- Jul 21, 2014
- 6
- 0
- C?ID=172529
The eBahn Bentley lists a procedure for testing the Heated Oxygen Sensor using a 'generic scan tool' as follows:
"Function test
Connect the scan tool.
Start engine and let it run at idle.
Select "Diagnostic mode 6: Check test results of components that are not continuously monitored" .
Select "Test-ID 01: Heated Oxygen Sensor" .
Select "Test-ID 131: Dynamic test" and check whether specified values are obtained.
Test-ID (TID) 131 (Hex-ID) ($83),
Component or System, Response Check. Reduced threshold upon suspicion of malfunction in catalytic converter
Min. Max.
3.500 ----
End diagnosis and switch ignition off"
Is the VCDS value at 074-3 this measured value? If not, is there some way to relate VCDS measured parameter numbers to whatever VW is referring to as a generic scan tool?
"Function test
Min. Max.
3.500 ----
