- Jun 28, 2016
- 98
- 31
- San Diego USA
- C?ID=281154
I'm going to try the "no oil" test again, and this time I will turn the engine over for 20 seconds or so with plugs out to purge the oil pressure system. Jack, when you say "Even remove oil sending unit while cranking it with plugs removed." are you referring to this? (minus hooking up the pressure gauge, of course)
http://forums.vwvortex.com/showthre...SI-Oil-Pressure-Switch-Replacement-(2007-Eos)
That looks like a royal pain. I'd prefer to try it without going through all that unless its absolutely necessary. And the oil filter housing should be ON? Last time I left it off with no mess of oil on the ground.
