so i apologize for the large text still trying to figure the posting out..so i have a mk7 gsw tdi and i was trying to do comfort windows open tweek/install.i get though kessy to adjustable and activate open/close english.when i get to the german "kessy komfort oeffnen"i get service not supported in active session"
i then tried again and got "security access required". any pointers?
while playing with vcds my battery died after about 20 minutes(i thought this was premature)and i thought i bricked my ecm!!! haaaaaaa got me right by the short and curlys!!
Saturday,20,April,2019,19:30:15:61679
VCDS Version: 18.9.1.0 (x64)
VIN: 3VWCA7AU9FM501766 License Plate:
Mileage: 92834km-57684mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75
VIN: 3VWCA7AU9FM501766 Mileage: 92834km-57684miles
Address 01: Engine (J623-CRUA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 022 N HW: 04L 907 309
Component: R4 2.0l TDI X23 9459
Revision: 85X23---
Coding: 011D0012032410081000
ASAM Dataset: EV_ECM20TDI01104L997022N 004002
ROD: EV_ECM20TDI01104L997022N.rod
VCID: 3B7FDB52B2954F92C8-806E
Readiness: 0 0 0 1 0
Part No SW: 0D9 300 041 N HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4512
Revision: 05853104 Serial number: TFK01501120125
Shop #: WSC 00066 790 00201
ROD: EV_TCMDQ250021.rod
VCID: 234F03322A251752E0-8076
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 50075000000447
Coding: 04FA6AA12420096D007E020681C92520562490004081A4B200630050C002
Shop #: WSC 01383 790 50316
VCID: 4797B7A2FE5D1B725C-8012
Revision: 00021000 Serial number: 0355862780
Coding: 030C0C
VCID: 3A71DE56BDAF769AD3-806E
Part No SW: 5GM 907 426 HW: 5GM 907 426
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 02020104200100000000000000000000
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: 050B7DAA84D1C962EE-8050
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-BV1.clb
Part No SW: 5Q0 937 087 Q HW: 5Q0 937 087 Q
Component: BCM PQ37BOSCH 028 0145
Revision: -------- Serial number: 86581712140706
Coding: 000118424041804169E44000000403001800000000000000000000000000
Shop #: WSC 00066 790 07031
ROD: EV_BCMBOSCH_014.rod
VCID: 4993B19AE849ED024A-801C
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 141210 043 0581
Serial number: 150203070414
541973 - Databus
Reset counter: 112
Mileage: 92639 km
Date: 2019.04.11
Time: 08:26:34
559125 - Databus
Reset counter: 112
Mileage: 92639 km
Date: 2019.04.11
Time: 08:26:34
555541 - Databus
Reset counter: 112
Mileage: 92639 km
Date: 2019.04.11
Time: 08:26:34
542229 - Databus
Reset counter: 112
Mileage: 92639 km
Date: 2019.04.11
Time: 08:26:34
542485 - Databus
Reset counter: 112
Mileage: 92639 km
Date: 2019.04.11
Time: 08:26:34
329480 - Heated Passenger Seat
B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
Reset counter: 118
Mileage: 92834 km
Date: 2019.04.19
Time: 07:01:30
Component: AirbagVW20 009 0825
Serial number: 003GCR013TGL
ROD: EV_AirbaVW20SMEVW37X.rod
Occupant Detection:
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J1500029OTJ0P
Coding: 303138
Subsystem 2 - Part No SW: ----------- HW: 480 001 112 14
Serial number: 35700000000942F8321G
Subsystem 3 - Part No SW: ----------- HW: 480 001 112 14
Serial number: 3580000000023D21221%
Subsystem 4 - Part No SW: ----------- HW: 480 401 112 14
Serial number: 3510002B31811B90813P
Subsystem 5 - Part No SW: ----------- HW: 480 400 812 14
Serial number: 35200029D1811B91527.
Subsystem 6 - Part No SW: ----------- HW: 480 400 212 14
Serial number: 3550002C718B3AB3F1CN
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 212 14
Serial number: 3560002C718B3AB2B23B
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20141217500378
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 040D60AE8FEBF06AF9-8050
Part No SW: 5G1 920 841 HW: 5G1 920 841
Component: KOMBI 243 4270
Coding: 0BA4121A2180CF05020868001000000000000000
VCID: 65CB5D2A649129624E-8030
Part No SW: 5Q0 907 530 AB HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2203
Revision: -------- Serial number: 22011510001256
Coding: 0901000800087300EF0000081C0F00000001050000000000000000000000
Shop #: WSC 00066 790 00199
VCID: 71E3397AA059F5C222-8024
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0101
Serial number: 27140003150690014527
Coding: 29FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0020000
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000015147004
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 346DF06E9FCB80EA09-8060
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 080115060502XI
Coding: 003013200000040000000000
VCID: 3E79D246A1875ABAEF-806A
Serial number: 00000000000000550428
Coding: 011000
65588 - Motor for Window Regulator
B1487 54 [009] - Missing Calibration / Basic Setting
Reset counter: 72
Mileage: 92639 km
Date: 2019.04.11
Time: 08:45:14
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0102
VCID: 438FA3B2CA65375280-8016
19460 - Databus
Fault Frequency: 47
Reset counter: 112
Mileage: 92639 km
Date: 2019.04.11
Time: 08:45:15
Motor status: 00
Supply voltage: 11.75 V
Temperature: 43.0 °C
KFC: 4C
KFA: 00 04
Environmental conditions: 21
uioUdNotFilt_xdu16: 11.72 V
uAdSensI_SwitchedKl30_xdu16: 11.72 V
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 131214060503EY
VCID: 3D7BD54AAC8141A2F6-8068
Serial number: 00000000000000539641
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0645
Serial number: V7B00401151026
Coding: 02730200FF00000021220001001800001F0100140100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 64CD402E6FAB506A59-8030
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9PS50155R
B11CF 53 [009] - Deactivated
Reset counter: 72
Mileage: 92639 km
Date: 2019.04.11
Time: 08:45:15
Voltage terminal 30: 11.7 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Component: OCULowMQBUS 007 0564
Coding: 02730002C2821A017F1E06000000
Shop #: WSC 00066 790 00123
ROD: EV_OCULowMQB.rod
End-------------------------(Elapsed Time: 03:45)--------------------------
