After updating the VCDS (release 18.9), I am not able to read codes anymore. An error windows appears (VCDS Release 19.9: Port test) with the message: Port Status: OK, Interface: NOt found! Press [OK] to open the config utility for a firmware update, Press [cancel] to abort. The system is updated though.
I was able to connect to the car and read error codes before the update, by selecting "Select Control Module" and "01-Engine". The VCDS was factory new, without any update.
Does somebody know where the problems is?
Thnx!
Thnx!
