nylund333
New Member
- May 17, 2019
- 4
- 2
- Sweden
- C?ID=105065 (NRRT)
Change my abs do no communication. So i need the coding for it
Friday,17,May,2019,15:57:21:16946
VCDS Version: 18.9.1.0 (x64)
VIN: WVWZZZ3CZ9E023234 License Plate: HPU619
Mileage: 228010km-141678mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 10 15 16 17 18 19 22 25 36 42 44 46 52 53 55 56
62 69 72
VIN: WVWZZZ3CZ9E023234 Mileage: 228010km-141678miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 EM HW: 03L 907 309
Component: R4 2,0L EDC G001SG 6223
Revision: 13H01--- Serial number: VWZCZ000000000
Coding: 0000172
Shop #: WSC 40780 222 83241
VCID: 74E3A9A617F91DEAC9-8020
001650 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Mileage: 228012 km
Date: 2019.04.01
Time: 01:27:13
Voltage: 11.86 V
Temperature: 7.2°C
Bin. Bits: 00110000
Time: 2.52 s
Temperature: 7.2°C
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
Component: J104 C4 440 V2 0011
Revision: --025--- Serial number: 00000786141960
Coding: 0000048
Shop #: WSC 05311 000 00000
VCID: 2B5172DA8A47021258-807E
Reset counter: 45
Mileage: 228012 km
Date: 2019.04.09
Time: 01:56:50
Hex Value: 0x0000
Voltage: 11.50 V
Bin. Bits: 00011111
Count: 199
Hex Value: 0x0000
Reset counter: 45
Mileage: 228012 km
Date: 2019.04.09
Time: 23:37:13
Hex Value: 0x0000
Voltage: 10.00 V
Bin. Bits: 00011111
Count: 149
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 DA HW: 3C0 907 044 DA
Component: ClimatronicPQ46 132 0811
Revision: 00132023 Serial number: 00000000000000
VCID: 63C1DAFAA2178A52A0-8036
00538 - Reference Voltage
Reset counter: 85
Mileage: 228012 km
Date: 2019.04.01
Time: 02:02:51
Reset counter: 85
Mileage: 228012 km
Date: 2019.04.01
Time: 02:02:51
Fault Status: 00101001
Reset counter: 85
Mileage: 228012 km
Date: 2019.04.01
Time: 02:02:54
Fault Status: 00100111
Reset counter: 85
Mileage: 228012 km
Date: 2019.04.01
Time: 02:02:55
Revision: 00H54000 Serial number: 00000008635926
Coding: EA8A8F0700041A00470A00000F000000000A59435C000120000000000000
Shop #: WSC 05124 000 00000
VCID: 33616ABA52775AD210-8066
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 280508 003 0205
Coding: 00046997
Shop #: WSC 05124
Component: RLS 110708 054 0402
Coding: 00208936
Shop #: WSC 05124
00156 - Control Circuit for Windshield Washer Pump
Reset counter: 85
Mileage: 228012 km
Date: 2019.04.01
Time: 02:02:00
Voltage: 12.00 V
02398 - Control Circuit for Rear Windshield Washer Pump
Reset counter: 85
Mileage: 228012 km
Date: 2019.04.01
Time: 02:02:00
Voltage: 12.00 V
00834 - Signal for Activation of Heated Rear Window
Reset counter: 85
Mileage: 228012 km
Date: 2019.03.31
Time: 06:05:00
Voltage: 12.20 V
02403 - Terminal 15 for Interior
Fault Status: 00101100
Reset counter: 85
Mileage: 228012 km
Date: 2019.04.01
Time: 02:02:00
Voltage: 12.05 V
Reset counter: 85
Mileage: 228012 km
Date: 2019.04.01
Time: 02:02:00
Voltage: 12.05 V
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 3C8 919 475 HW: 3C8 919 475
Component: PARKHILFE 8K H07 0007
Revision: -------- Serial number: 97550819101278
Coding: 110003
Shop #: WSC 05314 000 00000
VCID: 71EDA0B2A8EB28C222-8024
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__005 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPD5AFGN
Coding: 0012341
VCID: 3B71429A7A279292C8-806E
Subsystem 1 - Serial number: 6333FTS654601558
Subsystem 2 - Serial number: 6343FTS616111548
Subsystem 3 - Serial number: 6353ETS6LP54UVNH
Subsystem 4 - Serial number: 6363ETS6IND2UVNP
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 AE HW: 3C0 953 549 AE
Component: J0527 0020
Revision: 00026000 Serial number: 3C9953507AT
Coding: 0000112
VCID: 6FE9A6CA7EDF3E3234-803A
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 E HW: 3C0 920 871 E
Component: KOMBIINSTRUMENT VD1 2416
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 80093 222 69422
VCID: 264783EE91A53F7A87-8072
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 1K0 815 071 T
Component: Zuheizer 050 2504
Revision: 00050000 Serial number: 09009839000000
Coding: 0000011
VCID: 366753AE41054FFA37-8062
01406 - No Flame
Fault Frequency: 45
Reset counter: 74
Mileage: 43436 km
Date: 2009.10.10
Time: 10:08:47
Start
Temperature: 38.0°C
Temperature: 36.0°C
Voltage: 14.45 V
01444 - Under-Voltage Shut-Off (Automatic)
Fault Frequency: 15
Reset counter: 69
Mileage: 47301 km
Date: 2009.11.13
Time: 16:22:05
02251 - Heater Unit Locked
Reset counter: 34
Mileage: 52726 km
Date: 2010.01.08
Time: 11:05:02
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 H HW: 3C0 907 951
Component: J533__Gateway H13 0142
Revision: H13 Serial number: 2600P0862100A8
Coding: F9A3FF46000A022002
Part No SW: 0BS 907 554 A HW: 0BS 907 554 A
Component: Haldex 4Motion 4013
Coding: 0000005
VCID: 4483396607D9ED6AB9-8010
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 397D5892701BA082DA-806C
Component: ELV 027 0380
3C0905861G ELV 027 0380
02828 - Enabling Steering Column Lock from Diagnostic Interface
Reset counter: 85
Mileage: 228012 km
Date: 2019.04.01
Time: 02:02:49
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1101
Revision: 00005000 Serial number: 00000000000000
VCID: 2F6966CABE5F7E3274-807A
Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1517
Revision: 71009005 Serial number: 00000770888709
Coding: 0004535
VCID: 71EDA0B268EB28C222-8024
Reset counter: 85
Mileage: 228012 km
Date: 2019.04.01
Time: 02:02:51
Part No SW: 5N1 909 144 G HW: 5N1 909 148 F
Component: J500__APA-BS KL.083 0401
Revision: 1AH02234 Serial number: 00081270267802
Coding: 0000258
00576 - Terminal 15
Reset counter: 85
Mileage: 228012 km
Date: 2019.04.01
Time: 02:02:51
Term 15 Off
(no units): 12.0
Voltage: 12.10 V
Component: KSG PQ46 ELV 042 0472
Coding: 0091020051030E76300494157008CFCE707C01
Component: Neigungssensor 004 0611
Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1517
Revision: 71009005 Serial number: 00000796988701
Coding: 0004534
VCID: 72EFAFBE6DED13DADB-8026
Reset counter: 85
Mileage: 228012 km
Date: 2019.04.01
Time: 02:02:51
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000068865
Coding: 0000057
VCID: 285B8DD69BB1290AB5-807C
03200 - Switch for Electric Parking Brake (E538)
Fault Status: 11111100
Reset counter: 45
Mileage: 228012 km
Date: 2019.03.31
Time: 05:50:08
Voltage: 11.70 V
Count: 10
Hex Value: 0x1161
Hex Value: 0x0008
Hex Value: 0x1010
00576 - Terminal 15
Reset counter: 85
Mileage: 228012 km
Date: 2019.04.01
Time: 02:02:48
Voltage: 11.60 V
Count: 54
Hex Value: 0x1170
Hex Value: 0x0001
Hex Value: 0x0101
Component: AFS-Steuergeraet 0133
Coding: 2343937
VCID: 346369A657795DEA09-8060
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000035
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 012 0029
Revision: 00000000 Serial number: VWZ1Z2H5346053
Coding: 0500040004
Shop #: WSC 05311 000 08193
VCID: 65C5C4E26C23F4624E-8030
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000000504244
Coding: 0000144
VCID: 70EBA5B663E121CA2D-8024
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H07 0050
Revision: 3A002002 Serial number: 00000112543031
Coding: 4100000100000000
VCID: 2F6966CA7E5F7E3274-807A
Reset counter: 85
Mileage: 228011 km
Date: 2019.03.24
Time: 00:36:06
01316 - ABS Control Module
Reset counter: 85
Mileage: 228011 km
Date: 2016.07.05
Time: 19:51:13
00576 - Terminal 15
Reset counter: 85
Mileage: 228012 km
Date: 2019.04.01
Time: 02:02:50
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000000509622
Coding: 0000144
End-------------------------(Elapsed Time: 02:56)--------------------------
