Audi A6 C6 (facelift) heated seats... boost?
Unruled
C?ID=376974
Hi guys,
I've noticed how the heated seats in my Audi C6.5 are feeble at best. Via my VCDS I'm able to read all the values and in Module 8, measuring blocks 27 and 28 it gives me the information on the seats. In my car it's possible to set it to 6 levels, most of which are apparently far below body temperature :banghead:
Only settings 5 and 6 seems vaguely useful, where setting 6 sets the seats to 38 degrees (celcius, to be clear, that's only just above body temperature), and setting 5 sets them to 33 degrees, already below. I'm sorry, but how is that heated? It's more like lukewarm :facepalm:
Apparently this is simply the way they're programmed. If I briefly turn down the seats to let's say setting 3 (programmed to 17 degrees :banghead:), and then turn it back up to 6 it feels hotter for a bit, although it doesn't really ever display more than 39 degrees on VCDS.
So the question is simple: is it possible to adjust the target temperatures for these settings? I'd really be looking for something 10 degrees higher at least, I can always turn it down if it's too hot. But six settings, of which 5 are pointless... I don't get that. I know that in the pre-facelift models the heated seats were much better, but in mine they're very disappointing. I haven't been able to find anything simply browsing around...
Thanks in advance!
Edit: added the auto-scan
Mittwoch,11,März,2020,08:30:28:24747
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
VCDS Version: AIB 18.9.1.0  HEX-V2 CB: 0.4508.4
Datenstand: 20190215 DS296.0
www.vcds.de
Fahrzeug-Ident.-Nr.: WAUZZZ4F8AN073201   KFZ-Kennzeichen:
Fahrzeugtyp: 4F-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 13 15 16 17 19 34 42 46 47 4F 52 53 55
          56 5F 62 69 72 76
Fahrzeug-Ident.-Nr.: WAUZZZ4F8AN073201   Kilometerstand: 269670km
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
0E-Media Player 1 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
34-Niveauregelung -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
46-Komfortsystem -- Status: Fehler 0010
47-Soundsystem -- Status: i.O. 0000
4F-Zentralelektrik II -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
53-Feststellbremse -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
56-Radio -- Status: Fehler 0010
5F-Informationselek. I -- Status: i.O. 0000
62-Türelektr. hi. li. -- Status: i.O. 0000
69-Anhänger -- Status: i.O. 0000
72-Türelektr. hi. re. -- Status: i.O. 0000
76-Einparkhilfe -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CAHB)       Labeldatei:* Keine
   Teilenummer SW: 03L 906 019 M    HW: 03L 906 022 FG
   Bauteil: R4 2,0L EDC   X03 6417
   Revision: 11X03---    Seriennummer:
   Codierung: 010D002C02072220
   Betriebsnr.: WSC 92521 052 00000
   ASAM Datensatz: EV_ECM20TDI03L906019M A01003
   ROD: EV_ECM20TDI03L906019AF.rod
   VCID: 3536DAF225C77C1F7DB-8060
1 Fehler gefunden:
4799 - Luftmassenmesser (G70)
          P0102 00 [032] - Signal zu klein
          Sporadisch - unbestätigt - geprüft seit letzter Löschung
Adresse 02: Getriebe        Labeldatei: DRV\01J-927-156.lbl
   Teilenummer SW: 4F9 910 155 D    HW: 01J 927 156 JG
   Bauteil: V30 0AN 2.0l CR RdW 0020
   Revision: --H06---    Seriennummer: 00000000000474
   Codierung: 0000001
   Betriebsnr.: WSC 02325 785 00200
   VCID: 2C00FF96FA0D3DD7125-8078
Adresse 03: Bremsenelektronik        Labeldatei: DRV\4F0-910-517.lbl
   Teilenummer SW: 4F0 910 517 AK    HW: 4F0 614 517 AT
   Bauteil: ESP8 front      H03 0060
   Revision: 00000000    Seriennummer: 00000000000000
   Codierung: 0000380
   VCID: 6D8632920197F4DF45B-8038
Adresse 05: Zugangs-/Startber.        Labeldatei:. 4F0-910-852.clb
   Teilenummer SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Bauteil: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Seriennummer: 10602601543296
   Codierung: 0000131
   Betriebsnr.: WSC 02323 785 00200
   VCID: 25160AB299E70C9FCDB-8070
   Subsystem 1 - Teilenummer: 4F0 910 132 E
   Bauteil: FBSAUDIC6 EZS   H03 0020
   Subsystem 2 - Teilenummer: 4F0 910 220 D
   Bauteil: FBSAUDIC6 IDG   H01 0054
Adresse 08: Klima-/Heizungsel.        Labeldatei: 4F0-910-043.clb
   Teilenummer SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Bauteil: KLIMABETAETIGUNGH30 0080
   Revision: 00000076    Seriennummer: 00000000691520
   Codierung: 0000276
   VCID: 1D662252B1B7C45F95B-8048
Adresse 09: Zentralelektrik        Labeldatei: DRV\4F0-910-279.lbl
   Teilenummer SW: 4F0 910 279 N    HW: 4F0 907 279
   Bauteil: ILM Fahrer      H22 0320
   Revision: 00000000    Seriennummer: 4F0907279
   Codierung: 0003122
   Betriebsnr.: WSC 02335 785 00200
   VCID: 3430E7F6223D65174A5-8060
   Subsystem 1 - Teilenummer: 4F1 910 113 D  Labeldatei: DRV\1KX-955-119.CLB
   Bauteil: Wischer AudiC6  H10 0040
   Codierung: 00056595
   Subsystem 2 - Teilenummer: 8K0 910 557   Labeldatei: DRV\8K0-955-559.CLB
   Bauteil: REGENLICHTSENSORH04 0003
   Codierung: 00211757
Adresse 0E: Media Player 1 (R41)       Labeldatei: DRV\4E0-910-111.lbl
   Teilenummer SW: 4F0 035 110 A    HW: 4F0 035 110
   Bauteil: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 15763A7245879C1F5DB-8040
Adresse 13: Distanzregelung        Labeldatei: DRV\4F0-910-561.clb
   Teilenummer SW: 4F0 910 561 C    HW: 4F0 907 561 B
   Bauteil: ABSTANDSREGELUNGH02 0020
   Revision: --------    Seriennummer: 00000000000000
   Codierung: 0061161
   Betriebsnr.: WSC 00046 000 00000
   VCID: 231214AA97D3F2AFA3F-8076
Adresse 15: Airbag (J234)       Labeldatei:| DRV\4F0-910-655-10.clb
   Teilenummer SW: 4F0 910 655 Q    HW: 4F0 959 655 G
   Bauteil: Airbag AU1042 H07 0200
   Revision: --------    Seriennummer: 003F9002LUTN
   Codierung: 30314236303630303031554A304C34463053
   ASAM Datensatz: EV_Airba10AURB4 001001
   ROD: EV_Airba10AURB4.rod
   Seriennummer: 3574SRB40000AE19112+
   Seriennummer: 3584SRB40000AE404979
   Crashsensor für Seitenairbag hinten Fahrerseite:
   Seriennummer: 3516HRB4035COCQ723PL
   Crashsensor für Seitenairbag hinten Beifahrerseite:
   Seriennummer: 3526HRB402HCTBFR4J95
   Seriennummer: 3554NRB40000572DFEEN
   Crashsensor für Frontairbag Beifahrerseite:
   Seriennummer: 3564NRB4000056A3529.
Adresse 16: Lenkradelektronik        Labeldatei: DRV\4F0-910-549.lbl
   Teilenummer SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Bauteil: J0527               0530
   Revision: 00H05000    Seriennummer: 90026100700040
   Codierung: 0002052
   VCID: 270A00BAE3EB1E8FFF7-8072
   Subsystem 1 - Teilenummer: XXXXXXXXXXX
   Bauteil: E0221           H02 0100
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:. DRV\4F0-920-xxx-17.clb
   Teilenummer SW: 4F0 920 934 A    HW: 4F0 920 934 A
   Bauteil: KOMBIINSTR.   H08 0147
   Revision: 00300000    Seriennummer: DH622CA3A
   Codierung: 0F5F11050601000C010100
   Betriebsnr.: WSC 02391 823 56573
   VCID: 26140DBEE8E10787C41-8072
Adresse 19: Diagnoseinterface (J533)       Labeldatei:. 4F0-907-468.clb
   Teilenummer SW: 4F0 907 468 N    HW: 4F0 907 468 G
   Bauteil: GW-BEM 5CAN-M H06 0035
   Revision: MB200030    Seriennummer: 3000M103098034
   Codierung: 000B03
   VCID: 3A2CC9CE0C599367909-806E
   Subsystem 1 - Teilenummer SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Bauteil: J367-BDM  H07 0125
   Seriennummer: 00000000002790145919
Adresse 34: Niveauregelung        Labeldatei: DRV\4F0-910-553.clb
   Teilenummer SW: 4F0 910 553 C    HW: 4F0 907 553 A
   Bauteil: J197 LUFTFEDER  H17 0030
   Seriennummer: 00871001568800
   Codierung: 0000120
   Betriebsnr.: WSC 02895 202 82454
   VCID: 241017B692DDF597DA5-8070
Adresse 42: Türelektr. Fahrer (J386)       Labeldatei:. 4F0-959-793.clb
   Teilenummer SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Bauteil: TSG FA        H11 0250
   Revision:             Seriennummer: 0000103197575
   Codierung: 011C02205440410001
   VCID: 46D4AD3E48A1E787E41-8012
Adresse 46: Komfortsystem        Labeldatei:. 4F0-910-289.lbl
   Teilenummer SW: 4F0 910 289 N    HW: 4F0 907 289 N
   Bauteil: Komfortgeraet   H29 0250
   Revision: 02500029    Seriennummer: 01283689760000
   Codierung: 2237169
   VCID: 3536DAF229477C1F7DB-8060
   Subsystem 1 - Teilenummer: 1K0 951 605 C
   Bauteil: LIN BACKUP HORN H05 1501
   Subsystem 2 - Teilenummer: 4F0 910 177
   Bauteil: Innenraumueberw.H01 0020
3 Fehlercodes gefunden:
00317 - Steuergerät für Heckklappe (J605)
            004 - kein Signal/Kommunikation
             Umgebungsbedingungen:
                    Fehlerstatus: 01100100
                    Fehlerpriorität: 5
                    Fehlerhäufigkeit: 254
                    Verlernzähler: 27
                    Kilometerstand: 264740 km
                    Zeitangabe: 0
                    Datum: 2019.10.24
                    Zeit: 11:28:40
01697 - Fußraumleuchte hinten rechts (W46)
            011 - Unterbrechung
                    Fehlerstatus: 01101011
                    Fehlerpriorität: 3
                    Verlernzähler: 24
                    Kilometerstand: 262108 km
                    Zeitangabe: 0
                    Datum: 2019.08.19
                    Zeit: 17:15:29
01696 - Fußraumleuchte hinten links (W45)
            011 - Unterbrechung
                    Fehlerpriorität: 3
                    Verlernzähler: 24
                    Kilometerstand: 262510 km
                    Zeitangabe: 0
                    Datum: 2019.08.25
                    Zeit: 17:30:39
Adresse 47: Soundsystem (J525)       Labeldatei:. DRV\4F0-035-223-BO.clb
   Teilenummer SW: 4F0 035 223 P    HW: 4F0 035 223 P
   Bauteil: BOSE G3 C6    H01 0100
   Revision: AG001300    Seriennummer: 00000000117348
   Codierung: 0D010000
   Betriebsnr.: WSC 09581 002 1048576
   VCID: 290E0682F9FF28FFE93-807C
Adresse 4F: Zentralelektrik II        Labeldatei: DRV\4F0-910-280.lbl
   Teilenummer SW: 4F0 910 280     HW: 4F0 907 280 A
   Bauteil: ILM Beifahrer   H13 0100
   Revision:             Seriennummer: 00000000697775
   Codierung: 0001104
   VCID: 5EE4655EFC319F47CC1-800A
Adresse 52: Türelektr. Beifahr. (J387)       Labeldatei:. 4F0-959-792.clb
   Teilenummer SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Bauteil: TSG BF        H11 0250
   Revision:             Seriennummer: 0000103221619
   Codierung: 011C02205C40410001
   VCID: 45D6AA3275A7EC9FEDB-8010
Adresse 53: Feststellbremse        Labeldatei: DRV\4F0-910-801.clb
   Teilenummer SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Bauteil: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Codierung: 0000131
   Betriebsnr.: WSC 02145 785 00200
   VCID: 211E1EA28DCFE0BFB13-8074
Adresse 55: Leuchtweitenreg.        Labeldatei: DRV\8P0-907-357.lbl
   Teilenummer: 8P0 907 357 H
   Bauteil: Dynamische LWR  H02 0010
   Revision: 00000001    Seriennummer:
   Codierung: 0000004
   VCID: 3FDAB8DA1B7BB64FA77-806A
Adresse 56: Radio (R)       Labeldatei:. DRV\4F0-035-0xx-56.clb
   Teilenummer SW: 4F0 035 053 K    HW: 4F0 035 053
   Bauteil: Radio U Basic H45 0074
   Revision: AB001007    Seriennummer: 341C-0A7718746
   Codierung: 010003010000000000
   VCID: 25160AB295E70C9FCDB-8070
1 Fehler gefunden:
02984 - Verbindung zwischen Impedanzwandler 2 und Scheibenantenne
            011 - Unterbrechung
                    Fehlerpriorität: 5
                    Fehlerhäufigkeit: 44
                    Verlernzähler: 174
                    Kilometerstand: 259845 km
                    Zeitangabe: 0
                    Datum: 2019.06.06
                    Zeit: 20:59:50
                    Spannung: 14.10 V
Adresse 5F: Informationselek. I (J794)       Labeldatei:. DRV\4E0-035-6xx-5F.clb
   Teilenummer SW: 4E0 035 666 K    HW: 4E0 035 666 C
   Bauteil: H-BN-EU       H47 0187
   Revision: --------    Seriennummer: 454CV0A7544370
   Codierung: 010100010002DBFD01000F15EF6300030001
   VCID: 2E04F59EC0114FC73C1-807A
   Subsystem 1 - Teilenummer: 8R0 060 884 FC
   Bauteil: EUR 2018  2601
   Subsystem 2 - Teilenummer SW: 4F0 919 604     HW: 4F0 919 604
   Bauteil: DU7 High  H43 0306
   Seriennummer: 9356CP0A1223960
   Subsystem 3 - Teilenummer SW: 4F0 910 609 E    HW: 4F1 919 611 S
   Bauteil: Bedienteil MM  H01 0060
   Seriennummer: 00000001540309
   Subsystem 4 - Teilenummer: 8R0 906 961 A
   Bauteil: CD-Database  1293
Adresse 62: Türelektr. hi. li. (J388)       Labeldatei:. 4F0-959-795.clb
   Teilenummer SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Bauteil: TSG HL        H10 0251
   Revision:             Seriennummer: 0000010191910
   Codierung: 010800204040220001
   VCID: 44D0B7367E9DD597FA5-8010
Adresse 69: Anhänger        Labeldatei:. DRV\4F0-907-383.clb
   Teilenummer SW: 4F0 907 383 D    HW: 4F0 907 383 D
   Bauteil: J345  Towbar module 0040
   Revision: 00H06000    Seriennummer: 4F0907383D
   Codierung: 0065536
Adresse 72: Türelektr. hi. re. (J389)       Labeldatei:. 4F0-959-795.clb
   Bauteil: TSG HR        H10 0251
   Revision:             Seriennummer: 0000010193759
Adresse 76: Einparkhilfe        Labeldatei: DRV\4Fx-910-283.lbl
   Teilenummer SW: 4L0 910 283 B    HW: 4L0 919 283 B
   Bauteil: Parkhilfe 4-Kan H02 0500
   Revision: 00H02000    Seriennummer: 12331007702218
   Codierung: 0211016
   VCID: 290E0682F5FF28FFE93-807C
Ende--------(Dauer: 01:59, Batt.-Spannung Start/Ende: 14.3V/14.4V)---------
Hi and welcome.
Please post an Auto-Scan so people can see exactly what HVAC module you've got.
darkchina811
ITALY
C?ID=333184
we'll also need admaps of modules 08, 09 (and/or 46).
Unruled
C?ID=376974
Hi there,
Sorry for forgetting the auto-scan, here it is.
www.vcds.de
          56 5F 62 69 72 76
1 Fehler gefunden:
   Codierung: 0000001
   Codierung: 0000380
   Codierung: 0000131
   Codierung: 0000276
   Codierung: 0003122
   Codierung: 00056595
   Codierung: 00211757
   Revision: AA001001
   Codierung: 0061161
   Bauteil: J0527               0530
   Codierung: 0002052
   Codierung: 000B03
   Codierung: 0000120
   Codierung: 2237169
                    Fehlerpriorität: 5
                    Verlernzähler: 27
                    Zeitangabe: 0
                    Datum: 2019.10.24
                    Zeit: 11:28:40
            011 - Unterbrechung
                    Fehlerpriorität: 3
                    Verlernzähler: 24
                    Zeitangabe: 0
                    Datum: 2019.08.19
                    Zeit: 17:15:29
            011 - Unterbrechung
                    Fehlerpriorität: 3
                    Verlernzähler: 24
                    Zeitangabe: 0
                    Datum: 2019.08.25
                    Zeit: 17:30:39
   Codierung: 0D010000
   Codierung: 0001104
   Revision: --H05---
   Codierung: 0000131
   Codierung: 0000004
1 Fehler gefunden:
            011 - Unterbrechung
                    Fehlerpriorität: 5
                    Verlernzähler: 174
                    Zeitangabe: 0
                    Datum: 2019.06.06
                    Zeit: 20:59:50
                    Spannung: 14.10 V
   Codierung: 0065536
   Codierung: 0211016
Hmm that didn't hurt, apparently there's a fault with the air mass meter. I'll clear that and see if it returns. I'm not sure why there are faults with the tailgate, I don't have an electric one and the release does work. The lights for the rear seats is probably because I programmed them in, I guess they're not there in the rear. None of it has much to do with the heated seats though, so the question stands :)
Unruled
C?ID=376974
I'm happy to look into that, but I'm not sure what you mean. How do I do that? Do I need security codes for that?
You should have both actual and specified seat temperatures in MVBs 027 and 028. Do actual temperatures match specified?
I don't see any documented way to change the specified temperatures.
PS: Since this is an English language forum, in the future, please post data from the English version of VCDS. You can download it from this page and it will happily coexist with the German translation you are currently using (which should also be updated!).
Unruled
C?ID=376974
The specified and actual temperatures in measuring blocks 027 and 028 do match, yes. It's just that the specified temperature is very unambitious... I'm sorry to hear that's apparently simply what it is...
Sorry about the german software, that's what came with my VCDS. I wasn't aware that the English version will also work with it... My German is fine but I do prefer English, so I'll switch, thanks :) To be honest I didn't think updating it would be very useful as my car isn't that new either...
It's not about how new your car is, updating VCDS gets all the bug fixes, updated label files and other enhancements - which IMHO are always worth having, even on an older car ;)
Unruled
C?ID=376974
A little bump here... I have since updated, and am now using the English version of VCDS.
I'm wondering if there is a security code known for the 08 HVAC controller? It does seem to have a bunch of adaptation values I can access, but require a code for. Is there any way to get it? Otherwise my options are more hard-ware related I think, fooling the temperature sensor into thinking it's a bit colder than it actually is. That should be doable but it's a last resort :)
I've included the admaps for 08 and 09 since you asked for those :)
EDIT: Never mind the links, here they are in plain text.
Channel 08
;SW:4F0-910-043-B   HW:4F1-820-043-AL ---  Auto HVAC
;Component:KLIMABETAETIGUNGH30 0080, Coding:0000276
;Wednesday,22,April,2020,14:45:18:24747
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: 1D662252B1B7C45358D-8048
Channel,,Field 1,Field 2,Field 3,Field 4,
01,,ERROR:,Channel 01,Not,Available,
02,,ERROR:,Channel 02,Not,Available,
03,1,N/A,N/A,N/A,N/A,
04,0,N/A,N/A,N/A,N/A,
05,0,N/A,N/A,N/A,N/A,
06,0,N/A,N/A,N/A,N/A,
07,0,N/A,N/A,N/A,N/A,
08,,ERROR:,Channel 08,Not,Available,
09,0,N/A,N/A,N/A,N/A,
10,10,N/A,N/A,N/A,N/A,
11,1,N/A,N/A,N/A,N/A,
12,,ERROR:,Security,access,required,
13,,ERROR:,Security,access,required,
14,0,N/A,N/A,N/A,N/A,
15,60,N/A,N/A,N/A,N/A,
16,0,N/A,N/A,N/A,N/A,
17,0,N/A,N/A,N/A,N/A,
18,,ERROR:,Security,access,required,
19,0,N/A,N/A,N/A,N/A,
20,1,N/A,N/A,N/A,N/A,
21,1,N/A,N/A,N/A,N/A,
22,0,N/A,N/A,N/A,N/A,
23,0,N/A,N/A,N/A,N/A,
24,,ERROR:,Security,access,required,
25,,ERROR:,Security,access,required,
26,,ERROR:,Security,access,required,
27,2,N/A,N/A,N/A,N/A,
28,5,N/A,N/A,N/A,N/A,
29,,ERROR:,Security,access,required,
30,,ERROR:,Security,access,required,
31,,ERROR:,Channel 31,Not,Available,
32,,ERROR:,Security,access,required,
33,60,N/A,N/A,N/A,N/A,
34,0,N/A,N/A,N/A,N/A,
35,,ERROR:,Security,access,required,
36,,ERROR:,Channel 36,Not,Available,
37,,ERROR:,Security,access,required,
38,0,N/A,N/A,N/A,N/A,
39,2,N/A,N/A,N/A,N/A,
40,30,N/A,N/A,N/A,N/A,
41,0,N/A,N/A,N/A,N/A,
42,0,N/A,N/A,N/A,N/A,
43,48,N/A,N/A,N/A,N/A,
44,36,N/A,N/A,N/A,N/A,
45,12,N/A,N/A,N/A,N/A,
46,10,N/A,N/A,N/A,N/A,
47,2,N/A,N/A,N/A,N/A,
48,,ERROR:,Channel 48,Not,Available,
49,,ERROR:,Channel 49,Not,Available,
50,,ERROR:,Channel 50,Not,Available,
51,,ERROR:,Channel 51,Not,Available,
52,,ERROR:,Channel 52,Not,Available,
53,,ERROR:,Channel 53,Not,Available,
54,,ERROR:,Channel 54,Not,Available,
55,,ERROR:,Channel 55,Not,Available,
56,,ERROR:,Channel 56,Not,Available,
57,,ERROR:,Channel 57,Not,Available,
58,,ERROR:,Channel 58,Not,Available,
59,,ERROR:,Channel 59,Not,Available,
60,,ERROR:,Channel 60,Not,Available,
Channel 09
;SW:4F0-910-279-N   HW:4F0-907-279 ---  Cent. Elect. --- SA: 12151
;Component:ILM Fahrer      H22 0320, Coding:0003122
;Wednesday,22,April,2020,14:47:43:24747
;VCID: 3430E7F6223D651B873-8060
01,140,N/A,N/A,N/A,N/A,
02,18,N/A,N/A,N/A,N/A,
03,24,N/A,N/A,N/A,N/A,
04,8,OFF,N/A,N/A,N/A,
05,15,OFF,N/A,N/A,N/A,
06,38,OFF,N/A,N/A,N/A,
07,66,OFF,N/A,N/A,N/A,
08,100,OFF,N/A,N/A,N/A,
09,30,31.0 s,N/A,N/A,N/A,
10,5,N/A,N/A,N/A,N/A,
11,20,20.0 %,N/A,N/A,N/A,
12,60,N/A,N/A,N/A,N/A,
13,50,N/A,N/A,N/A,N/A,
14,1,N/A,N/A,N/A,N/A,
15,1,Enabled,N/A,N/A,N/A,
16,1,N/A,N/A,N/A,N/A,
17,3,N/A,N/A,N/A,N/A,
18,50,N/A,N/A,N/A,N/A,
20,6,N/A,N/A,N/A,N/A,
21,0,N/A,N/A,N/A,N/A,
22,40,N/A,N/A,N/A,N/A,
23,5,N/A,N/A,N/A,N/A,
24,0,N/A,N/A,N/A,N/A,
25,30,N/A,N/A,N/A,N/A,
26,,ERROR:,Channel 26,Not,Available,
27,,ERROR:,Channel 27,Not,Available,
28,,ERROR:,Channel 28,Not,Available,
29,,ERROR:,Channel 29,Not,Available,
30,,ERROR:,Channel 30,Not,Available,
32,,ERROR:,Channel 32,Not,Available,
33,,ERROR:,Channel 33,Not,Available,
34,,ERROR:,Channel 34,Not,Available,
35,,ERROR:,Channel 35,Not,Available,
37,,ERROR:,Channel 37,Not,Available,
38,,ERROR:,Channel 38,Not,Available,
39,,ERROR:,Channel 39,Not,Available,
40,,ERROR:,Channel 40,Not,Available,
41,,ERROR:,Channel 41,Not,Available,
42,,ERROR:,Channel 42,Not,Available,
43,,ERROR:,Channel 43,Not,Available,
44,,ERROR:,Channel 44,Not,Available,
45,,ERROR:,Channel 45,Not,Available,
46,,ERROR:,Channel 46,Not,Available,
47,,ERROR:,Channel 47,Not,Available,
60,65535,Adapt Value,Learned,N/A,N/A,
61,65535,Adapt Value,Learned,N/A,N/A,
62,65535,Adapt Value,Learned,N/A,N/A,
63,65535,Adapt Value,Learned,N/A,N/A,
64,65535,Adapt Value,Learned,N/A,N/A,
65,65535,Adapt Value,Learned,N/A,N/A,
66,65535,Adapt Value,Learned,N/A,N/A,
67,65535,Adapt Value,Learned,N/A,N/A,
68,65535,Adapt Value,Learned,N/A,N/A,
69,65535,Adapt Value,Learned,N/A,N/A,
70,65535,Adapt Value,Learned,N/A,N/A,
71,65535,Adapt Value,Learned,N/A,N/A,
72,65535,Adapt Value,Learned,N/A,N/A,
73,65535,Adapt Value,Learned,N/A,N/A,
74,65535,Adapt Value,Learned,N/A,N/A,
75,65535,Adapt Value,Learned,N/A,N/A,
76,65535,Adapt Value,Learned,N/A,N/A,
77,65535,Adapt Value,Learned,N/A,N/A,
78,65535,Adapt Value,Learned,N/A,N/A,
79,65535,Adapt Value,Learned,N/A,N/A,
80,65535,Adapt Value,Learned,N/A,N/A,
81,65535,Adapt Value,Learned,N/A,N/A,
82,65535,Adapt Value,Learned,N/A,N/A,
83,65535,Adapt Value,Learned,N/A,N/A,
84,65535,Adapt Value,Learned,N/A,N/A,
85,,ERROR:,Channel 85,Not,Available,
86,,ERROR:,Channel 86,Not,Available,
87,,ERROR:,Channel 87,Not,Available,
88,,ERROR:,Channel 88,Not,Available,
89,,ERROR:,Channel 89,Not,Available,
90,,ERROR:,Channel 90,Not,Available,
91,,ERROR:,Channel 91,Not,Available,
92,,ERROR:,Channel 92,Not,Available,
93,,ERROR:,Channel 93,Not,Available,
94,,ERROR:,Channel 94,Not,Available,
95,,ERROR:,Channel 95,Not,Available,
96,,ERROR:,Channel 96,Not,Available,
97,,ERROR:,Channel 97,Not,Available,
98,,ERROR:,Channel 98,Not,Available,
99,,ERROR:,Channel 99,Not,Available,
100,,ERROR:,Channel 100,Not,Available,
101,,ERROR:,Channel 101,Not,Available,
102,,ERROR:,Channel 102,Not,Available,
103,,ERROR:,Channel 103,Not,Available,
104,,ERROR:,Channel 104,Not,Available,
105,,ERROR:,Channel 105,Not,Available,
106,,ERROR:,Channel 106,Not,Available,
107,,ERROR:,Channel 107,Not,Available,
108,,ERROR:,Channel 108,Not,Available,
109,,ERROR:,Channel 109,Not,Available,
110,,ERROR:,Channel 110,Not,Available,
111,,ERROR:,Channel 111,Not,Available,
112,,ERROR:,Channel 112,Not,Available,
113,,ERROR:,Channel 113,Not,Available,
114,,ERROR:,Channel 114,Not,Available,
115,,ERROR:,Channel 115,Not,Available,
116,,ERROR:,Channel 116,Not,Available,
117,,ERROR:,Channel 117,Not,Available,
118,,ERROR:,Channel 118,Not,Available,
119,,ERROR:,Channel 119,Not,Available,
120,,ERROR:,Channel 120,Not,Available,
121,,ERROR:,Channel 121,Not,Available,
122,,ERROR:,Channel 122,Not,Available,
123,,ERROR:,Channel 123,Not,Available,
124,,ERROR:,Channel 124,Not,Available,
125,,ERROR:,Channel 125,Not,Available,
126,,ERROR:,Channel 126,Not,Available,
127,,ERROR:,Channel 127,Not,Available,
128,,ERROR:,Channel 128,Not,Available,
129,,ERROR:,Channel 129,Not,Available,
130,,ERROR:,Channel 130,Not,Available,
131,,ERROR:,Channel 131,Not,Available,
132,,ERROR:,Channel 132,Not,Available,
133,,ERROR:,Channel 133,Not,Available,
134,,ERROR:,Channel 134,Not,Available,
135,,ERROR:,Channel 135,Not,Available,
136,,ERROR:,Channel 136,Not,Available,
137,,ERROR:,Channel 137,Not,Available,
138,,ERROR:,Channel 138,Not,Available,
139,,ERROR:,Channel 139,Not,Available,
140,,ERROR:,Channel 140,Not,Available,
141,,ERROR:,Channel 141,Not,Available,
142,,ERROR:,Channel 142,Not,Available,
143,,ERROR:,Channel 143,Not,Available,
144,,ERROR:,Channel 144,Not,Available,
145,,ERROR:,Channel 145,Not,Available,
146,,ERROR:,Channel 146,Not,Available,
147,,ERROR:,Channel 147,Not,Available,
148,,ERROR:,Channel 148,Not,Available,
149,,ERROR:,Channel 149,Not,Available,
150,,ERROR:,Channel 150,Not,Available,
151,,ERROR:,Channel 151,Not,Available,
152,,ERROR:,Channel 152,Not,Available,
153,,ERROR:,Channel 153,Not,Available,
154,,ERROR:,Channel 154,Not,Available,
155,,ERROR:,Channel 155,Not,Available,
156,,ERROR:,Channel 156,Not,Available,
157,,ERROR:,Channel 157,Not,Available,
158,,ERROR:,Channel 158,Not,Available,
159,,ERROR:,Channel 159,Not,Available,
160,,ERROR:,Channel 160,Not,Available,
161,,ERROR:,Channel 161,Not,Available,
162,,ERROR:,Channel 162,Not,Available,
163,,ERROR:,Channel 163,Not,Available,
164,,ERROR:,Channel 164,Not,Available,
165,,ERROR:,Channel 165,Not,Available,
166,,ERROR:,Channel 166,Not,Available,
167,,ERROR:,Channel 167,Not,Available,
168,,ERROR:,Channel 168,Not,Available,
169,,ERROR:,Channel 169,Not,Available,
170,,ERROR:,Channel 170,Not,Available,
171,,ERROR:,Channel 171,Not,Available,
172,,ERROR:,Channel 172,Not,Available,
173,,ERROR:,Channel 173,Not,Available,
174,,ERROR:,Channel 174,Not,Available,
175,,ERROR:,Channel 175,Not,Available,
176,,ERROR:,Channel 176,Not,Available,
177,,ERROR:,Channel 177,Not,Available,
178,,ERROR:,Channel 178,Not,Available,
179,,ERROR:,Channel 179,Not,Available,
180,,ERROR:,Channel 180,Not,Available,
Unruled
C?ID=376974
I was trying to use an attachment, but the forum doesn't seem to support them? The files aren't in plain text (csv) so copy-pasting them doesn't really work. Is there an easier/safer way to share the files?
Correct. We don't allow attachments.
A .CSV file is just text, with the fields separated by commas. Open with Notepad, copy & paste the contents.
Unruled
C?ID=376974
Ah, I'll be darned. Here they are, sorry for the confusion :)
Channel 08
Channel 09
I wasn't sure how long to keep going... does this even stop at some point?
Yes at channel 255.
I'm not seeing anything obvious there.
Have you looked at MVB 027 and 028 in the HVAC module? It should have actual and specified seat temperatures. I thinking that your best bet might be to convince the module that the seat temperature is lower than it actually is with some kind of hardware add on, but I'm not sure what kind of temperature sensor is being used here.
Unruled
C?ID=376974
Yeah I used those measuring blocks, was looking for a way to adjust the specified temperatures in relation to the setting on the dials, but I guess that's not really possible then? Was hoping to find a setting under the security code.
Will have to use a hardware approach then :)
Unruled
C?ID=376974
Little bit of feedback post solution.
I've gone the hardware route. The seat uses a 9kOhm NTC thermistor for the temp readout. I added a 2kOhm potentiometer inline with the thermistor, and ended up using about 1kOhm as a good setting. Seats now reach a toasty 46 degrees centigrade, as opposed to 38 before the modification. All intermediate settings scale logically. If it's a bit much, I'll dial it down.
Apparently the controller is very straight-forward and easy to fool, lucky me. Thanks for thinking along with me :)
