- Mar 26, 2020
- 22
- 12
- Southampton, UK
- C?ID=380307
Hi All. Symptoms starts fine from cold and revs up fine but when warm you have to keep the key on until it catches very sluggish from rest, you have to wait for the turbo to spool up and off we go runs ok.
Did have a 000833 - Camshaft Position Sensor (G40) P0341 - 000 - Implausible Signal.. before i striped and retimeed the cam. any idea what 48.0 Start Synchronisation means ??
so far.
new moo valve
rebuild turbo {not by me}
Many thanks for sharing my problems. john {jack iam ok for soup}
so far.
new moo valve
Address 01: Engine (070 906 016 DS)
11:18:51 Group 004: Unit Injector
798 /min Engine Speed (G28)
3.1 °BTDC Injection Start (specified)
7.7°KW Injection Duration (specified)
-6.9°KW Torsion Value
11:18:51 Group 013: Idle Stabilization (Injection Quantity Deviation - Cylinder 1-4)
2.16 mg/str Injection Quantity Deviation Cyl. 1
0.92 mg/str Injection Quantity Deviation Cyl. 2
-0.31 mg/str Injection Quantity Deviation Cyl. 3
-0.64 mg/str Injection Quantity Deviation Cyl. 4
11:18:51 Group 051: Speed Recording
399 /min Camshaft Speed
00010000 Inject. Sequence Shut-Off Status
Wednesday,08,April,2020,11:54:18:62543
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
VIN: WV2ZZZ7HZ8H015277 License Plate: HKOI
Mileage: 496720km-308647mi Repair Order: 8/5/20
57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ8H015277 Mileage: 496720km-308647miles
Address 01: Engine Labels: 070-906-016-BPC.clb
Part No SW: 070 906 016 DS HW: 070 906 016 DS
Component: R5 2,5L EDC 000SG 1585
Revision: --H05--- Serial number: VWZ7Z0G5463049
Coding: 0001072
Shop #: WSC 80093 222 69422
VCID: 6491AC44A244FBDBD7A-5184
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High
Mileage: 496720 km
RPM: 777 /min
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 00000000
Temperature: 66.6°C
Temperature: 55.8°C
Address 03: ABS Brakes Labels:. 7H0-907-37x-ABS.clb
Part No SW: 7H0 907 379 S HW: 7H0 907 379 S
Component: (M)ABS MK25E 0103
Revision: 00H21001
Coding: 0000552
Shop #: WSC 02756 790 00000
VCID: 45D751C009BEA2D3204-5160
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 7H0 820 045 AL
Component: CLIMA/AC 0303
VCID: 6FBBD3687B824883BA8-5160
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels:. 7H0-937-049.lbl
Part No: 7H0 937 049 T
Component: BORDNETZ SGVER 1.0 2001
Coding: 0000101
VCID: 43D34FD8078A9CE30E0-513C
Part No: 1C0 909 605 A
Component: 3C AIRBAG VW51 0010
Coding: 13123
Shop #: WSC 02756
VCID: 221DEA5CFDD0B5EB656-513C
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H0 920 951 T
Coding: 00413
Shop #: WSC 77824
VCID: 3D273920646EEA13784-513C
WV2ZZZ7HZ8H015277 VWZ7Z0G5463049
01304 - Radio
49-00 - No Communications
Address 18: Aux. Heat Labels: 7H0-819-008.lbl
Part No: 7H0 815 071 F
Component: Standheizung 0209
VCID: 2B0307788F1A74A3D60-513C
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 02756
VCID: 70B9D01463BC577BA32-513C
01304 - Radio
Address 45: Inter. Monitor Labels: 7Hx-951-171.lbl
Part No: 7H0 951 171 B
Component: Innenraumueberw. 2920
Coding: 0000022
Shop #: WSC 02757 790 00000
VCID: 290FFD7085E666B324C-51CE
Subsystem 1 - Part No: 7H5 951 178
Component: Innenraumueberw. 1607
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433 B
Component: C11 Komfortgerát 0004
Coding: 00030
Shop #: WSC 02756
VCID: 323D1A1CAD30256B956-4B1E
End----------(Elapsed Time: 05:48, VBatt start/end: 14.5V/12.4V)-----------
