Current Versions
   #321
But I'm told that my Hex-Net is up to date. Where do I find the CFB & BL info?
VCIConfig will show them to you, but we don't have a Mac build of that ready, so you'll need something running Windows to use it.
Of course, I could also check the server...
[time passes]
You have CFB: 0.10, BL: 0.27, and DS: 0000050
VCIConfig would probably update your BL to 0.28, but this makes no perceptible functional difference.
romad
Prescott, AZ
C?ID=208765
Thanks, Uwe.
So the first digit of the Dataset is ignored and only the last 7 digits are important?
I was hoping I could use Codeweavers Crossover application to run the Windows applications but it looks like the last time any was tried was in 2012 and it failed to run on Crossover 12.
   #323
Thanks, Uwe.
It's not ignored. It contains flags that specify what (if any) old data must be scrubbed and replaced. But the actual version info is indeed in the digits on the right.
Shaun
Bump for new beta versions CB V0.4417 and DS 60000055
Beta Versions:
These updates are optional. If you are unsure, you do not need to do anything, you can stay on the release channel. If you accept some risks and wish to test the latest stuff, you can switch your interface to the beta update channel via the advanced tab in VCIConfig.
CB V0.4417
* Support for new UDS loc descriptions
* Support for new dataset
* Fix to make DTC clear counting consistent
* Adds support for ROD clear option
DS 60000055
* New rod and label data
* Support for ROD clear option
   #325
WebCF
C?ID=166818
CB: 0.4422
* Adds new UDS addresses
0.4417 -> 0.4422? Whats with 18-21? ;)
   #326
The only way to get a new version into an interface for internal testing is to give it a new version number. Not every version that we test is going to be be made available to the public.
MasterTommy
Amsterdam
C?ID=295586
What is ‘ROD clear option’?:)
   #328
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
It's a mini factory reset for VCDS Mobile, just for the ASAM/ROD data cache. It zaps anything you've downloaded over-the-air within Mobile, or with the VCIConfig utility. It's really only needed if you're troubleshooting something to do with ASAM/ROD data within VCDS Mobile running on HEX-NET. It has nothing to do with VCDS on Windows, and it doesn't apply to HEX-V2 at all.
   #329
romad
Prescott, AZ
C?ID=208765
I just did a check for any updates and was told my Hex-Net was up-to-date. However, the CodeBlock version on it is V0.4411, while version V0.4417 is listed as the current one in Post 1 of this thread. Why am I being told my device is up-to-date?
APP Id (1) CodeBlock V0.4411 API V4
FW version: 0.254.
Dataset: 00000050
K1: OK
K2: OK
CAN: Testing
VCDS-Cloud: OK
Config: OK
   #330
Release channel vs. Beta...
Use VCIConifg to set yourself to Beta if you wish.
romad
Prescott, AZ
C?ID=208765
Ah, OK that explains it. I'll just stay with the release version. Thanks, Uwe. Oh, my computer is an iMac so I just use Firefox to connect.
   #333
Shaun
Bump for CB V0.4430
* More fixes for Kline long header packets
* Fix for comms drop with certain modules that wait a long time to respond
   #334
tmoe
C?ID=109772
Bump for CB V0.4430
during update of cb V0.4430 from cb V0.4427 the process locked up and now the hexnet is no longer functioning. Just has one red light blinking when I plug in usb cable to test or config. Anyway to recover it?
   #335
Mike@Gendan
Swansea, UK
C?ID=57030
Does the Windows VCDS Interface Config Utility (VCIConfig) still retrieve the serial number ok?
If so, try this
   #336
tmoe
C?ID=109772
If so, try this
funny that thread was exactly what was going on with my hex-net. I did the reboot everything and it started but would fail with an error code -8 or com error or something like that. I normally don't have upnp enabled on my core router to the internet but I enabled it and then comm to ross-tech update servers started to work again. I forgot this has happened to me in the past and I forgot to enable before I start the CB update.
Many thanks for the info.
   #337
romad
Prescott, AZ
C?ID=208765
I just did an update and I'm told I am up to date with the following:
CB: 0.4411
FW: 0.254
CFB: 0.10
BL: 0.28
DS: 00000050
Does that look good for the channel I'm on? In Post #1 it lists BL: as 0.27
   #338
Shaun
Yes you are on release, so that is correct.
   #339
Of course he could set himself to Beta if he wanted to. ;)
romad
Prescott, AZ
C?ID=208765
No, I'm fine with the release channel. My only concern was with the BL version discrepancy between what I was told I had and what was shown here
