I'm having an issue with my white cluster swap. I used a 36/32 pin adapter so i'm having an error code for the 2nd fuel pressure sensor causing my fuel gauge to be off. i'm planning on fixing this today. The issue i can't figure out is that the vehicle status lists two items that i can't "ok" out of. the airbag error, due to the airbag igniter 2 not being resisted out (Planning on doing this weekend), and a service interval reminder. i tried clicking ok on the steering wheel, the back button, i just can't seem to get past the vehicle status menu. I'm guessing this is the reason i'm not able to see any of the audio track names, etc. I can see all other menus such as bluetooth (when my phone is connected), MFA for mpgs, speed, etc, and settings menu (minus convenience). When i had the red cluster, i had to ok past the airbag issue before i could see track names from the radio but i can't seem to do that anymore since the cluster upgrade. Any help would be appreciated. Below is a list of the hardware i'm using:
MK6 GLI Steering Wheel
RCD510 from 2014 Passat (1K0 035 188 F)
Bluetooth Module (7P6035730N)
White Cluster from 2013 Passat (3C8920 971B)
CAN Gateway (3C0907530Q)
Tuesday,08,May,2018,11:35:16:45999
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
Workshop Code: 028 00028 000001
VIN: WVWFU93C96P141044 License Plate: XXXXXX
Mileage: 93810km-58290mi Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 22 25 36 42 44 46 52 53 56
62 65 72 77
VIN: WVWFU93C96P141044 Mileage: 93810km-58290miles
Address 01: Engine Labels: 03H-906-032-BLV.clb
Part No SW: 03H 997 033 M HW: Hardware No
Component: P3.6-FSI-LEV2 G00 2370
Revision: --H08--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 00028 028 00001
VCID: 372823B8C346BE4F832-8062
000406 - Engine Oil Temp. Sensor (G8)
P0196 - 004 - Implausible Signal
Mileage: 93497 km
Date: 2018.05.05
Time: 00:04:46
RPM: 646 /min
Load: 31.0 %
Temperature: 65.0°C
Temperature: 45.0°C
Absolute Pres.: 830.0 mbar
Voltage: 13.716 V
Part No SW: 09G 927 750 HK HW: 09G 927 750 AJ
Component: AQ 250 6F 1271
Revision: 00H38000 Serial number:
Coding: 0000072
Shop #: WSC 20129 444 64522
VCID: 015C8D60DD0230FF7D6-8054
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658525310
Coding: 0046544
Shop #: WSC 20129 444 84803
VCID: 303A18A426286977C28-8064
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AC HW: 3C0 907 044 AC
Component: ClimatronicPQ46 050 0404
Revision: 00050005 Serial number: 00000000000000
VCID: 629EA2EC38448BE704C-8036
00710 - Defroster Flap Positioning Motor (V107)
Reset counter: 159
Mileage: 93815 km
Date: 2018.05.08
Time: 11:29:23
00716 - Air recirculation Flap Positioning Motor (V113)
Reset counter: 159
Mileage: 93815 km
Date: 2018.05.08
Time: 11:29:23
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000002275893
Coding: E5848B1340041000400A00000F00000000680040640000
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 00028
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7E2039462
VCID: 2B000FC80F0E0AAFF7A-807E
Reset counter: 159
Mileage: 93815 km
Date: 2018.05.08
Time: 11:28:44
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0M AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3PQVZGM%
Coding: 0012365
VCID: 2E0606DC3C1C7F87D04-807A
Subsystem 1 - Part No: 3C0 959 339 A
Component: BF-Gewichtsens. 006 0002
Subsystem 2 - Serial number: 00000000032UUM
Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME0D32666CJÿ†63
Subsystem 5 - Serial number: 2666CJÿ†6342MSME0D451A70Cÿ†63
Subsystem 6 - Serial number: 51A70Cÿ†6351HTS69SDQUAL2Jÿ†63
Subsystem 7 - Serial number: QUAL2Jÿ†6361HTS69SDMAN72 ÿ†63
Subsystem 8 - Serial number: MAN72 ÿ†63727TS6I2IIPQI20ÿ†63
Subsystem 9 - Serial number: IPQI20ÿ†63827TS6I2I6QN23Fÿ
Subsystem 10 - Serial number: 6QN23Fÿ
01587 - Igniter 2 for Airbag; Drivers Side (N250)
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
Component: J0527 0025
Revision: 00030000 Serial number: 3C5953507CN
Coding: 0002811
VCID: 74B2D4B492B01557660-8020
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H08 0010
Coding: 00000131
Part No SW: 3C8 920 971 B HW: 3C8 920 971 B
Component: KOMBI H05 0705
Coding: 261F00
VCID: 2C020CD406800D97FE0-8078
9459739 - Fuel Level Sensor 2
B1058 1B [009] - Resistance Too High
Reset counter: 158
Mileage: 93815 km
Date: 2018.05.08
Time: 11:19:24
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3640P1612801E9
Coding: FD82FF0700170200F102
VCID: 2F381BD83B16768FDB2-807A
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0002
Revision: 00005000 Serial number: 1166279TPYVX04
VCID: 6D84C1D0F19AC49FA9E-8038
Address 22: AWD Labels: None
VCID: 55F489307D0A6C5F71E-8000
No Faults Found
Part No SW: 3C0 959 433 Q HW: 3C0 959 433 Q
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 20129 444 54527
VCID: 382A2084CE58B1378A8-806C
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
VCID: 2C020CD40A000D97FE0-8078
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2461
Coding: 0001463
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 333017A8D73E526FBFA-8066
Component: KSG PQ46 RDK 051 0218
Coding: 1B910F8801860E761804141FF00A8F0E081800
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1K0 959 702 L
Coding: 0001462
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000013
VCID: 211CEDE07DC2D0FF5D6-8074
Part No SW: 1K0 035 188 F HW: 1K0 035 188 F
Component: Radio Prem-8 H05 0008
Revision: -----09S Serial number: VWZ4Z7N3483641
Coding: 0501000001000B
VCID: 2B000FC8030E0AAFF7A-807E
02633 - Antenna for Satellite Tuner
Fault Status: 01101011
Reset counter: 159
Mileage: 93815 km
Date: 2018.05.08
Time: 11:28:42
Reset counter: 159
Mileage: 93815 km
Date: 2018.05.08
Time: 11:28:42
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2432
Coding: 0000144
VCID: 313C1DA02D22607FCD6-8064
Component: RDK 0420
Coding: 0100100
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 323E12AC28245B67B4C-8066
Part No SW: 7P6 035 730 N HW: 7P6 035 730 N
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007666860899
Coding: 0A10040000010110
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3D243190EDFA941F59E-8068
End----------(Elapsed Time: 02:11, VBatt start/end: 13.7V/13.7V)-----------
