Results 1 to 9 of 9
Thread: Vw Caddy -08 new engine
    Feb 2017
    Oulu, Finland
    Hi!
    Volkswagen Caddy MY08 it has been necessary to change the new engine. From the previous engine connecting rod had come out of the engine block.
    The new engine is installed, but the car is not running normally. The car starts, but does not go longer than 2 seconds. In addition, the instrument cluster screen does not show anything.
    Sunday,02,April,2017,19:05:34:57660
    VCDS Version: 17.1.3.0 (x64)
    Dealer/Shop Name: J.P
    VIN: WV2ZZZ2KZ8X147343   License Plate:
    Mileage: 212860km-132265mi   Repair Order:
    Chassis Type: 2K (1K0)
    Scan: 01 02 03 08 09 15 16 17 18 19 25 42 46 52 56 69
    VIN: WV2ZZZ2KZ8X147343   Mileage: 212860km-132265miles
    Address 01: Engine        Labels: 03G-906-021-BLS.clb
       Part No SW: 03G 906 021 PF    HW: 03G 906 021 AB
       Component: R4 1,9L EDC G000AG  2388
       Revision: --H08---    Serial number: VWX7Z0H33NE1IJ
       Coding: 0000078
       Shop #: WSC 73000 205 66168
       VCID: 72D399B56D4E1DD1EF-8026
    8 Faults Found:
    000275 - Intake Air Temp. Sensor (G42)
                   P0113 - 000 - Signal too High - Intermittent
                        Voltage: 11.55 V
                        Temperature: 133.2C
                        Temperature: 14.4C
                        Temperature: 15.3C
    000568 - Manifold Pressure / Boost Sensor (G31)
                   P0238 - 000 - Signal too High - Intermittent
    005746 - Coolant Fan Control 1
                   P1672 - 000 - Open or Short to Ground - Intermittent
                        Voltage: 11.55 V
                        Bin. Bits: 00101011
                        Temperature: 14.4C
                        Duty Cycle: 9.7 %
    005716 - Please check DTC Memory of Instrument Cluster
                   P1654 - 000 -  - Intermittent
    005697 - Please check DTC Memory of A/C Controller
                   P1641 - 000 -
                        Mileage: 212865 km
                        Time: 00:00:15
                        Voltage: 11.93 V
                        Bin. Bits: 00101011
                        Temperature: 14.4C
                        (no units): 16.0
    005488 - Engine Start Blocked by Immobilizer
                   P1570 - 000 -  - MIL ON
                        Mileage: 212865 km
                        Time: 00:00:15
    000258 - Mass Air Flow Sensor (G70)
                   P0102 - 000 - Signal too Low - Intermittent
                        Fault Status: 00110000
                        Mileage: 212865 km
                        Time: 00:00:12
                        RPM: 882 /min
                        Duty Cycle: 100.6 %
                        Bin. Bits: 00101000
                        Mass Air / Rev.: 450.0 mg/str
                        Mass Air / Rev.: 0.0 mg/str
    001384 - Cruise Control Switch (E45)
                   P0568 - 000 - Implausible Signal - Intermittent
                        Mileage: 212865 km
                        Time: 00:00:12
    Readiness: 0 2 0 0 0
       Part No SW: 02E 300 050 K    HW: 02E 927 770 AD
       Component: GSG DSG         082 1401
       Revision: 04808020    Serial number: 00000910110544
       Shop #: WSC 04940 001 00001
       VCID: 1A039115D57E859107-804E
       Part No SW: 2K3 907 379     HW: 2K3 907 379
       Revision: 00H13001
       Coding: 0021202
       Shop #: WSC 35110 377 00162
       VCID: 73DD9CB1125414D9E4-8026
       Part No SW: 1K0 907 044 DA    HW: 1K0 907 044 DA
       Component: ClimatronicPQ35 130 1213
       Revision: 00130023    Serial number: 00000000000000
       VCID: 69E1FED94098DE095E-803C
    00538 - Reference Voltage
                002 - Lower Limit Exceeded
                009 - Open or Short to Ground
                007 - Short to Ground
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
       Revision: 00H54000    Serial number: 01000008309592
       Coding: 0988CF030004100057000000000000000008FF075C000100000000000000
       Shop #: WSC 35110 377 08192
       VCID: 71D196B9684826C916-8024
       Subsystem 1 - Part No: 2K1 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 100408 021  0501
       Coding: 00038805
       Shop #: WSC 35110
    Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
       Part No SW: 6Q0 909 605 AJ    HW: 6Q0 909 605 AJ
       Component: 1C AIRBAG VW52  025 2400
       Revision: 06025000    Serial number: 0037UR003TS+
       Coding: 0012611
       VCID: 7F3540812E1C40B990-802A
       Part No SW: 1K0 953 549 BK    HW: 1K0 953 549 BK
       Component: J0527           051 0100
       Coding: 0011022
       VCID: 7CCFB78D3F0A5BA1B5-8028
       Part No SW: 1T0 920 854 C    HW: 1T0 920 854 C
       Component: KOMBIINSTRUMENT VDD 1222
       Revision: V0002000    Serial number: VWX7Z0H33NE1IJ
       Coding: 0016101
       Shop #: WSC 00999 444 64523
       VCID: 345F5FAD57DA53E13D-8060
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 5K0 963 271 C
       Component: Standheizer     050 2606
       Revision: 00050000    Serial number: 09021535000000
       Coding: 0001012
       VCID: 2F5550C1BEFC703940-807A
    02245 - Connection; RF Remote Control
                        Fault Frequency: 84
                        Reset counter: 5
                        Mileage: 211886 km
    00664 - Fuel gauge
                        Reset counter: 31
                        Mileage: 212242 km
    01410 - Heater Over-Temp
                        Reset counter: 31
                        Mileage: 212242 km
    02251 - Heater Unit Locked
                        Reset counter: 5
    Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 090408F1010829
       Coding: AD801F46000A027400
       Shop #: WSC 73008 205 97539
       VCID: 305753BDA3C26FC159-8064
       Component: IMMO            VDD 1222
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
       Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
       Component: Tuer-SG         006 1205
       Coding: 0000048
       VCID: 38476B9D4BB2B78111-806C
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 CP
       Coding: 808B04087F2D8405484A036010C0
       VCID: 0037C37D53E23F41E9-8054
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
       Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
       Coding: 0000048
       VCID: 39416E9970B8AE89EE-806C
       Part No: 1K0 035 186 AD
       Component: Radio GR0       034 0033
       Revision: 0003404S    Serial number: VWZ2Z2H7303777
       Coding: 0020401
       VCID: 68E7FBDD5B92E70141-803C
    Address 69: Trailer
    End-------------------------(Elapsed Time: 01:09)--------------------------
    Information exchange engine:
    - The new engine is the same as the previous broken gone (BLS, 77 kilowatts)
    - The new engine is two years later, vw caddy.
    - ECU, ignition key (1pcs) and the immobilizer box of the original car.
    Is it possible to get to work on the new engine an old engine ECU?
    If it's possible, how I get to work on the new enginge an old engine ECU?
    Does this require key adjustment?
    ECU does not seem to be happy with immobilizer.
    I would start by looking in 25-Immobilzer MVBs for clues.
    Nov 2014
    New Zealand
    The BLS engine likes to go bang...
    Quote Originally Posted by V3lmu View Post
    Do you mean nothing AT ALL, or nothing about the immobilizer???
    If the Engine ECU, Key and Instrument Cluster are all original, it shouldn't have an immobilizer fault after changing the engine only... maybe some other faults, if they aren't compatible.
    Check all the fuses too - just in case
  4. Likes Uwe, Jack@European_Parts liked this post
    Feb 2017
    Oulu, Finland
    I have checked the 17-Instuments and 25-immobilizer. Neither one found fault codes.
    Feb 2017
    Oulu, Finland
    Quote Originally Posted by NZDubNurd View Post
    We tried that if we take the plus side from the car battery off for 30 sec and we reconnected it back to battery. To the Instruments info display there comes info for 10 sec (clock, and driven kilometers) and then the info display shuts down.
    Nov 2014
    New Zealand
    I'm no expert here, but having fiddled wit a LOT of Touran wiring etc - it sounds a bit like the Cluster is getting it's constant live feed, but not it's ignition feed... I don't know if that would let it communicate though???
    If it were me, I'd be checking:
    1) The cluster has it's constant live feed 12V (Cluster pin T36/2 via fuse SB6, probably - check your diagrams). I'm sure it DOES have this.
    2) The cluster has it's switched 12v feed 12V (Cluster pin T36/1 via fuse SC16, probably - check your diagrams). This is the one I wonder about.
    I think in my Touran, when I connect the battery, the cluster does light up for a short time. Then it lights up again, when I switch the ignition on... which yours doesn't It would explain the engine shutting off, due to no immo data coming from the cluster to the engine ECU.
  8. Likes Uwe, Jack@European_Parts liked this post
    Feb 2017
    Oulu, Finland
    Engine is running
    New engine is running now.
    Fuses have been checked and found there was a blown fuse and a small short circuit.
  10. Likes Uwe, Jack@European_Parts, NZDubNurd liked this post
  11. #8
    Nov 2014
    New Zealand
    WoooHooo!!
  12. Likes Jack@European_Parts liked this post
  13. #9
    Aug 2015
    Would be interesting to know where the "small short circuit" was.
    Shaun.
  14. Likes Uwe liked this post
