VW 1.8t 20v powered kit car
   #21
veedabowlu
C?ID=56963
Correct, very much like the Mk.4 VWs, e.g. the Mk.4 R32.
Ok, but that gives me a VERY small selection of parts vehicles... why can't I hybrid the ME7.5, with, or with out the J519/ J533?
   #22
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I don't think anyone's saying you must have/must not have a gateway.
What we're saying is you must have an ECU and TCM (plus matching ABS/ESP, if you expect that to actually work) that are known to peacefully coexist in some existing vehicle somewhere.
IIRC there exist vehicles with ME 7.1/7.5 with a CAN gateway. The presence or lack of a gateway isn't the deciding factor in anything here.
veedabowlu
C?ID=56963
IS there a longitudinal DSG FWD?
   #26
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Saw these guys on Youtube, they've done a few cars, and I thought of you.
This is one of a couple DSG mash-ups they've done, and this one is to a 1.8T 20V. They're using some sort of custom DSG management box. Might be worth looking into.
Another, different engine but still with custom DSG management.
https://www.facebook.com/BobaMotoring/?tn-str=k*F
veedabowlu
C?ID=56963
Yes, I Have seen those exact cars..
Uwe, specifically did the Audi Come with DSG FWD? If so, which era & flavor DQ 500... 501...?
   #28
veedabowlu
C?ID=56963
Well we have gone in a different direction with the 1.8t dsg kit car... now the donor IS an 06' Audi A3 2.0t (timing belt) engine and its matching DSG transmission.
Customer and designer are figuring out wheel/tire size combinations and have come up with this...
opting to go with 245/35/19 tires for the front, and 275/35/19 for the rear. The difference in diameter is 0.8" or about 3.1% (about 25 revolutions per mile difference per https://tiresize.com/comparison/)
this shouldn't affect the ABS module and shift timing for the DSG, should it?
   #29
Elder Moreira dos Santos
Brazil
C?ID=304355
Olá
Desculpe responder ao tópico depois de tanto tempo...
Mas queria dizer que sim, é possível instalar Dsg na Ecu 7.5
Instalei no meu Gti mk4 2003 aqui no Brasil, peguei o dsg de um Passat 2011 dq250
Funciona perfeito a comunicação da ecu e tcu
   #30
Olá
veedabowlu
C?ID=56963
Olá
Can you give more information as to what EXACTLY you did?
