Hi
I am using VCDS 17.1.3.0,and I noticed several modules are not in the result of autoscan.
Result of AutoScan:
and this is the ADP Map of CAN Gateway(19):
In this case, VCDS should detect the below modules, but it didn't.
- Missing 'Central Module Comfort System' in the result of AutoScan.
- the belows are not in coded list of Module#19
BB-Door Rear Drv
BC-Door Rear Pass
- Different total number of modules.
Please check and hope this information helps your update work on VCDS.
Thank you!
Yuhji
Result of AutoScan:
Chassis Type F4 (8W2)
Scan: 01 02 03 08 09 13 15 16 17 19 42 44 52 57 5F 6C 6D 81 8B A5
BB BC
VIN: WAUZZZF43HA******
;SW:8W2-907-468-D HW:8W2-907-468-D --- CAN Gateway
;Component:Gateway H30 0308, Coding:030100010000864029070000005900125C900007100000000175078E10000000
;EV_CGateCONTIAU491,002040,EV_CGateCONTIAU491.rod
;Saturday,04,February,2017,14:05:38:34370
;VCDS Version: Release 17.1.2 (x64) Data version: 20170131 DS267.1
;VCID: 4796A5E1FE2BB67962-8012
IDE00001-IDE00332-Production mode-Buttons for multi-function steering wheel,Deactivating
IDE00001-IDE10279-Production mode-Onboard data collector,Deactivating
IDE00001-MAS01490-Production mode-Energy management,Deactivating
IDE00001-MAS11109-Production mode-Drahtlosnetzwerkverbindung,Deactivating
IDE00002-Transport mode,not activated
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active
IDE00820-MAS03504-Activating and deactivating all development messages-XCP,not active
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active
IDE01211-Static current measuring mode,not activated
IDE01996-MAS00796-Installation list: specified installations-Engine Control Module (ECM),coded
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,coded
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,coded
IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded
IDE01996-SFT00017-Installation list: specified installations-Engine Control Module 2,Not coded
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,coded
IDE01996-SFT00021-Installation list: specified installations-Airbag,coded
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded
IDE01996-SFT00025-Installation list: specified installations-Gateway,coded
IDE01996-SFT00027-Installation list: specified installations-Active Steering,Not coded
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded
IDE01996-SFT00033-Installation list: specified installations-Battery Energy Control Module 2,Not coded
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,Not coded
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded
IDE01996-SFT00040-Installation list: specified installations-Climate Control Unit Rear,Not coded
IDE01996-SFT00042-Installation list: specified installations-Control Unit Wireless Charging,Not coded
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,Not coded
IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,Not coded
IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded
IDE01996-SFT00070-Installation list: specified installations-Central Module Comfort System,coded
IDE01996-SFT00072-Installation list: specified installations-Seat Adjustment Rear Driver Side,Not coded
IDE01996-SFT00074-Installation list: specified installations-Rear light,Not coded
IDE01996-SFT00080-Installation list: specified installations-Seat Adjustment 3rd Row,Not coded
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded
IDE01996-SFT00090-Installation list: specified installations-Longitudinal control,Not coded
IDE01996-SFT00091-Installation list: specified installations-Seat Adjustment Rear Passenger Side,Not coded
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded
IDE01996-SFT00107-Installation list: specified installations-Aerodynamics Control Unit,Not coded
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,coded
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,coded
IDE01996-SFT00113-Installation list: specified installations-Battery Charger,Not coded
IDE01996-SFT00116-Installation list: specified installations-Chassis Control,coded
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,Not coded
IDE01996-SFT00127-Installation list: specified installations-Information Control Unit 2,Not coded
IDE01996-SFT00129-Installation list: specified installations-Gear Shift Control Module,coded
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded
IDE01996-SFT00132-Installation list: specified installations-Night Vision,Not coded
IDE01996-SFT00139-Installation list: specified installations-Adaptive Cruise Control 2,coded
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,coded
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded
IDE01996-SFT00172-Installation list: specified installations-Reductant Control Module,Not coded
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,Not coded
IDE01996-SFT00186-Installation list: specified installations-Assembly Mounting,Not coded
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded
IDE01996-SFT00196-Installation list: specified installations-DC/DC Converter Control Module,Not coded
IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded
IDE01996-SFT00203-Installation list: specified installations-Rear Axle Steering,Not coded
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded
IDE01996-SFT00219-Installation list: specified installations-Front Corner Radar 1,Not coded
IDE01996-SFT00220-Installation list: specified installations-Front Corner Radar 2,Not coded
IDE01996-SFT00221-Installation list: specified installations-Control Module 2 For Sunroof,Not coded
IDE01996-SFT09760-Installation list: specified installations-Sun Roof,Not coded
IDE02332-Deactivate production mode,0
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,75 Ah
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,361020K0W7
IDE03903-Production process data 1,00 00 00 A2 AA AA
IDE04159-Deactivation of start-stop function,regular operation
IDE06425-Roller test bench mode: functional,not activated
IDE06748-Pause recommendation,activated
IDE07139-Normal bus behavior during diagnosis,active
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,10.20 l/100km
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,40.10 km/h
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,100 W
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,10 W
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,990 W
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,24 A
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,23.10 kWh/100 km
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,23.10 kWh/100 km
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,23.10 kWh/100 km
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,23.10 kWh/100 km
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,23.10 kWh/100 km
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,23.10 kWh/100 km
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),24.10 kWh/100 km
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,10.30 l/100km
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,23.30 kWh/100 km
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,23.10 kWh/100 km
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,6.10 kg/100 km
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,10.20 l/100km
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,10.20 l/100km
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,10.20 l/100km
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,10.20 l/100km
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,10.20 l/100km
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,10.20 l/100km
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,10.20 l/100km
IDE10351-MAS10445-Message mirroring-Data bus CAN 1,not active
IDE10351-MAS10446-Message mirroring-Data bus CAN 2,not active
IDE10351-MAS10447-Message mirroring-Data bus CAN 3,not active
IDE10351-MAS10448-Message mirroring-Data bus CAN 4,not active
IDE10351-MAS10449-Message mirroring-Data bus CAN 5,not active
IDE10351-MAS10450-Message mirroring-Data bus CAN 6,not active
IDE10351-MAS10451-Message mirroring-Data bus Flexray A,not active
IDE10351-MAS10452-Message mirroring-Data bus LIN 1,not active
IDE10351-MAS10453-Message mirroring-Data bus LIN 2,not active
IDE10351-MAS10454-Message mirroring-Data bus LIN 3,not active
IDE10351-MAS10460-Message mirroring-Target bus,not active
IDE11688-IDE08958-Anforderung Autonomer Betrieb-High-voltage system: start request,regular operation
IDE11688-MAS08040-Anforderung Autonomer Betrieb-Automatic recharging of starter battery,regular operation
IDE11688-MAS13088-Anforderung Autonomer Betrieb-Vorkonditionierung des Innenraums,regular operation
ENG06184-Adaption_high_voltage_zero_potential,regular operation
ENG06185-ENG06245-BCmE general functionality-BCmE Consumers,not active
ENG06185-ENG06247-BCmE general functionality-BCmE LED_filter,not active
ENG06185-ENG06246-BCmE general functionality-BCmE LiveTips,not active
ENG06185-ENG06248-BCmE general functionality-BCmE_auxiliary_heater,not active
ENG06185-ENG06249-BCmE general functionality-BCmE_current_range_calculation,not active
ENG06187-ENG06266-BCmE_consumer_activation_[l/h]-BCmE_consumption_auxilary_heating,not active
ENG06187-ENG06273-BCmE_consumer_activation_[l/h]-BCmE_consumption_auxilary_heating_on_CAN,not active
ENG06187-ENG06265-BCmE_consumer_activation_[l/h]-BCmE_consumption_climate_control_unit,not active
ENG06187-ENG06272-BCmE_consumer_activation_[l/h]-BCmE_consumption_fog_light_rear,not active
ENG06187-ENG06274-BCmE_consumer_activation_[l/h]-BCmE_consumption_front_window_heating,not active
ENG06187-ENG06276-BCmE_consumer_activation_[l/h]-BCmE_consumption_mirro_ heating,not active
ENG06187-ENG06270-BCmE_consumer_activation_[l/h]-BCmE_consumption_neck_heating,not active
ENG06187-ENG06267-BCmE_consumer_activation_[l/h]-BCmE_consumption_rear_heating,not active
ENG06187-ENG06268-BCmE_consumer_activation_[l/h]-BCmE_consumption_seat_heating_ front,not active
ENG06187-ENG06277-BCmE_consumer_activation_[l/h]-BCmE_consumption_seat_heating_rear,not active
ENG06187-ENG06269-BCmE_consumer_activation_[l/h]-BCmE_consumption_seat_ventilation_front,not active
ENG06187-ENG06278-BCmE_consumer_activation_[l/h]-BCmE_consumption_seat_ventilation_rear,not active
ENG06187-ENG06275-BCmE_consumer_activation_[l/h]-BCmE_consumption_steering_wheel_heating,not active
ENG06187-ENG06271-BCmE_consumer_activation_[l/h]-BCmE_consumptionfog_light_front,not active
ENG06188-ENG06280-BCmE_consumer_activation_[range_gain_km]-BCmE_range_gain_auxilary_heating,not active
ENG06188-ENG06287-BCmE_consumer_activation_[range_gain_km]-BCmE_range_gain_auxilary_heating_on_CAN,not active
ENG06188-ENG06279-BCmE_consumer_activation_[range_gain_km]-BCmE_range_gain_climate_control_unit,not active
ENG06188-ENG06285-BCmE_consumer_activation_[range_gain_km]-BCmE_range_gain_fog_light_front,not active
ENG06188-ENG06286-BCmE_consumer_activation_[range_gain_km]-BCmE_range_gain_fog_light_rear,not active
ENG06188-ENG06288-BCmE_consumer_activation_[range_gain_km]-BCmE_range_gain_front_window_heating,not active
ENG06188-ENG06290-BCmE_consumer_activation_[range_gain_km]-BCmE_range_gain_mirror_heating,not active
ENG06188-ENG06284-BCmE_consumer_activation_[range_gain_km]-BCmE_range_gain_neck_heating,not active
ENG06188-ENG06281-BCmE_consumer_activation_[range_gain_km]-BCmE_range_gain_rear_heating,not active
ENG06188-ENG06282-BCmE_consumer_activation_[range_gain_km]-BCmE_range_gain_seat_heating_front,not active
ENG06188-ENG06291-BCmE_consumer_activation_[range_gain_km]-BCmE_range_gain_seat_heating_rear,not active
ENG06188-ENG06283-BCmE_consumer_activation_[range_gain_km]-BCmE_range_gain_seat_ventilation_front,not active
ENG06188-ENG06292-BCmE_consumer_activation_[range_gain_km]-BCmE_range_gain_seat_ventilation_rear,not active
ENG06188-ENG06289-BCmE_consumer_activation_[range_gain_km]-BCmE_range_gain_steering_wheel_heating,not active
ENG06189-ENG06189-BCmE_display_structure-,not active
ENG06189-ENG06293-BCmE_display_structure-front_window_heating_consumption_as_a_part_of_climate_control_unit,not active
ENG06189-ENG06296-BCmE_display_structure-LiveTips_only_in_efficiency_mode,not active
ENG06189-ENG06294-BCmE_display_structure-PTC_(low_voltage)_consumption,not active
ENG06189-ENG06295-BCmE_display_structure-PTC_(low_voltage)_range_gain,not active
ENG06186-ENG06841-BCmE_LiveTip_activiation-BCmE_ac_close_roof,not active
ENG06186-ENG06256-BCmE_LiveTip_activiation-BCmE_ac_close_window,not active
ENG06186-ENG06255-BCmE_LiveTip_activiation-BCmE_ac_close_window_and_roof,not active
ENG06186-ENG06250-BCmE_LiveTip_activiation-BCmE_activate_instrument_cluster,not active
ENG06186-ENG06262-BCmE_LiveTip_activiation-BCmE_aerodynami_Close_wi_dow_and roof,not active
ENG06186-ENG06264-BCmE_LiveTip_activiation-BCmE_aerodynamic_Close_window,not active
ENG06186-ENG06263-BCmE_LiveTip_activiation-BCmE_aerodynamic-Close-roof,not active
ENG06186-ENG06258-BCmE_LiveTip_activiation-BCmE_car_ready_for_start_stop_do_not_declutch,not active
ENG06186-ENG06254-BCmE_LiveTip_activiation-BCmE_driving_level_d,not active
ENG06186-ENG06261-BCmE_LiveTip_activiation-BCmE_engine_brake_do_not_declutch,not active
ENG06186-ENG06260-BCmE_LiveTip_activiation-BCmE_engine_start_no_throttle,not active
ENG06186-ENG06259-BCmE_LiveTip_activiation-BCmE_shift_gearin_observe_shift_advice,not active
ENG06186-ENG06257-BCmE_LiveTip_activiation-BCmE_start_stop_deactivated_via_push_button,not active
ENG06186-ENG06251-BCmE_LiveTip_activiation-BCmE_warmup_while_standing,not active
ENG06186-ENG06252-BCmE_LiveTip_activiation-convertibe_ac_off,not active
ENG06186-ENG06253-BCmE_LiveTip_activiation-stop_inhibited_throttle_while-standing,not active
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,120
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,6000 ms
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms
ENG118777-ENG05100-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Number_of_Keys,1
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,500 ms
ENG118777-ENG05096-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_1,500 ms
ENG118777-ENG05097-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_2,1500 ms
ENG118777-ENG05098-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_3,500 ms
ENG118777-ENG05099-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_4,500 ms
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,6000 ms
ENG118775-energy_management_deactiv_stage,regular operation
ENG06183-HVK_Warning,regular operation
ENG118451-ENG118685-Switch_on_ban_independent_car_heater-Set_point_target_time,80 min
ENG118451-ENG118684-Switch_on_ban_independent_car_heater-Switch_on_ban_activation,regular operation
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated
ENG118774-ENG05123-WakeUpMonitor_Activation-Activation_Bus_Activity,activated
ENG118774-ENG05062-WakeUpMonitor_Activation-Activation_Cluster_Sleep,activated
ENG118774-ENG05063-WakeUpMonitor_Activation-Activation_Cluster_Start,activated
ENG118774-ENG05125-WakeUpMonitor_Activation-Activation_CWUP,activated
ENG118774-ENG05058-WakeUpMonitor_Activation-Activation_Keeping_Awake,activated
ENG118774-ENG05124-WakeUpMonitor_Activation-Activation_Knock_Out,activated
ENG118774-ENG05059-WakeUpMonitor_Activation-Activation_Logical_Wakeup,activated
ENG118774-ENG05126-WakeUpMonitor_Activation-Activation_NFU,activated
ENG118774-ENG05060-WakeUpMonitor_Activation-Activation_Physical_Wakeup,activated
ENG118774-ENG05127-WakeUpMonitor_Activation-Activation_SBU,activated
ENG118773-ENG05118-WakeUpMonitor_Configuration-Max_Num_Cluster_Sleep,20 counts
ENG118773-ENG05119-WakeUpMonitor_Configuration-Max_Num_Cluster_Start,20 counts
ENG118773-ENG05120-WakeUpMonitor_Configuration-Max_Num_CWUP,30 counts
ENG118773-ENG05117-WakeUpMonitor_Configuration-Max_Num_Knock_Out,3 counts
ENG118773-ENG05115-WakeUpMonitor_Configuration-Max_Num_Logical_Wakeup,40 counts
ENG118773-ENG05121-WakeUpMonitor_Configuration-Max_Num_NF,20 min
ENG118773-ENG05116-WakeUpMonitor_Configuration-Max_Num_Physical_Wakeup,10 counts
ENG118773-ENG05122-WakeUpMonitor_Configuration-Max_Num_Sb,20 min
ENG118773-ENG05114-WakeUpMonitor_Configuration-Max_Time_Keeping_Awake,20 min
ENG118773-ENG109064-WakeUpMonitor_Configuration-Start_Delay,0 s (second)
ENG118773-ENG05113-WakeUpMonitor_Configuration-Wake_Delay,20 min
Elapsed Time: 00:23
BB-Door Rear Drv
BC-Door Rear Pass
Thank you!
Yuhji
