This is from my Audi RS4.
Does anyone know what causes this fault? The Intake Manual is new, the fuel system is new. The Audi fuel pressure pumps are new.
It started about a 3 months after I installed the new Intake Manifold.
Best Regards,
MaseratiTMC
Best Regards,
MaseratiTMC
Wednesday,18,March,2020,01:13:15:07599
VCDS Version: 19.6.2.2 HEX-V2 CB: 0.4508.4
67 69 75 76 77
VIN: WUARU78E17N901656 Mileage: 181670km-112884miles
Address 01: Engine Labels:. 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 A HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0060
Revision: 57H13--- Serial number: XXXXXXXXXXXXXX
Coding: 01040009180F0160
Shop #: WSC 09222 067 57207
VCID: 2411EDA582DA25D78DD-8070
008567 - Bank 1; System Too Lean off Idle
P2177 - 001 - - Intermittent - MIL ON
Fault Status: 10100001
Fault Frequency: 6
Mileage: 181303 km
RPM: 2828 /min
Load: 25.1 %
Speed: 74.0 km/h
Temperature: 75.0°C
Temperature: 22.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.716 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Fault Status: 01101000
Mileage: 181672 km
Load: 0.0 %
Temperature: 86.0°C
Temperature: 73.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.811 V
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B030699EF04EAAF4C7-807E
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2833
Coding: 00000
VCID: 6D87C8811480249F123-50D0
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 01023
Shop #: WSC 65536
VCID: 3D2738C10460741FE23-4AA4
Address 11: Engine II Labels:. 079-910-560-BNS2.lbl
Shop #: WSC 09222 444 84347
P0300 - 001 -
Fault Status: 01100001
Mileage: 181485 km
RPM: 1390 /min
Load: 54.9 %
Temperature: 24.0°C
Temperature: 27.0°C
Voltage: 12.700 V
000771 - Cylinder 3
P0303 - 001 - Misfire Detected
Mileage: 181485 km
RPM: 1390 /min
Load: 54.9 %
Temperature: 24.0°C
Temperature: 27.0°C
Voltage: 12.700 V
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N0G03B4N
Coding: 0432607
VCID: 3C2135C51A6A7D17D5D-8068
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 3BK6Y
Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB4037E0795Sÿ†63
Subsystem 5 - Serial number: E0795Sÿ†6342DRB4037B492CWÿ†63
Subsystem 6 - Serial number: B492CWÿ†6352ARB4015CBA50Qÿ†63
Subsystem 7 - Serial number: CBA50Qÿ†6362ARB4015F4A9E+ÿ†63
Subsystem 8 - Serial number: F4A9E+ÿ†63729RB40169BD4B ÿ†63
Subsystem 9 - Serial number: 9BD4B ÿ†63829RB40169BD21Rÿ
Subsystem 10 - Serial number: 9BD21Rÿ
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0301
Coding: 04441
Shop #: WSC 06335
VCID: 44D14D25678A05D7ADD-4AA4
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 S HW: 8E0 920 981 S
Component: KOMBI+WFS 4 H14 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0023261
Shop #: WSC 09222 512 00000
VCID: 3D2738C10160741FE23-5118
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023261
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
VCID: 71BFD4F10888C07F36B-4B1E
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8E0 035 192 J HW: 8E0 035 192 J
Component: RNS-E US3 H72 0110
Revision: 03S Serial number: AUZBZ7F2463116
Coding: 0309637
Shop #: WSC 02195 785 00200
VCID: 2B030699EF24EAAF4C7-513C
Reset counter: 106
Date: 2005.08.27
Time: 15:48:11
Voltage: 12.50 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00857 - CD Changer Unit (R41)
Reset counter: 97
Date: 2019.08.12
Time: 16:46:40
16352 - Control Module - Electrical Error
014 - Defective
Fault Status: 01101110
Reset counter: 180
Date: 2013.05.02
Time: 18:41:42
02218 - Satellite Radio (R146)
Reset counter: 52
Date: 2019.06.09
Time: 16:29:54
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4135
Coding: 11820
Shop #: WSC 06335
VCID: 78A9E9D56BC29137F15-4AA4
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000019
VCID: 290FFC91E5F8F8BFBEB-807C
Component: AFS-Modul links H03 0010
Component: AFS-Modul rechtsH03 0010
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0309637
Reset counter: 106
Date: 2005.08.27
Time: 15:48:11
Voltage: 12.50 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Reset counter: 97
Date: 2019.08.12
Time: 16:46:40
014 - Defective
Reset counter: 180
Date: 2013.05.02
Time: 18:41:42
Reset counter: 52
Date: 2019.06.09
Time: 16:29:54
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0062523
Shop #: WSC 02197 785 00200
VCID: 2A0D039DE0DEF3A7B71-513C
02214 - Tire Pressure Warning
Reset counter: 10
(no units): 1.0
Temperature: 23.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Turn Rate: 0.00°/s
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Revision: 00H06000 Serial number: 00067802020618
Coding: 0000304
VCID: 313F14F1CD08807F76B-5160
Part No SW: 8P0 862 335 J HW: 8P0 862 335 J
Component: FSE_255x BT H21 0290
Revision: 00000001 Serial number: 00000000493814
Coding: 0011877
VCID: 3D2738C10160741FE23-50D0
End----(Elapsed Time: 04:34, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Address 01: DTCs cleared
Address 56: DTCs cleared
