Data bus issue code - 01312
mkv_racer
C?ID=106940
So while pulling some wiring something shorted now I can't talk to the ecu, abs and possibly others. Also, Oil warning and "brakes" warning come on. Car starts and runs just not great. Thinking the Central electronics module is fried. replaced ecu (just cause it was easy) same problem.
Any help is appreciated.
Ignore all the bulb and door module warnings. Those are not connected. Not part of the problem.
Sunday,05,April,2020,17:23:30:29885
VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
VIN: WVWFV71K97W169218   License Plate: ORANGE CAR
Mileage: 146600km-91093mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 22 25 44 46
VIN: WVWFV71K97W169218   Mileage: 146600km-91093miles
1C-Position Sensing -- Status: Not registered 0011
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
   Part No: 1K0 820 047 GS
   VCID: 7BB60A383A91DD5E57-802E
7 Faults Found:
            013 - Check DTC Memory
01296 - Sensor for Vent Temperature; Center (G191)
            010 - Open or Short to Plus
00898 - Control Circuit A/C compressor
            009 - Open or Short to Ground
01316 - ABS Control Module
   Revision: 00H52000    Serial number: 00000006577201
   Coding: 11040801400A00005F00000032000000005000005F0001
   Shop #: WSC 09113 444 54770
   VCID: 6C9439644FFF4AE6CE-8038
   Component: Wischer 181206 020  0501
   Coding: 00038805
   Shop #: WSC 09113
7 Faults Found:
                    Fault Status: 01101001
                    Reset counter: 150
                    Mileage: 146609 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.45 V
                    Fault Status: 01101010
                    Reset counter: 150
                    Mileage: 146609 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.45 V
                    Reset counter: 150
                    Mileage: 146609 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.45 V
                    Fault Status: 00100101
                    Reset counter: 190
                    Mileage: 146609 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.45 V
                    Reset counter: 150
                    Mileage: 146609 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.40 V
                    Reset counter: 150
                    Mileage: 146609 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.45 V
                    Reset counter: 150
                    Mileage: 146609 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.45 V
Address 15: Airbags
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Coding: 0012122
   Shop #: WSC 01279 785 00200
   VCID: 77BE160806B9F93E33-8022
00002 - Transmission Control Unit
   Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
   Revision: V0003000    Serial number: VWZ7Z0G8013723
   Coding: 0000207
   Shop #: WSC 01286 386 08256
   VCID: 312AE810A85DE70EBD-8064
7 Faults Found:
                    Fault Frequency: 9
                    Reset counter: 150
                    Fault Frequency: 14
                    Reset counter: 150
                    Mileage: 146578 km
                    Time: 17:00:43
                    Reset counter: 190
                    Fault Frequency: 9
                    Reset counter: 150
                    Fault Frequency: 9
                    Reset counter: 150
                    Reset counter: 150
                    Mileage: 146609 km
                    Time: 01:36:15
00438 - Fuel Supply Sensor 2 (G169)
                    Reset counter: 150
                    Mileage: 146609 km
                    Time: 00:24:35
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 110107F2001582
   Coding: BF03030007000000
   VCID: 2F2EEE68BE69F1FEAB-807A
01312 - Powertrain Data Bus
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 150
                    Mileage: 146609 km
                    Time: 01:50:11
                    Mileage: 146609 km
                    Time: 01:50:11
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T1RYX03
   VCID: 7DB204202485D36E69-8028
                    Fault Frequency: 21
                    Reset counter: 150
                    Mileage: 146609 km
                    Time: 21:31:39
Address 22: AWD
   Component: IMMO            VDD 1610
01176 - Key
                    Mileage: 146609 km
                    Time: 17:27:38
00003 - Control Module
            014 - Defective
                    Mileage: 146483 km
                    Time: 14:16:51
Address 44: Steering Assist
   Component:    KSG PQ35 RDK 052 0218
   Coding: 0000000000000000000000800001000188B820
   Shop #: WSC 01287 785 00200
   VCID: 044471C4476FA2A626-8050
                    Fault Status: 01101101
                    Reset counter: 150
                    Fault Frequency: 20
                    Reset counter: 150
                    Mileage: 146561 km
                    Time: 02:06:39
                    Fault Frequency: 20
                    Reset counter: 150
                    Mileage: 146561 km
                    Time: 02:06:39
00625 - Vehicle Speed Signal
                    Reset counter: 150
                    Mileage: 146609 km
                    Time: 01:42:58
00830 - Convertible Top Control Module (J256)
                    Reset counter: 190
                    Reset counter: 150
                    Mileage: 146609 km
                    Time: 01:36:15
End----------(Elapsed Time: 00:43, VBatt start/end: 14.5V/14.5V)-----------
gokarty
C?ID=401142
Did you individually check each fuse in all fuse boxes?
Did you try a battery disconnect? (might not help if something was shorted but worth a shot)
mkv_racer
C?ID=106940
yes and yes.
Jef
HQ
Can't help but notice this:
Is there ANY hardware in this car that was NOT factory installed? Maybe some parts swapping or something?
Ah main fuse is blow here or a terminal X relay for load reduction is FUBAR, maybe even ignition switch.
Just what location were you pulling in and how hard to do this? :rolleyes:
You sure you didn't inadvertently unplug something? :p
mkv_racer
C?ID=106940
lots removed. AWD swapped. But none of that changed since this problem started.
This is a gutted race car so expect all the misc. codes. We just pulled down the wire running up the A-pillar and got a minor spark then had the problem. Backprobed every fuse in both fuse panels. Also Tach doesn't work.
Sorry, feel kinda scattered in the information.
mkv_racer
C?ID=106940
Didn't really pull anything. Just unclipped.
Nothing was plugged in before. Harness goes up A-pillar then down into the dash.
Show pictures please of this race car, harness area and how you make your terminations of connection?
I hope not with these?
media.nl
mkv_racer
C?ID=106940
media.nl
Lol. No not with those. Everything is currently just unplugged. No wires were cut.
mkv_racer
C?ID=106940
So ECM is up and oil light is off. Still can't talk to ABS. From the Bentley it looks like pin 29 should have power but doesn't. Is there a way to get a good wiring diagram? The Bentley manual leaves me wanting component and splice locations.
gokarty
C?ID=401142
Have you tried Bentley's erWin? Usually you have to pay an access fee but you can download everything (the PDF files) in a day onto your computer.
They usually have the wiring diagrams for the entire car either in PDF form and/or using their "iWire" utility.
Here's a link to erWin: https://erwinusa.bentleymotors.com/erwin/showHome.do
Hope this helps
Regards,
gokarty
mkv_racer
C?ID=106940
