Need Login Code for Address 13: Auto Dist. Reg (J428)
Amedeo
Romania - Rm.Valcea
C?ID=14228
Hello Ross-Tech Forum
I need Loghin Code for Address 13: Auto Dist. Reg (J428)
Code 14117 not working
Monday,15,April,2019,11:57:51:61525
VCDS Version: 18.9.1.0  HEX-NET CB: 0.4502.4
VIN: TMBCJ9NE5J0098561   License Plate: xxxxxx
Mileage: 29982km-18629mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 3C 42 44 4B 52
          5F D6 D7
VIN: TMBCJ9NE5J0098561   Mileage: 29982km-18629miles
Address 01: Engine (J623-DCYA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 RH    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H24 4380
   Revision: B5H24---
   Coding: 01250012036605081000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM20TDI01104L906026RH 004001
   ROD: EV_ECM20TDI01104L906026RH.rod
   VCID: 014A4E3E90F95F42D2-8054
   Part No SW: 0GC 300 012 B    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1405
   Revision: 00H06V07
   ROD: EV_TCMDQ381061.rod
   VCID: 220821B2353FA45AEB-8076
   Revision: 00000000    Serial number: 61467000001354
   Coding: 2407629124290974407C070640C4292446249002E002947236615070C089430000000012121212B8586C384E4484EE
   VCID: 77BE20E6CE3D11F2EC-8022
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0442412915
   Coding: 032C0C
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_KessyHellaMQBAB 002020
   VCID: 3C34FFCAB79BF2AAC1-8068
   Part No SW: 5E0 907 044 AS    HW: 5E0 907 044 AS
   Component: Climatronic   H04 2001
   Revision: 00001K00
   Coding: 01010104002110011005000D00101022
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ACClimaBHBVW37X 006146
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 76A02DE2C93768FAF7-8022
   Air quality sensor:
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001713900984
   Shop #: WSC 73430 790 00000
   ROD: EV_BCMBOSCH_018.rod
   VCID: 095A561EA8C917028A-805C
   Subsystem 1 - Part No SW: 5E1 955 119 A    HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 170424  051 0915
   Serial number: 887353F0401711401359
   Coding: 164DDD
   Component: RLHS  042 0105
   Serial number: S8Y17M05D29H06M27S08
   Coding: 00885D
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418617145
   Coding: 0471055051
   VCID: 4BD6AC16E235451278-801E
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 3300600101FFC728949C810520400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E30F5C2A187E0BAEF-806A
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] -  -
          [FAULT_ALIGNMENT_NOT_OK]
                    Reset counter: 47
                    Mileage: 29982 km
                    Date: 2019.04.15
                    Time: 11:12:56
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 14.6 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] -  -
          [FAULT_MISALIGNMENT_VERTICAL]
                    Reset counter: 47
                    Mileage: 29982 km
                    Date: 2019.04.15
                    Time: 11:12:56
   Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
   Component: Airbag VW21   006 0702
   Revision: --------    Serial number: 003W6P7AKRFG
   Coding: 98FCC000000000005C5400CC000800000065
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 085C531AB3C36E0A95-805C
   Belt Pretensioner left:
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169593D27051790602
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169592D26051790757
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 454 001 605 17
   Serial number: 35700000000DB6C8B42$
   Subsystem 4 - Part No SW: -----------    HW: 454 001 605 17
   Serial number: 35800000000F86D8B42/
   Subsystem 5 - Part No SW: -----------    HW: 454 801 705 17
   Serial number: 3510048469010000000+
   Subsystem 6 - Part No SW: -----------    HW: 454 801 705 17
   Serial number: 35200C2BDC310000000L
   Subsystem 7 - Part No SW: -----------    HW: 454 800 105 17
   Serial number: 3550028C74D10000000H
   Part No SW: 5Q0 953 521 LA    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0245
   Revision: FF036036    Serial number: 20170529500520
   Coding: 6414
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CB43FCAF71B32AA81-8028
291104 - Temperature Sensor for Heated Steering Wheel
          B1455 01 [008] - Electrical Failure
                    Reset counter: 87
                    Mileage: 29982 km
                    Date: 2019.04.15
                    Time: 11:25:14
                    Ubat 30 Voltage: 12.90 V
                    Internal error state: 0
                    LIN_Temp: 254
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 18
                    Slope: 133
                    kp: 18
                    OUT: 50
                    Temperatur Statisch: 30
                    p_t_soll_0: 34.00 °C
                    p_t_soll_1: 39.00 °C
                    p_t_soll_2: 44.00 °C
   Part No SW: 5E0 920 751 E    HW: 5E0 920 751 E
   Component: KOMBI         303 0310
   Coding: 07A40018AD80000801882A095001000000000000
   VCID: 271E30A65E1D4172BC-8072
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   433 4303
   Revision: --------    Serial number: 0006365022
   Coding: 030100045F087300EB00025E1C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3326D4F69AC53DD210-8066
   Subsystem 2 - Part No SW: 3V0 919 719 C    HW: 3V0 919 719 C
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000D0979120517
   Serial number: 758860000017051912EE
   Serial number: HA1-00020.04.17
   Coding: 0001
   VCID: 4AD8A912ED4F5C1A43-801E
   Revision: 00000000    Serial number: 17000143810004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424D7EA9FCB3AEA09-8060
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0022
   Serial number: Y0006QE328166
   Coding: 0010000000000500018480808080000000008181000000D400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   Component: HRE_Master    H12 0080
   Serial number: 0441162265
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D32F2CEAC81FBA2F6-8068
   Component: HRE_Slave  H12 0080
   Serial number: 0440460711
   Coding: 020111
   Component: TSG FS        011 0032
   Serial number: 0000259295020
   Coding: 001D0120DE00048000001100
   VCID: 47DE9026FE5DA1725C-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0007
   Serial number: 00000000000014931721
   Coding: 010200
   Part No SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 0107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45C29A2EC451B362AE-8010
Address 4B: Multifunc. Module (J745)       Labels:* None
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 28051710801347
   Coding: 000000070100047200003D00010000000000000000000000000000000000
   VCID: 72A811F2A55F74DADB-8026
   Component: TSG BFS       011 0032
   Serial number: 0000259188596
   VCID: 46C09D22F957B87AA7-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0007
   Serial number: 00000000000014919328
   Coding: 190200
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 840 C    HW: 5Q0 035 840 C
   Component: MU-S--ER      H41 0456
   Serial number: SKZAZ2T5227265
   Coding: 03730100FF00000051110001000002232F0208C40120850003
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 2D12C28E7CE16B2246-8078
   Subsystem 1 - Part No SW: 5E0 919 605 N    HW: 5E0 919 605 N
   Component: ABT_Std-2  H50 8120
   Serial number: SKZ6ZHT1530910
Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
   Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
   Component: LED1L         H06 0005
   ROD: EV_LED_PLUS_L_KEBODAVW416_SK26.rod
   VCID: 7EB035C2E10720BAAF-802A
Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
   Component: LED1R         H06 0005
   ROD: EV_LED_PLUS_R_KEBODAVW416_SK26.rod
End----------(Elapsed Time: 01:33, VBatt start/end: 14.7V/14.8V)-----------
                Address 13: Auto Dist. Reg  (5Q0 907 572 J)
12:00:15
  IDE06307-MAS00109   Stop prevention history data-Hours 19
  IDE06308-MAS00109   Start request history data-Hours 17
  IDE08768   Mirror deviation: horizontal 24.464 °
  IDE08936   Misalignment angle: horiz -0.146 °
  IDE08937   Misalignment angle: horiz: fast algorithm -0.397 °
  IDE09380-MAS08804   Performed adjustment-Horizontal offset angle -0.02 °
  IDE11924-MAS13427   Correction angle-Horizontal correction angle: dynamic 0.000 °
  IDE11924-MAS13429   Correction angle-Horizontal correction angle: currently -0.390 °
  IDE11924-MAS13887   Correction angle-Horizontal correction angle static -0.020 °
12:00:43
  IDE08769   Mirror deviation: vertical -24.464 °
  IDE09380-MAS08805   Performed adjustment-Vertical offset angle 2.10 °
  IDE09906   Vertical deadjustment 6.783 °
  IDE11924-MAS13428   Correction angle-Vertical correction angle: dynamic 0.000 °
  IDE11924-MAS13430   Correction angle-Vertical correction angle: currently 6.770 °
  IDE11924-MAS13888   Correction angle-Vertical correction angle static 2.100 °
The car was moved in service with the plugs of Sensor for Automatic Distance Regulation removed. The angles were ok before.
Thank you for your help.
I'm not sure why you posted this in Forum Support and Feedback. Moved to Car Repair Support.
If the sensor(s) were not moved at all, have you tried just driving the car some?
Amedeo
Romania - Rm.Valcea
C?ID=14228
Mr. Uwe,
First of all, I apologize for the place I posted, and thank you for moving it where it should be. This is my first post and I hope I will not make mistakes anymore.
Yes, I drove my car behind the other machine at about 50 km / h and the fault did not change to intermittent.
myounus
Northwest UK
C?ID=321059
You'll either need to adjust the screws a little or I would personally get it recalibrated. I've removed my own ACC numerous times and re-fitted it without seeing that issue. It usually happens when it's been knocked or the adjustment is slightly out.
Amedeo
Romania - Rm.Valcea
C?ID=14228
It has no screws except fastening. Everything adapts with the tester. Thanks anyway.
myounus
Northwest UK
C?ID=321059
If you remove it you'll see that it's fixed onto adjustment screws.
Amedeo
Romania - Rm.Valcea
C?ID=14228
I was at the dealership, and in 20 minutes was ready. Only with the tester on the stand they did recalibration. Do not have walked in any adjustment screw.
The customer will return next week, I will make the test again and I'll post here.
Thank you, and if you have the security code, please send me. Maybe next time I can do it myself."
NEtech
C?ID=56995
I need Login Code for Address 13: Auto Dist. Reg (J428)
What exactly do you need login for, which basic setting or Adaptation, or other ?
Did they use calibration boards, together with tester ?
Was is static or dynamic calibration procedure ?
