Oil level correction.
victor35ma
Los Angeles CA.
C?ID=242342
hello, is it possible to make an oil level correction using VCDS?
I got this car and we replaced engine oil 4.9L according to specs, but oil level is marking 1/4 bellow the MAX.
url]
Saturday,20,April,2019,15:04:58:23194
VCDS Version: 18.9.1.0  HEX-NET CB: 0.4437.4
VIN: WAUJF78K69N047743   License Plate: 6ZRP148
Mileage: 180650km-112250mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 65 72
          77
VIN: WAUJF78K69N047743   Mileage: 180650km-112250miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Revision: E1H14---
   Coding: 0104010A02070160
   Shop #: WSC 22145 444 13987
   VCID: F9BA8A4A788348821A-80AC
11 Faults Found:
4527 - Coolant Fan Control Circuit 1
          P0480 00 [036] - Electrical Malfunction
                    Mileage: 180654 km
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 12.368 V
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
          P0016 00 [237] - Incorrect Correlation
                    Fault Frequency: 51
                    Mileage: 178541 km
                    Date: 2019.02.26
                    Time: 17:35:19
                    Engine speed: 1115.00 /min
                    Normed load value: 6.7 %
                    Vehicle speed: 27 km/h
                    Coolant temperature: 77 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 13.782 V
5671 - Boost Pressure Regulation
          P0299 00 [096] - Control Range Not Reached
                    Mileage: 180315 km
                    Date: 2019.03.13
                    Time: 18:14:34
                    Engine speed: 2327.50 /min
                    Normed load value: 82.4 %
                    Vehicle speed: 48 km/h
                    Coolant temperature: 96 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 14.324 V
                    Unlearning counter according OBD: 35
4010 - Idle Control System
          P0506 00 [237] - RPM Lower than Expected
                    Mileage: 180646 km
                    Date: 2019.03.17
                    Time: 12:45:07
                    Engine speed: 643.00 /min
                    Normed load value: 20.4 %
                    Intake air temperature: 57 °C
4054 - Cylinder 1
          P0301 00 [237] - Misfire Detected
                    Mileage: 180639 km
                    Date: 2019.03.17
                    Time: 08:08:18
                    Engine speed: 1343.00 /min
                    Normed load value: 31.8 %
                    Vehicle speed: 68 km/h
                    Coolant temperature: 82 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 13.923 V
4060 - Cylinder 3
          P0303 00 [236] - Misfire Detected
                    Mileage: 180639 km
                    Date: 2019.03.17
                    Time: 08:08:18
4063 - Cylinder 4
          P0304 00 [237] - Misfire Detected
                    Mileage: 180639 km
                    Date: 2019.03.17
                    Time: 08:08:18
4057 - Cylinder 2
          P0302 00 [236] - Misfire Detected
                    Mileage: 180639 km
                    Date: 2019.03.17
                    Time: 08:08:18
4051 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [237] - -
                    Mileage: 180639 km
                    Date: 2019.03.17
                    Time: 08:07:54
                    Engine speed: 1014.00 /min
                    Normed load value: 11.4 %
                    Vehicle speed: 16 km/h
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 13.593 V
4106 - Bank 1; System too Rich at Idle
          P2188 00 [096] - -
4201 - Fuel Level too Low
          P1250 00 [096] - -
   Part No SW: 8K0 927 155 AD    HW: 0AW 927 156 H
   Component: 0AW 20TFSIUSA H01 0004
   Revision: --H01---    Serial number: 0000000286
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMVL381 A02006
   ROD: EV_TCMVL381.rod
   VCID: F5A2867A549B2CE27E-80A0
2225 - RPM Signal from ECU
          P0727 00 [108] - No Signal
                    Fault Frequency: 17
                    Mileage: 179883 km
                    Date: 2019.03.11
                    Time: 15:34:49
                    Engine speed: 100.00 /min
                    Transmission input speed: 1 /min
                    Transmission output speed: 1 /min
                    Engine torque: -40 Nm
                    Transmission fluid temperature: 20 °C
                    Accelerator position: 0.0 %
                    Clutch status: 13
   Part No SW: 8K0 907 379 AE    HW: 8K0 907 379 AE
   Component: ESP8 front    H04 0240
   Coding: 080500
   Shop #: WSC 02391 823 56573
   VCID: FCB4935E7FB17DAA01-80A8
   Part No SW: 8K0 907 064 F    HW: 8K0 907 064 F
   Component: BCM2 1.1      H80 0145
   Coding: 090100
   Shop #: WSC 02399 823 56573
   VCID: B3267862126F72D290-80E6
   Serial number: 0508000077145005
   Serial number: 0208000093481011
   Part No SW: 8T1 820 043 T    HW: 8T1 820 043 T
   Component: KLIMA 1 ZONE  H06 0150
   Revision: A0000000    Serial number: 01131120080598
   Coding: 64002000
   VCID: C2C82DA65DD5CB5A0B-8096
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 68
                    Mileage: 180654 km
                    Date: 2008.05.27
                    Time: 00:02:02
00256 - A/C Pressure/Temperature Sensor (G395)
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 68
                    Mileage: 180654 km
                    Date: 2008.05.27
                    Time: 00:02:04
                    Temperature: 21.0°C
                    Temperature: 19.0°C
                    Load: 0.0 %
                    Absolute Pres.: 1.0 bar
                    Current: 0.000 A
                    Temperature: 19.0°C
   Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
   Revision: 04022001    Serial number: 00000000268926
   Coding: 690000B1063C00010000080000007F5F0F14520800000021000000
   VCID: AF2E7412FE475632F4-80FA
   Component: WWS 211108  H06 0070
   Serial number: SWF08110216715
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 T    HW: 8K0 941 531 T
   Component: E1 - LDS  H07 0080
   Serial number: 00000000001111080968
   Subsystem 3 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
                    Fault Status: 00101100
                    Fault Frequency: 40
                    Reset counter: 104
                    Mileage: 177168 km
                    Date: 2019.01.31
                    Time: 13:15:00
   Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
   Serial number: 0039KD14KST+
   Shop #: WSC 02135 785 00200
   VCID: C0CC27AE5BD9D94A1D-8094
   Serial number: 5810000R0800002WSB
   Serial number: 6334MSME435226656
   Serial number: 6344MSME43522E52B
   Serial number: 6352QSME51120E066
   Serial number: 6362QSME74111030
   Serial number: 63732SME52132600I
   Serial number: 63832SME49050E28%
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90319HKI0008K
   Coding: 000034
   VCID: BD325E5A242BB4A276-80E8
   Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
   Component: KOMBIINSTR.   H17 0224
   Revision: 00000000    Serial number: 9DR28LNA8
   Coding: 8B1209000300D705020000
   VCID: AD126E1AF44B2422C6-80F8
   Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0095
   Revision: GB300043    Serial number: 4300G08B08830E
   Coding: 000303
   VCID: CBD600826A9F0A12F8-809E
   Component: J367-BDM  H04 0150
   Serial number: 18053E55051108
   Part No SW: 8T0 035 785     HW: 8T0 035 785
   Revision: 00000000
   Coding: 020302
   VCID: F8BC8F4E4B89518A65-80AC
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008061733
   Coding: 011C03204000410001
   VCID: C1CA22AA58D3D04212-8094
   Revision: 00002001    Serial number: 0116040902
   Coding: 0106023A007A400400B001
   Component: GTO BF  H06 0040
   Serial number: 00000000000000102367
   Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS034  H06 0037
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 125
                    Mileage: 156261 km
                    Date: 2018.03.03
                    Time: 14:21:47
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 125
                    Mileage: 156261 km
                    Date: 2018.03.03
                    Time: 14:21:48
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S2100000
   Coding: 0203010102
   VCID: EE90A91639CD1F3ABF-80BA
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008103707
   VCID: C0CC27AE53D9D94A1D-8094
                    Fault Frequency: 23
                    Reset counter: 108
                    Mileage: 177779 km
                    Date: 2019.02.17
                    Time: 11:16:32
   Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
   Component: EPB Audi B8   H06 0070
   Revision: 00000003    Serial number: 10000000131744
   VCID: B2287D66ED757BDA9B-80E6
   Part No SW: 8T1 035 186 K    HW: 8T1 035 186 K
   Component: Con3 Sirius   H01 0231
   Revision: 00000003    Serial number: AUZ5Z6H1147703
   Coding: 04020002010185004119070800
   VCID: BFCE24522E27A6B264-80EA
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
            000 -  -
                    Reset counter: 124
                    Mileage: 156259 km
                    Date: 2018.03.03
                    Time: 13:45:48
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000100499201
   Coding: 010C03204000210001
   VCID: C4C42BBE47C1C56A39-8090
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13140782162359
   Coding: 0CD154
   VCID: B02C776EE37949CAED-80E4
   Revision:             Serial number: 0000100499198
   Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
   Component: FSE_256x BT     H33 0550
   Revision: 00000000    Serial number: 00000005027082
   Coding: 0010370
   Shop #: WSC 02256 785 00200
   VCID: BB365042FA3FBA9248-80EE
End----(Elapsed Time: 01:48, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
                Address 01: Engine  (8K2 907 115 AL)
15:21:58
  IDE00025   Coolant temperature 94 °C
  IDE00151   Oil fill level 75.828 mm
  IDE00178   Camshaft adjustment intake bank 1: specified value 28.000 °
  IDE00179   Camshaft adjustment intake bank 1: actual value 27.953 °
  IDE00182   Camshaft adaptation intake bank 1: phase position -0.40 °
  IDE00347   Air mass: actual value: 2.97 g/s
  IDE00560-MAS04121   Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage 0.645 V
  IDE00560-MAS04122   Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation 99.2 %
  IDE00597   Long term adaptation of mixture formation bank 1 0.0 %
  IDE00604   Short term adaptation of mixture formation bank 1 0.0 %
  IDE03711   Mass flow through throttle valve 10.6 kg/h
No, you cannot change the oil level via the data port. ;)
I suppose you would like to change what it is displaying? And I guess this engine does not have a dip-stick?
I don't have much faith in that display immediately after changing the oil. Drive car for a few days, see what it says then, and top it off.
Oh, and better 3/4 full than over-filled!
Zenerdiode
Newcastle, England
C?ID=24330
Remember that the display is supposed to represent what you would see on the end of the dipstick. Typically it requires one litre to go from the bottom of that mark to the top. So in your case, about 300ml would see it at the top.
victor35ma
Los Angeles CA.
C?ID=242342
I suppose you would like to change what it is displaying? -Uwe-
yes and no. as you can notice in the log file it is full of oil 4.9L and also within 73 mm so it is a glitch...
i just And I guess this engine does not have a dip-stick?
you know it doesnt
Ok... well, this car runs like that. it doesnt go eather low or ok . with 4.9L what is it? what is causing it?
thanks again
victor35ma
Los Angeles CA.
C?ID=242342
look at the log file, it say IDE00151 Oil fill level 75.828 mm so it is ok. the display is wrong or not?
DrPeter
16.4905° S, 151.7375° W
I would not say the the display is wrong, it works for what it is, a consumer's way of checking the oil level and technically not to be used when servicing the vehicle, that is why the T40178B - Oil Level gauge. :)
Maybe you can find a dipstick for this engine that will work?
drpeter
People have successfully installed directly through the drain plug center being drilled and running a hose to engine to keep sealed a telescope site glass too.
