Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 36 3C 42 44 46 47 52
53 56 5C 5F 62 69 6C 6D 72 A9 C0
VIN: WAUZZZ8R7EA054561 Mileage: 87020km-54071miles
C0-Act. for Ext. Noise -- Status: Malfunction 0010
Address 01: Engine (J623-CGQB) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 907 589 HW: 4G0 907 589
Component: 3.0BTD EDC17 H25 0003
Revision: 57H25---
Coding: 2A2A4032257603020000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30BTD0118K5907589 001006
ROD: EV_ECM30BTD011_AU48.rod
VCID: 7EA5FA71B07A408B20F-802B
4330 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 87027 km
Date: 2020.12.06
Time: 17:25:05
Coolant temperature: 50 ∞C
Intake air temperature: 31 ∞C
Voltage terminal 30: 12.100 V
ACC target acceleration: 0.007 m/s≤
ACC control module received status-Bits 0-7: 7
Active brake system error status-Bits 0-7: 1
Status of ACC/CCS acceleration interface-Bits 0-7: 4
Acceleration: 0.000 m/s≤
Engine status: COENG_READY
Part No SW: 8R0 927 158 AE HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H16 1005
Revision: --H16---
VCID: 00598489CA8E367B523-8055
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AF HW: 8R0 907 379 AF
Component: ESP8 quattro H09 0030
Coding: 24ED0C01
Shop #: WSC 06335 000 00000
VCID: 04518899DE162A5B76B-8051
Part No SW: 8K0 907 064 HR HW: 8K0 907 064 GR
Component: BCM2 2.0 H13 0641
Coding: 05B54000000000000000
VCID: 074B9F95EF200143139-8053
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K2 820 043 T HW: 8K2 820 043 T
Revision: D1000000 Serial number: 01181020131270
Coding: 3625628080
VCID: 3A2D3661EC52ACAB5C7-806F
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000051250401
Coding: 260000318074AFF2118140C300001D0D0F9DE70827090201000008004401010200020034000000
Shop #: WSC 12345 123 61029
VCID: 7AADF661ACD26CAB1C7-802F
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 131007 H11 0050
Serial number: 90243015130829085044
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 21851352
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000001410130258
Subsystem 4 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 5 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Serial number: A71802D6000000000001
Address 13: Auto Dist. Reg (J428) Labels: Redir Fail!
Part No SW: 8R0 907 561 A HW: 8R0 907 561 A
Component: ACC3 H11 0100
Coding: 008189
VCID: 372B2F55DF40B1C3A39-8063
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Serial number: 003JPDB0VM61
Coding: 304A3431313030303030554A305238523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 48C95CA9A23ECE3BDA3-801D
Serial number: 6334MSME7F141273D
Serial number: 6344MSME7F54612AO
Serial number: 6352QSME0B383A68Q
Serial number: 6362QSME47380740B
Serial number: 63732SME48423560V
Serial number: 63832SME3A420F685
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H05 0005
Revision: -------- Serial number: 90372RAJ000FI
Coding: 0000FF
Shop #: WSC 12345 123 12345
VCID: 44D148999E96EA5B36B-8011
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 931 G HW: 8R0 920 931 G
Component: KOMBIINSTR. H35 0564
Revision: 00000000 Serial number: ZDM39KNAE
Coding: B3EF22006F010008010000
VCID: 392F296DE954A7B355D-806D
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0056
Revision: 1Z110028 Serial number: 2841Z139290316
Coding: 80CD07FF00
VCID: 4CC160B9B6C6221BFEB-8019
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Serial number: 30283621231461241028
Serial number: 13289003273011200410
Part No SW: 8K0 907 144 L HW: 8K0 907 144 L
Component: DYNAMIKLENK. H06 0720
Revision: 52001005 Serial number: --------------
Coding: 040100
VCID: 38292C69D25EBEBBAA3-806D
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02022064747464545425363E00
VCID: 7CA1F079A6E6529B0EB-8029
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0076
Revision: AA000000 Serial number: 00000078516505
Coding: 01781B00000000000000
VCID: 42DD4E818482E46B047-8017
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0317972623
Coding: 010322
Shop #: WSC 06334 000 00000
VCID: 3FDB4775F7F089836B9-806B
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0317656987
Coding: 010322
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000077773363
Coding: 011D12205E01440004
VCID: 4FFB77B547D019039B9-801B
Part No SW: 8R0 909 144 Q HW: 8R0 909 144 L
Component: RCevo H54 0702
Revision: 00000002 Serial number: 0000061061
Coding: 010001010001
Shop #: WSC 29511 004 1048576
ASAM Dataset: EV_RCEPSAU48X 104002
ROD: EV_RCEPSAU48X_104.rod
VCID: 46D55291A82AD84B28F-8013
Revision: 00002001 Serial number: 0314765179
Coding: 01000E2A20B930958420053680040047
Subsystem 1 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 2 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813021423703
VCID: 2D070D3D2D1C0B13C95-8079
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000078886375
VCID: 4EC56AB140DA100B90F-801B
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 00000001384306
ROD: EV_ParkiBrake_AU48.rod
VCID: 392F296DE9D4A7B355D-806D
Part No SW: 4G0 035 061 L HW: 4G0 035 061
Component: Radio U DAB H60 0133
Revision: AB001007 Serial number: 109J-0D7712271
Coding: 040103010000000001
VCID: 2615F21108EA384B08F-8073
Address 5C: Lane Maintain. Labels: None
Part No SW: 8T0 907 217 A HW: 4E0 907 217 C
Component: J759 HC 0040
Revision: 00H08006 Serial number: 600213A22000E3
Coding: 0032004
VCID: 372B2F55D340B1C3A39-8063
Part No SW: 8R2 035 754 F HW: 8R2 035 754 C
Component: H-BN-RW H46 0739
Revision: -------- Serial number: 210JO0D7521034
Coding: 1A0A01060205E9EF7D80CB4E00000403FC0000020000000000
Subsystem 1 - Part No: 8R0 060 884 AS
Component: ROW 2013 0506
Component: DU7 High H42 0104
Serial number: A130J 0D2850866
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001647862
Component: CD-Database 5298
Reset counter: 30
Mileage: 87027 km
Date: 2020.12.06
Time: 17:22:50
Bin. Bits: 00000001 00000000
Bin. Bits: 00000000 00000000
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000079068460
Coding: 010C12204001240004
VCID: 46D55291A8AAD84B28F-8013
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 B HW: 8K0 907 383 B
Component: Anhaenger H08 0080
Revision: 1A002002 Serial number: 00000116068013
Coding: 0300000000000000
Shop #: WSC 21540 822 92067
VCID: 33331B45CB385DE39F1-8067
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H08--- Serial number: 525PA8-J37A8I4
Coding: 1031010
VCID: 34311859C2365ADB86B-8061
Address 6D: Trunk Elect. (J605) Labels: 4L0-910-945.clb
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
VCID: 3B233365E36895A3471-806F
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Serial number: 8R0827852B
Component: TSG HR H01 0510
Revision: Serial number: 0000079068501
Part No SW: 8R0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0007
Serial number: 131005200520
VCID: 79AFE96DA95467B315D-802D
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 8R0 907 160 HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0002
Serial number: 130919200620
VCID: 71BFD14DF1242FF3ADD-8025
0006 - Actuator 1 for Engine Noise Simulation
C113C 13 [008] - Open Circuit
Mileage: 87027 km
Date: 2020.12.06
Time: 17:09:44
End----------(Elapsed Time: 02:05, VBatt start/end: 12.1V/12.1V)-----------
Sunday,06,December,2020,17:40:43:54103
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
VIN: WAUZZZ8R7EA054561 License Plate:
Mileage: 87020km-54071mi Repair Order:
Revision: 57H25---
U1113 00 [039] - -
Mileage: 87027 km
Date: 2020.12.06
Time: 17:33:30
Engine speed: 739.00 /min
Normed load value: 25.5 %
Intake air temperature: 30 ∞C
Voltage terminal 30: 13.760 V
Engine status: COENG_RUNNING
Revision: --H16---
Coding: 24ED0C01
Coding: 3625628080
Coding: 01DD13
Coding: 02005C
H05 0012
H05 0012
Coding: 008189
Coding: 0000FF
Coding: 80CD07FF00
Coding: 040100
Revision: AA001002
Coding: 010322
Coding: 010322
Coding: 0032004
Reset counter: 30
Mileage: 87027 km
Date: 2020.12.06
Time: 17:38:01
Coding: 1031010
Mileage: 87027 km
Date: 2020.12.06
Time: 17:09:44
End----------(Elapsed Time: 02:03, VBatt start/end: 14.2V/14.3V)-----------
