The easiest way is to fit 1K0 614 517 xx (number from controler, NOT PUMP) + Right DuoSensor and you have Hill Hold , only few wires changes, but pipes stay this same
Jump to MK60EC1 is more wires change, pipes change , issue with coding , but also possible ,
It seems as though it is a component like this onewhat is the right duoSensor?
No. The above mentioned that it is the controller itself. The pump has its own part number1K0 614 517 xx is the Pump part of the ABS..... not?
