-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08224-MAS02444-Personalization settings key 4-Central locking,global opening ,3
IDE08224-MAS06456-Personalization settings key 4-Autolock,On ,3
IDE08224-MAS06457-Personalization settings key 4-autounlock,On ,3
IDE08224-MAS06696-Personalization settings key 4-Comfort opening sunroof,OFF ,3
IDE08224-MAS06697-Personalization settings key 4-Acoustic acknowledge signal,On ,3
IDE08224-MAS06698-Personalization settings key 4-Freeway flashing,On ,3
IDE08224-MAS06740-Personalization settings key 4-Release button in rear lid handle locked,OFF ,3
IDE08224-MAS06756-Personalization settings key 4-Window shade automatic,OFF ,3
IDE08224-MAS06880-Personalization settings key 4-Mirror fold-in (Audi),OFF ,3
IDE08224-MAS10221-Personalization settings key 4-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE08224-MAS10228-Personalization settings key 4-Comfort opening window: driver side,OFF ,3
IDE08224-MAS10229-Personalization settings key 4-Comfort opening window: frt. pass. side,OFF ,3
IDE08224-MAS10230-Personalization settings key 4-Comfort opening rear window: driver side,OFF ,3
IDE08224-MAS10231-Personalization settings key 4-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08225-MAS02444-Personalization settings vehicle-Central locking,global opening ,3
IDE08225-MAS06456-Personalization settings vehicle-Autolock,On ,3
IDE08225-MAS06457-Personalization settings vehicle-autounlock,On ,3
IDE08225-MAS06696-Personalization settings vehicle-Comfort opening sunroof,OFF ,3
IDE08225-MAS06697-Personalization settings vehicle-Acoustic acknowledge signal,On ,3
IDE08225-MAS06698-Personalization settings vehicle-Freeway flashing,On ,3
IDE08225-MAS06740-Personalization settings vehicle-Release button in rear lid handle locked,OFF ,3
IDE08225-MAS06756-Personalization settings vehicle-Window shade automatic,OFF ,3
IDE08225-MAS06880-Personalization settings vehicle-Mirror fold-in (Audi),OFF ,3
IDE08225-MAS10221-Personalization settings vehicle-Rear lid unlocking through rear lid opening sensors,On ,3
IDE08225-MAS10228-Personalization settings vehicle-Comfort opening window: driver side,OFF ,3
IDE08225-MAS10229-Personalization settings vehicle-Comfort opening window: frt. pass. side,OFF ,3
IDE08225-MAS10230-Personalization settings vehicle-Comfort opening rear window: driver side,OFF ,3
IDE08225-MAS10231-Personalization settings vehicle-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08225-MAS16238-Personalization settings vehicle-Keyless access authorization,On ,3
IDE08225-MAS20619-Personalization settings vehicle-Keyless access authorization: automatic opening,not active ,3
IDE08226-Use of personalization settings,Key ,1
IDE08398-Delay time alarm triggering,0 s,1
IDE08399-Delay time crash unlocking,2.5 s,1
IDE08400-Betätigungszeit Öffnen der Heckklappe mit Funkfernbedienung,800 ms,1
IDE09735-CU tailgate opener: sensor 1: threshold value 1,15 ,1
IDE09736-CU tailgate opener: sensor 1: threshold value 2,10 ,1
IDE09737-CU tailgate opener: sensor 1: threshold value 3,10 ,1
IDE09738-CU tailgate opener: sensor 1: threshold value 4,10 ,1
IDE09739-CU tailgate opener: sensor 1: threshold value 5,10 ,1
IDE09740-CU tailgate opener: sensor 2: threshold value 1,02 ,1
IDE09741-CU tailgate opener: sensor 2: threshold value 2,1F ,1
IDE09742-CU tailgate opener: sensor 2: threshold value 3,02 ,1
IDE09743-CU tailgate opener: sensor 2: threshold value 4,1F ,1
IDE09744-CU tailgate opener: sensor 2: threshold value 5,E0 ,1
IDE09745-CU tailgate opener: sensor 1: timer value 1,AA ,1
IDE09746-CU tailgate opener: sensor 1: timer value 2,00 ,1
IDE09747-CU tailgate opener: sensor 1: timer value 3,09 ,1
IDE09748-CU tailgate opener: sensor 1: timer value 4,E1 ,1
IDE09749-CU tailgate opener: sensor 1: timer value 5,00 ,1
IDE09750-CU tailgate opener: sensor 2: timer value 1,0B ,1
IDE09751-CU tailgate opener: sensor 2: timer value 2,AA ,1
IDE09752-CU tailgate opener: sensor 2: timer value 3,9E ,1
IDE09753-CU tailgate opener: sensor 2: timer value 4,CC ,1
IDE09754-CU tailgate opener: sensor 2: timer value 5,95 ,1
IDE09755-CU tailgate opener: sensor 1: burst length,10 ,1
IDE09756-CU tailgate opener: sensor 1: active screening,10 ,1
IDE09757-CU tailgate opener: sensor 2: burst length,02 ,1
IDE09758-CU tailgate opener: sensor 2: active screening,1F ,1
IDE09759-CU for tailgate opener: reset all counters,E0 ,1
IDE09760-CU for tailgate opener: check sum,AA ,1
IDE09829-CU tailgate opener: foot gestic recognition: timer value 1,02 ,1
IDE09830-CU tailgate opener: foot gestic recognition: timer value 2,1F ,1
IDE09831-CU for tailgate opener: play protection increments,06 ,1
IDE09832-CU for tailgate opener: play protection decrements,19 ,1
IDE09833-CU for tailgate opener: play protection threshold active,FF ,1
IDE09834-CU for tailgate opener: play protection threshold inactive,05 ,1
IDE09835-CU for tailgate opener: play protection decrement interval,3C ,1
IDE09836-CU tailgate opener: sensor 1: control parameter,10 ,1
IDE09837-CU tailgate opener: sensor 2: control parameter,10 ,1
IDE09838-CU tailgate opener: foot gestic recognition: evaluation,00 ,1
IDE09839-CU for tailgate opener: parameter set version,00 45 ,2
IDE10086-IDE02262-Personal settings of key 1: Part 2-synchronous mirror adjustment,OFF ,1
IDE10086-IDE03946-Personal settings of key 1: Part 2-Mirror dimming,OFF ,1
IDE10086-MAS05213-Personal settings of key 1: Part 2-Mirror heater,OFF ,1
IDE10086-MAS06870-Personal settings of key 1: Part 2-Mirror lowering in reverse travel,OFF ,1
IDE10086-MAS06881-Personal settings of key 1: Part 2-Mirror fold-in (VW),OFF ,1
IDE10087-IDE02262-Personal settings of key 2: Part 2-synchronous mirror adjustment,OFF ,1
IDE10087-IDE03946-Personal settings of key 2: Part 2-Mirror dimming,OFF ,1
IDE10087-MAS05213-Personal settings of key 2: Part 2-Mirror heater,OFF ,1
IDE10087-MAS06870-Personal settings of key 2: Part 2-Mirror lowering in reverse travel,OFF ,1
IDE10087-MAS06881-Personal settings of key 2: Part 2-Mirror fold-in (VW),OFF ,1
IDE10088-IDE02262-Personal settings of key 3: Part 2-synchronous mirror adjustment,OFF ,1
IDE10088-IDE03946-Personal settings of key 3: Part 2-Mirror dimming,OFF ,1
IDE10088-MAS05213-Personal settings of key 3: Part 2-Mirror heater,OFF ,1
IDE10088-MAS06870-Personal settings of key 3: Part 2-Mirror lowering in reverse travel,OFF ,1
IDE10088-MAS06881-Personal settings of key 3: Part 2-Mirror fold-in (VW),OFF ,1
IDE10089-IDE02262-Personal settings of key 4: Part 2-synchronous mirror adjustment,OFF ,1
IDE10089-IDE03946-Personal settings of key 4: Part 2-Mirror dimming,OFF ,1
IDE10089-MAS05213-Personal settings of key 4: Part 2-Mirror heater,OFF ,1
IDE10089-MAS06870-Personal settings of key 4: Part 2-Mirror lowering in reverse travel,OFF ,1
IDE10089-MAS06881-Personal settings of key 4: Part 2-Mirror fold-in (VW),OFF ,1
IDE10090-IDE02262-Personal settings of vehicle: Part 2-synchronous mirror adjustment,OFF ,1
IDE10090-IDE03946-Personal settings of vehicle: Part 2-Mirror dimming,OFF ,1
IDE10090-MAS05213-Personal settings of vehicle: Part 2-Mirror heater,OFF ,1
IDE10090-MAS06870-Personal settings of vehicle: Part 2-Mirror lowering in reverse travel,OFF ,1
IDE10090-MAS06881-Personal settings of vehicle: Part 2-Mirror fold-in (VW),OFF ,1
IDE10283-Key identification: transponder ID,FF FF FF FF ,4
IDE10318-Sunshade activation,cannot be activated ,1
IDE10347-Trip distance challenge,00 00 00 00 00 00 00 00 ,8
IDE10836-Enable code for vehicle positioning system,18477 ,2
IDE10858-Number of simultaneously adapting key,0 ,1
IDE10913-MAS10979-Setting the key data-Start page,00 00 ,3
IDE10913-MAS10980-Setting the key data-No. of pages,00 ,3
IDE10913-MAS11635-Setting the key data-Data security,encrypted ,3
IDE11476-Ignition lock: variant,Audi ,1
IDE11487-Trunk emergency release,OFF ,1
IDE11700-Parameter group 1,FF FF FF 80 00 00 00 00 00 00 0F 32 0A 05 80 0F 19 50 46 46 00 0A 02 14 3C 01 00 14 00 02 05 00 0A 14 B4 14 01 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 39 DE ,255
IDE11701-Parameter group 2,FF FF FF FF F0 00 00 00 00 00 00 00 1E 01 1E 0A 00 0A 03 00 00 00 1E 0A 3C 3C 01 04 00 01 03 00 00 00 01 50 96 01 01 02 FF 00 FF 00 00 5A 14 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1A E6 ,255
IDE11702-Parameter group 3,FF FF FF C0 00 00 00 00 00 00 0A 0C 14 16 14 16 02 00 0A 14 16 14 1E 14 3C 14 1E 0A FF FF FF 05 28 3C 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1C 1B ,255
IDE11703-Parameter group 4,E0 00 00 00 00 00 00 00 00 00 7F FF 83 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C AA ,255
IDE11704-Parameter group 5,E0 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B3 CA ,255
IDE11705-Parameter group 6,FF FF C0 00 00 00 00 00 00 00 F5 96 02 0A 64 02 01 00 96 06 96 06 96 06 96 06 14 00 0F 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 44 ,255
IDE11706-Parameter group 7,FF FF FF FF FF E0 00 00 00 00 02 0A 32 3C 18 14 05 0A 1E 01 02 5A 14 14 0A 00 00 06 05 0F 14 00 5A 02 32 14 05 05 05 05 05 05 05 01 00 32 0A 05 1E 06 14 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 2B ,255
IDE11707-Parameter group 8,FF FF FF FE 00 00 00 00 00 00 01 00 00 1E 00 05 32 00 00 01 07 00 07 00 00 02 01 01 04 00 14 1E 0A 02 0A 02 1E 64 1E 0A 3C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 0B ,255
IDE11708-Parameter group 9,80 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F3 FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B6 9E ,255
IDE11709-Parameter group 10,FF E0 00 00 00 00 00 00 00 00 00 0A 00 0A 00 1C 00 3C 00 32 0A 05 05 32 05 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 92 E4 ,255
IDE11798-Speed-dependent activation of the back window heater,activated ,1
IDE11935-MAS13456-Personalization-Automatic key assignment,activated ,1
IDE11935-MAS13457-Personalization-Status of personalization,activated ,1
IDE12303-MAS14243-Separation monitoring radio key to rear lid-Minimum opening angle of the rear lid for activation,3 %,6
IDE12303-MAS14244-Separation monitoring radio key to rear lid-Minimum opening angle of the rear lid to reverse,224 %,6
IDE12303-MAS14245-Separation monitoring radio key to rear lid-Lock vehicle after closing,OFF ,6
IDE12303-MAS14246-Separation monitoring radio key to rear lid-Monitoring time for rear lid restart,0 %,6
IDE12303-MAS14247-Separation monitoring radio key to rear lid-Monitoring time for rear lid closing,0 %,6
IDE12465-Rear lid opener control module: response in trailer mode,not activated ,2
IDE12481-MAS06700-Horn and flasher via smartphone app-Speed threshold,0 km/h,5
IDE12481-MAS14561-Horn and flasher via smartphone app-Division factor of horn frequency,0 ,5
IDE12481-MAS14562-Horn and flasher via smartphone app-Maximum execution duration,45 s,5
IDE12548-MAS14750-NFC communication: settings-Command category for single-sided NFC authentication,00 ,27
IDE12548-MAS14751-NFC communication: settings-Command for one-sided NFC authentication,10 ,27
IDE12548-MAS14752-NFC communication: settings-Parameter 1 for one-sided NFC authentication,00 ,27
IDE12548-MAS14753-NFC communication: settings-Parameter 2 for one-sided NFC authentication,00 ,27
IDE12548-MAS14754-NFC communication: settings-Command category for two-sided NFC authentication,00 ,27
IDE12548-MAS14755-NFC communication: settings-Command for two-sided NFC authentication,10 ,27
IDE12548-MAS14756-NFC communication: settings-Parameter 1 for two-sided NFC authentication,10 ,27
IDE12548-MAS14757-NFC communication: settings-Parameter 2 for two-sided NFC authentication,00 01 02 ,27
IDE12548-MAS14758-NFC communication: settings-Time point for NFC advance authentication,Last door closed ,27
IDE12548-MAS14761-NFC communication: settings-Block NFC device in the interior,not activated ,27
IDE12548-MAS14762-NFC communication: settings-NFC event search,activated ,27
IDE12548-MAS15378-NFC communication: settings-Command category to trigger an event,00 ,27
IDE12548-MAS15379-NFC communication: settings-Command to trigger an event,10 ,27
IDE12548-MAS15380-NFC communication: settings-Parameter 1 to trigger an event,20 ,27
IDE12548-MAS15381-NFC communication: settings-Parameter 2 to trigger an event,00 ,27
IDE12548-MAS15382-NFC communication: settings-Command category for vehicle data,00 ,27
IDE12548-MAS15383-NFC communication: settings-Command for vehicle data,10 ,27
IDE12548-MAS15384-NFC communication: settings-Parameter 1 for vehicle data,90 ,27
IDE12548-MAS15385-NFC communication: settings-Parameter 2 for vehicle data,01 ,27
IDE12548-MAS15386-NFC communication: settings-Command category for event data,00 ,27
IDE12548-MAS15387-NFC communication: settings-Command for event data,10 ,27
IDE12548-MAS15388-NFC communication: settings-Parameter 1 for event data,90 ,27
IDE12548-MAS15389-NFC communication: settings-Parameter 2 for event data,00 ,27
IDE12548-MAS16723-NFC communication: settings-Expected length of triggering event,00 ,27
IDE12548-MAS16724-NFC communication: settings-Expected length of vehicle data,00 ,27
IDE12548-MAS16725-NFC communication: settings-Expected length of event data,00 ,27
IDE12548-MAS18680-NFC communication: settings-Mobile device charger: duration of charge interruption,2540 ms,27
IDE12792-MAS02444-Personalization of user account 1-Central locking,global opening ,3
IDE12792-MAS06456-Personalization of user account 1-Autolock,On ,3
IDE12792-MAS06457-Personalization of user account 1-autounlock,On ,3
IDE12792-MAS06696-Personalization of user account 1-Comfort opening sunroof,OFF ,3
IDE12792-MAS06697-Personalization of user account 1-Acoustic acknowledge signal,On ,3
IDE12792-MAS06698-Personalization of user account 1-Freeway flashing,On ,3
IDE12792-MAS06740-Personalization of user account 1-Release button in rear lid handle locked,OFF ,3
IDE12792-MAS06756-Personalization of user account 1-Window shade automatic,OFF ,3
IDE12792-MAS06880-Personalization of user account 1-Mirror fold-in (Audi),OFF ,3
IDE12792-MAS10221-Personalization of user account 1-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12792-MAS10228-Personalization of user account 1-Comfort opening window: driver side,OFF ,3
IDE12792-MAS10229-Personalization of user account 1-Comfort opening window: frt. pass. side,OFF ,3
IDE12792-MAS10230-Personalization of user account 1-Comfort opening rear window: driver side,OFF ,3
IDE12792-MAS10231-Personalization of user account 1-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12792-MAS20789-Personalization of user account 1-Signature for tail light,0 ,3
IDE12793-IDE02262-Personalization of user account 1: part 2-synchronous mirror adjustment,OFF ,1
IDE12793-IDE03946-Personalization of user account 1: part 2-Mirror dimming,OFF ,1
IDE12793-MAS05213-Personalization of user account 1: part 2-Mirror heater,OFF ,1
IDE12793-MAS06870-Personalization of user account 1: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12793-MAS06881-Personalization of user account 1: part 2-Mirror fold-in (VW),OFF ,1
IDE12794-MAS02444-Personalization of user account 2-Central locking,global opening ,3
IDE12794-MAS06456-Personalization of user account 2-Autolock,On ,3
IDE12794-MAS06457-Personalization of user account 2-autounlock,On ,3
IDE12794-MAS06696-Personalization of user account 2-Comfort opening sunroof,OFF ,3
IDE12794-MAS06697-Personalization of user account 2-Acoustic acknowledge signal,On ,3
IDE12794-MAS06698-Personalization of user account 2-Freeway flashing,On ,3
IDE12794-MAS06740-Personalization of user account 2-Release button in rear lid handle locked,OFF ,3
IDE12794-MAS06756-Personalization of user account 2-Window shade automatic,OFF ,3
IDE12794-MAS06880-Personalization of user account 2-Mirror fold-in (Audi),OFF ,3
IDE12794-MAS10221-Personalization of user account 2-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12794-MAS10228-Personalization of user account 2-Comfort opening window: driver side,OFF ,3
IDE12794-MAS10229-Personalization of user account 2-Comfort opening window: frt. pass. side,OFF ,3
IDE12794-MAS10230-Personalization of user account 2-Comfort opening rear window: driver side,OFF ,3
IDE12794-MAS10231-Personalization of user account 2-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12794-MAS20789-Personalization of user account 2-Signature for tail light,0 ,3
IDE12795-IDE02262-Personalization of user account 2: part 2-synchronous mirror adjustment,OFF ,1
IDE12795-IDE03946-Personalization of user account 2: part 2-Mirror dimming,OFF ,1
IDE12795-MAS05213-Personalization of user account 2: part 2-Mirror heater,OFF ,1
IDE12795-MAS06870-Personalization of user account 2: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12795-MAS06881-Personalization of user account 2: part 2-Mirror fold-in (VW),OFF ,1
IDE12796-MAS02444-Personalization of user account 3-Central locking,global opening ,3
IDE12796-MAS06456-Personalization of user account 3-Autolock,On ,3
IDE12796-MAS06457-Personalization of user account 3-autounlock,On ,3
IDE12796-MAS06696-Personalization of user account 3-Comfort opening sunroof,OFF ,3
IDE12796-MAS06697-Personalization of user account 3-Acoustic acknowledge signal,On ,3
IDE12796-MAS06698-Personalization of user account 3-Freeway flashing,On ,3
IDE12796-MAS06740-Personalization of user account 3-Release button in rear lid handle locked,OFF ,3
IDE12796-MAS06756-Personalization of user account 3-Window shade automatic,OFF ,3
IDE12796-MAS06880-Personalization of user account 3-Mirror fold-in (Audi),OFF ,3
IDE12796-MAS10221-Personalization of user account 3-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12796-MAS10228-Personalization of user account 3-Comfort opening window: driver side,OFF ,3
IDE12796-MAS10229-Personalization of user account 3-Comfort opening window: frt. pass. side,OFF ,3
IDE12796-MAS10230-Personalization of user account 3-Comfort opening rear window: driver side,OFF ,3
IDE12796-MAS10231-Personalization of user account 3-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12796-MAS20789-Personalization of user account 3-Signature for tail light,0 ,3
IDE12797-IDE02262-Personalization of user account 3: part 2-synchronous mirror adjustment,OFF ,1
IDE12797-IDE03946-Personalization of user account 3: part 2-Mirror dimming,OFF ,1
IDE12797-MAS05213-Personalization of user account 3: part 2-Mirror heater,OFF ,1
IDE12797-MAS06870-Personalization of user account 3: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12797-MAS06881-Personalization of user account 3: part 2-Mirror fold-in (VW),OFF ,1
IDE12798-MAS02444-Personalization of user account 4-Central locking,global opening ,3
IDE12798-MAS06456-Personalization of user account 4-Autolock,On ,3
IDE12798-MAS06457-Personalization of user account 4-autounlock,On ,3
IDE12798-MAS06696-Personalization of user account 4-Comfort opening sunroof,OFF ,3
IDE12798-MAS06697-Personalization of user account 4-Acoustic acknowledge signal,On ,3
IDE12798-MAS06698-Personalization of user account 4-Freeway flashing,On ,3
IDE12798-MAS06740-Personalization of user account 4-Release button in rear lid handle locked,OFF ,3
IDE12798-MAS06756-Personalization of user account 4-Window shade automatic,OFF ,3
IDE12798-MAS06880-Personalization of user account 4-Mirror fold-in (Audi),OFF ,3
IDE12798-MAS10221-Personalization of user account 4-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12798-MAS10228-Personalization of user account 4-Comfort opening window: driver side,OFF ,3
IDE12798-MAS10229-Personalization of user account 4-Comfort opening window: frt. pass. side,OFF ,3
IDE12798-MAS10230-Personalization of user account 4-Comfort opening rear window: driver side,OFF ,3
IDE12798-MAS10231-Personalization of user account 4-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12798-MAS20789-Personalization of user account 4-Signature for tail light,0 ,3
IDE12799-IDE02262-Personalization of user account 4: part 2-synchronous mirror adjustment,OFF ,1
IDE12799-IDE03946-Personalization of user account 4: part 2-Mirror dimming,OFF ,1
IDE12799-MAS05213-Personalization of user account 4: part 2-Mirror heater,OFF ,1
IDE12799-MAS06870-Personalization of user account 4: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12799-MAS06881-Personalization of user account 4: part 2-Mirror fold-in (VW),OFF ,1
IDE12800-MAS02444-Personalization of user account 5-Central locking,global opening ,3
IDE12800-MAS06456-Personalization of user account 5-Autolock,On ,3
IDE12800-MAS06457-Personalization of user account 5-autounlock,On ,3
IDE12800-MAS06696-Personalization of user account 5-Comfort opening sunroof,OFF ,3
IDE12800-MAS06697-Personalization of user account 5-Acoustic acknowledge signal,On ,3
IDE12800-MAS06698-Personalization of user account 5-Freeway flashing,On ,3
IDE12800-MAS06740-Personalization of user account 5-Release button in rear lid handle locked,OFF ,3
IDE12800-MAS06756-Personalization of user account 5-Window shade automatic,OFF ,3
IDE12800-MAS06880-Personalization of user account 5-Mirror fold-in (Audi),OFF ,3
IDE12800-MAS10221-Personalization of user account 5-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12800-MAS10228-Personalization of user account 5-Comfort opening window: driver side,OFF ,3
IDE12800-MAS10229-Personalization of user account 5-Comfort opening window: frt. pass. side,OFF ,3
IDE12800-MAS10230-Personalization of user account 5-Comfort opening rear window: driver side,OFF ,3
IDE12800-MAS10231-Personalization of user account 5-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12800-MAS20789-Personalization of user account 5-Signature for tail light,0 ,3
IDE12801-IDE02262-Personalization of user account 5: part 2-synchronous mirror adjustment,OFF ,1
IDE12801-IDE03946-Personalization of user account 5: part 2-Mirror dimming,OFF ,1
IDE12801-MAS05213-Personalization of user account 5: part 2-Mirror heater,OFF ,1
IDE12801-MAS06870-Personalization of user account 5: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12801-MAS06881-Personalization of user account 5: part 2-Mirror fold-in (VW),OFF ,1
IDE12802-MAS02444-Personalization of user account 6-Central locking,global opening ,3
IDE12802-MAS06456-Personalization of user account 6-Autolock,On ,3
IDE12802-MAS06457-Personalization of user account 6-autounlock,On ,3
IDE12802-MAS06696-Personalization of user account 6-Comfort opening sunroof,OFF ,3
IDE12802-MAS06697-Personalization of user account 6-Acoustic acknowledge signal,On ,3
IDE12802-MAS06698-Personalization of user account 6-Freeway flashing,On ,3
IDE12802-MAS06740-Personalization of user account 6-Release button in rear lid handle locked,OFF ,3
IDE12802-MAS06756-Personalization of user account 6-Window shade automatic,OFF ,3
IDE12802-MAS06880-Personalization of user account 6-Mirror fold-in (Audi),OFF ,3
IDE12802-MAS10221-Personalization of user account 6-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12802-MAS10228-Personalization of user account 6-Comfort opening window: driver side,OFF ,3
IDE12802-MAS10229-Personalization of user account 6-Comfort opening window: frt. pass. side,OFF ,3
IDE12802-MAS10230-Personalization of user account 6-Comfort opening rear window: driver side,OFF ,3
IDE12802-MAS10231-Personalization of user account 6-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12802-MAS20789-Personalization of user account 6-Signature for tail light,0 ,3
IDE12803-IDE02262-Personalization of user account 6: part 2-synchronous mirror adjustment,OFF ,1
IDE12803-IDE03946-Personalization of user account 6: part 2-Mirror dimming,OFF ,1
IDE12803-MAS05213-Personalization of user account 6: part 2-Mirror heater,OFF ,1
IDE12803-MAS06870-Personalization of user account 6: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12803-MAS06881-Personalization of user account 6: part 2-Mirror fold-in (VW),OFF ,1
IDE12804-MAS02444-Personalization of user account 7-Central locking,global opening ,3
IDE12804-MAS06456-Personalization of user account 7-Autolock,On ,3
IDE12804-MAS06457-Personalization of user account 7-autounlock,On ,3
IDE12804-MAS06696-Personalization of user account 7-Comfort opening sunroof,OFF ,3
IDE12804-MAS06697-Personalization of user account 7-Acoustic acknowledge signal,On ,3
IDE12804-MAS06698-Personalization of user account 7-Freeway flashing,On ,3
IDE12804-MAS06740-Personalization of user account 7-Release button in rear lid handle locked,OFF ,3
IDE12804-MAS06756-Personalization of user account 7-Window shade automatic,OFF ,3
IDE12804-MAS06880-Personalization of user account 7-Mirror fold-in (Audi),OFF ,3
IDE12804-MAS10221-Personalization of user account 7-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12804-MAS10228-Personalization of user account 7-Comfort opening window: driver side,OFF ,3
IDE12804-MAS10229-Personalization of user account 7-Comfort opening window: frt. pass. side,OFF ,3
IDE12804-MAS10230-Personalization of user account 7-Comfort opening rear window: driver side,OFF ,3
IDE12804-MAS10231-Personalization of user account 7-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12804-MAS20789-Personalization of user account 7-Signature for tail light,0 ,3
IDE12805-IDE02262-Personalization of user account 7: part 2-synchronous mirror adjustment,OFF ,1
IDE12805-IDE03946-Personalization of user account 7: part 2-Mirror dimming,OFF ,1
IDE12805-MAS05213-Personalization of user account 7: part 2-Mirror heater,OFF ,1
IDE12805-MAS06870-Personalization of user account 7: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12805-MAS06881-Personalization of user account 7: part 2-Mirror fold-in (VW),OFF ,1
IDE12808-Personalization of user account 1: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12809-Personalization of user account 2: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12810-Personalization of user account 3: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12811-Personalization of user account 4: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12812-Personalization of user account 5: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12813-Personalization of user account 6: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12814-Personalization of user account 7: name,47 61 73 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12815-MAS15187-User accounts for the NFC devices-User account of NFC device 1,0 ,8
IDE12815-MAS15188-User accounts for the NFC devices-User account of NFC device 2,0 ,8
IDE12815-MAS15189-User accounts for the NFC devices-User account of NFC device 3,0 ,8
IDE12815-MAS15190-User accounts for the NFC devices-User account of NFC device 4,0 ,8
IDE12815-MAS15191-User accounts for the NFC devices-User account of NFC device 5,0 ,8
IDE12815-MAS15192-User accounts for the NFC devices-User account of NFC device 6,0 ,8
IDE12815-MAS15193-User accounts for the NFC devices-User account of NFC device 7,0 ,8
IDE12815-MAS15194-User accounts for the NFC devices-User account of NFC device 8,0 ,8
IDE12815-MAS15195-User accounts for the NFC devices-User account of NFC device 9,0 ,8
IDE12815-MAS15196-User accounts for the NFC devices-User account of NFC device 10,0 ,8
IDE12815-MAS15197-User accounts for the NFC devices-User account of NFC device 11,0 ,8
IDE12815-MAS15198-User accounts for the NFC devices-User account of NFC device 12,0 ,8
IDE12815-MAS15199-User accounts for the NFC devices-User account of NFC device 13,0 ,8
IDE12815-MAS15200-User accounts for the NFC devices-User account of NFC device 14,0 ,8
IDE12815-MAS15201-User accounts for the NFC devices-User account of NFC device 15,0 ,8
IDE12815-MAS15202-User accounts for the NFC devices-User account of NFC device 16,0 ,8
IDE12938-MAS15390-NFC communication 2: settings-Command category for SELECT,00 ,22
IDE12938-MAS15391-NFC communication 2: settings-Command for SELECT,A4 ,22
IDE12938-MAS15392-NFC communication 2: settings-Parameter 1 for SELECT,04 ,22
IDE12938-MAS15393-NFC communication 2: settings-Parameter 2 for SELECT,00 ,22
IDE12938-MAS15394-NFC communication 2: settings-Utility data length for SELECT,0F ,22
IDE12938-MAS15395-NFC communication 2: settings-Application ID for SELECT,A0 00 00 07 02 00 00 00 00 00 00 01 00 00 01 00 ,22
IDE12938-MAS15396-NFC communication 2: settings-Expected length for SELECT,10 ,22
IDE13253-MAS16009-Convertible top convenience operation-Convenience closure with radio key,On ,2
IDE13253-MAS16010-Convertible top convenience operation-Convenience opening with lock cylinder,On ,2
IDE13253-MAS16011-Convertible top convenience operation-Convenience closing with exterior door handle touch sensor,On ,2
IDE13253-MAS16012-Convertible top convenience operation-Convenience opening with radio key,On ,2
IDE13253-MAS16013-Convertible top convenience operation-Convenient opening with lock cylinder,On ,2
IDE13254-MAS16014-Convenience opening: control points-Convenience opening of the window regulator with radio key,On ,2
IDE13254-MAS16015-Convenience opening: control points-Convenience opening of the window regulator with lock cylinder,On ,2
IDE13254-MAS16016-Convenience opening: control points-Convenience opening of the window regulator with window regulator button,On ,2
IDE13254-MAS16017-Convenience opening: control points-Convenience opening of the roof shade with the radio key,On ,2
IDE13254-MAS16018-Convenience opening: control points-Convenience opening of the roof shade with lock cylinder,On ,2
IDE13254-MAS16019-Convenience opening: control points-Convenience opening of the roof shade with window regulator button,On ,2
IDE13254-MAS16020-Convenience opening: control points-Comfort opening only for driver door,OFF ,2
IDE13254-MAS16029-Convenience opening: control points-Convenience opening of the sunroof with radio key,On ,2
IDE13254-MAS16030-Convenience opening: control points-Convenience opening of the sunroof with lock cylinder,On ,2
IDE13254-MAS16031-Convenience opening: control points-Convenience opening of the sun roof with window regulator button,On ,2
IDE13254-MAS16032-Convenience opening: control points-Convenience opening of rear sun roof with radio key,On ,2
IDE13254-MAS16033-Convenience opening: control points-Convenience opening of rear sun roof with lock cylinder,On ,2
IDE13254-MAS16034-Convenience opening: control points-Comfort opening of the rear sunroof with window regulator button,On ,2
IDE13255-MAS16021-Convenience closing: control points-Convenience closure of the window regulator with radio key,On ,2
IDE13255-MAS16022-Convenience closing: control points-Convenience closure of the window regulator with lock cylinder,On ,2
IDE13255-MAS16023-Convenience closing: control points-Convenience closure of the window regulator with window regulator button,On ,2
IDE13255-MAS16024-Convenience closing: control points-Convenience closure of window regulator with outside door handle sensor,On ,2
IDE13255-MAS16025-Convenience closing: control points-Convenience closing of the roof shade with the radio key,On ,2
IDE13255-MAS16026-Convenience closing: control points-Convenience closure of the roof shade with lock cylinder,On ,2
IDE13255-MAS16027-Convenience closing: control points-Convenience closure of the roof shade with window regulator button,On ,2
IDE13255-MAS16028-Convenience closing: control points-Convenience closure of roof shade with outside door handle,On ,2
IDE13255-MAS16035-Convenience closing: control points-Convenience closure of sun roof with radio key,On ,2
IDE13255-MAS16036-Convenience closing: control points-Convenience closing of the sunroof with lock cylinder,On ,2
IDE13255-MAS16037-Convenience closing: control points-Convenience closure of the sun roof with window regulator button,On ,2
IDE13255-MAS16038-Convenience closing: control points-Convenience closure of sunroof with outside door handle sensor,On ,2
IDE13255-MAS16039-Convenience closing: control points-Convenience closure of rear sun roof with radio key,On ,2
IDE13255-MAS16040-Convenience closing: control points-Convenience closure of rear sun roof with lock cylinder,On ,2
IDE13255-MAS16041-Convenience closing: control points-Convenience closure of the rear sun roof with window regulator button,On ,2
IDE13255-MAS16042-Convenience closing: control points-Convenience closure of rear sunroof with outside door handle sensor,On ,2
IDE14072-MAS17381-Central locking system actuation counter: configuration-Interface 1: counter 1,0 ,12
IDE14072-MAS17382-Central locking system actuation counter: configuration-Interface 2: counter 1,0 ,12
IDE14072-MAS17383-Central locking system actuation counter: configuration-Interface 3: counter 1,0 ,12
IDE14072-MAS17384-Central locking system actuation counter: configuration-Interface 1: counter 2,0 ,12
IDE14072-MAS17385-Central locking system actuation counter: configuration-Interface 2: counter 2,0 ,12
IDE14072-MAS17386-Central locking system actuation counter: configuration-Interface 3: counter 2,0 ,12
IDE14072-MAS17387-Central locking system actuation counter: configuration-Interface 1: counter 3,0 ,12
IDE14072-MAS17388-Central locking system actuation counter: configuration-Interface 2: counter 3,0 ,12
IDE14072-MAS17389-Central locking system actuation counter: configuration-Interface 3: counter 3,0 ,12
IDE14072-MAS17390-Central locking system actuation counter: configuration-Interface 1: counter 4,0 ,12
IDE14072-MAS17391-Central locking system actuation counter: configuration-Interface 2: counter 4,0 ,12
IDE14072-MAS17392-Central locking system actuation counter: configuration-Interface 3: counter 4,0 ,12
IDE14661-MAS18674-NFC communication 3: settings-Trigger event waiting time,0 ms,8
IDE14661-MAS18675-NFC communication 3: settings-Waiting time for sending event data,0 ms,8
IDE14661-MAS18676-NFC communication 3: settings-Waiting time for sending vehicle health data,300 ms,8
IDE14661-MAS18677-NFC communication 3: settings-Trigger NFC event,activated ,8
IDE14661-MAS18678-NFC communication 3: settings-Send NFC event data,activated ,8
IDE14661-MAS18679-NFC communication 3: settings-Send NFC vehicle health data,activated ,8
MAS13921-IDE00047-Control module rear lid opening: dataset-Parameter set version,0 ,37
MAS13921-IDE80001-Control module rear lid opening: dataset-Analysis 1,1 ,37
MAS13921-IDE80002-Control module rear lid opening: dataset-Analysis 2,1 ,37
MAS13921-IDE80003-Control module rear lid opening: dataset-Analysis 3,1 ,37
MAS13921-IDE80004-Control module rear lid opening: dataset-Analysis 4,0 ,37
MAS13921-IDE80005-Control module rear lid opening: dataset-Analysis 5,16 ,37
MAS13921-IDE80006-Control module rear lid opening: dataset-Analysis 6,16 ,37
MAS13921-IDE80007-Control module rear lid opening: dataset-Analysis 7,16 ,37
MAS13921-IDE80008-Control module rear lid opening: dataset-Analysis 8,16 ,37
MAS13921-IDE80009-Control module rear lid opening: dataset-Analysis 9,2 ,37
MAS13921-IDE80010-Control module rear lid opening: dataset-Analysis 10,31 ,37
MAS13921-IDE80011-Control module rear lid opening: dataset-Analysis 11,2 ,37
MAS13921-IDE80012-Control module rear lid opening: dataset-Analysis 12,31 ,37
MAS13921-IDE80013-Control module rear lid opening: dataset-Analysis 13,224 ,37
MAS13921-IDE80014-Control module rear lid opening: dataset-Analysis 14,10 ,37
MAS13921-IDE80015-Control module rear lid opening: dataset-Analysis 15,10 ,37
MAS13921-IDE80016-Control module rear lid opening: dataset-Analysis 16,0 ,37
MAS13921-IDE80017-Control module rear lid opening: dataset-Analysis 17,0 ,37
MAS13921-IDE80018-Control module rear lid opening: dataset-Analysis 18,9 ,37
MAS13921-IDE80019-Control module rear lid opening: dataset-Analysis 19,0 ,37
MAS13921-IDE80020-Control module rear lid opening: dataset-Analysis 20,active ,37
MAS13921-IDE80021-Control module rear lid opening: dataset-Analysis 21,not active ,37
MAS13921-IDE80022-Control module rear lid opening: dataset-Analysis 22,not active ,37
MAS13921-IDE80023-Control module rear lid opening: dataset-Analysis 23,Bottom ,37
MAS13921-IDE80024-Control module rear lid opening: dataset-Analysis 24,Dynamic ,37
MAS13921-IDE80025-Control module rear lid opening: dataset-Analysis 25,3 ,37
MAS13921-IDE80026-Control module rear lid opening: dataset-Analysis 26,not active ,37
MAS13921-IDE80027-Control module rear lid opening: dataset-Analysis 27,Dynamic ,37
MAS13921-IDE80028-Control module rear lid opening: dataset-Analysis 28,10 ,37
MAS13921-IDE80029-Control module rear lid opening: dataset-Analysis 29,6 ,37
MAS13921-IDE80030-Control module rear lid opening: dataset-Analysis 30,active ,37
MAS13921-IDE80031-Control module rear lid opening: dataset-Analysis 31,30 ,37
MAS13921-IDE80032-Control module rear lid opening: dataset-Analysis 32,2 ,37
MAS13921-IDE80033-Control module rear lid opening: dataset-Analysis 33,12 ,37
MAS13921-IDE80034-Control module rear lid opening: dataset-Analysis 34,4 ,37
MAS13921-IDE80035-Control module rear lid opening: dataset-Analysis 35,Do not reset ,37
MAS13921-IDE80036-Control module rear lid opening: dataset-Analysis 36,16 ,37
MAS13921-IDE80037-Control module rear lid opening: dataset-Analysis 37,16 ,37
MAS13921-IDE80038-Control module rear lid opening: dataset-Analysis 38,16 ,37
MAS13921-IDE80039-Control module rear lid opening: dataset-Analysis 39,16 ,37
MAS13921-IDE80040-Control module rear lid opening: dataset-Analysis 40,2 ,37
MAS13921-IDE80041-Control module rear lid opening: dataset-Analysis 41,31 ,37
MAS13921-IDE80042-Control module rear lid opening: dataset-Analysis 42,2 ,37
MAS13921-IDE80043-Control module rear lid opening: dataset-Analysis 43,31 ,37
MAS13921-IDE80044-Control module rear lid opening: dataset-Analysis 44,224 ,37
MAS13921-IDE80045-Control module rear lid opening: dataset-Analysis 45,10 ,37
MAS13921-IDE80046-Control module rear lid opening: dataset-Analysis 46,10 ,37
MAS13921-IDE80047-Control module rear lid opening: dataset-Analysis 47,0 ,37
MAS13921-IDE80048-Control module rear lid opening: dataset-Analysis 48,0 ,37
MAS13921-IDE80049-Control module rear lid opening: dataset-Analysis 49,0 ,37
MAS13921-IDE80050-Control module rear lid opening: dataset-Analysis 50,0 ,37
MAS13921-IDE80051-Control module rear lid opening: dataset-Analysis 51,6 ,37
MAS13921-IDE80052-Control module rear lid opening: dataset-Analysis 52,25 ,37
MAS13921-IDE80053-Control module rear lid opening: dataset-Analysis 53,255 ,37
MAS13921-IDE80054-Control module rear lid opening: dataset-Analysis 54,5 ,37
MAS13921-IDE80055-Control module rear lid opening: dataset-Analysis 55,60 ,37
MAS13921-IDE80056-Control module rear lid opening: dataset-Analysis 56,149 ,37
MAS13921-MAS01078-Control module rear lid opening: dataset-Vehicle type,0 ,37
MAS13921-MAS14087-Control module rear lid opening: dataset-time delay activation,not active ,37
MAS19655-MAS19656-Heckklappe öffnen durch Doppelbetätigung der Funkfernbedienung-Actuation time 1 for double-actuation,5100 ms,4
MAS19655-MAS19657-Heckklappe öffnen durch Doppelbetätigung der Funkfernbedienung-Actuation time 2 for double-actuation,5100 ms,4
MAS19655-MAS19658-Heckklappe öffnen durch Doppelbetätigung der Funkfernbedienung-Time window for double-actuation,1.40 s,4
ENG146368-ENG146489-central_locking_system-autolock_rear,On ,2
ENG146368-ENG146488-central_locking_system-beep_at_opening,On ,2
ENG146368-ENG146490-central_locking_system-global_unlocking_via_kessy_double_puls,OFF ,2
ENG146368-ENG146491-central_locking_system-unlocking_rear_via_vip_at_s_contact_active,OFF ,2
ENG146414-ffb_kessy_active_for_piloted_parking,Kessy_and_ffb_at_kl15_on_and_piloted_parking_event_active ,1
ENG146373-headlamp_range_adjustment,OFF ,1
ENG146406-ENG146575-Heated_front_window_lin_relais-Off_delay,0.50 s,14
ENG146406-ENG146574-Heated_front_window_lin_relais-On_delay,0.50 s,14
ENG146406-ENG146571-Heated_front_window_lin_relais-Threshold_driver_side_off,150 W,14
ENG146406-ENG146570-Heated_front_window_lin_relais-Threshold_driver_side_on,300 W,14
ENG146406-ENG146573-Heated_front_window_lin_relais-Threshold_passenger_side_off,350 W,14
ENG146406-ENG146572-Heated_front_window_lin_relais-Threshold_passenger_side_on,500 W,14
ENG146406-ENG146576-Heated_front_window_lin_relais-Two_Relais_installed,1 ,14
ENG146400-ENG146554-Heated_rear_window_with_extension-Default_activation_time,10 min,16
ENG146400-ENG155020-Heated_rear_window_with_extension-Delay_time_deactivate_heated_rear_window,25.50 ,16
ENG146400-ENG146546-Heated_rear_window_with_extension-Interval_1,5 min,16
ENG146400-ENG146547-Heated_rear_window_with_extension-Interval_2,7 min,16
ENG146400-ENG146548-Heated_rear_window_with_extension-Interval_3,15 min,16
ENG146400-ENG146549-Heated_rear_window_with_extension-Interval_4,20 min,16
ENG146400-ENG146550-Heated_rear_window_with_extension-Renewal_interval_1,0 min,16
ENG146400-ENG146551-Heated_rear_window_with_extension-Renewal_interval_2,3 min,16
ENG146400-ENG146552-Heated_rear_window_with_extension-Renewal_interval_3,5 min,16
ENG146400-ENG146553-Heated_rear_window_with_extension-Renewal_interval_4,0 min,16
ENG146400-ENG146555-Heated_rear_window_with_extension-Speed_theshold,50 ,16
ENG146400-ENG145114-Heated_rear_window_with_extension-Temperature_1,132 ,16
ENG146400-ENG145115-Heated_rear_window_with_extension-Temperature_2,124 ,16
ENG146400-ENG146545-Heated_rear_window_with_extension-Temperature_3,116 ,16
ENG146374-hella_debug_switch,00 00 ,2
ENG146372-ENG146515-horn_settings-number_of_acoustic_acknowlagement_signals_zv_close,2 ,2
ENG146372-ENG146514-horn_settings-number_of_acoustic_acknowlagement_signals_zv_open,0 ,2
ENG153896-ENG146539-Mobile_Key-idle_time_state_S1,60 ,4
ENG153896-ENG155141-Mobile_Key-idle_time_state_S2,20 ,4
ENG153896-ENG155142-Mobile_Key-idle_time_vtan_state_S1,60 ,4
ENG153896-ENG155143-Mobile_Key-idle_time_vtan_state_S2,20 ,4
ENG146397-ENG146535-mq_ewi_activation-ewi_mode,On ,4
ENG146397-ENG146534-mq_ewi_activation-ewi_trace,On ,4
ENG146397-ENG146536-mq_ewi_activation-ewi_trace_messages,FF FF FF ,4
ENG247341-Personalisation_2_0_ew,150 ms,5
ENG146405-ENG146480-Personalisation_ew-Delay_Time,0.40 s,8
ENG146405-ENG146558-Personalisation_ew-FSG_Setup2_Bit1,0 ,8
ENG146405-ENG146559-Personalisation_ew-FSG_Setup2_Bit2,0 ,8
ENG146405-ENG146560-Personalisation_ew-FSG_Setup2_Bit3,1 ,8
ENG146405-ENG146561-Personalisation_ew-FSG_Setup2_Bit4,0 ,8
ENG146405-ENG146562-Personalisation_ew-FSG_Setup2_Bit5,0 ,8
ENG146405-ENG146563-Personalisation_ew-FSG_Setup2_Bit6,1 ,8
ENG146405-ENG146564-Personalisation_ew-FSG_Setup2_Bit7,1 ,8
ENG146405-ENG146569-Personalisation_ew-Minimum_display_duration,1 ,8
ENG146405-ENG146566-Personalisation_ew-Number_of_accounts,7 ,8
ENG146405-ENG146577-Personalisation_ew-Prioritization_device,0 ,8
ENG146405-ENG146567-Personalisation_ew-Time_slot_driver_door_opening,0.30 s,8
ENG146405-ENG146565-Personalisation_ew-Time_slot_key_identification,5 ,8
ENG146405-ENG146568-Personalisation_ew-Timeout_drive_active,60 ,8
ENG146375-ENG146520-pwm_levels_hl_1-pwm_high_1,200 ,3
ENG146375-ENG146521-pwm_levels_hl_1-pwm_high_2,255 ,3
ENG146375-ENG146519-pwm_levels_hl_1-pwm_low,255 ,3
ENG146384-ENG146520-pwm_levels_hl_10-pwm_high_1,255 ,3
ENG146384-ENG146521-pwm_levels_hl_10-pwm_high_2,255 ,3
ENG146384-ENG146519-pwm_levels_hl_10-pwm_low,200 ,3
ENG146385-ENG146520-pwm_levels_hl_11-pwm_high_1,200 ,3
ENG146385-ENG146521-pwm_levels_hl_11-pwm_high_2,255 ,3
ENG146385-ENG146519-pwm_levels_hl_11-pwm_low,255 ,3
ENG146386-ENG146520-pwm_levels_hl_12-pwm_high_1,200 ,3
ENG146386-ENG146521-pwm_levels_hl_12-pwm_high_2,255 ,3
ENG146386-ENG146519-pwm_levels_hl_12-pwm_low,255 ,3
ENG146387-ENG146520-pwm_levels_hl_13-pwm_high_1,200 ,3
ENG146387-ENG146521-pwm_levels_hl_13-pwm_high_2,255 ,3
ENG146387-ENG146519-pwm_levels_hl_13-pwm_low,255 ,3
ENG146388-ENG146520-pwm_levels_hl_14-pwm_high_1,255 ,3
ENG146388-ENG146521-pwm_levels_hl_14-pwm_high_2,255 ,3
ENG146388-ENG146519-pwm_levels_hl_14-pwm_low,200 ,3
ENG146389-ENG146520-pwm_levels_hl_15-pwm_high_1,200 ,3
ENG146389-ENG146521-pwm_levels_hl_15-pwm_high_2,255 ,3
ENG146389-ENG146519-pwm_levels_hl_15-pwm_low,255 ,3
ENG146390-ENG146520-pwm_levels_hl_16-pwm_high_1,255 ,3
ENG146390-ENG146521-pwm_levels_hl_16-pwm_high_2,200 ,3
ENG146390-ENG146519-pwm_levels_hl_16-pwm_low,255 ,3
ENG146391-ENG146520-pwm_levels_hl_17-pwm_high_1,200 ,3
ENG146391-ENG146521-pwm_levels_hl_17-pwm_high_2,255 ,3
ENG146391-ENG146519-pwm_levels_hl_17-pwm_low,255 ,3
ENG146392-ENG146520-pwm_levels_hl_18-pwm_high_1,255 ,3
ENG146392-ENG146521-pwm_levels_hl_18-pwm_high_2,255 ,3
ENG146392-ENG146519-pwm_levels_hl_18-pwm_low,255 ,3
ENG146393-ENG146520-pwm_levels_hl_19-pwm_high_1,255 ,3
ENG146393-ENG146521-pwm_levels_hl_19-pwm_high_2,255 ,3
ENG146393-ENG146519-pwm_levels_hl_19-pwm_low,255 ,3
ENG146376-ENG146520-pwm_levels_hl_2-pwm_high_1,200 ,3
ENG146376-ENG146521-pwm_levels_hl_2-pwm_high_2,255 ,3
ENG146376-ENG146519-pwm_levels_hl_2-pwm_low,255 ,3
ENG146394-ENG146520-pwm_levels_hl_20-pwm_high_1,255 ,3
ENG146394-ENG146521-pwm_levels_hl_20-pwm_high_2,255 ,3
ENG146394-ENG146519-pwm_levels_hl_20-pwm_low,255 ,3
ENG146395-ENG146520-pwm_levels_hl_21-pwm_high_1,255 ,3
ENG146395-ENG146521-pwm_levels_hl_21-pwm_high_2,255 ,3
ENG146395-ENG146519-pwm_levels_hl_21-pwm_low,255 ,3
ENG146377-ENG146520-pwm_levels_hl_3-pwm_high_1,255 ,3
ENG146377-ENG146521-pwm_levels_hl_3-pwm_high_2,255 ,3
ENG146377-ENG146519-pwm_levels_hl_3-pwm_low,200 ,3
ENG146378-ENG146520-pwm_levels_hl_4-pwm_high_1,255 ,3
ENG146378-ENG146521-pwm_levels_hl_4-pwm_high_2,255 ,3
ENG146378-ENG146519-pwm_levels_hl_4-pwm_low,200 ,3
ENG146379-ENG146520-pwm_levels_hl_5-pwm_high_1,200 ,3
ENG146379-ENG146521-pwm_levels_hl_5-pwm_high_2,255 ,3
ENG146379-ENG146519-pwm_levels_hl_5-pwm_low,255 ,3
ENG146380-ENG146520-pwm_levels_hl_6-pwm_high_1,200 ,3
ENG146380-ENG146521-pwm_levels_hl_6-pwm_high_2,255 ,3
ENG146380-ENG146519-pwm_levels_hl_6-pwm_low,255 ,3
ENG146381-ENG146520-pwm_levels_hl_7-pwm_high_1,200 ,3
ENG146381-ENG146521-pwm_levels_hl_7-pwm_high_2,255 ,3
ENG146381-ENG146519-pwm_levels_hl_7-pwm_low,255 ,3
ENG146382-ENG146520-pwm_levels_hl_8-pwm_high_1,255 ,3
ENG146382-ENG146521-pwm_levels_hl_8-pwm_high_2,255 ,3
ENG146382-ENG146519-pwm_levels_hl_8-pwm_low,255 ,3
ENG146383-ENG146520-pwm_levels_hl_9-pwm_high_1,200 ,3
ENG146383-ENG146521-pwm_levels_hl_9-pwm_high_2,255 ,3
ENG146383-ENG146519-pwm_levels_hl_9-pwm_low,255 ,3
ENG146399-ENG146543-remote_functions-idle_time_bap_remote_beep,500 ,8
ENG146399-ENG146544-remote_functions-idle_time_state_S0,1 ,8
ENG146399-ENG146539-remote_functions-idle_time_state_S1,60 ,8
ENG146399-ENG146540-remote_functions-idle_time_state_S3,2000 ,8
ENG146399-ENG146537-remote_functions-Rear_lid_handle_release_button_activation_time,15 ,8
ENG146399-ENG146538-remote_functions-Rear_lid_handle_release_button_active,active ,8
ENG146399-ENG146541-remote_functions-remote_beep_activation_time_high,100 ,8
ENG146399-ENG146542-remote_functions-remote_beep_activation_time_low,900 ,8
ENG146403-ENG114991-RF_adjustment-channel_1,4E ,3
ENG146403-ENG114992-RF_adjustment-channel_2,50 ,3
ENG146403-ENG114993-RF_adjustment-channel_3,4C ,3
ENG146402-ENG114991-RF_calibration-channel_1,FF FF FF ,9
ENG146402-ENG114992-RF_calibration-channel_2,FF FF FF ,9
ENG146402-ENG114993-RF_calibration-channel_3,FF FF FF ,9
ENG129054-ENG144985-SERVICE_KEY-debounce_kilometer,15 km,9
ENG129054-ENG144693-SERVICE_KEY-Distance,20 km,9
ENG129054-ENG144983-SERVICE_KEY-hazard_warning_switch_delay_time,10 s,9
ENG129054-ENG144980-SERVICE_KEY-retry_request_obdc,3 ,9
ENG129054-ENG144979-SERVICE_KEY-timeout_request_obdc,30 s,9
ENG129054-ENG146532-SERVICE_KEY-write_cycles_per_key_and_day,20 ,9
ENG129054-ENG144984-SERVICE_KEY-write_data_delay_time,40 s,9
ENG129054-ENG144982-SERVICE_KEY-write_delay_speed,20 km/h,9
ENG129054-ENG144981-SERVICE_KEY-write_delay_time,20 s,9
ENG146371-ENG146510-sounder_settings-beeptime,60_ms ,2
ENG146371-ENG146511-sounder_settings-beeptime_closing_central_locking,single_beep ,2
ENG146371-ENG146513-sounder_settings-beeptime_opening_central_locking,no_beep ,2
ENG146371-ENG247388-sounder_settings-beeptime_reunlock,60_ms ,2
ENG146371-ENG146512-sounder_settings-sounder_sound,frequency_modulated ,2
ENG146364-ENG146516-Terminal_Control-deactivation_time_kl15,30 min,3
ENG146364-ENG146517-Terminal_Control-delay_time_leave_concept,200 ms,3
ENG146398-wiping_indicator,00010111 ,1
ENG146401-Write_key_content,17 00 01 0A 28 14 0F 14 FF 05 00 0A 32 FF FF FF 9E CC 10 10 10 10 02 1F 02 1F E0 AA 00 00 06 19 FF 05 3C 00 95 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,98
Elapsed Time: 01:46
