Audi A3, 2004, databus (and power?) problem
LN-TAL
Norway
C?ID=13729
Hi there,
the symptoms: I was driving, and noticed that the light in the instrument cluster went black. Then it came back, went black again, and then all the dials went to 0. Came back, gone again. This happened a few times, then everything was back to normal.
The scan is first before I deleted the codes, and the last part is after I cleared codes (its the same file). It seems like the CAN gateway has 00470 still. Any ideas ?
Wednesday,22,May,2019,18:42:55:41099
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4502.4
VIN: WAUZZZ8P54A165042   License Plate: BR51499
Mileage: 200790km-124765mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 47 52 55 56 76 7D
VIN: WAUZZZ8P54A165042   Mileage: 200790km-124765miles
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Malfunction 1010
76-Park Assist -- Status: Malfunction 1010
7D-Aux. Heat -- Status: Malfunction 1010
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 016 G    HW: 028 101 136 4
   Component: R4 2,0L EDC G000SG  9884
   Revision: 12345678    Serial number: AUX7Z0D3FN70K1
   Coding: 0000072
   Shop #: WSC 74565 000 00000
   VCID: A71EB103164D1F723C-80F2
16785 - EGR System
            P0401 - 000 - Insufficient Flow - Intermittent
                    RPM: 1806 /min
                    Torque: 92.0 Nm
                    Speed: 46.0 km/h
                    Load: 25.1 %
                    Duty Cycle: 14.7 %
                    Bin. Bits: 00101000
                    Mass Air / Rev.: 355.0 mg/str
                    Mass Air / Rev.: 675.0 mg/str
18107 - Powertrain Data Bus
            P1699 - 000 - Missing Message from Steering Wheel Electronics - Intermittent
                    RPM: 2268 /min
                    Torque: 0.0 Nm
                    Speed: 58.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 00101000
                    Bin. Bits: 00000000
                    (no units): 0.0
18043 - Powertrain Data Bus
            P1635 - 000 - Missing Message from A/C Controller - Intermittent
                    RPM: 2184 /min
                    Torque: 0.0 Nm
                    Speed: 56.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 11001000
                    Bin. Bits: 00000000
                    (no units): 0.0
Readiness: 1 1 0 0 0
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0023174
   Shop #: WSC 06435 000 00000
   VCID: BA387877F5FF929A53-80EE
   Part No SW: 8P0 820 043 E    HW: 8P0 820 043 E
   Component: KlimavollautomatH12 0150
   Revision: 015231      Serial number: 8P0820043E
   VCID: AE10442739B74E3AFF-80FA
                    Reset counter: 214
                    Mileage: 200795 km
                    Date: 2019.05.22
                    Time: 18:05:15
00483 - Control Module for Auxiliary Air Heater
                    Reset counter: 214
                    Mileage: 200795 km
                    Date: 2019.05.22
                    Time: 18:05:22
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 A    HW: 8P0 907 279 A*
   Component: Bordnetz-SG 1.0 H30 0501
   Revision: 00030000    Serial number: 00000000690970
   Coding: 030ACA0083140400640000322800000000
   Shop #: WSC 12345 123 12345
   VCID: BB367D73FAC5AB9248-80EE
   Subsystem 1 - Part No: 8P1 955 119 C  Labels: 1TX-955-119.CLB
   Component: Wischer WWS Audi350 0180
   Coding: 16711696
   Shop #: WSC 12345
7 Faults Found:
Address 15: Airbags        Labels: 8P0-959-655-84.lbl
   Part No SW: 8P0 959 655 D    HW: 8P0 959 655 D
   Component: Airbag 8.4ED    H00 0140
   Coding: 0010602
   VCID: C3C605938235D35200-8096
   Part No SW: 8P0 953 549 G    HW: 8P0 953 549 G
   Component: Lenks‰ulenmodul H36 0070
   Coding: 0000042
   VCID: C2C800979D2FDA5A0B-8096
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
   Part No SW: 8P0 920 930 F    HW: 8P0 920 930 F
   Component: KOMBIINSTR. VDO H25 0140
   Revision: D09         Serial number: 2243DD09053438
   Coding: 0004003
   Shop #: WSC 80093 222 69422
   VCID: B5226B4BDCE17DE2BE-80E0
Address 18: Aux. Heat        Labels: 1K0-815-005.clb
   Part No: 1K0 815 005 EF
   Component: Heizgeraet      H08 0040
   Revision:        A    Serial number: 09011596
   Coding: 0001011
   Shop #: WSC 38059 136 84162
   VCID: EA988837C5DFE21AE3-80BE
                    Reset counter: 214
                    Mileage: 200795 km
                    Date: 2019.05.22
                    Time: 18:05:16
                    Reset counter: 214
                    Mileage: 200794 km
                    Date: 2019.05.22
                    Time: 18:04:56
   Part No SW: 1K0 907 530 D    HW: 1K0 907 951
   Component: Gateway         H08 0100
   Revision: 08          Serial number: 2500104325011F
   Coding: 7D0F1F42070100
   Shop #: WSC 06435 123 12345
   VCID: A81CB23F1B53100A35-80FC
8 Faults Found:
                    Fault Status: 01101100
                    Fault Frequency: 11
                    Reset counter: 174
                    Mileage: 200787 km
                    Date: 2019.05.22
                    Time: 16:01:19
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 214
                    Mileage: 200794 km
                    Date: 2019.05.22
                    Time: 18:04:12
                    Fault Frequency: 10
                    Reset counter: 214
                    Mileage: 200794 km
                    Date: 2019.05.22
                    Time: 18:04:32
                    Reset counter: 214
                    Mileage: 200794 km
                    Date: 2019.05.22
                    Time: 18:04:46
                    Reset counter: 214
                    Mileage: 200794 km
                    Date: 2019.05.22
                    Time: 18:04:46
                    Reset counter: 214
                    Mileage: 200794 km
                    Date: 2019.05.22
                    Time: 18:04:46
                    Reset counter: 214
                    Mileage: 200794 km
                    Date: 2019.05.22
                    Time: 18:04:47
                    Reset counter: 214
                    Mileage: 200794 km
                    Date: 2019.05.22
                    Time: 18:04:55
   Revision: D09         Serial number: AUX7Z0D3FN70K1
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
   Part No: 8P0 959 801 A
   Component: Tuersteuerger.  H10 0010
   Coding: 0000048
   VCID: B93A677BF0F999825A-80EC
   Part No: 1K1 909 144 F
   Component: EPS_ZFLS Kl.10      1301
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 B
   Component:    KSG          H02 0040
   Coding: 188800186D288505484A016000
00849 - S-contact at Ignition/Starter Switch (D)
   Part No SW: 8P3 035 382     HW: 8P3 035 382
   Component: AB2 SUBWOOFERBOXH25 0160
   Revision: 00003       Serial number: 10000001119925
   VCID: F0AC9A5FE30318CAAD-80A4
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
   Part No: 8P0 959 802 A
   Coding: 0000048
   Part No: 8P0 907 357 A
   Coding: 0000001
   VCID: B83C627FCBF3808AA5-80EC
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 186     HW: 8P0 035 186
   Component: concert II EU   H53 0060
   Revision:      08S    Serial number: AUZ2Z3D2056623
   Coding: 0001001
   VCID: EFAE9923FE3D0732B4-80BA
Address 76: Park Assist        Labels: 8P0-919-283.lbl
   Part No SW: 8P0 919 283     HW: 8P0 919 283
   Component: Parkhilfe 4-Kan H06 0020
   Coding: 0000003
   VCID: F8BCA27F8B73408A65-80AC
                    Fault Status: 00101110
                    Fault Frequency: 85
                    Reset counter: 214
                    Mileage: 200794 km
                    Date: 2019.05.22
                    Time: 18:04:07
                    Reset counter: 214
                    Mileage: 200794 km
                    Date: 2019.05.22
                    Time: 18:04:09
                    Reset counter: 214
                    Mileage: 200794 km
                    Date: 2019.05.22
                    Time: 18:04:38
                    Fault Frequency: 11
                    Reset counter: 214
                    Mileage: 200794 km
                    Date: 2019.05.22
                    Time: 18:04:29
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
                    Reset counter: 171
                    Mileage: 200620 km
                    Date: 2019.05.22
                    Time: 10:15:17
   Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
   Revision: 00700000    Serial number:
   VCID: AC144E2F0FAB3C2AD1-80F8
End----------(Elapsed Time: 01:25, VBatt start/end: 12.5V/12.5V)-----------
   Coding: 0000072
Readiness: 0 0 1 1 1
   Coding: 0023174
                    Reset counter: 214
                    Mileage: 200795 km
                    Date: 2019.05.22
                    Time: 18:05:15
                    Reset counter: 214
                    Mileage: 200795 km
                    Date: 2019.05.22
                    Time: 18:05:22
   Coding: 16711696
   Shop #: WSC 12345
   Coding: 0010602
   Coding: 0000042
   Coding: 0004003
   Coding: 0001011
                    Reset counter: 174
                    Mileage: 200796 km
                    Date: 2019.05.22
                    Time: 18:46:51
   Coding: 0000048
   Coding: 0000048
   Coding: 0000001
   Coding: 0001001
   Coding: 0000003
End----------(Elapsed Time: 01:22, VBatt start/end: 14.0V/14.2V)-----------
I'm thinking a malfunctioning gateway or bad connection to it.......
Verify ignition switch and terminal relays too.
LN-TAL
Norway
C?ID=13729
Thanks for your reply. And the gateway is located with the instrument cluster in this car ?
They indeed share 920 numbers......... :rolleyes:
Uhm, no. This is an 8P A3, very Mk.5-like. It has a stand-alone gateway that's not part of the cluster! In fact, the gateway has all "1K0-907" (Mk.5 Golf) part numbers, while the instrument cluster has all 8P0-920 part numbers.
I apologize I was thinking immobilizer what was I thinking, dah.....
I been out of pocket last two weeks guys sorry.
I'll go stand in the corner with asshole of the day hat now till milk time.
LN-TAL
Norway
C?ID=13729
I realised that after the golfi_vend posted :)
So I will open up the gateway module, and resolder all the solder joints. But to me it looked like the cluster lost its power, first thing I noticed was the indication light for headlight went black, then the LCD screen went black, and last the background lights and gauges went to zero. But it might be that the power was still there, but "there is no input so I have nothing to display, so lets just go to standby mode and see if the inputs is coming back" ?
LN-TAL
Norway
C?ID=13729
Looks like resoldering all the soldering joints in the gateway module solved the problem for now. At least the fault codes got cleared, and has stayed away since then.
