I have a set of those and it checked OK but I would have liked the accuracy of a proper digital deep reach (for the centre bore) vernier 3 point bore micrometer would give but they are daft money and with it being a new genuine carrier I assume (never assume, always check) that it is to spec. My gut feeling is it is something to do with the chain cover but a new one is £500 so it is an expensive gut feeling.
Hi Crasher,
I've read your discussion with
@naushad2982 with high interest since I am also struggling with the same symptoms on a 1.4L TSI CAVD in a VW Scirocco MKIII for almost half a year now.
Did you finally find the root cause and were you able to fix the issue?
If yes, I would be very grateful if you could share your experience with me!
Here is my story with this engine so far:
After the timing chain jumped I had the head repaired, new pistons, chain set incl. adjuster, hydros, all valves.
Turbo was also done.
After that the engine ran, but was too loud in my opinion. Oil pressure measured warm 0.3 bar at idle. 1.2 bar at 3000.
Lamp never on. Then oil pump changed - no change.
Checked oil pressure at turbo in parallel - idle warm 1 bar. 3000 - 3 bar.
According to a few UK forums, changing camshaft housing and camshafts should fix the problem. Done - as before.
Replaced Oil cooler then - no change and now given up.
Driven 150km already then oil pressure lamp popped up. Hydros loud and power too low. One notices that the adjuster does not work ... Really do not know what to do.
If there is any advice from anyone on how to proceed now, I would appreciate it very much!
Thanks in advance
