Hi All,
I'm new to this world. And started a retro fit on my just purchased Audi A5 2011 cabrio. Im trying to add puddle lights, warning lights and footwell lights. and folding Wing mirrors. I also stripped the sunshade trim so I can pull some power wires for my dash cam.
Anyway with help of some nice people I manage to do the wiring bit (for puddle/warning and footwell lights) and purchased a ross-tech cable for the coding bit. and decided to test these before I goto mirrors.
But when I select the module its coming with "only limited options are available" and it won't show any options in the long code I'm stuck and I don't know what to do. You guys are my last hope.
I attached some snapshots see the link.
Do I need to put everything back before I change any codes? Please please help. Any advice is greatly appreciated.
If you need anything please let me know. Thank you so so so so much again. I also pasted full scan details below if that any help?
Wednesday,29,March,2017,11:34:34:44713
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 17.1.3.0
VIN: WAUZZZ8F0BN018916 License Plate: SH11RRH
Mileage: 98170km-61000mi Repair Order:
Chassis Type: 8F (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 26 42 46 52 53 55 56 5F 62 72
VIN: WAUZZZ8F0BN018916 Mileage: 98170km-61000miles
26-Auto Roof -- Status: Malfunction 0010
53-Parking Brake -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CAHA) Labels: 03L-906-019-CAG.clb
Part No SW: 03L 906 022 NP HW: 03L 906 019 AL
Component: R4 2,0L EDC H34 9098
Revision: 25H34---
Coding: 22194012232503080000
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM20TDI03L906022NP A02009
ROD: EV_ECM20TDI03L906022NP.rod
VCID: 000F611E9BADAA41E9-8055
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BF HW: 8K0 907 379 BF
Component: ESP8 front H04 0030
Coding: 160504
Shop #: WSC 02391 823 56573
VCID: 7EF31FE6E959DCB19B-802B
Reset counter: 61
Mileage: 98178 km
Date: 2010.01.22
Time: 00:00:01
Hex Value: 0x0000
Hex Value: 0x0280
Hex Value: 0x002E
Hex Value: 0x8493
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CP HW: 8K0 907 064 CP
Component: BCM2 2.0 H05 0435
Coding: 033300
Shop #: WSC 02399 823 56573
VCID: 000F611E93ADAA41E9-8055
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0811000049273020
Component: J764 ELV MLB H37 0042
Serial number: 2311000059786011
Fault Status: 00101101
Fault Frequency: 6
Reset counter: 61
Mileage: 98179 km
Date: 2017.03.23
Time: 13:28:40
02811 - Control Module for Electronic Steering Column Lock (J764)
Fault Frequency: 6
Reset counter: 61
Mileage: 98179 km
Date: 2017.03.23
Time: 13:28:40
00166 - Access/Start Authorization Switch (E415)
Reset counter: 61
Mileage: 98179 km
Date: 2017.03.23
Time: 13:28:40
Part No SW: 8T2 820 043 AG HW: 8T2 820 043 AG
Component: KLIMA 3 ZONEN H08 0180
Revision: D1000000 Serial number: 01010420111258
Coding: 34370000
VCID: 77FD0AC2C663EDF9D8-8023
Fault Frequency: 10
Reset counter: 21
Mileage: 98179 km
Date: 2017.03.22
Time: 14:13:33
Temperature: 9.0∞C
Voltage: 13.00 V
Output: 0 W
Output: 0 W
Temperature: 10.0∞C
008 - Implausible Signal
Fault Frequency: 10
Reset counter: 21
Mileage: 98179 km
Date: 2017.03.22
Time: 14:13:33
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000860508
Coding: 260050914034AF000009000300005D5D001D038806010141000000
VCID: 3C77D5EEBFC50EA1F5-8069
Subsystem 1 - Part No SW: 8F2 955 119 HW: 8K2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 280311 H06 0021
Serial number: SWF11030285002
Coding: 00FD11
Component: RLS H04 0003
Serial number: 11372506
Coding: 02562A
Component: E1 - LDS H03 0031
Serial number: 00000000003103111764
9 Faults Found:
Fault Status: 00101100
Reset counter: 61
Mileage: 98179 km
Date: 2017.03.26
Time: 14:03:00
00910 - Indicator Lamp for Emergency Flashers (K6)
Reset counter: 61
Mileage: 98179 km
Date: 2017.03.26
Time: 14:03:00
Reset counter: 61
Mileage: 1048574 km
Reset counter: 61
Mileage: 1048574 km
Reset counter: 61
01800 - Light Switch (E1)
Reset counter: 61
03280 - Switch Position of Light-Switch Knob
Reset counter: 61
Reset counter: 61
00908 - Control Module for Wiper Motor
Reset counter: 61
Mileage: 1048574 km
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 AA HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0080
Revision: 11001001 Serial number: 12501108805620
Coding: 100201
VCID: 78FF09FECB7DE281D1-802D
Address 15: Airbags (J234) Labels: 8F0-959-655.clb
Part No SW: 8F0 959 655 C HW: 8F0 959 655 C
Component: AirbagVW-AU10 H11 0430
Serial number: 003JND703VP
Coding: 30413635353130303030554A305238463053
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaAU10SMEAU485.rod
VCID: 387FC9FE83FD228111-806D
Serial number: 6334MSME5E644217G
Serial number: 6344MSME5E307338H
Serial number: 6352QSME210633686
Serial number: 6362QSME14092E74J
Serial number: 63732SME3D0A1A4EB
Serial number: 63832SME5608125C$
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KD4000MG
Coding: 000016
VCID: 3D71D8EAA4DF07A9C2-8069
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 983 B HW: 8T0 920 983 B
Component: KOMBIINSTR. H41 0258
Revision: 00000000 Serial number: EHY62TX3C
Coding: 2F04180002002600010000
Address 19: CAN Gateway
Address 26: Auto Roof (J256) Labels: 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H11 0190
ASAM Dataset: EV_ElectRoofContr 001008
ROD: EV_ElectRoofContr.rod
VCID: 71E934DAA007B3C916-8025
0032 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 40
Time: 00:00:00
0033 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 40
Time: 00:00:00
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1501
Coding: 011042724009330C03
VCID: 53A59E52325BE1D904-8007
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0147685883
Coding: 011B06A200B904608020033680000000
11 Faults Found:
03156 - Sensor for Anti-Theft System (G578)
Reset counter: 21
Mileage: 98179 km
Date: 2017.03.19
Time: 16:41:17
00218 - Humidity Sensor (G355)
Reset counter: 21
Mileage: 98179 km
Date: 2017.03.19
Time: 16:41:17
01565 - Luggage Compartment Light (W3)
Fault Status: 00101001
Reset counter: 61
Mileage: 98179 km
Date: 2017.03.25
Time: 16:28:28
00830 - Convertible Top Control Module (J256)
Reset counter: 61
Mileage: 98179 km
Date: 2017.03.25
Time: 16:28:28
Reset counter: 61
Mileage: 98179 km
Date: 2017.03.28
Time: 19:03:06
Reset counter: 61
Mileage: 98179 km
Date: 2017.03.28
Time: 19:03:06
Reset counter: 61
Mileage: 98179 km
Date: 2017.03.28
Time: 19:03:06
Reset counter: 61
Mileage: 98179 km
Date: 2017.03.28
Time: 19:03:06
Fault Frequency: 0
Reset counter: 0
Raw, Form. N/A: 000 000 000
Fault Frequency: 0
Reset counter: 0
Fault Frequency: 0
Reset counter: 0
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
Coding: 011042324009330C03
VCID: 52AB9B560D41E8D10F-8007
Fault Status: 01101100
Reset counter: 21
Mileage: 98179 km
Date: 2017.03.14
Time: 21:51:25
Reset counter: 21
Mileage: 98179 km
Date: 2017.03.14
Time: 21:51:25
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000774922
VCID: 3467FDCE9795C6E13D-8061
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
Coding: 0000001
VCID: 3979CCFA70F73B89EE-806D
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 21
Mileage: 98179 km
Date: 2017.03.13
Time: 22:11:55
Part No SW: 4G0 035 056 D HW: 4G0 035 056
Component: Radio U STD H52 0094
Revision: AB001007 Serial number: 469D 0B7709114
Coding: 010003020100000101
VCID: 224B0B963D615851DF-8077
00417 - Left Front DSP Mid-Bass Speaker (R101)
Fault Status: 00101011
Reset counter: 61
Voltage: 12.60 V
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
Reset counter: 61
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
Reset counter: 61
Voltage: 12.60 V
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T2 035 666 J HW: 8T2 035 666 E
Component: H-BN-EU H51 0174
Revision: -------- Serial number: 475C60B7565849
Coding: 01010103000681ED01000B1E000000010100
VCID: 428BAB16DD217851BF-8017
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0098
Serial number: 9466CZ0B0552972
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Serial number: 00000000794941
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
02168 - Left Front Microphone (R140)
Fault Status: 01101011
Reset counter: 21
Mileage: 98179 km
Date: 2017.03.25
Time: 18:13:34
Voltage: 11.80 V
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 L HW: 8T0 959 795 C
Component: TSG HL H07 1501
Coding: 010002324009370C03
VCID: 54A79D4E3755E6E11D-8001
03531 - Belt Assistant
003 - Mechanical Failure
Fault Status: 01100011
Reset counter: 21
Mileage: 98179 km
Date: 2017.03.19
Time: 02:50:31
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H07 1501
End-------------------------(Elapsed Time: 03:09)--------------------------
