- Feb 1, 2017
- 134
- 47
- Oulu, Finland
- C?ID=229426
Hi!
Volkswagen Caddy MY08 it has been necessary to change the new engine. From the previous engine connecting rod had come out of the engine block.
The new engine is installed, but the car is not running normally. The car starts, but does not go longer than 2 seconds. In addition, the instrument cluster screen does not show anything.
Information exchange engine:
- The new engine is the same as the previous broken gone (BLS, 77 kilowatts)
- The new engine is two years later, vw caddy.
- ECU, ignition key (1pcs) and the immobilizer box of the original car.
Is it possible to get to work on the new engine an old engine ECU?
If it's possible, how I get to work on the new enginge an old engine ECU?
Does this require key adjustment?
Sunday,02,April,2017,19:05:34:57660
VCDS Version: 17.1.3.0 (x64)
Dealer/Shop Name: J.P
VIN: WV2ZZZ2KZ8X147343 License Plate:
Mileage: 212860km-132265mi Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 02 03 08 09 15 16 17 18 19 25 42 46 52 56 69
VIN: WV2ZZZ2KZ8X147343 Mileage: 212860km-132265miles
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 021 PF HW: 03G 906 021 AB
Component: R4 1,9L EDC G000AG 2388
Revision: --H08--- Serial number: VWX7Z0H33NE1IJ
Coding: 0000078
Shop #: WSC 73000 205 66168
VCID: 72D399B56D4E1DD1EF-8026
8 Faults Found:
000275 - Intake Air Temp. Sensor (G42)
P0113 - 000 - Signal too High - Intermittent
Load: 0.0 %
Voltage: 11.55 V
Temperature: 133.2°C
Temperature: 14.4°C
Temperature: 15.3°C
000568 - Manifold Pressure / Boost Sensor (G31)
P0238 - 000 - Signal too High - Intermittent
005746 - Coolant Fan Control 1
P1672 - 000 - Open or Short to Ground - Intermittent
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 00101011
Temperature: 14.4°C
Duty Cycle: 9.7 %
005716 - Please check DTC Memory of Instrument Cluster
P1654 - 000 - - Intermittent
005697 - Please check DTC Memory of A/C Controller
P1641 - 000 -
Mileage: 212865 km
Time: 00:00:15
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00101011
Temperature: 14.4°C
(no units): 16.0
005488 - Engine Start Blocked by Immobilizer
P1570 - 000 - - MIL ON
Mileage: 212865 km
Time: 00:00:15
000258 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low - Intermittent
Fault Status: 00110000
Mileage: 212865 km
Time: 00:00:12
RPM: 882 /min
Load: 0.0 %
Duty Cycle: 100.6 %
Bin. Bits: 00101000
Mass Air / Rev.: 450.0 mg/str
Mass Air / Rev.: 0.0 mg/str
001384 - Cruise Control Switch (E45)
P0568 - 000 - Implausible Signal - Intermittent
Mileage: 212865 km
Time: 00:00:12
Readiness: 0 2 0 0 0
Part No SW: 02E 300 050 K HW: 02E 927 770 AD
Component: GSG DSG 082 1401
Revision: 04808020 Serial number: 00000910110544
Shop #: WSC 04940 001 00001
VCID: 1A039115D57E859107-804E
Part No SW: 2K3 907 379 HW: 2K3 907 379
Revision: 00H13001
Coding: 0021202
Shop #: WSC 35110 377 00162
VCID: 73DD9CB1125414D9E4-8026
Part No SW: 1K0 907 044 DA HW: 1K0 907 044 DA
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
VCID: 69E1FED94098DE095E-803C
00538 - Reference Voltage
002 - Lower Limit Exceeded
009 - Open or Short to Ground
007 - Short to Ground
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Revision: 00H54000 Serial number: 01000008309592
Coding: 0988CF030004100057000000000000000008FF075C000100000000000000
Shop #: WSC 35110 377 08192
VCID: 71D196B9684826C916-8024
Subsystem 1 - Part No: 2K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 100408 021 0501
Coding: 00038805
Shop #: WSC 35110
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AJ HW: 6Q0 909 605 AJ
Component: 1C AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037UR003TS+
Coding: 0012611
VCID: 7F3540812E1C40B990-802A
Part No SW: 1K0 953 549 BK HW: 1K0 953 549 BK
Component: J0527 051 0100
Coding: 0011022
VCID: 7CCFB78D3F0A5BA1B5-8028
Part No SW: 1T0 920 854 C HW: 1T0 920 854 C
Component: KOMBIINSTRUMENT VDD 1222
Revision: V0002000 Serial number: VWX7Z0H33NE1IJ
Coding: 0016101
Shop #: WSC 00999 444 64523
VCID: 345F5FAD57DA53E13D-8060
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 5K0 963 271 C
Component: Standheizer 050 2606
Revision: 00050000 Serial number: 09021535000000
Coding: 0001012
VCID: 2F5550C1BEFC703940-807A
02245 - Connection; RF Remote Control
Fault Frequency: 84
Reset counter: 5
Mileage: 211886 km
00664 - Fuel gauge
Reset counter: 31
Mileage: 212242 km
01410 - Heater Over-Temp
Reset counter: 31
Mileage: 212242 km
02251 - Heater Unit Locked
Reset counter: 5
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 090408F1010829
Coding: AD801F46000A027400
Shop #: WSC 73008 205 97539
VCID: 305753BDA3C26FC159-8064
Component: IMMO VDD 1222
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.clb
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1205
Coding: 0000048
VCID: 38476B9D4BB2B78111-806C
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 808B04087F2D8405484A036010C0
VCID: 0037C37D53E23F41E9-8054
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.clb
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000048
VCID: 39416E9970B8AE89EE-806C
Part No: 1K0 035 186 AD
Component: Radio GR0 034 0033
Revision: 0003404S Serial number: VWZ2Z2H7303777
Coding: 0020401
VCID: 68E7FBDD5B92E70141-803C
Address 69: Trailer
End-------------------------(Elapsed Time: 01:09)--------------------------
