- Feb 21, 2016
- 32
- 9
- Denver, CO, USA
- C?ID=133121
While I realize the VCDS-Mobile app is basically just a way to find the IP address of the HEX-NET interface, an update is long overdue. What are the plans to update the app given it won't work with newer versions of iOS? See screenshot below. Currently I just use the IP address found and open the interface in Safari which is much faster, but there is still a lot to be desired. I would be thrilled to see a 'dashboard' where I can see realtime data logging (e.g. boost, rpm, temp, etc.) instead of having to tap multiple times to get to the advanced measuring blocks section or the clunky graphs / gauges pages. The UI can be dramatically improved in my opinion. I've used VCDS for almost 15 years but I think a barrier to entry for some newer folks is the difficulty of using the VCDS software. I know some people just want to 'roll my windows down with my key fob'. The UI should be so much simpler for some common tasks. Or at least have the ability to create shortcuts to some common views and tasks. /rant over/
