Two week update.
A day or so after getting the 7LA EX1 back on the road I followed the PS bleeding procedure in the manual to the letter. It's now tomb quiet which is a huge relief (worth the 1 day cost of the manuals all by itself). The car produced great power for a few days and then seemed to suffer from some transition where it would lag a bit before deciding whether boost would be coming on line. Then it got so that if you babied the throttle it might not boost but if you let off and then "gave it the news" it would pin you in your seats (which never gets old).
I also never got the wipers to work, which hasn't been the end of the world because it hasn't been raining here in the PNW.
Today I am going through three tasks:
1) get the wipers to function
2) re-do all three ground terminals on the firewall
3) lube the upper pivot points of the turbo controllers.
Damn if the manual didn't pay for itself again doing the wipers. I pulled out the monkey bars+ electric motor and decided to get super careful about the installation. I looked through the manual and found where it said I'd have to log into the car and disable the built in stutter that it has for some sophisticated reason prior to disconnecting the plug. Well that ship had sailed so I hoped to crap it wouldn't need something I couldn't do.
In order to access the shaft where the monkey bars attach to the motor you have to pull the whole thing out and get to the back side. Once detached, I plugged the motor back in and turned on the ignition (the manual sez..). The motor rotated and found it's own resting place, and it rotated more than I expected. I figured that I removed the motor when it was in the rest position and arranging the arms per a photograph I'd taken to assure the same position.
Where the manual paid for itself was during the time that I was trying to locate the arms it wouldn't move when the wiper switch was moved. Right there in black and white it reminded me that the wipers would be disabled with the hood up. Dude, I was about to pull hair. It wasn't a new motor, so I didn't think there would be any coding (for wipers. what has the world come to?)
Most importantly, the manual contained a diagram indicating proper set up of the monkey bars showing a 4mm gap between the primary crank arm and a big pin. We all own gauge pins in the form of drill bits so I did some quick math and came up with a "go, no go" pair, either of which would have been accurate enough for this set up, but I'm a geek so there it is.
I moved on to the ground studs because it was much easier to do them with the wiper system out of the car. Afterwards I came back and installed it. Hood down, it works perfectly in all modes. High five to the forehead.
The ground studs:
The first one I did is in the far left corner under the pivot point of the left wiper. The plastic cowling has to be out for this entire job, so I'll assume anyone following along will deduce that by now.
I removed the acorn nut with a 10mm socket on a long extension. I then pulled two wires off the ground stud and discarded the plastic tarantula that holds water and debris. I blew the area out with an air compressor (tons of dirt, needles and goo came out). Next I cleaned the area around the ground stud with glass cleaner to remove the more determined crap and corrosion. I wanted to use something that would do a good job, evaporate quickly and not leave a residue.
Using a wire wheel on my dremel tool I polished the two terminals brighter than a new penny and did the same with the ground stud itself, the area around the base of the ground stud and the bottom side of the acorn nut. I reassembled and torqued the assembly and then I painted the whole mess with liquid tape.
Then I did the same to the other side. I did them one at a time even though they're ground wires so mixing them up wouldn't have an effect. The more outboard terminal (the lower one in this picture, and in fact down hill (perhaps downstream would give a better visual)) was FULL of goo and water even though it's been in the 80s for days here. Again, everything bright, shiny and clean then gooped with liquid tape.
Heading back out now to find a lazy engineer's method of lubing pivot points you can't see.
