MK7 GTI and R DSG Reset of Adaption procedure
   #21
fmannix10
Ireland
C?ID=166285
Hi.
Mine was a hint at a slip followed by a hard clamp. More like the DSG was over powered by the extra boost and the DSG either adjusted its pressure or I just got lucky. I've heard it can monitor slip and adjust if more pressure is needed.
In any case, mine was not like what you show.
The JB1 guys said it is normal for it to slip a little in 3rd and 4th for 200+400rpms. I don't think it is nor should it be considered normal.
I have since put the JB1 back on but at 4.8 this time. I've had no slip since.
JB1 will stay on until 5000 miles when I plan to sell it and flash UM ECU+TCU.
I plan to keep the car for a while so if it ever slips. I will flash back to stock if needed.
Interesting that someone said it looks normal. Everyone has told me mine is slipping and not normal including BMS. I tried 4.5 on mine as well as a low power map 6 but it still had the same effect just a little less noticeable when adding less boost. I might try the basic settings again but keep it standard for a bit so it can re learn before enabling the JB1. Just to confirm you used the procedure in post #15 and you didn't do any other procedure, right?
Also you said you plan to get tune at 5k Miles. Your car is not brand new right? The clutches may need some time to bed in fully.
   #22
Mosquito
C?ID=14113
What I was told is that it is normal for it to slip slightly in 3rd and 4th and in the mid range as torque spikes. It was suggested to me that a tweak to Map 6 might help. Now running 4.5 on Map 1 has so far been issue free though the transmission does vibrate ever so slightly compared to stock. Its just not as smooth.
Keep in mind, in my case, it didn't slip in a way that I could say, video it. You'd have to sort of know the car to know it was about to slip and I had no interest in replicating it. I come from a MK6 MT Stage 2 with clutch upgrade and while DSG is different, any slip will glaze a surface. If I was in your shoes, I'd personally take out the JB1 all together, do the DSG reset procedure and drive the car stock and in manual mode for a week of daily driving in hopes of roughing up the disk surfaces again. just as a safe measure. Whether needed or not, it wouldn't hurt.
The DSG reset from #15 did help me though my issue was not severe. My car was purchased new 5 weeks ago, ran stock for over 1000 miles, broken in but has never been launched. I don't plan to do so, ever. The JB1 I purchased to test the hardware pre flash with TD1 in mind. Car now has 2000+ miles.
I don't plan to brake anything, but if anything must go. I want it to go now rather than later.
My tuner agrees with the approach.
I don't race it. Just spirited driving.
Hope that helps and good luck in your case.
   #23
Jef
HQ
Positive feedback:
ST?ID=74962
APR clutch kit and such, said it worked as described. Some one should buy Dana a vegi Wawa sandwich!
   #24
Gti Jazz Blue
Hampshire UK
C?ID=55809
Is this the latest info on Basic setting on this gearbox.
I've got a 2017 UK Octavia vRS with the DQ250 Gearbox, I've asked the dealer a couple of time to look at an intermittent issue with a hard shift from low speed and light throttle into 2nd gear (from 1st gear) - of course no errors and no fault found. I asked about a gearbox reset and they won't do it as they haven't seen any issue. As I've got VCDS I thought that I would try it myself.
Thanks.
Paul
VCDS Details of the gearbox:
Part No SW: 0D9 300 042 S HW: 02E 927 770 AS
Component: DQ250-6F MQB H54 5013
Revision: 06454104 Serial number: TFK01702212115
Shop #: WSC 73430 031 00063
ROD: EV_TCMDQ250021_VW27.rod
VCID: 2953828248350762CB7-807C
Dana
Western PA, USA
Yes it is. I have personally completed this on 3 MQB 6-speed DSGs (that weren't broken) over the years without issue so you should be OK.
Gti Jazz Blue
Hampshire UK
C?ID=55809
Thanks Dana - I will give it a go and see if my issue goes.
   #27
thg
New Member
After run "Basic settings of transmission" from the drop-down box, do I have to run other functions in the dropdown?:
https://ibb.co/9v0cwk8
My Golf 7 2.0 TDI 150 HP DSG6 make more and more hard shifts than earlier and it's time to change the gearoil and therefore I want to make a calibration etc. to make the shift perfect again.
Do you recommend to run the calibration before or after the gearoil change or both, so I do it 2 times?
Please post post an Auto-Scan for context.
silence23
Slovakia
C?ID=69675
So what is the full "basic setiing" procedure for DQ250 0D9? Engine on idle from beginning with foot on brake?
Which steps need to be done in which order?
Friday,10,March,2023,18:06:43:36626
VCDS Version: 23.3.0.0 (x64)
Data version: 20230228 DS346.1
VIN:   License Plate:
Mileage: 235570km-146376mi   Repair Order:
Chassis Type  NP-SK48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 2B 36 3C 42 44 47
          4B 52 5F 6C 6D 75 A5
VIN:    Mileage: 235570km-146376miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CJXA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 259 B    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---    CVN: 0998B610
   Coding: 0C1D001A2466050B3004
   Shop #: WSC 33361 790 00132
   ASAM Dataset: EV_ECM20TFS0203G0906259B 001003
   ROD: EV_ECM20TFS0203G0906259B_SK48.rod
   VCID: 2B5142A4428A22CB46-807E
   VINID: 91D4935497A019A1C50892401CD3F2D0C0
   Part No SW: 0D9 300 018 C    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01708040077 CVN: 0000580D
   ROD: EV_TCMDQ250021.rod
   VCID: 1C3391781724D5733F-8048
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 62407000000036
   Coding: 1D076B9C542223754780070040CA69B8D62AC4E2E002967538415078C2A9420000000012121212B835351919323200
   VCID: 79FDA8ECF856405B84-802C
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0454450929 Dataset Number: V03935254SK 0001
   Coding: 032C0C070F
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E777BF0A1F8A763F1-806A
   Subsystem 1 - Part No SW: 3AA 962 243 G    HW: 3AA 962 243 G
   Component: GEB.F.Heckoef  H16 0903
   Serial number: 84523798
   Part No SW: 3V0 907 044 CJ    HW: 3V0 907 044 CJ
   Component: AC Automat    H34 4402
   Revision: 20K10000    Serial number: 00000B00642189 Dataset Number: 0000
   Coding: 11010004004111011005100000101122
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 7EF7BBF0E1786763B1-802A
   Humidity sensor: exterior:
   Rear air conditioning block 1:
   Subsystem 2 - Part No SW: 3V0 907 049 E    HW: 3V0 907 049 E
   Component: E265KlimaHeck  H02 0101
   Serial number:       06051501850797
263425 - Air Quality Sensor
          B10AF 04 [009] - Internal System Fault
                    Fault Frequency: 13
                    Reset counter: 235
                    Mileage: 235480 km
                    Date: 2023.03.08
                    Time: 15:55:21
                    Outside temperature: 11.0 °C
                    Voltage terminal 30: 12.9 V
                    System run time-Engine running time: 253 s
                    Air quality status: Malfunction
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001724701137 Dataset Number: V03935261XB 0001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 081BDD28B3BC29D38B-805C
   Wiper motor control module:
   Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 170727  032 0121
   Serial number: 00000001707240309431
   Coding: 164DDD
   Component: RLHS  047 0105
   Serial number: S3Y17M09D14H03M46S49
   Coding: 00084D
   Serial number: 000000000ZY172310EPN
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223972233119
204546 - Remote key 2
                    Reset counter: 91
                    Mileage: 232244 km
                    Date: 2022.12.02
                    Time: 10:15:57
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): OFF
                    Status Bremslichtschalter (CAN): OFF
                    OFF: operated
                    Position lamps: Not operated
                    Automatic high beam assist: Not operated
                    Low beam: Not operated
                    Parking light left: Not operated
                    Parking light right: Not operated
                    last_wakeup: no cause for fault protection
                    Voltage: 12.9 V
                    Outside temperature: 10.0 °C
264968 - Sensor 2 for interior monitoring
          B1332 29 [008] - Signal Implausible
                    Reset counter: 252
                    Mileage: 234390 km
                    Date: 2023.02.03
                    Time: 11:46:42
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Automatic high beam assist: operated
                    Voltage: 12.6 V
                    Outside temperature: 5.5 °C
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418617163 Dataset Number: V03935262KV 0001
   Coding: 0471155851
   VCID: 4B912224E24A02CB66-801E
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H04 0195
   Dataset Number: V03935249LS 0001
   Coding: 3200674255FFC428949C8045
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 356564DC94CE643B20-8060
2068 - Databus
                    Reset counter: 13
                    Mileage: 235093 km
                    Date: 2023.02.28
                    Time: 07:39:42
                    Control Module temperature: 5 °C
                    Voltage terminal 15: 14.7 V
                    Velocity_vehicle_reference: 7.73 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.63 m/s˛
   Part No SW: 5Q0 959 655 BK    HW: 5Q0 959 655 BK
   Component: AirbagVW21    005 0336
   Serial number: 003VXR3BR039 Dataset Number: V03935255BD 0001
   Coding: 98FCC0C0000000005C5400CF004800000065
   VCID: 0A1FE720ADB05BC39D-805E
   Subsystem 1 - Part No SW: -----------    HW: 480 000 409 17
   Serial number: 3570000000044754B62F
   Subsystem 2 - Part No SW: -----------    HW: 480 000 409 17
   Serial number: 35800000000EE8AC172+
   Subsystem 3 - Part No SW: -----------    HW: 480 400 509 17
   Serial number: 3510001A3270BC53512S
   Subsystem 4 - Part No SW: -----------    HW: 480 400 509 17
   Serial number: 352000199269FFB2E1AS
   Subsystem 5 - Part No SW: -----------    HW: 480 400 509 17
   Serial number: 3550001C32685222B25V
   Part No SW: 5Q0 953 521 GE    HW: 5Q0 953 569 A
   Revision: FF035035    Serial number: 20170906501205 Dataset Number: V03935265ZH 0001
   Coding: 6414
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7BF1B2E4F26A724B96-802E
   Part No SW: 3V0 920 750 B    HW: 3V0 920 750 B
   Component: KOMBI         301 0310
   Coding: 07A5001AEF80000801886A0B5001000800000000
   Shop #: WSC 73430 031 00132
   VCID: 326F5FC065A0730305-8066
   Part No SW: 5Q0 963 272 H    HW: 5Q0 963 272 H
   Component: STH-MQB       008 0075
   Coding: 9309
   VCID: 3B7172E4B2EAB24BD6-806E
   Auxiliary heating remote control:
   Component: R64 D208L  004 0401
   Serial number: 00000000000000304537
0036 - Fuel Level too Low
          P1250 00 [008] - -
                    Reset counter: 2
                    Mileage: 234504 km
                    Date: 2023.02.07
                    Time: 17:13:05
                    Parking heater: operating condition: Start
                    7B
                    Coolant temperature of parking heater: 32 °C
                    Coolant temperature: 39 °C
                    Engine running status: detected
                    Fuel level: 10 l
                    Heating performance: 5000 W
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 07091710523527 Dataset Number: V03935258RY 0001
   Coding: 0B0100047F085900EB00025A1C0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00160
   GVL: 01D63C000800060040DC80008006C80000000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 33615AC49ABA7A0B0E-8066
   Generator:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000A1605280817
   Serial number: 5255514804
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: U13DCAC  H25 0780
   Serial number: 0058587
   Serial number: HA1-00018.07.17 Dataset Number: v1260x015G0 0000
   Coding: 0301
   VCID: 4A9F2720ED301BC35D-801E
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Serial number: 17000241004008
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB_VW41.rod
   VCID: 71ED90CCA026081B3C-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0022
   Serial number: Y0006QI621990
   Coding: 0010000000000500018480808080000000008181000000D400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   VCID: 3C7371F8B7E4B573DF-8068
   Component: HRE_Master    H12 0080
   Serial number: 0452800963 Dataset Number: V03935251FB 0001
   Coding: 02011103
   ROD: EV_HREntryHella_SK48.rod
   VCID: 3D757CFCACFEBC7BE8-8068
   Lane change assistance control module 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0453830369
   Coding: 020111
   Component: TSG FS        011 0032
   Serial number: 0000277367668  Dataset Number: V03935256LS 0001
   Coding: 001D0820DE00040000001100
   VCID: 47991E14FE22E6AB42-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000016251633
   Coding: 110200
   Part No SW: 5Q0 909 143 P    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2051
   Revision: 00000000    Serial number: 0001956740 Dataset Number: V03935255ZZ 0001
   Coding: 01000011004000
   ROD: EV_SteerAssisVWBSMQBA_009_VW48.rod
   VCID: 408B0508DB0CD19383-8014
Address 47: Sound System (J525)       Labels:| 81A-035-466.clb
   Part No SW: 81A 035 223     HW: 81A 035 223
   Component: MIB2_amp_P_SK H10 0410
   Revision: 00000001    Serial number: SKZ8Z1HJE02QA88 Dataset Number: V03935263JW 0001
   Coding: 0384010000AA002FAA0000000000
   Shop #: WSC 33361 790 00156
   ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
   ROD: EV_AMPMst16C5Gen2ALPI.rod
   VCID: 59BDC86C5896605BE4-800C
Address 4B: Multifunc. Module
Interface not compatible.
   Component: TSG BFS       011 0032
   Serial number: 0000276508871  Dataset Number: V03935256LW 0001
   Coding: 001D0220DE00040000001100
   VCID: 46871310F928FFA3B9-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000016207716
   Coding: 090200
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 565 035 043 A    HW: 565 035 043
   Component: MU-H-N-EU     H54 1163
   Serial number: A856H0HB013013 Dataset Number: V03935269RW 0001
   Coding: 03840101000000005111000200000A002F0100E401208500DE
   ROD: EV_MUHig4CGen2HBAS_AU37.rod
   VCID: 102BF548CBEC611353-8044
   Subsystem 1 - Part No SW: 3V0 919 606 D    HW: 3V0 919 606 D
   Component: ABT_High-2  H50 9130
   Serial number: SKZ6ZHT2422684
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 820 BL    HW: -----------
   Component: ECE 2023  --- 0310
   Compact disc data bank:
   Component: Gracenote2  --- 1016
   Dataset Number: V03935246QD 0001
   Coding: 04840101A2002017000040
   VCID: 397D68ECB8D6805BC4-806C
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31538481200000 Dataset Number: V03935263DB 0001
   Coding: 1008
   ROD: EV_DeckLidCONTIAU736_AU37.rod
   VCID: 418D000CD006D89B8C-8014
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0717
   Revision: --------    Dataset Number: V03935265GS 0001
   Coding: 03840101EA421A0D3B1CBE020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW32.rod
   Component: MQB_B_MFK     H08 0272
   Serial number: 31081712K22699 Dataset Number: V03935262LW 0001
   Coding: 0204080100000401002223548150A90088000E100040
   Shop #: WSC 04828 002 1048576
End---------------------(Elapsed Time: 06:15, udsna)-----------------------
