7.5 facelift taillights retrofit- GTI clubsport
   #22
Qassem
Kuwait
C?ID=325382
Finally my wife helped me catching this video with my phone front camera ,
The problem is :
Pressing the brake causes flickering effect on the outer taillights.
The middle LED line flickering while pressing
The lower LED brightness decreased a lot after breaking (also flickering even without breaking but to a lower extent)
Also notice at the end of the video the lower LED line gains the brightness again because the switch is turned off.
Any help, or should I change the harness :-(
MasterTommy
Amsterdam
C?ID=295586
Did you see this with your own eyes? Because you wouldn’t be the first to assume flickering LED’s on video = flickering IRL.
Qassem
Kuwait
C?ID=325382
Yes , I am the one who is taking the video, and I was looking directly to the taillights while I am taking the the video.
Any ideas ??!
   #26
Qassem
Kuwait
C?ID=325382
add 2 wires from inside to outside
Thanks man , I will try tomorrow, I am busy with blind spot retrofit.
Really appreciate your efforts:-)
   #27
Qassem
Kuwait
C?ID=325382
Finally sorted out :-)
Just adjusted the “Dimmwert” value from 100 t0 127 in both inner and outer taillights.
It’s perfect now (no flickering), just the plug and play harnesses without any extra wires from inner to outer.
Thank you a lot guys.
   #28
vag_superstreet
TH
C?ID=369241
I have the same harness but I dont have the coding for it. Please can you share the adaptation code for this harness?
   #29
vastechnics
C?ID=143747
YOU need change following in adaptions channels:
Leuchte23SL HLC10-Lichtfunktion C 23 - inactive
Leuchte23SL HLC10-Lichtfunktion D 23 - inactive
Leuchte23SL HLC10-Lichtfunktion E 23 - inactive
Leuchte23SL HLC10-Dimming Direction EF 23 - maximize
Leuchte24SL HRA65-Lichtfunktion C 24 - inactive
Leuchte24SL HRA65-Lichtfunktion D 24 - inactive
Leuchte24SL HRA65-Lichtfunktion E 24 - inactive
that should do the trick
