Audi A3 Virtual Cockpit Check Engine Light
hro0250
Washington, USA
C?ID=409496
Hi I’m new to the forum and to VW/Audi ownership. I just picked up a 2020 A3 premium plus without virtual cockpit. Because I'm not to up to date on VCDS programming I bought a virtual cockpit gauge cluster upgrade kit from a company and paid for remote programming services as well. The install went well and the new cluster is working perfectly except for the check engine light. I have a background in car electronic wiring and programming (mostly Ford products) however I can’t seem to get rid of the check engine light fault code U0155; lost communication with instrument panel cluster. I’ve gone over the forum post here (https://forums.ross-tech.com/showth...-8V-S3-PFL&highlight=retrofit+virtual+cockpit) and followed his diagram for the wire pinouts in the new cluster harness to make sure I had all connections. The guy who I paid to program with VCDS said it is an unusual error and has no idea why the check engine light is still on.. I initially thought it was because I was missing pin 1 (H20 connection in OBD) on the new cluster but after adding that wire the light is still on. I’m not sure if more coding is needed, additional wiring, or if I’m simply out of luck. Unfortunately I don’t have a screenshot or copy of his VCDS readout but any help would be greatly appreciated. Thank you for your time. :)
May I be so bold as to suggest that the owner of a 2020 Audi, who is doing retrofit/upgrades to his car and is seeking help in this forum, should consider spending the $199 it would take to have his own VCDS so he can post data here? ;)
hro0250
Washington, USA
C?ID=409496
Would that help? I honestly don't know, even the owner of a 2020 Audi doesn't always have more money to throw at the problem with no understood solution lol. Do you need my VCDS data readout to diagnose the problem? Because if I knew there was a solution at the end of that $200 then, yes, I would definitely consider. Like I said, my background is in Ford products which do not have different error codes other than what a typical OBDII scanner can detect, which is how I know my error code is U0115. I appreciate the reply however :)
Bruce
Near Philadelphia, PA, USA
Would that help? I honestly don't know, ..... Do you need my VCDS data readout to diagnose the problem?
I don't mean to be flip but our clair voyant ways do not work well.. We need information from the vehicle - information that is supplied by a full vag diagnostic tool. Else, all we can do is guess.
Because if I knew there was a solution at the end of that $200 then, yes, I would definitely consider. .... I appreciate the reply however :)
When you go to a doctor to ask for help, does he give a guarantee of a solution for the fee you pay?
We never give guarantees that we can provide a solution. However we also know that without the information from the tool, our ability to assist a user who has modified their brand new 2020 model is next to impossible.
Did you consider calling the guy who did the mods and asking him to email you the autoscan from VCDS? You could post "that autoscan" and avoid the investment in a tool that will let you maintain your brand new ride.
Would that help?
All I'll say is that this forum has been setup by the makers of VCDS to support owners/users of VCDS with diagnosing and fixing problems with VAG vehicles.
VCDS provides more detail of fault codes (as much as VAG will provide) than most generic OBDII scanners can/do, so a VCDS scan is usually more helpful.
If you are not and don't want to become an owner/user of VCDS then maybe you should be looking for help from Audi owners forums?
hro0250
Washington, USA
C?ID=409496
I'm sorry, I'm 22 and was just asking for some advise, I'm not a seasoned VCDS expert. I apologize that I didn't immediately order an expensive service because someone on an Internet forum told me to, I like to be sure of what I buy. I understand that you are not clairvoyant, I'm not asking for you to work magic. If an autoscan is what is needed to diagnose then I will have to buy VCDS; understood.
Thank you PetrolDave, I understand that they can provide more insight for experts, these are the type of answers I was hoping to get. However this is the free section of the forum, I figured I would see what, if anything, could be done before I jump the gun and purchase things I don't even know how to operate.
As for how doctors work, my mom is currently battling breast cancer so I'm acutely aware of how they operate, thanks. :)
Bruce
Your autoscan done by the guy who coded your cluster mod, is still stored on his pc. Call him and ask him to email it to you. It should cost you nothing to get that from him.
hro0250
Washington, USA
C?ID=409496
Thanks Bruce, I appreciate the help. I asked him but unfortunately he's horribly flakey, I probably should've just purchased VCDS and done it myself from the outset. If I don't hear from him within a day I'll pick up a copy of VCDS and post my autoscan.
hro0250
Washington, USA
C?ID=409496
Update: I never heard back from him so I bought VCDS, should be here by Wednesday. I had another question however; the company I purchased my virtual cockpit upgrade from also told me to buy an MMI unit from them to activate Nav and all other features on the VC. I wanted to do this anyways but not for the price they wanted. I was able to buy one cheaper on eBay which they confirmed would work in my car, but they need me to send the unit to them for programming? Is this also something I can do myself with VCDS or do they need the physical unit to change internal components? I'm hoping I don't need to send it to Europe and I can configure it to my car myself. Thanks :)
Edit: My question is why do they need the physical unit to program it when they were able to remotely program my virtual cockpit?
Bruce
If they are modifying the program in the control unit, then yes, you need to send it to them. VCDS does not allow one to put new programs into control modules. This is referred to as "flashing the module." VCDS allows one to turn on and off options through the control modules ability to be "coded". As I am not intimately familiar with the needs of your modification, I cannot say if the module has to be flashed or it can be mod'd by coding. Maybe others will know more than I.
hro0250
Washington, USA
C?ID=409496
That's a good question.. I got one from a car with Nav (it has the LTE antenna areal port and a SIM card slot). I plugged it in to my car to verify it works and I noticed it doesn't have navigation on the main home screen. Really all I wanted was an MMI unit with all the correct fakra connectors on the back for the VC as well as nav. My car had every other program on MMI already. It sounds like navigation may need to be flashed onto the module..
When I plug it in to my car everything starts up and appears to work, but there is no sound from the radio, and it won't allow me to connect bluetooth/use apple CarPlay. It also doesn't have all the correct vehicle settings, it seems as though I can add those with VCDS but navigation may not be on it...
DV52
C?ID=194404
hro0250: I note your continued attempts to resolve this matter.
If you have purchased a new MMI from eBay and if "everything starts up and appears to work, but there is no sound from the radio" -I suspect that you have Component Protection DTC s in both the hex5F and Hex19 modules.
Of course, the only way to confirm this suspicion is for you to follow Uwe's tactful, but nevertheless necessary advice below:
Without a current, complete (meaning unedited) copy of an auto-scan for the car - all responses by others on this forum (including my reply) are just sheer speculation!!
hro0250
Washington, USA
C?ID=409496
Thanks Don, as I said in my previous post, I have purchased VCDS and I will be posting an autoscan hopefully tomorrow. I will also plug in my new MMI unit to ensure its fault codes show up on the autoscan as well. However even speculation at this point is helpful as I was kind of thrown to the wind by this company, so I am trying my best to gather info and learn as I go. :thumbs:
hro0250
Washington, USA
C?ID=409496
Alright.. I see more error codes than I'd like, hopefully now they make sense to you guys.
Tuesday,30,June,2020,16:56:44:03229
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUJEGFF4LA039731   License Plate:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 39 3C 42 44 47 4B
          52 5F 6C A5 BB BC CF D6 D7
VIN: WAUJEGFF4LA039731   Mileage: 3227km-2005miles
2B-Steer. Col. Lock -- Status: Malfunction 0010
Address 01: Engine (J623-DHHA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 0A2500324466010F3000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001003
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C21313366EB6E3B4F3-8068
38649 - EVAP Purge System
          P00FE 00 [096] - Line Restricted / Blocked
                    Mileage: 3003 km
                    Date: 2020.06.25
                    Time: 15:55:56
                    Engine speed: 1504.00 /min
                    Vehicle speed: 60 km/h
                    Coolant temperature: 100 °C
                    Intake air temperature: 51 °C
                    Voltage terminal 30: 14.433 V
                    Unlearning counter according OBD: 30
                    Engine: operating status: PUC
                    STATE_LS_SAE[1]: OL_INTR
                    T_AST_SAE: 643 s
                    MAP_MES_SAE: 30 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 3.071 V
                    FAC_TPS_1_SAE: 13.281250 %
                    FUP_H_SAE: 8060.0 kPa
19868 - No Communication with Instrument Cluster
          U0155 00 [175] - -
                    Mileage: 2288 km
                    Date: 2020.06.08
                    Time: 18:15:37
                    Engine speed: 1135.75 /min
                    Normed load value: 8.6 %
                    Coolant temperature: 78 °C
                    Intake air temperature: 46 °C
                    Voltage terminal 30: 13.750 V
                    Engine: operating status: IS
                    ECU_STATE: SYN_ENG_IGK_ON
                    Engine oil temperature: 67.0 °C
                    Time since engine start: 52.0 s
                    T_ES: 0 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Status: OK
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: operated
                    Cruise control switch actuation-Coding: plausible
                    Cruise control switch actuation-Limit function: not selected
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: operated
                    Cruise control switch actuation-Large increment: not activated
                    Cruise control switch actuation-Control component verified: Yes
                    T_AST_SAE: 0 s
23079 - Control unit for information electronics 1
          U1054 00 [047] - No Communication
                    Mileage: 2288 km
                    Date: 2020.06.08
                    Time: 18:15:37
                    T_ES: 0 min
                    T_AST_SAE: 0 s
   Part No SW: 0GC 300 013 M    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2402
   Revision: 00H06V09
   ROD: EV_TCMDQ381061.rod
   VCID: 2E050B7BA0978CABF17-807A
   Part No SW: 5Q0 614 517 FH    HW: 5Q0 614 517 BS
   Component: ESC           H82 0191
   Revision: 00000000    Serial number: 61709000000162
   Coding: 13FF6B9250232275897E0B03A0C469C8D60A4491D005967C1841505492A84A0B0000000012121212B835351919323200
   Shop #: WSC 00046 000 00000
   VCID: 7CA1F133266BAE3B0F3-8028
8236 - Databus
          [FCAN: Kombi_01 messagei is not received]
                    Reset counter: 141
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 11:38:20
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0533132295
   Coding: 030C0C1720
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D754D715212FF320D-8010
12718086 - Databus
          [Message WFS_01 missing]
                    Reset counter: 143
                    Mileage: 2288 km
                    Date: 2020.06.08
                    Time: 16:38:00
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: OFF
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: OFF
                    ZAT_pressed: OFF
                    Park selector lever position: Engaged and locked
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 12.439 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: Open
                    Front Passenger Door: Open
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID sensor 1 authentication: status: No response
                    ID sensor 2 authentication: status: No response
                    ID sensor 3 authentication: status: No response
                    ID sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 8V0 820 043 AL    HW: 8V0 820 043 AL
   Component: AC Automat    H03 0161
   Revision: 20001000    Serial number: 00000001931597
   Coding: 03000014010000001000000000001400
   Shop #: WSC 06335 790 00021
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008026
   Subsystem 1 - Part No SW: 4H0 907 658 D    HW: 4H0 907 658 D
   Component: G935 MuFu  H04 0010
   Serial number: 2510191409PAG0MUFU05
459011 - Databus
                    Reset counter: 141
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 11:38:20
   Part No SW: 5Q0 937 085 CB    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H40 0312
   Serial number: 01001931300722
   Shop #: WSC 06324 790 00021
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 7BA3F22F2365A903069-802E
   Component: WWS371 190823  043  0585
   Serial number:         190913083158
   Coding: 0A47F7
   Component: G397_RLFS  H06  0002
   Serial number: 22072612X81A955547A0
   Coding: 00006C
   Component: E1 - LDS MQB  H06  0032
   Serial number: 28 08 2019  20001138
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY1928019A7
   Component: Sirene, DWA  005  0314
   Serial number: 00000000000031914425
   Sun Roof:
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H04  0005
   Serial number: 0000FST002FEBW200000
   Coding: 101F00
   Steering Column Switch:
   Subsystem 7 - Part No SW: 82A 953 521 CQ    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0070
   Serial number: 00000026101904401337
395273 - Control Circuit for Signal Horn
          B1344 14 [008] - Open or Short to Ground
                    Reset counter: 161
                    Mileage: 2958 km
                    Date: 2020.06.24
                    Time: 17:12:50
539925 - Databus
          [Kombi_02 Datenbus fehlende Botschaft]
                    Reset counter: 143
                    Mileage: 2288 km
                    Date: 2020.06.08
                    Time: 16:38:00
558869 - Databus
          [Kombi_01 Datenbus fehlende Botschaft]
                    Reset counter: 141
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 11:38:20
   Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0061
   Serial number: 000150057319291
   Coding: 0270167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009048
   ROD: EV_EPHVA2CAU3700000_009_AU37.rod
   VCID: 55F78497E5819F7350D-8000
12670209 - Databus
          [Steuergerät für Schalttafeleinsatz-J285 - Kombi_01 - kein Signal/keine Kommunikation]
                    Reset counter: 141
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 11:38:20
   Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
   Coding: B50087C111FFC428949C815580302600000000000000000004
   VCID: 44D149D31E1B16FB373-8010
1080 - Databus
          [FAULT_TIMEOUT_KOMBI_01]
                    Reset counter: 141
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 11:38:20
                    Control Module temperature: 35 °C
                    Voltage terminal 15: 11.1 V
                    Status_ACC_System: ACC_Off_MainSwitch_Off
   Component: AirbagVW20    012 0830
   Serial number: 003GCR0GXXFQ
   Coding: 9DCCFCC0000000005000001AC248000000C5
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 47CB5EDF2F2D3DE3D21-8012
   Belt Pretensioner left:
   Component: BeltPretRevFL  H37 0350
   Serial number: 34230167A25101920306
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H37 0350
   Serial number: 34230168A22101920366
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001X8DVJ
   Coding: 303430
   Subsystem 4 - Part No SW: -----------    HW: 480 003 010 19
   Serial number: 357000000002F3512044
   Subsystem 5 - Part No SW: -----------    HW: 480 003 010 19
   Serial number: 35800000000DF658BF36
   Subsystem 6 - Part No SW: -----------    HW: 480 400 511 19
   Component: SideSensor_Dr  002 6149
   Serial number: 35100012A62E7526950Z
   Subsystem 7 - Part No SW: -----------    HW: 480 400 511 19
   Component: SideSensor_Pr  002 6149
   Serial number: 35200012A62E7524816Z
   Subsystem 8 - Part No SW: -----------    HW: 480 402 210 19
   Component: FrontSensor_D  004 6149
   Serial number: 35500012C62E74E485CI
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 402 210 19
   Component: FrontSensor_P  004 6149
   Serial number: 35600012C62E74E2F40B
1051904 - Databus
          [NWD: 0x30B Kombi_01Timeout]
                    Reset counter: 141
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 11:38:20
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790     HW: 8V0 920 790
   Component: FBenRDW       H13 0045
   Coding: 048418506F80CE080085E8001000500000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001023
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 79AFE82729599B13145-802C
          U1014 00 [009] - -
          [ECU incorrectly coded]
                    Fault Frequency: 89
                    Reset counter: 134
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 11:42:11
9582600 - Switch for Instrument Cluster
          B1893 13 [009] - Open Circuit
                    Fault Frequency: 202
                    Reset counter: 134
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 11:42:11
16777022 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
          [NAV_SD_0x32 communication error bap_error_timeout heartbeat]
                    Fault Frequency: 9
                    Reset counter: 164
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 11:42:11
   Component: GW MQB High   442 4388
   Revision: --------    Serial number: 0000233123
   Coding: 030100043F0859005B00005E180B00000001010000000000000000000000
   ROD: EV_GatewNF_AU37.rod
   VCID: 70B9D5037A23DA5BA3B-8024
   Component: 4-01-0D-01-04
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20200122020402 20064
   Serial number: 75886003911910250CF1
131604 - No Communication with Instrument Cluster
          U0155 00 [008] - -
          [Timeout Knoten 0x14 / 17 - Steuergerät für Schalttafeleinsatz]
                    Reset counter: 143
                    Mileage: 2288 km
                    Date: 2020.06.08
                    Time: 16:38:00
                    Supply voltage: Terminal 30: 12.3 V
                    Terminal 15: OFF
131699 - Control unit for information electronics 1
          [Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
                    Reset counter: 143
                    Mileage: 2289 km
                    Date: 2020.06.08
                    Time: 16:23:19
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: OFF
197169 - Controls in Steering Wheel
          U108E 00 [008] - No Communications
          [MFL (LIN#2) Timeout]
                    Reset counter: 161
                    Mileage: 2958 km
                    Date: 2020.06.24
                    Time: 17:35:44
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: OFF
8526361 - LV Energy Management
          B1802 F1 [008] - Warning Triggered
                    Reset counter: 141
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 11:15:22
                    Supply voltage: Terminal 30: 11.2 V
                    Terminal 15: On
   Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00025.09.19
   Coding: 0001
   Shop #: WSC 06325 790 00021
   VCID: 4CC161F3364BDEBBFF3-8018
16654 - Databus
          [Kombi - TO -- Kombi_01]
                    Fault Priority: 8
                    Reset counter: 141
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 11:38:20
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H07 0022
   VCID: 42DD4FCB040F18CB05F-8016
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000307431007
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_AU37.rod
   VCID: 313F1007B1A99353EC5-8064
12666387 - Databus
          [Timeout Message WFS_01]
                    Reset counter: 143
                    Mileage: 2288 km
                    Date: 2020.06.08
                    Time: 16:38:00
                    Result lock conditions: valid
                    ESCL locked: Yes
                    ESCL unlocked: No
                    Lock sensor: operated
                    Unlock sensor: not activated
                    Error mode 1: not active
                    Error mode 2: not active
                    Clamp S: OFF
                    Clamp 15: OFF
                    Clamp 15 Status: valid
                    Remote Start: not active
                    Driver door: Open
                    Central locking locked external: unlocked
                    Central locking safed external: Vehicle not secured
                    Clamp Request: No
                    Request highside lock: No
                    HW highside lock: OFF
                    Highside unlock: No
                    Motor break: not active
                    Activation lowside unlock: OFF
                    Activation lowside lock: OFF
                    I2C overflow: No
                    I2C error pathflags: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C length failure: No
                    I2C error sda: No
                    I2C communication failure: i2c no comm failure
                    I2C state esp 10: i2c cnd true
                    I2C cnd haco message: valid
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: Yes
                    Signature IMS OK: Yes
                    IMS responded: Yes
                    Positive authentification in current KL15 cycle: No
                    Lifestate: Immobilizer download obtained
                    Learn mode: Adapted
                    Authentication valid (T1): No
                    State of authentication state machine: WFS_AUTH_INIT_e
                    Vehicle speed: 0.00 km/h
                    UBat internal: 11.7 V
                    UMotorBridge: 6.4 V
                    Lock condition engine speed: Condition met
                    Lock condition clamp S: Condition met
                    Lock condition clamp 15: Condition met
                    Lock condition E2E clamp status: Condition met
                    Lock condition timeout clamp status: Condition met
                    Lock condition vehicle speed: Condition met
                    Lock condition E2E vehicle speed: Condition met
                    Lock condition timeout vehicle speed: Condition met
                    Lock condition Mode1: Condition met
                    Lock condition drive readiness: Condition met
                    Lock condition selector lever position parking: Condition met
                    Clamp enable ESCL: not enabled
                    Lock condition timeout distance pulse: Condition met
                    Lock condition E2E distance pulse: Condition met
                    Lock condition difference distance pulse: Condition met
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Part No SW: 3Q0 907 566 J    HW: 3Q0 907 566
   Component: MRR1Rear      H25 0640
   Revision: --------
   Coding: 04C002
   VCID: 3FDB463F77FD75236A1-806A
1311234 - Control Module for Lane-Change Assist
          C1114 F3 [008] - Limited Visibility
                    Reset counter: 144
                    Mileage: 2308 km
                    Date: 2020.06.09
                    Time: 06:17:15
                    Control Module temperature: 32 °C
                    Voltage terminal 30: Measured value not available
                    Vehicle speed: 75.85 km/h
                    Terminal 15 status: Measured value not available
                    Voltage terminal 15: 12.60 V
1183837 - Databus
          [databus message missing - Kombi]
                    Reset counter: 141
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 11:38:20
                    Control Module temperature: 43 °C
                    Voltage terminal 15: 10.80 V
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0325
   Serial number: YE007SIU1030A
   Coding: 005E1B204000008000000002
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: 49CF58E73939CB93C45-801C
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1D9130E3BE67B473-8020
22016 - Databus
          [KFC_KOMBI_01 Botschaft - CAN-Timeout]
                    Reset counter: 141
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 11:38:20
                    Motor status: 00
                    Supply voltage: 11.25 V
                    Temperature: 25.0 °C
                    KFC: 56
                    KFA: 00 00
                    Environmental conditions: 20
                    uioUdNotFilt_xdu16: 11.41 V
                    uAdSensI_SwitchedKl30_xdu16: 11.32 V
                    NoInitCause_AsicSens: [0x00] ASC_CTRL_SAS_NO_ERR
                    NoInitCause_RackPos_Rohwert: 00 00
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_KMN_RACKPOS_SET: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_WHLSPDPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
Address 47: Sound System (J525)       Labels:| 81A-035-466.clb
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAK5F02TC51
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 2411E953FE5B36FB173-8070
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 02111910802027
   Coding: 000000050900147200112300040000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003_VW41.rod
   VCID: 372B2E1F5FCD4D63A21-8062
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0325
   Serial number: YE007SJ112625
   Coding: 005E13204000008000000002
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   VCID: 48C95DE32233329BDBB-801C
   Part No SW: 8V1 035 652 D    HW: 8V1 035 652
   Component: MU-HS-S-US    050 0185
   Coding: 017301000000000011220002061A00232F002DE401F001040A
   ASAM Dataset: EV_MUHigScl6C3DELP 001011
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 38292D2352D3421BABB-806C
   Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0014
   Serial number: AUZ8Z9K1Y0LRB2
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 BR    HW: 8V0 919 614 BR
   Component: ControlUnit_B  H50 0106
   Serial number: ALJAL112091900050238
11 Faults Found:
          B201A 00 [009] - -
          [Check software version management]
                    Fault Frequency: 84
                    Reset counter: 134
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 10:32:25
                    Voltage terminal 30: 11.5 V
                    Status_Software_Version_Management-module_name: C
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [008] - Open Circuit
                    Reset counter: 143
                    Mileage: 2288 km
                    Date: 2020.06.08
                    Time: 00:00:43
                    Voltage terminal 30: 11.3 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [008] - Open Circuit
                    Reset counter: 143
                    Mileage: 2288 km
                    Date: 2020.06.08
                    Time: 00:00:43
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 0 dBµV
0009 - Antenna for Satellite Radio
          B10F4 13 [008] - Open Circuit
                    Reset counter: 143
                    Mileage: 2288 km
                    Date: 2020.06.08
                    Time: 00:00:43
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Channel selection for satellite radio: 0
                    Satellite radio tuner status-Audio Signal: Not available
                    Satellite radio tuner status-Antenna current: 255 mA
                    Satellite radio tuner status-Reception quality: Not available
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: Initial_value_forMPFA_not_coded
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: FF
2565 - GPS Antenna
          B1054 13 [008] - Open Circuit
          [GPS aerial - open circuit]
                    Reset counter: 143
                    Voltage terminal 30: 12.5 V
1562 - Microphone 1
          B129B 11 [008] - Short to Ground
                    Reset counter: 141
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 11:16:39
6179 - Display Module 1 for Multimedia System
          B1297 F6 [008] - Cable for Video Signal; Open Circuit
                    Reset counter: 143
                    Mileage: 2288 km
                    Date: 2020.06.08
                    Time: 00:00:43
6666 - Optical data bus
          U1049 00 [008] - Open circuit
                    Reset counter: 143
                    Mileage: 2288 km
                    Date: 2020.06.08
                    Time: 16:37:59
                    Voltage terminal 30: 12.4 V
                    Temperature of MOST transceiver-max.value: -50 °C
                    Temperature of MOST transceiver-min.value: 0 °C
                    Temperature of MOST transceiver-Current: 35 °C
6698 - Optical data bus
          [Optical data bus: open circuit: wakeup]
                    Reset counter: 143
                    Mileage: 2288 km
                    Date: 2020.06.08
                    Time: 16:38:00
6667 - Optical Data Bus for Information Electronics 1
          U10CA 00 [008] - Intermittent Disruption
          [Optical data bus: sporadic open circuit in central processor]
                    Reset counter: 143
                    Mileage: 2288 km
                    Date: 2020.06.08
                    Time: 00:02:12
                    Voltage terminal 30: 13.8 V
                    Temperature of MOST transceiver-Current: 27 °C
6669 - Optical Data Bus for Digital Sound System
          U10CC 00 [008] - Intermittent Disruption
          [Optical data bus: sporadic open circuit in sound]
                    Reset counter: 143
                    Mileage: 2288 km
                    Date: 2020.06.08
                    Time: 00:01:02
                    Voltage terminal 30: 13.3 V
                    Temperature of MOST transceiver-Current: 29 °C
   Component: RVC Compact   H18 0231
   Coding: 0273010102002001400040
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
   VCID: 392F282769D95B13545-806C
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 08111915P10142
   Coding: 040307010000020101220046C14E490080000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D945C30A030ADB13B-8014
1122612 - Databus
          [TIMEOUT_Kombi_01]
                    Reset counter: 141
                    Mileage: 2230 km
                    Date: 2020.06.08
                    Time: 11:38:20
                    Control Module temperature: 52 °C
                    Outside air temperature: 13.5 °C
                    System run time: 5849.3 s
                    Voltage terminal 15: 11.2 V
                    mid: 01 CF
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
   Part No SW: 5Q0 959 395 K    HW: 8W1 959 395 D
   Component: TSG HFS004 0325
   Serial number: YE007SJ51109E
   Coding: 000C13204000008000000002
   ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
   Component: TSG HBFS004 0325
   Serial number: YE007SJ51109B
   ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
   Part No SW: 3Q0 907 590 J    HW: 3Q0 907 590
   Revision: --------
   Coding: 04C002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
   Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
   Component: LED1L         H09 0008
   ROD: EV_LEDModLeftMELCOAU736_AU37.rod
   VCID: 176BCE9F3F0D6D63821-8042
   Component: LED1R         H09 0008
End----------(Elapsed Time: 01:50, VBatt start/end: 12.2V/12.2V)-----------
OP is now verified. Moving to Retrofits.
This car has a boatload of fault codes that are flagged "Intermittent". Please clear all fault codes, cycle the ignition, and then re-scan it. Doing so should improve the signal-to-noise ratio in the data tremendously. :)
hro0250
Washington, USA
C?ID=409496
Will do, updated autoscan coming this evening.
Thanks! :thumbs:
DV52
C?ID=194404
Arrrrh.......... that's better (thanks for posting) - now we can see the heart-beat of the car in all of its pristine detail!!!
It looks like you were a busy boy on the 8th June 2020 @ about 11:30 AM - I'm guessing that's when you did the hex 17 module swap, maybe (with an auto-scan we can even see what color underpants you were wearing on that day - but that's probably too much information ;)).
I'm looking forward to seeing the refreshed auto-scan as Uwe has suggested; sans the misdemeanor DTC s which were likely generated while you were busy unplugging/reconnecting various wires/sockets.
In any event, if I look only at those DTC s in your auto-scan that have a respectable "Fault frequency" (meaning the number of times that the fault has been re-recorded by the CAN network on any subsequent ignition cycle after first registration), it seems that it's all happening in the hex 17 module (perhaps unsurprisingly)
So, in repesct of the "Control Module Incorrectly Coded" DTC on the hex17 module - here's how the long-code looks in a more readable form:
Byte	Hex	Binary
0	04	00000100
1	84	10000100
2	18	00011000
3	50	01010000
4	6F	01101111
5	80	10000000
6	CE	11001110
7	08	00001000
8	00	00000000
9	85	10000101
10	E8	11101000
11	00	00000000
12	10	00010000
13	00	00000000
14	50	01010000
15	00	00000000
16	00	00000000
17	00	00000000
18	00	00000000
19	00	00000000
I've highlighted Byte 14, Bit 5 which according to my database is the software switch for intelligent park assist - I note that on the hex44 module, Byte 0, Bit 1 is set -suggesting that the car has parallel parking capabilities, Can you confirm that the car has this facility?
In respect of the only other "respectable" fault frequency DTC - Switch for Instrument Cluster B1893 13 [009] - Open Circuit, this very much looks like this is a wiring matter. Given the non-specific nature of the fault descriptor, its difficult to be precise as to which switch this is - perhaps some one else here can advise?
hro0250
Washington, USA
C?ID=409496
I can confirm my car does have self-park capabilities. The open circuit is also me, I do not have the 0.0 trip reset button installed. It was on back order so for now it is not wired in. The garbage trip button that came with my Aliexpress kit broke before I could even install it so I decided to buy the OEM, it just took a month coming from Germany.
This autoscan looks better. Any thoughts?
Wednesday,01,July,2020,17:07:30:03229
VIN: WAUJEGFF4LA039731   Mileage: 3295km-2047miles
   Revision: --H13---
          U0155 00 [039] - -
                    Mileage: 3295 km
                    Date: 2020.07.01
                    Time: 16:58:25
                    Coolant temperature: 92 °C
                    Intake air temperature: 50 °C
                    Voltage terminal 30: 12.265 V
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 104.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 14 min
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    T_AST_SAE: 0 s
          U1054 00 [039] - No Communication
                    Mileage: 3295 km
                    Date: 2020.07.01
                    Time: 16:58:25
                    ECU_STATE: ENG_STOP
                    T_ES: 14 min
                    T_AST_SAE: 0 s
Readiness: 1110 1101
   Revision: 00H06V09
   Coding: 030C0C1720
   Coding: 0A47F7
   Coding: 00006C
   Sun Roof:
   Coding: 101F00
   Coding: 0270167851
   Coding: 333135
   Coding: 333135
   Occupant Detection:
   Coding: 303430
          U1014 00 [009] - -
                    Reset counter: 136
                    Mileage: 3295 km
                    Date: 2020.07.01
                    Time: 17:00:44
                    Reset counter: 136
                    Mileage: 3295 km
                    Date: 2020.07.01
                    Time: 17:00:44
   Coding: 0001
   Revision: --------
   Coding: 04C002
   Coding: 931F0000
          B201A 00 [009] - -
                    Reset counter: 136
                    Mileage: 3295 km
                    Date: 2020.07.01
                    Time: 17:02:45
                    Voltage terminal 30: 12.2 V
   Revision: --------
   Coding: 04C002
End----------(Elapsed Time: 01:43, VBatt start/end: 12.1V/12.1V)-----------
DV52
C?ID=194404
^^^ more information please: As I understand, this car has 2 x retrofitted modules; hex17 and hex5F.
If I'm reading the last auto-scan above correctly, it was generated with an NAR hex5F module (note: Component: MU-HS-S-US ). The fact that the scan doesn't have CP errors kind-of confirms this speculation. So, if the scan was made with the original factory fitted MIB (which worked perfectly well with the factory fitted hex01 module - I assume), why is the ECU complaining about comms loss with the MIB? Incidentally, this MIB also doesn't have SATNAV (Byte 3 = hex0). Have you checked the integrity of the hex 5F quad-connector/wires after replacing the eBay module with the original MIB?
hro0250
Washington, USA
C?ID=409496
Sorry I should've clarified, that is my OEM MIB. I didn't want to add the eBay one and confuse anyone until I could solve the check engine light. So it should not have navigation fitted nor component protection. I will post an autoscan of the eBay MIB later on. So for now the only retrofitted module is the hex17.
