Results 1 to 6 of 6
Thread: 05 Audi A6 aftermarket led tail lights retrofit
    Sep 2016
    Ok i drove out 2 hour to help a fellow Audi owner with a 2005 Audi A6 .i recoded in group 46 original
    Code was 0423997 . i subtracted 131072 AND 4096 from the existing code giving me 0288829. The code was excepted and brake lights and turn signals worked correctly . On my way home the guy called me and said now when he unlocks his doors with the remote or pulls the key from the ignition and the doors unlocke the fuel door pops open . I followed the coding instructions from
    http://forums.ross-tech.com/showthre...Light-retrofit
    Sorry I don't have the scan read out and won't be able to get it because the car is a 2 hour drive . Any help would be greatly appreciated.
    So you made coding changes to someone else's car without doing an Auto-Scan?
    At the very least you should have a CodingLog file.
    Sep 2016
    I did auto scan . I just didn't record the info . I did write down the original coding to switch it back .
    Sep 2016
    I am trying to pull all logs but they only show in Microsoft excel
    Quote Originally Posted by Keithwidney View Post
    If you did an Auto-Scan, it got auto-saved to the Scans sub-folder. Please have a look there.
  6. #6
    Sep 2016
    Searched and can not find the log . I do have the original coding to switch back but then the led tail lights will not work.
