2004 Audi A4 cluster adaptation
rrador
Canada
C?ID=68027
Is it possible to adapt new cluster for this car with vcds? I don't see procedure in the wiki.
Tried as immo3 cluster but that does not work.
It is RB4 cluster
Wednesday,29,May,2019,16:54:04:38330
VCDS Version: 18.9.1.0 (x64)
VIN: WAUAC48H24K014230   License Plate:
Mileage: 10km-6mi   Repair Order:
Chassis Type: 8H (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
          67 69 75 76 77
VIN: WAUAC48H24K014230   Mileage: 10km-6miles
Address 01: Engine        Labels: 06B-909-518-AMB.lbl
   Part No SW: 8E0 909 518 AK    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT     G   0006
   Coding: 0016584
   Shop #: WSC 93030 999 83980
   VCID: 79F93B8D334CE8829A-5140
18107 - Powertrain Data Bus
            P1699 - 008 - Missing Message from Steering Wheel Electronics - Intermittent
18043 - Powertrain Data Bus
            P1635 - 008 - Missing Message from A/C Controller - Intermittent
18058 - Powertrain Data Bus
            P1650 - 004 - Missing Message from Instrument Cluster - Intermittent
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 8E0 910 155 F    HW: 01J 927 156 JK
   Component: V30 01J 1.8l5VT USA 3220
   Revision: 00000007    Serial number: 00000001210603
   Coding: 0001001
   Shop #: WSC 93030 999 72925
   VCID: 285F2EC99866A10AB5-5122
18270 - Powertrain Data Bus
            P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
   Part No: 8E0 614 517
   Component: ABS/ESP front       3429
   Coding: 04279
   Shop #: WSC 00001
   VCID: 65C167FDFFF47C624E-5122
   Part No: 8E0 820 043 AD
   Component:   A4 Klimaautomat   1323
   Coding: 00100
   Shop #: WSC 00672
   VCID: 63C579E5F1C00252A0-5122
00532 - Supply Voltage B+
            49-00 - No Communications
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  KAN 0517
   Coding: 01014
   Shop #: WSC 00672
   VCID: 3561F7BD0FD4CCE23E-4AE8
8 Faults Found:
            57-00 - Electric Circuit Failure
01501 - Bulb for Blinkers; Rear Left (M6)
            79-10 - Please Check Fault Codes - Intermittent
Address 15: Airbags        Labels: 8H0-959-655-84.lbl
   Part No: 8H0 959 655 B
   Component: Airbag 8.4EC        2015
   Coding: 0010105
   Shop #: WSC 00672 785 00200
   VCID: 3979FB8D73CC2882DA-5122
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0611
   Coding: 01041
   Shop #: WSC 00672
   VCID: 3E73E8913AE20FBAEF-4AE8
   Part No: 8H0 920 900 C
   Component: KOMBI+WEGFAHRS. RB4 D17
   Coding: 02301
   VCID: 275D2DF5C578AE72BC-5122
   WAUAC48H34K009019     AUZ6Z0C0259440
01176 - Key
            65-10 - Unauthorized - Intermittent
01304 - Radio
   Part No: 8H0 959 433 C
   Component: Komfortgerát T7B    1412
   Coding: 11788
   Shop #: WSC 00672
   VCID: 3467CAB904AED5EA09-4AE8
   Subsystem 1 - Part No: Steuerger
   Component: t Fahr. antwortet nicht
   Subsystem 2 - Part No: 8H1959802
   Component: Tõrsteuer.BF BRM 0001
   Subsystem 3 - Part No: 8H0959801A
   Component: Tõrsteuer.HL BRM 0001
   Subsystem 4 - Part No: 8H0959802A
   Component: Tõrsteuer.HR BRM 0001
11 Faults Found:
00962 - Alarm via. Tilt Sensor
            35-00 -  -
            35-00 -  -
            35-00 -  -
            35-00 -  -
00892 - Switch for Trunk Closing Cylinder (F248)
            37-00 - Faulty
            37-00 - Faulty
   Part No: 4Z7 907 357
   Coding: 00070
   Shop #: WSC 00672
   VCID: 04075A79148EA56AF9-4B1A
End-------------------------(Elapsed Time: 05:49)--------------------------
That is not a new cluster it is a used cluster & with a different identity.
I could help you with a data transfer, provided you supply the needed controllers, all keys and proof of purchase with ownership credentials.
WAUAC48H24K014230
Emission standard0GNEmission standard ULEV 1
Vehicle Identification No.WAUAC48H24K014230
ModelAudi A4 Cabrio. 1,8
AA4C
Date of production26.11.2003
Model year2004
Sales type8H752H
Engine CodeAMB
Transmission CodeGHX
8H0 920 900 EX920-000instrument cluster260KM/H
"CDN"+
PR-9Q2
Vehicle Identification No.WAUAC48H34K009019
AA4C
Date of production11.09.2003
Model year2004
Sales type8H752H
Engine CodeAMB
8H0 920 900 EX920-000instrument cluster260KM/H"CDN"+
PR-9Q2
It is an Immo-3 cluster.
Are you certain both PINs are correct?
Is the key in the ignition matched to the old cluster and ECU?
It is a very common issue for incorrect pirated Chinese tools to corrupt the ability to do an 050 in RB type cluster due to protection Electronic Counter Measures by "ECM" in cluster for tampering.
rrador
Canada
C?ID=68027
WAUAC48H24K014230
AA4C
Model year2004
Sales type8H752H
Engine CodeAMB
"CDN"+
PR-9Q2
AA4C
Model year2004
Sales type8H752H
Engine CodeAMB
PR-9Q2
Used but virginised so for purposes of programming it's like brand new.
If original cluster was available i wouldn't be here, transferring data is easy
rrador
Canada
C?ID=68027
So it should program just like any other immo3 cluster? Just wasn't sure about that part because every time I did one of these original cluster was available to just transfer immo data from it.
Anything is possible but codes should be correct, read them with couple different tools to confirm.
Car is theft recovery from an auction and a lot of parts were missing along with the key, so it's a new blank key. Could that be a problem? But I'm pretty sure with immo3 that shouldn't matter as long the pins are correct
Yes, it sounds like that's the problem. With Immo-3 you can match one thing (key, cluster, or ECU) if the other two are already match, but you don't have that at the moment. I'm not sure what the solution is here.
I am OP , very common mistakes are made, send it to me for data transfer.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Manual Transfer only , which can not be done only with VCDS. But even if he has original key , used cluster at this car can not be adopted with VCDS, unless you set it to Factory 04 or 01 mode , even if you have both Pins.
( Jack Please do not comment on this ,Please , I like to respect UWE form last discussion)
No Marin, the forum doesn't work like that.
Again if the proper security clearance is had and input, with a successful login, you can indeed set this in adaption in VCDS & to the "desired immobilizer status"! or if the cluster is in a new mode status as the OP stated or as OP aforementioned a new blank key transponder can be married and then an 050 can take place or manual data transfer can save used transponders or if you know what you are doing you can default the ID48 transponders with OEM tools or some aftermarket tools.
Now if the EEPROM is off from improper tools used, that must be fixed manually too!
OP says it's virgin......
OP says new blank key!
OP please post adaption data or immobilizer status in advanced measuring blocks......
rrador
Canada
C?ID=68027
Yes new blank key. Not from dealer but we cut a new key with blank transponder.
Cluster has immo status 1
Thursday,30,May,2019,17:31:53:38330
VIN: WAUAC48H34K009019 License Plate:
Address 17: Instruments (8H0 920 900 C)
17:31:34
30 Adaptation Channel
9 Adaptation Channel
4 Adaptation Channel
3 Adaptation Channel
40 Adaptation Channel
41 Adaptation Channel
42 Adaptation Channel
43 Adaptation Channel
44 Adaptation Channel
45 Adaptation Channel
46 Adaptation Channel
1 Immobilizer Status
17:32:29
47 Adaptation Channel
48 Adaptation Channel
60 Adaptation Channel
61 Adaptation Channel
62 Adaptation Channel
18 Adaptation Channel
19 Adaptation Channel
4 Number of adapted Keys
rrador
Canada
C?ID=68027
OK all done. Was able to read pin/cs from ecu and write into cluster and new vin.
After that adapt the new key and all is good.
Thanks everyone for the help
