Thursday,06,February,2020,10:03:31:60802 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4 Data version: 20190930 DS308.0 www.Ross-Tech.com VIN: WAULF78K59N068768 License Plate: Chassis Type: 8K-AU48 (8T0) Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 65 72 77 VIN: WAULF78K59N068768 Mileage: 206820km-128511miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 2E-Media Player 3 -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 0010 65-Tire Pressure -- Status: Malfunction 0010 72-Door, Rear Right -- Status: Malfunction 0010 77-Telephone -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D Component: 2.0l R4/4V TF H14 0001 Revision: E1H14--- Coding: 0104010A190F0160 Shop #: WSC 09396 002 1048576 ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001 ROD: EV_ECM20TFS0118K2907115AL.rod VCID: 79BACD3FF834D087E0-802C 4 Faults Found: 7225 - Cam Adjustment Actuator A; Cylinder 4 P11AD 00 [109] - Elec. Malf. or Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.05 Time: 09:15:11 Engine speed: 178.00 /min Normed load value: 42.4 % Vehicle speed: 0 km/h Coolant temperature: 5 °C Intake air temperature: 3 °C Ambient air pressure: 950 mbar Voltage terminal 30: 11.049 V Unlearning counter according OBD: 40 4060 - Cylinder 3 P0303 00 [101] - Misfire Detected Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.05 Time: 09:39:24 Engine speed: 754.50 /min Normed load value: 12.9 % Vehicle speed: 0 km/h Coolant temperature: 75 °C Intake air temperature: 10 °C Ambient air pressure: 950 mbar Voltage terminal 30: 13.782 V Unlearning counter according OBD: 80 4057 - Cylinder 2 P0302 00 [101] - Misfire Detected Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.05 Time: 09:39:24 Engine speed: 754.50 /min Normed load value: 12.9 % Vehicle speed: 0 km/h Coolant temperature: 75 °C Intake air temperature: 10 °C Ambient air pressure: 950 mbar Voltage terminal 30: 13.782 V Unlearning counter according OBD: 80 4051 - Random/Multiple Cylinder Misfire Detected P0300 00 [101] - - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.05 Time: 09:38:18 Engine speed: 747.00 /min Normed load value: 12.5 % Vehicle speed: 0 km/h Coolant temperature: 75 °C Intake air temperature: 9 °C Ambient air pressure: 950 mbar Voltage terminal 30: 13.735 V Unlearning counter according OBD: 80 Readiness: 1110 0101 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb Part No SW: 8K0 927 158 C HW: 0B6 927 156 Component: 0B6 20TFSIUSA H04 0050 Revision: --H04--- Coding: 001002 Shop #: WSC 02145 785 00200 ASAM Dataset: EV_TCMAL651 A01004 ROD: EV_TCMAL651.rod VCID: 3620060389AAFFFF4D-8062 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 AF HW: 8K0 907 379 AF Component: ESP8 quattro H04 0210 Revision: -------- Serial number: -------------- Coding: 150500 Shop #: WSC 02391 823 56573 VCID: 7DB2D92FE41CECA7CC-8028 2 Faults Found: 00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 9 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:34 Freeze Frame: Hex Value: 0x00C0 Hex Value: 0x0082 Hex Value: 0x002E Hex Value: 0x0286 Hex Value: 0x00FF 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 18:45:13 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4082 Hex Value: 0x0025 Hex Value: 0x46AA Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 F HW: 8K0 907 064 F Component: BCM2 1.1 H80 0145 Revision: 00002001 Coding: 090100 Shop #: WSC 02399 823 56573 VCID: 33263F1792D8EAD76A-8066 Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A Component: FBSAUDIB8 IDG H37 0060 Serial number: 0509000010202006 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H36 0041 Serial number: 0209000012848015 3 Faults Found: 00956 - Key 2 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2019.12.27 Time: 09:41:23 00447 - Function Limitation due to Over-Voltage 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 9 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:21 01330 - Central Control Module for Central Convenience (J393) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:51 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA Component: KLIMA 1 ZONE H06 0150 Revision: A1000000 Serial number: 01130320090031 Coding: 64002000 Shop #: WSC02391 823 56573 VCID: 70ACF01BA34E91CF57-8024 3 Faults Found: 00457 - Central Electronics Control Module / BCM (J519) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:32 00256 - A/C Pressure/Temperature Sensor (G395) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:49 Freeze Frame: Temperature: 6.0°C 00447 - Function Limitation due to Over-Voltage 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:37:14 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 D HW: 8K0 907 063 D Component: BCM1 1.0 H24 0253 Revision: 05024001 Serial number: 00000000225447 Coding: 690000B1063C00010000080300007F5F0F1452080000000100 0000 Shop #: WSC 02391 823 56573 VCID: 302C301B63CED1CF17-8064 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 180309 H06 0070 Serial number: SWF09030185532 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 941 531 T HW: 8K0 941 531 T Component: E1 - LDS H07 0090 Serial number: 00000000001203091159 9 Faults Found: 03351 - Bulb for DRL and Marker Light; Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:00 03354 - Bulb for DRL and Marker Light; Right 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:00 00978 - Lamp for Low Beam; Left (M29) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.04 Time: 13:05:00 00979 - Lamp for Low Beam; Right (M31) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.04 Time: 13:05:00 01497 - Bulb for Blinkers; Front Right (M7) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.05 Time: 09:17:00 03188 - Bulb for Side Marker Light; Front Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.04 Time: 13:05:00 03189 - Bulb for Side Marker Light; Front Right 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.04 Time: 13:05:00 02745 - Bulb for Daytime Running Light; Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:00 02746 - Bulb for Daytime Running Light; Right 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:00 ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 8K0-959-655.clb Part No SW: 8K0 959 655 F HW: 8K0 959 655 F Component: AirbagVW-AU10 H27 0410 Serial number: 0039KD14XSN5 Coding: 303836354230303030304A55304C384B3053 Shop #: WSC 02135 785 00200 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_A02.rod VCID: 40CC60DBDB6E414FE7-8014 Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B Component: BF-Gewichtss. H01 0030 Serial number: 5810000R0900003JA6 Crash sensor for side airbag: driver side: Serial number: 6334MSME46340C1BE Crash sensor for side airbag: front passenger side: Serial number: 6344MSME4463086EJ Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME621E520EL Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME461F0922H 2 Faults Found: 9443859 - Driver's Front Airbag Crash Sensor B101A 15 [137] - Open or Short to Plus MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.02 Time: 15:28:25 9444115 - Front Passenger's Front Airbag Crash Sensor B101B 15 [137] - Open or Short to Plus MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.02 Time: 15:28:25 ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90304ICD0004X Coding: 000034 Shop #: WSC 02391 823 56573 VCID: 3D32192FA49C2CA78C-8068 Component: E221 - MFL H02 0003 2 Faults Found: 00447 - Function Limitation due to Over-Voltage 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:38:59 00888 - Wiper Switch for Intermittent Operation (E22) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 2 Fault Frequency: 12 Reset counter: 10 Mileage: 205825 km Time Indication: 0 Date: 2019.12.03 Time: 05:38:09 ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 950 A HW: 8K0 920 950 A Component: KOMBIINSTR. H18 0224 Revision: 00000000 Serial number: 9DR1EGC39 Coding: 8B1209000300D705020000 Shop #: WSC 02391 823 56573 VCID: 2D12296F74FCBC273C-8078 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 M HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0095 Revision: GB300043 Serial number: 4300G0930686F2 Coding: 000303 Shop #: WSC 02391 823 56573 VCID: 4BD647F7EA28921702-801E Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H06 0160 Serial number: 19068C5E110209 2 Faults Found: 03041 - Energy Management Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 10 Reset counter: 48 Mileage: 206827 km Time Indication: 0 Date: 2020.01.16 Time: 18:47:00 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 7 Fault Frequency: 3 Reset counter: 48 Mileage: 206827 km Time Indication: 0 Date: 2020.02.03 Time: 04:06:00 ------------------------------------------------------------------------------- Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb Part No SW: 8T0 035 785 HW: 8T0 035 785 Component: SG ext.Player H06 0210 Revision: 00000000 Coding: 020302 Shop #: WSC 02391 823 56573 VCID: 78BCC83BCB3EC98F9F-802C 1 Fault Found: 00447 - Function Limitation due to Over-Voltage 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 255 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:18 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8K0 959 793 D HW: 8K0 959 793 D Component: TSG FA H11 0250 Revision: Serial number: 0000008591368 Coding: 011C03204000410001 Shop #: WSC 02391 823 56573 VCID: 41CA65DFD8644847E8-8014 3 Faults Found: 02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 254 Reset counter: 46 Mileage: 200391 km Time Indication: 0 Date: 2019.08.09 Time: 16:25:38 00447 - Function Limitation due to Over-Voltage 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:36:22 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:37:15 ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 F HW: 8K0 907 064 F Component: BCM2 1.1 H80 0145 Revision: 00002001 Serial number: 0117171294 Coding: 0106023A007A000400B001 Shop #: WSC 02391 823 56573 VCID: 33263F1792D8EAD76A-8066 Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H03 1301 Subsystem 2 - Part No SW: 8K0 959 591 HW: 8K0 959 591 Component: J245 PS034 H06 0037 3 Faults Found: 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 214 Mileage: 196167 km Time Indication: 0 Date: 2019.03.18 Time: 09:45:51 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 214 Mileage: 196167 km Time Indication: 0 Date: 2019.03.18 Time: 09:46:32 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:51 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb Part No SW: 8T0 035 223 AB HW: 8T0 035 223 Component: DSP STD H07 0220 Revision: S2100000 Coding: 0203010102 Shop #: WSC 02391 823 56573 VCID: 6E90EE63B97A873F45-803A 2 Faults Found: 02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 74 Reset counter: 49 Mileage: 196240 km Time Indication: 0 Date: 2019.03.19 Time: 22:50:20 Freeze Frame: Voltage: 11.80 V Temperature: -2.0°C Bin. Bits: 00000000 02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 74 Reset counter: 49 Mileage: 196240 km Time Indication: 0 Date: 2019.03.19 Time: 22:50:20 Freeze Frame: Voltage: 11.80 V Temperature: -2.0°C Bin. Bits: 00000000 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8K0 959 792 D HW: 8K0 959 792 D Component: TSG BF H11 0250 Revision: Serial number: 0000008606952 Coding: 011C03204000410001 Shop #: WSC 02391 823 56573 VCID: 40CC60DBD36E414FE7-8014 2 Faults Found: 00447 - Function Limitation due to Over-Voltage 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:36:21 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:37:15 ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 G HW: 8K0 907 801 G Component: EPB Audi B8 H08 0080 Revision: 00000003 Serial number: 10000000194622 Shop #: WSC 00000 000 00000 VCID: 33263F1792D8EAD76A-8066 2 Faults Found: 01321 - Control Module for Airbags (J234) 013 - Check DTC Memory - MIL ON Freeze Frame: Fault Status: 11101101 Fault Priority: 4 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:34 Freeze Frame: Voltage: 10.80 V Count: 80 Speed: 0.0 km/h Hex Value: 0x02E0 Hex Value: 0x0001 Hex Value: 0x0101 01314 - Engine Control Module 013 - Check DTCMemory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 4 Fault Frequency: 1 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 18:45:14 Freeze Frame: Voltage: 14.00 V Count: 58 Speed: 0.0 km/h Hex Value: 0x0270 Hex Value: 0x0001 Hex Value: 0x0101 ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb Part No SW: 8T1 035 186 R HW: 8T1 035 186 R Component: Con3 Sirius H01 0301 Revision: 00000003 Serial number: AUZ5Z6I1188533 Coding: 04020002010185004119070800 Shop #: WSC 02391 823 56573 VCID: 46C076C3F14A6F7FDD-8012 Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E Component: Display 2 Faults Found: 02635 - Tuner Not Enabled/Activated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 214 Mileage: 196167 km Time Indication: 0 Date: 2019.03.18 Time: 09:36:54 03157 - Functionality limited due to Communications Disruption 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 165 Reset counter: 47 Mileage: 196207 km Time Indication: 0 Date: 2019.03.18 Time: 17:56:09 Freeze Frame: Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 10000000 Bin. Bits: 00000000 Bin. Bits: 00000000 ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HL H10 0251 Revision: Serial number: 0000100819785 Coding: 010C03204000210001 Shop #: WSC 02391 823 56573 VCID: 44C46CCBC7765D6FC3-8010 2 Faults Found: 00447 - Function Limitation due to Over-Voltage 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:36:22 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:37:16 ------------------------------------------------------------------------------- Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb Part No SW: 8K0 907 273 A HW: 8K0 907 273 A Component: J502-RDK H03 0250 Revision: 00001001 Serial number: 13374790243434 Coding: 0CD154 Shop #: WSC02391 823 56573 VCID: 302C301B63CED1CF17-8064 2 Faults Found: 02214 - Tire Pressure Warning 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 9 Mileage: 206827 km Time Indication: 0 Date: 2020.02.05 Time: 09:50:26 Freeze Frame: 0.00 Bin. Bits: 00001000 01001000 Voltage: 12.60 V Text: 01,0°C; 7,67bar;3390855650;00h;-50°C 01521 - Sensor for Tire Pressure 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.05 Time: 09:33:13 Freeze Frame: 0.00 Bin. Bits: 00001000 11001001 Voltage: 14.00 V Text: 01,0°C;n.erkannt;3390855811;--h;---°C ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HR H10 0251 Revision: Serial number: 0000100819719 Coding: 010C03204000210001 Shop #: WSC 02391 823 56573 VCID: 44C46CCBC7765D6FC3-8010 2 Faults Found: 00447 - Function Limitation due to Over-Voltage 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 6 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:32 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 46 Time Indication: 0 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8T0 862 336 C HW: 8T0 862 336 C Component: FSE_256x BT H33 0550 Revision: 00000000 Serial number: 00000005034728 Coding: 0010370 Shop #: WSC 02335 785 00200 VCID: 3B3617377A882297B2-806E 1 Fault Found: 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 7 Fault Frequency: 1 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:18 End----------(Elapsed Time: 01:39, VBatt start/end: 12.1V/12.1V)
Due to the lack of line breaks, this is essentially illegible. What intermediate software was this text passed through?Code:Thursday,06,February,2020,10:03:31:60802 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4 Data version: 20190930 DS308.0 www.Ross-Tech.com VIN: WAULF78K59N068768 License Plate: Chassis Type: 8K-AU48 (8T0) Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 65 72 77 VIN: WAULF78K59N068768 Mileage: 206820km-128511miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 2E-Media Player 3 -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 0010 65-Tire Pressure -- Status: Malfunction 0010 72-Door, Rear Right -- Status: Malfunction 0010 77-Telephone -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D Component: 2.0l R4/4V TF H14 0001 Revision: E1H14--- Coding: 0104010A190F0160 Shop #: WSC 09396 002 1048576 ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001 ROD: EV_ECM20TFS0118K2907115AL.rod VCID: 79BACD3FF834D087E0-802C 4 Faults Found: 7225 - Cam Adjustment Actuator A; Cylinder 4 P11AD 00 [109] - Elec. Malf. or Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.05 Time: 09:15:11 Engine speed: 178.00 /min Normed load value: 42.4 % Vehicle speed: 0 km/h Coolant temperature: 5 °C Intake air temperature: 3 °C Ambient air pressure: 950 mbar Voltage terminal 30: 11.049 V Unlearning counter according OBD: 40 4060 - Cylinder 3 P0303 00 [101] - Misfire Detected Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.05 Time: 09:39:24 Engine speed: 754.50 /min Normed load value: 12.9 % Vehicle speed: 0 km/h Coolant temperature: 75 °C Intake air temperature: 10 °C Ambient air pressure: 950 mbar Voltage terminal 30: 13.782 V Unlearning counter according OBD: 80 4057 - Cylinder 2 P0302 00 [101] - Misfire Detected Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.05 Time: 09:39:24 Engine speed: 754.50 /min Normed load value: 12.9 % Vehicle speed: 0 km/h Coolant temperature: 75 °C Intake air temperature: 10 °C Ambient air pressure: 950 mbar Voltage terminal 30: 13.782 V Unlearning counter according OBD: 80 4051 - Random/Multiple Cylinder Misfire Detected P0300 00 [101] - - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.05 Time: 09:38:18 Engine speed: 747.00 /min Normed load value: 12.5 % Vehicle speed: 0 km/h Coolant temperature: 75 °C Intake air temperature: 9 °C Ambient air pressure: 950 mbar Voltage terminal 30: 13.735 V Unlearning counter according OBD: 80 Readiness: 1110 0101 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb Part No SW: 8K0 927 158 C HW: 0B6 927 156 Component: 0B6 20TFSIUSA H04 0050 Revision: --H04--- Coding: 001002 Shop #: WSC 02145 785 00200 ASAM Dataset: EV_TCMAL651 A01004 ROD: EV_TCMAL651.rod VCID: 3620060389AAFFFF4D-8062 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 AF HW: 8K0 907 379 AF Component: ESP8 quattro H04 0210 Revision: -------- Serial number: -------------- Coding: 150500 Shop #: WSC 02391 823 56573 VCID: 7DB2D92FE41CECA7CC-8028 2 Faults Found: 00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 9 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:34 Freeze Frame: Hex Value: 0x00C0 Hex Value: 0x0082 Hex Value: 0x002E Hex Value: 0x0286 Hex Value: 0x00FF 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 18:45:13 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4082 Hex Value: 0x0025 Hex Value: 0x46AA Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 F HW: 8K0 907 064 F Component: BCM2 1.1 H80 0145 Revision: 00002001 Coding: 090100 Shop #: WSC 02399 823 56573 VCID: 33263F1792D8EAD76A-8066 Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A Component: FBSAUDIB8 IDG H37 0060 Serial number: 0509000010202006 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H36 0041 Serial number: 0209000012848015 3 Faults Found: 00956 - Key 2 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2019.12.27 Time: 09:41:23 00447 - Function Limitation due to Over-Voltage 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 9 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:21 01330 - Central Control Module for Central Convenience (J393) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:51 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA Component: KLIMA 1 ZONE H06 0150 Revision: A1000000 Serial number: 01130320090031 Coding: 64002000 Shop #: WSC02391 823 56573 VCID: 70ACF01BA34E91CF57-8024 3 Faults Found: 00457 - Central Electronics Control Module / BCM (J519) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:32 00256 - A/C Pressure/Temperature Sensor (G395) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:49 Freeze Frame: Temperature: 6.0°C 00447 - Function Limitation due to Over-Voltage 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:37:14 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 D HW: 8K0 907 063 D Component: BCM1 1.0 H24 0253 Revision: 05024001 Serial number: 00000000225447 Coding: 690000B1063C00010000080300007F5F0F1452080000000100 0000 Shop #: WSC 02391 823 56573 VCID: 302C301B63CED1CF17-8064 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 180309 H06 0070 Serial number: SWF09030185532 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 941 531 T HW: 8K0 941 531 T Component: E1 - LDS H07 0090 Serial number: 00000000001203091159 9 Faults Found: 03351 - Bulb for DRL and Marker Light; Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:00 03354 - Bulb for DRL and Marker Light; Right 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:00 00978 - Lamp for Low Beam; Left (M29) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.04 Time: 13:05:00 00979 - Lamp for Low Beam; Right (M31) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.04 Time: 13:05:00 01497 - Bulb for Blinkers; Front Right (M7) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.05 Time: 09:17:00 03188 - Bulb for Side Marker Light; Front Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.04 Time: 13:05:00 03189 - Bulb for Side Marker Light; Front Right 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.04 Time: 13:05:00 02745 - Bulb for Daytime Running Light; Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:00 02746 - Bulb for Daytime Running Light; Right 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:00 ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 8K0-959-655.clb Part No SW: 8K0 959 655 F HW: 8K0 959 655 F Component: AirbagVW-AU10 H27 0410 Serial number: 0039KD14XSN5 Coding: 303836354230303030304A55304C384B3053 Shop #: WSC 02135 785 00200 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_A02.rod VCID: 40CC60DBDB6E414FE7-8014 Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B Component: BF-Gewichtss. H01 0030 Serial number: 5810000R0900003JA6 Crash sensor for side airbag: driver side: Serial number: 6334MSME46340C1BE Crash sensor for side airbag: front passenger side: Serial number: 6344MSME4463086EJ Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME621E520EL Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME461F0922H 2 Faults Found: 9443859 - Driver's Front Airbag Crash Sensor B101A 15 [137] - Open or Short to Plus MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.02 Time: 15:28:25 9444115 - Front Passenger's Front Airbag Crash Sensor B101B 15 [137] - Open or Short to Plus MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.02 Time: 15:28:25 ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90304ICD0004X Coding: 000034 Shop #: WSC 02391 823 56573 VCID: 3D32192FA49C2CA78C-8068 Component: E221 - MFL H02 0003 2 Faults Found: 00447 - Function Limitation due to Over-Voltage 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:38:59 00888 - Wiper Switch for Intermittent Operation (E22) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 2 Fault Frequency: 12 Reset counter: 10 Mileage: 205825 km Time Indication: 0 Date: 2019.12.03 Time: 05:38:09 ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 950 A HW: 8K0 920 950 A Component: KOMBIINSTR. H18 0224 Revision: 00000000 Serial number: 9DR1EGC39 Coding: 8B1209000300D705020000 Shop #: WSC 02391 823 56573 VCID: 2D12296F74FCBC273C-8078 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 M HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0095 Revision: GB300043 Serial number: 4300G0930686F2 Coding: 000303 Shop #: WSC 02391 823 56573 VCID: 4BD647F7EA28921702-801E Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H06 0160 Serial number: 19068C5E110209 2 Faults Found: 03041 - Energy Management Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 10 Reset counter: 48 Mileage: 206827 km Time Indication: 0 Date: 2020.01.16 Time: 18:47:00 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 7 Fault Frequency: 3 Reset counter: 48 Mileage: 206827 km Time Indication: 0 Date: 2020.02.03 Time: 04:06:00 ------------------------------------------------------------------------------- Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb Part No SW: 8T0 035 785 HW: 8T0 035 785 Component: SG ext.Player H06 0210 Revision: 00000000 Coding: 020302 Shop #: WSC 02391 823 56573 VCID: 78BCC83BCB3EC98F9F-802C 1 Fault Found: 00447 - Function Limitation due to Over-Voltage 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 255 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:18 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8K0 959 793 D HW: 8K0 959 793 D Component: TSG FA H11 0250 Revision: Serial number: 0000008591368 Coding: 011C03204000410001 Shop #: WSC 02391 823 56573 VCID: 41CA65DFD8644847E8-8014 3 Faults Found: 02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 254 Reset counter: 46 Mileage: 200391 km Time Indication: 0 Date: 2019.08.09 Time: 16:25:38 00447 - Function Limitation due to Over-Voltage 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:36:22 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:37:15 ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 F HW: 8K0 907 064 F Component: BCM2 1.1 H80 0145 Revision: 00002001 Serial number: 0117171294 Coding: 0106023A007A000400B001 Shop #: WSC 02391 823 56573 VCID: 33263F1792D8EAD76A-8066 Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H03 1301 Subsystem 2 - Part No SW: 8K0 959 591 HW: 8K0 959 591 Component: J245 PS034 H06 0037 3 Faults Found: 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 214 Mileage: 196167 km Time Indication: 0 Date: 2019.03.18 Time: 09:45:51 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 214 Mileage: 196167 km Time Indication: 0 Date: 2019.03.18 Time: 09:46:32 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:51 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb Part No SW: 8T0 035 223 AB HW: 8T0 035 223 Component: DSP STD H07 0220 Revision: S2100000 Coding: 0203010102 Shop #: WSC 02391 823 56573 VCID: 6E90EE63B97A873F45-803A 2 Faults Found: 02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 74 Reset counter: 49 Mileage: 196240 km Time Indication: 0 Date: 2019.03.19 Time: 22:50:20 Freeze Frame: Voltage: 11.80 V Temperature: -2.0°C Bin. Bits: 00000000 02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 74 Reset counter: 49 Mileage: 196240 km Time Indication: 0 Date: 2019.03.19 Time: 22:50:20 Freeze Frame: Voltage: 11.80 V Temperature: -2.0°C Bin. Bits: 00000000 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8K0 959 792 D HW: 8K0 959 792 D Component: TSG BF H11 0250 Revision: Serial number: 0000008606952 Coding: 011C03204000410001 Shop #: WSC 02391 823 56573 VCID: 40CC60DBD36E414FE7-8014 2 Faults Found: 00447 - Function Limitation due to Over-Voltage 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:36:21 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:37:15 ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 G HW: 8K0 907 801 G Component: EPB Audi B8 H08 0080 Revision: 00000003 Serial number: 10000000194622 Shop #: WSC 00000 000 00000 VCID: 33263F1792D8EAD76A-8066 2 Faults Found: 01321 - Control Module for Airbags (J234) 013 - Check DTC Memory - MIL ON Freeze Frame: Fault Status: 11101101 Fault Priority: 4 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:34 Freeze Frame: Voltage: 10.80 V Count: 80 Speed: 0.0 km/h Hex Value: 0x02E0 Hex Value: 0x0001 Hex Value: 0x0101 01314 - Engine Control Module 013 - Check DTCMemory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 4 Fault Frequency: 1 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 18:45:14 Freeze Frame: Voltage: 14.00 V Count: 58 Speed: 0.0 km/h Hex Value: 0x0270 Hex Value: 0x0001 Hex Value: 0x0101 ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb Part No SW: 8T1 035 186 R HW: 8T1 035 186 R Component: Con3 Sirius H01 0301 Revision: 00000003 Serial number: AUZ5Z6I1188533 Coding: 04020002010185004119070800 Shop #: WSC 02391 823 56573 VCID: 46C076C3F14A6F7FDD-8012 Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E Component: Display 2 Faults Found: 02635 - Tuner Not Enabled/Activated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 214 Mileage: 196167 km Time Indication: 0 Date: 2019.03.18 Time: 09:36:54 03157 - Functionality limited due to Communications Disruption 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 165 Reset counter: 47 Mileage: 196207 km Time Indication: 0 Date: 2019.03.18 Time: 17:56:09 Freeze Frame: Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 10000000 Bin. Bits: 00000000 Bin. Bits: 00000000 ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HL H10 0251 Revision: Serial number: 0000100819785 Coding: 010C03204000210001 Shop #: WSC 02391 823 56573 VCID: 44C46CCBC7765D6FC3-8010 2 Faults Found: 00447 - Function Limitation due to Over-Voltage 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:36:22 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:37:16 ------------------------------------------------------------------------------- Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb Part No SW: 8K0 907 273 A HW: 8K0 907 273 A Component: J502-RDK H03 0250 Revision: 00001001 Serial number: 13374790243434 Coding: 0CD154 Shop #: WSC02391 823 56573 VCID: 302C301B63CED1CF17-8064 2 Faults Found: 02214 - Tire Pressure Warning 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 9 Mileage: 206827 km Time Indication: 0 Date: 2020.02.05 Time: 09:50:26 Freeze Frame: 0.00 Bin. Bits: 00001000 01001000 Voltage: 12.60 V Text: 01,0°C; 7,67bar;3390855650;00h;-50°C 01521 - Sensor for Tire Pressure 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.05 Time: 09:33:13 Freeze Frame: 0.00 Bin. Bits: 00001000 11001001 Voltage: 14.00 V Text: 01,0°C;n.erkannt;3390855811;--h;---°C ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HR H10 0251 Revision: Serial number: 0000100819719 Coding: 010C03204000210001 Shop #: WSC 02391 823 56573 VCID: 44C46CCBC7765D6FC3-8010 2 Faults Found: 00447 - Function Limitation due to Over-Voltage 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 6 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:32 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 46 Time Indication: 0 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8T0 862 336 C HW: 8T0 862 336 C Component: FSE_256x BT H33 0550 Revision: 00000000 Serial number: 00000005034728 Coding: 0010370 Shop #: WSC 02335 785 00200 VCID: 3B3617377A882297B2-806E 1 Fault Found: 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 7 Fault Frequency: 1 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:18 End----------(Elapsed Time: 01:39, VBatt start/end: 12.1V/12.1V)
Got the exact same issue with a 2.0T Q5....did you get any resolution?Is there any adaptations that should be reset after a chain failure and replacement? Car is missing at idle but runs smooth above 1100 rpms.
Thanks for the reply...interesting.....watched a VCDS tutorial by the Humble Mechanic, in it he specifically listed, in the Basic Tests module, he stated ;Start a new thread but there is no reset of adaptions necessary as it is mechanical timing itself unless you have another issue or it wasnt assembled correctly or repair procedures weren't followed correctly.
